USB Device buffer overflow
Hello,
Similar to CVE-2021-39685 affecting the Linux kernel U-Boot is vulnerable to a buffer overflow present in the USB Gadget stack. Handling of a control transfer request with wLength larger than USB_BUFSIZ (4096) may result in a buffer overflow.
The buffer for USB control endpoint is allocated in the composite_bind function implemented in drivers/usb/gadget/composite.c. The buffer size is set to USB_BUFSIZ (4096) bytes.
/* preallocate control response and buffer */ cdev->req = usb_ep_alloc_request(gadget->ep0, GFP_KERNEL); if (!cdev->req) goto fail; cdev->req->buf = memalign(CONFIG_SYS_CACHELINE_SIZE, USB_BUFSIZ); if (!cdev->req->buf) goto fail; cdev->req->complete = composite_setup_complete; gadget->ep0->driver_data = cdev;
In the composite_setup function data transfer phase is set up to the length of "value" bytes which in multiple cases may be controlled by an attacker (is set to wLength).
if (value >= 0) { req->length = value; req->zero = value < w_length; value = usb_ep_queue(gadget->ep0, req, GFP_KERNEL); if (value < 0) { debug("ep_queue --> %d\n", value); req->status = 0; composite_setup_complete(gadget->ep0, req); } }
In example the OS descriptor handler may be forced to set value to w_length.
} else { /* "extended compatibility ID"s */ count = count_ext_compat(os_desc_cfg); buf[8] = count; count *= 24; /* 24 B/ext compat desc */ count += 16; /* header */ put_unaligned_le32(count, buf); buf += 16; fill_ext_compat(os_desc_cfg, buf); value = w_length; }
Execution of this code path for wLength set to a value larger then USB_BUFSIZ will result in a buffer overflow. Since wLength is a double byte value it may have values up to 0xffff.
Besides the common OS descriptor handler this issue may be exploited for some of the available gadgets e.g. f_dfu, f_sdp where "value" is derived from wLength.
drivers/usb/gadget/f_dfu.c
static int handle_dnload(struct usb_gadget *gadget, u16 len) { struct usb_composite_dev *cdev = get_gadget_data(gadget); struct usb_request *req = cdev->req; struct f_dfu *f_dfu = req->context;
if (len == 0) f_dfu->dfu_state = DFU_STATE_dfuMANIFEST_SYNC;
req->complete = dnload_request_complete;
return len; }
drivers/usb/gadget/f_sdp.c
if (req_type == USB_TYPE_CLASS) { int report = w_value & HID_REPORT_ID_MASK;
/* HID (SDP) request */ switch (ctrl->bRequest) { case HID_REQ_SET_REPORT: switch (report) { case 1: value = SDP_COMMAND_LEN + 1; req->complete = sdp_rx_command_complete; sdp_func->ep_int_enable = false; break; case 2: value = len; req->complete = sdp_rx_data_complete; sdp_func->state = SDP_STATE_RX_FILE_DATA_BUSY; break; } }
Please find attached a patch addressing this issue. Depending on request direction wLength larger than USB_BUFSIZ will result in either endpoint stall or value trim.
Best regards, Szymon
Hello Szymon,
Looks like a generalization of CVE-2022-2347 I found earlier. While both I and Venkatesh Yadav Abbarapu of AMD made patches for that CVE localized to DFU, given the presence of the same problematic pattern elsewhere, the bounds check aspect of that CVE fix would perhaps be better in a centralized location like what you did here.
Sultan
On Nov 16, 2022, at 6:56 PM, Szymon Heidrich szymon.heidrich@gmail.com wrote: Hello,
return len; }
/* HID (SDP) request */ switch (ctrl->bRequest) { case HID_REQ_SET_REPORT: switch (report) { case 1: value = SDP_COMMAND_LEN + 1; req->complete = sdp_rx_command_complete; sdp_func->ep_int_enable = false; break; case 2: value = len; req->complete = sdp_rx_data_complete; sdp_func->state = SDP_STATE_RX_FILE_DATA_BUSY; break; } } }
Best regards, Szymon <0001-Prevent-buffer-overflow-on-USB-control-endpoint.patch>
Hi Szymon,
[Adding Marek]
On Wed, Nov 16, 2022 at 8:56 PM Szymon Heidrich szymon.heidrich@gmail.com wrote:
Hello,
if (len == 0) f_dfu->dfu_state = DFU_STATE_dfuMANIFEST_SYNC; req->complete = dnload_request_complete; return len;
Thanks for the patch. Please submit it via git send-email instead of attachment.
Assure that the control endpoint buffer of size USB_BUFSIZ (4096) can not be overflown during handling of USB control transfer requests with wLength greater than USB_BUFSIZ.
Signed-off-by: Szymon Heidrich szymon.heidrich@gmail.com --- drivers/usb/gadget/composite.c | 11 +++++++++++ 1 file changed, 11 insertions(+)
diff --git a/drivers/usb/gadget/composite.c b/drivers/usb/gadget/composite.c index 2a309e624e..cb89f6dca9 100644 --- a/drivers/usb/gadget/composite.c +++ b/drivers/usb/gadget/composite.c @@ -1019,6 +1019,17 @@ composite_setup(struct usb_gadget *gadget, const struct usb_ctrlrequest *ctrl) u8 endp; struct usb_configuration *c;
+ if (w_length > USB_BUFSIZ) { + if (ctrl->bRequestType & USB_DIR_IN) { + /* Cast away the const, we are going to overwrite on purpose. */ + __le16 *temp = (__le16 *)&ctrl->wLength; + *temp = cpu_to_le16(USB_BUFSIZ); + w_length = USB_BUFSIZ; + } else { + goto done; + } + } + /* * partial re-init of the response message; the function or the * gadget might need to intercept e.g. a control-OUT completion
[Adding Lukasz and Marek]
On Thu, Nov 17, 2022 at 6:50 AM Szymon Heidrich szymon.heidrich@gmail.com wrote:
} else {
goto done;
-- 2.38.1
Won't this end up sending corrupted packets in case they are longer than USB_BUFSIZ ?
Where do such long packets come from ?
What is the test-case ?
The USB host will not attempt to retrieve more than wLenght bytes during transfer phase. If the device would erroneously attempt to provide more data it would result in an unexpected state. In case of most implementations the buffer for endpoint 0 along with max control transfer is limited to 4096 bytes (USB_BUFSIZ for U-Boot and Linux kernel). Still according to the USB specification wLength is two bytes an the device may receive requests with wLength larger than 4096 bytes e.g. in case of a custom/malicious USB host. For example one may build libusb with MAX_CTRL_BUFFER_LENGTH altered to 0xffff and this will allow the host to send requests with wLength up to 0xffff. In this case the original implementation may result in buffer overflows as in multiple locations a value directly derived from wLength is set as the transfer phase length. With the change applied IN requests with wLength larger than USB_BUFSIZ will be trimmed to USB_BUFSIZ, otherwise the host would read wLength-USB_BUFSIZ past cdev->req->buf. I am not aware of any cases where more than USB_BUFSIZ would be provided from a buffer other than cdev->req->buf. In case I missed such case please let me know.
Why shouldn't the patch do simple
w_length = min(w_length, USB_BUFSIZ);
The composite_setup function in composite.c uses w_length but function specific setup functions are passed the struct usb_ctrlrequest *ctrl so both must be updated. If only w_length is updated using min(w_length, USB_BUFSIZ) than function specific setup will still receive the original request including unaltered wLength so it may again return a number of bytes greater than buffer size resulting in an overflow.
Can you fill this sanitization into the setup wrapper here ?
https://patchwork.ozlabs.org/project/uboot/patch/20221216032047.536441-1-mar...
That way, it would apply for all the gadget drivers and you won't have to deal with the const overwrite , right ?
On Thu, Nov 17, 2022 at 6:50 AM Szymon Heidrich szymon.heidrich@gmail.com wrote: > > Assure that the control endpoint buffer of size USB_BUFSIZ (4096) > can not be overflown during handling of USB control transfer > requests with wLength greater than USB_BUFSIZ. > > Signed-off-by: Szymon Heidrich szymon.heidrich@gmail.com > --- > drivers/usb/gadget/composite.c | 11 +++++++++++ > 1 file changed, 11 insertions(+) > > diff --git a/drivers/usb/gadget/composite.c b/drivers/usb/gadget/composite.c > index 2a309e624e..cb89f6dca9 100644 > --- a/drivers/usb/gadget/composite.c > +++ b/drivers/usb/gadget/composite.c > @@ -1019,6 +1019,17 @@ composite_setup(struct usb_gadget *gadget, const struct usb_ctrlrequest *ctrl) > u8 endp; > struct usb_configuration *c; > > + if (w_length > USB_BUFSIZ) { > + if (ctrl->bRequestType & USB_DIR_IN) { > + /* Cast away the const, we are going to overwrite on purpose. */ > + __le16 *temp = (__le16 *)&ctrl->wLength; > + *temp = cpu_to_le16(USB_BUFSIZ); > + w_length = USB_BUFSIZ;
Sure, that should be fine. I'll provide a patch when when this is merged, OK?
On 11/17/22 12:50, Fabio Estevam wrote: > [Adding Lukasz and Marek] > > On Thu, Nov 17, 2022 at 6:50 AM Szymon Heidrich > szymon.heidrich@gmail.com wrote: >> >> Assure that the control endpoint buffer of size USB_BUFSIZ (4096) >> can not be overflown during handling of USB control transfer >> requests with wLength greater than USB_BUFSIZ. >> >> Signed-off-by: Szymon Heidrich szymon.heidrich@gmail.com >> --- >> drivers/usb/gadget/composite.c | 11 +++++++++++ >> 1 file changed, 11 insertions(+) >> >> diff --git a/drivers/usb/gadget/composite.c b/drivers/usb/gadget/composite.c >> index 2a309e624e..cb89f6dca9 100644 >> --- a/drivers/usb/gadget/composite.c >> +++ b/drivers/usb/gadget/composite.c >> @@ -1019,6 +1019,17 @@ composite_setup(struct usb_gadget *gadget, const struct usb_ctrlrequest *ctrl) >> u8 endp; >> struct usb_configuration *c; >> >> + if (w_length > USB_BUFSIZ) { >> + if (ctrl->bRequestType & USB_DIR_IN) { >> + /* Cast away the const, we are going to overwrite on purpose. */ >> + __le16 *temp = (__le16 *)&ctrl->wLength; >> + *temp = cpu_to_le16(USB_BUFSIZ); >> + w_length = USB_BUFSIZ;
Please review/test the aforementioned patch and let me know if it works for you, the patch can still be tweaked one way or the other.
Is there anything additional required from my side?
Sorry for the delay, I am still processing outstanding email.
Could you please review this patch?
I have it (or rather, one outstanding reply) in the pipeline, sorry for the delay.
Fabio Estevam
Sultan Khan
Szymon Heidrich
