[U-Boot] [PATCH 7/7] driver: net: fsl-mc: Remove portal id hard-coding
Management Complex firmware 9.0 has fixed the issue of dprc_destroy_container i.e. the used portal is not return to the free pool. Which was resulting in error ethernet driver want to use this portal via either DPL or dynamically in Linux.
So, Remove hard-coding of portal id.
Signed-off-by: Prabhakar Kushwaha prabhakar@freescale.com --- drivers/net/fsl-mc/mc.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/net/fsl-mc/mc.c b/drivers/net/fsl-mc/mc.c index a45a30d..9e042f6 100644 --- a/drivers/net/fsl-mc/mc.c +++ b/drivers/net/fsl-mc/mc.c @@ -821,7 +821,7 @@ static int dprc_init(void) DPRC_CFG_OPT_OBJ_CREATE_ALLOWED | DPRC_CFG_OPT_ALLOC_ALLOWED; cfg.icid = DPRC_GET_ICID_FROM_POOL; - cfg.portal_id = 250; + cfg.portal_id = DPRC_GET_PORTAL_ID_FROM_POOL; err = dprc_create_container(root_mc_io, MC_CMD_NO_FLAGS, root_dprc_handle, &cfg,
Slightly reformat commit message. Applied to u-boot-fsl-qoriq master. Awaiting upstream.
Thanks.
York
Prabhakar Kushwaha
york sun
