[U-Boot] [PATCH v3 1/2] dm: Add support for scsi/sata based devices
All sata based drivers are bind and corresponding block device is created. Based on this find_scsi_device() is able to get back block device based on scsi_curr_dev pointer.
intr_scsi() is commented now but it can be replaced by calling find_scsi_device() and scsi_scan().
scsi_dev_desc[] is commented out but common/scsi.c heavily depends on it. That's why CONFIG_SYS_SCSI_MAX_DEVICE is hardcoded to 1 and symbol is reassigned to a block description allocated by uclass. There is only one block description by device now but it doesn't need to be correct when more devices are present.
scsi_bind() ensures corresponding block device creation. uclass post_probe (scsi_post_probe()) is doing low level init.
SCSI/SATA DM based drivers requires to have 64bit base address as the first entry in platform data structure to setup mmio_base.
Changes in v3: - Fix scsi_scan return path - Fix header location uclass-internal.h - Add scsi_max_devs under !DM_SCSI - Add new header device-internal because of device_probe() - Redesign block device creation algorithm - Use device_unbind in error path - Create block device with id and lun numbers (lun was there in v2) - Cleanup dev_num initialization in block device description with fixing parameters in blk_create_devicef - Create new Kconfig menu for SATA/SCSI drivers - Extend description for DM_SCSI - Fix Kconfig dependencies - Fix kernel doc format in scsi_platdata - Fix ahci_init_one - vendor variable
Changes in v2: - Use CONFIG_DM_SCSI instead of mix of DM_SCSI and DM_SATA Ceva sata has never used sata commands that's why keep it in SCSI part only. - Separate scsi_scan() for DM_SCSI and do not change cmd/scsi.c - Extend platdata
common/board_r.c | 4 +-- common/scsi.c | 76 +++++++++++++++++++++++++++++++++++++++++++++ drivers/block/Kconfig | 12 +++++++ drivers/block/Makefile | 1 + drivers/block/ahci.c | 30 +++++++++++++----- drivers/block/blk-uclass.c | 2 +- drivers/block/scsi-uclass.c | 29 +++++++++++++++++ include/ahci.h | 2 +- include/dm/uclass-id.h | 1 + include/sata.h | 2 ++ include/scsi.h | 20 +++++++++++- 11 files changed, 166 insertions(+), 13 deletions(-) create mode 100644 drivers/block/scsi-uclass.c
diff --git a/common/board_r.c b/common/board_r.c index d959ad3c6f90..108cabbd023b 100644 --- a/common/board_r.c +++ b/common/board_r.c @@ -620,7 +620,7 @@ static int initr_ambapp_print(void) } #endif
-#if defined(CONFIG_SCSI) +#if defined(CONFIG_SCSI) && !defined(CONFIG_DM_SCSI) static int initr_scsi(void) { puts("SCSI: "); @@ -923,7 +923,7 @@ init_fnc_t init_sequence_r[] = { initr_ambapp_print, #endif #endif -#ifdef CONFIG_SCSI +#if defined(CONFIG_SCSI) && !defined(CONFIG_DM_SCSI) INIT_FUNC_WATCHDOG_RESET initr_scsi, #endif diff --git a/common/scsi.c b/common/scsi.c index 04add624958f..e7efa5ae797c 100644 --- a/common/scsi.c +++ b/common/scsi.c @@ -10,7 +10,10 @@ #include <inttypes.h> #include <pci.h> #include <scsi.h> +#include <dm/device-internal.h> +#include <dm/uclass-internal.h>
+#if !defined(CONFIG_DM_SCSI) #ifdef CONFIG_SCSI_DEV_LIST #define SCSI_DEV_LIST CONFIG_SCSI_DEV_LIST #else @@ -31,6 +34,7 @@ #endif #define SCSI_DEV_LIST {SCSI_VEND_ID, SCSI_DEV_ID} #endif +#endif
#if defined(CONFIG_PCI) && !defined(CONFIG_SCSI_AHCI_PLAT) const struct pci_device_id scsi_device_list[] = { SCSI_DEV_LIST }; @@ -39,11 +43,13 @@ static ccb tempccb; /* temporary scsi command buffer */
static unsigned char tempbuff[512]; /* temporary data buffer */
+#if !defined(CONFIG_DM_SCSI) static int scsi_max_devs; /* number of highest available scsi device */
static int scsi_curr_dev; /* current device */
static struct blk_desc scsi_dev_desc[CONFIG_SYS_SCSI_MAX_DEVICE]; +#endif
/* almost the maximum amount of the scsi_ext command.. */ #define SCSI_MAX_READ_BLK 0xFFFF @@ -444,6 +450,7 @@ static void scsi_init_dev_desc_priv(struct blk_desc *dev_desc) #endif }
+#if !defined(CONFIG_DM_SCSI) /** * scsi_init_dev_desc - initialize all SCSI specific blk_desc properties * @@ -460,6 +467,7 @@ static void scsi_init_dev_desc(struct blk_desc *dev_desc, int devnum)
scsi_init_dev_desc_priv(dev_desc); } +#endif
/** * scsi_detect_dev - Detect scsi device @@ -540,6 +548,73 @@ removable: * (re)-scan the scsi bus and reports scsi device info * to the user if mode = 1 */ +#if defined(CONFIG_DM_SCSI) +int scsi_scan(int mode) +{ + unsigned char i, lun; + struct uclass *uc; + struct udevice *dev; /* SCSI controller */ + int ret; + + if (mode == 1) + printf("scanning bus for devices...\n"); + + ret = uclass_get(UCLASS_SCSI, &uc); + if (ret) + return ret; + + uclass_foreach_dev(dev, uc) { + struct scsi_platdata *plat; /* scsi controller platdata */ + + /* probe SCSI controller driver */ + ret = device_probe(dev); + if (ret) + return ret; + + /* Get controller platdata */ + plat = dev_get_platdata(dev); + + for (i = 0; i < plat->max_id; i++) { + for (lun = 0; lun < plat->max_lun; lun++) { + struct udevice *bdev; /* block device */ + /* block device description */ + struct blk_desc *bdesc; + char str[10]; + + /* + * Create only one block device and do detection + * to make sure that there won't be a lot of + * block devices created + */ + snprintf(str, sizeof(str), "id%dlun%d", i, lun); + ret = blk_create_devicef(dev, "scsi_blk", + str, IF_TYPE_SCSI, + -1, 0, 0, &bdev); + if (ret) { + debug("Can't create device\n"); + return ret; + } + bdesc = dev_get_uclass_platdata(bdev); + + scsi_init_dev_desc_priv(bdesc); + bdesc->lun = lun; + ret = scsi_detect_dev(i, bdesc); + if (ret) { + device_unbind(bdev); + continue; + } + + if (mode == 1) { + printf(" Device %d: ", 0); + dev_print(bdesc); + } /* if mode */ + } /* next LUN */ + } + } + + return 0; +} +#else int scsi_scan(int mode) { unsigned char i, lun; @@ -576,6 +651,7 @@ int scsi_scan(int mode) #endif return 0; } +#endif
#ifdef CONFIG_BLK static const struct blk_ops scsi_blk_ops = { diff --git a/drivers/block/Kconfig b/drivers/block/Kconfig index fe5aa07f921a..ecca1ef44636 100644 --- a/drivers/block/Kconfig +++ b/drivers/block/Kconfig @@ -19,6 +19,14 @@ config AHCI operations at present. The block device interface has not been converted to driver model.
+config DM_SCSI + bool "Support SCSI controllers with driver model" + depends on BLK + help + This option enables the SCSI uclass which supports SCSI and SATA HDDs. + For every device configuration (IDs/LUNs) is created block device + with RAW read/write and filesystem support. + config BLOCK_CACHE bool "Use block device cache" default n @@ -27,3 +35,7 @@ config BLOCK_CACHE This is most useful when accessing filesystems under U-Boot since it will prevent repeated reads from directory structures and other filesystem data structures. + +menu "SATA/SCSI device support" + +endmenu diff --git a/drivers/block/Makefile b/drivers/block/Makefile index 436b79f98165..a72feecd5456 100644 --- a/drivers/block/Makefile +++ b/drivers/block/Makefile @@ -12,6 +12,7 @@ obj-y += blk_legacy.o endif
obj-$(CONFIG_AHCI) += ahci-uclass.o +obj-$(CONFIG_DM_SCSI) += scsi-uclass.o obj-$(CONFIG_SCSI_AHCI) += ahci.o obj-$(CONFIG_DWC_AHSATA) += dwc_ahsata.o obj-$(CONFIG_FSL_SATA) += fsl_sata.o diff --git a/drivers/block/ahci.c b/drivers/block/ahci.c index 5139989d0b5f..d419855bd845 100644 --- a/drivers/block/ahci.c +++ b/drivers/block/ahci.c @@ -168,7 +168,7 @@ int ahci_reset(void __iomem *base)
static int ahci_host_init(struct ahci_probe_ent *probe_ent) { -#ifndef CONFIG_SCSI_AHCI_PLAT +#if !defined(CONFIG_SCSI_AHCI_PLAT) && !defined(CONFIG_DM_SCSI) # ifdef CONFIG_DM_PCI struct udevice *dev = probe_ent->dev; struct pci_child_platdata *pplat = dev_get_parent_platdata(dev); @@ -198,7 +198,7 @@ static int ahci_host_init(struct ahci_probe_ent *probe_ent) writel(cap_save, mmio + HOST_CAP); writel_with_flush(0xf, mmio + HOST_PORTS_IMPL);
-#ifndef CONFIG_SCSI_AHCI_PLAT +#if !defined(CONFIG_SCSI_AHCI_PLAT) && !defined(CONFIG_DM_SCSI) # ifdef CONFIG_DM_PCI if (pplat->vendor == PCI_VENDOR_ID_INTEL) { u16 tmp16; @@ -327,6 +327,7 @@ static int ahci_host_init(struct ahci_probe_ent *probe_ent) writel(tmp | HOST_IRQ_EN, mmio + HOST_CTL); tmp = readl(mmio + HOST_CTL); debug("HOST_CTL 0x%x\n", tmp); +#if !defined(CONFIG_DM_SCSI) #ifndef CONFIG_SCSI_AHCI_PLAT # ifdef CONFIG_DM_PCI dm_pci_read_config16(dev, PCI_COMMAND, &tmp16); @@ -338,14 +339,15 @@ static int ahci_host_init(struct ahci_probe_ent *probe_ent) pci_write_config_word(pdev, PCI_COMMAND, tmp16); # endif #endif +#endif return 0; }
static void ahci_print_info(struct ahci_probe_ent *probe_ent) { -#ifndef CONFIG_SCSI_AHCI_PLAT -# ifdef CONFIG_DM_PCI +#if !defined(CONFIG_SCSI_AHCI_PLAT) && !defined(CONFIG_DM_SCSI) +# if defined(CONFIG_DM_PCI) || defined(CONFIG_DM_SCSI) struct udevice *dev = probe_ent->dev; # else pci_dev_t pdev = probe_ent->dev; @@ -372,7 +374,7 @@ static void ahci_print_info(struct ahci_probe_ent *probe_ent) else speed_s = "?";
-#ifdef CONFIG_SCSI_AHCI_PLAT +#if defined(CONFIG_SCSI_AHCI_PLAT) || defined(CONFIG_DM_SCSI) scc_s = "SATA"; #else # ifdef CONFIG_DM_PCI @@ -424,13 +426,15 @@ static void ahci_print_info(struct ahci_probe_ent *probe_ent) }
#ifndef CONFIG_SCSI_AHCI_PLAT -# ifdef CONFIG_DM_PCI +# if defined(CONFIG_DM_PCI) || defined(CONFIG_DM_SCSI) static int ahci_init_one(struct udevice *dev) # else static int ahci_init_one(pci_dev_t dev) # endif { +#if !defined(CONFIG_DM_SCSI) u16 vendor; +#endif int rc;
probe_ent = malloc(sizeof(struct ahci_probe_ent)); @@ -450,6 +454,7 @@ static int ahci_init_one(pci_dev_t dev) probe_ent->pio_mask = 0x1f; probe_ent->udma_mask = 0x7f; /*Fixme,assume to support UDMA6 */
+#if !defined(CONFIG_DM_SCSI) #ifdef CONFIG_DM_PCI probe_ent->mmio_base = dm_pci_map_bar(dev, PCI_BASE_ADDRESS_5, PCI_REGION_MEM); @@ -473,6 +478,10 @@ static int ahci_init_one(pci_dev_t dev) if (vendor == 0x197b) pci_write_config_byte(dev, 0x41, 0xa1); #endif +#else + struct scsi_platdata *plat = dev_get_platdata(dev); + probe_ent->mmio_base = (void *)plat->base; +#endif
debug("ahci mmio_base=0x%p\n", probe_ent->mmio_base); /* initialize adapter */ @@ -954,14 +963,17 @@ int scsi_exec(ccb *pccb)
- +#if defined(CONFIG_DM_SCSI) +void scsi_low_level_init(int busdevfunc, struct udevice *dev) +#else void scsi_low_level_init(int busdevfunc) +#endif { int i; u32 linkmap;
#ifndef CONFIG_SCSI_AHCI_PLAT -# ifdef CONFIG_DM_PCI +# if defined(CONFIG_DM_PCI) struct udevice *dev; int ret;
@@ -969,6 +981,8 @@ void scsi_low_level_init(int busdevfunc) if (ret) return; ahci_init_one(dev); +# elif defined(CONFIG_DM_SCSI) + ahci_init_one(dev); # else ahci_init_one(busdevfunc); # endif diff --git a/drivers/block/blk-uclass.c b/drivers/block/blk-uclass.c index 2e041c2b3dc7..38cb9388da6f 100644 --- a/drivers/block/blk-uclass.c +++ b/drivers/block/blk-uclass.c @@ -26,7 +26,7 @@ static const char *if_typename_str[IF_TYPE_COUNT] = {
static enum uclass_id if_type_uclass_id[IF_TYPE_COUNT] = { [IF_TYPE_IDE] = UCLASS_INVALID, - [IF_TYPE_SCSI] = UCLASS_INVALID, + [IF_TYPE_SCSI] = UCLASS_SCSI, [IF_TYPE_ATAPI] = UCLASS_INVALID, [IF_TYPE_USB] = UCLASS_MASS_STORAGE, [IF_TYPE_DOC] = UCLASS_INVALID, diff --git a/drivers/block/scsi-uclass.c b/drivers/block/scsi-uclass.c new file mode 100644 index 000000000000..123b25c406a4 --- /dev/null +++ b/drivers/block/scsi-uclass.c @@ -0,0 +1,29 @@ +/* + * Copyright (c) 2015 Google, Inc + * Written by Simon Glass sjg@chromium.org + * Copyright (c) 2016 Xilinx, Inc + * Written by Michal Simek + * + * Based on ahci-uclass.c + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <dm.h> +#include <scsi.h> + +#if !defined(CONFIG_SPL_BUILD) +static int scsi_post_probe(struct udevice *dev) +{ + debug("%s: device %p\n", __func__, dev); + scsi_low_level_init(0, dev); + return 0; +} + +UCLASS_DRIVER(scsi) = { + .id = UCLASS_SCSI, + .name = "scsi", + .post_probe = scsi_post_probe, +}; +#endif diff --git a/include/ahci.h b/include/ahci.h index a956c6ff5df7..4876b41e9010 100644 --- a/include/ahci.h +++ b/include/ahci.h @@ -145,7 +145,7 @@ struct ahci_ioports { };
struct ahci_probe_ent { -#ifdef CONFIG_DM_PCI +#if defined(CONFIG_DM_PCI) || defined(CONFIG_DM_SCSI) struct udevice *dev; #else pci_dev_t dev; diff --git a/include/dm/uclass-id.h b/include/dm/uclass-id.h index eb78c4dac485..8c92d0b03088 100644 --- a/include/dm/uclass-id.h +++ b/include/dm/uclass-id.h @@ -66,6 +66,7 @@ enum uclass_id { UCLASS_REMOTEPROC, /* Remote Processor device */ UCLASS_RESET, /* Reset controller device */ UCLASS_RTC, /* Real time clock device */ + UCLASS_SCSI, /* SCSI device */ UCLASS_SERIAL, /* Serial UART */ UCLASS_SPI, /* SPI bus */ UCLASS_SPMI, /* System Power Management Interface bus */ diff --git a/include/sata.h b/include/sata.h index b35359aa5a19..d18cc9aa8754 100644 --- a/include/sata.h +++ b/include/sata.h @@ -2,6 +2,7 @@ #define __SATA_H__ #include <part.h>
+#if !defined(CONFIG_DM_SCSI) int init_sata(int dev); int reset_sata(int dev); int scan_sata(int dev); @@ -15,5 +16,6 @@ int __sata_stop(void); int sata_port_status(int dev, int port);
extern struct blk_desc sata_dev_desc[]; +#endif
#endif diff --git a/include/scsi.h b/include/scsi.h index c8796785a465..190dacd0f2ec 100644 --- a/include/scsi.h +++ b/include/scsi.h @@ -166,8 +166,11 @@ typedef struct SCSI_cmd_block{ void scsi_print_error(ccb *pccb); int scsi_exec(ccb *pccb); void scsi_bus_reset(void); +#if !defined(CONFIG_DM_SCSI) void scsi_low_level_init(int busdevfunc); - +#else +void scsi_low_level_init(int busdevfunc, struct udevice *dev); +#endif
/*************************************************************************** * functions residing inside cmd_scsi.c @@ -175,6 +178,21 @@ void scsi_low_level_init(int busdevfunc); void scsi_init(void); int scsi_scan(int mode);
+#if defined(CONFIG_DM_SCSI) +/** + * struct scsi_platdata - stores information about SCSI controller + * + * @base: Controller base address + * @max_lun: Maximum number of logical units + * @max_id: Maximum number of target ids + */ +struct scsi_platdata { + unsigned long base; + unsigned long max_lun; + unsigned long max_id; +}; +#endif + #define SCSI_IDENTIFY 0xC0 /* not used */
/* Hardware errors */
This patch also includes ARM64 zynqmp changes: - Remove platform non DM initialization - Remove hardcoded sata base address
Signed-off-by: Michal Simek michal.simek@xilinx.com Reviewed-by: Simon Glass sjg@chromium.org ---
Changes in v3: - Extend Kconfig help description - sort dm.h - Remove SPL undefinition from board file - Fix Kconfig dependecies
Changes in v2: - make ceva_init_sata static - Move SATA_CEVA to defconfig - Initalized max_lun and max_id platdata
arch/arm/include/asm/arch-zynqmp/hardware.h | 2 -- board/xilinx/zynqmp/zynqmp.c | 11 -------- configs/xilinx_zynqmp_ep_defconfig | 2 ++ configs/xilinx_zynqmp_zcu102_defconfig | 2 ++ configs/xilinx_zynqmp_zcu102_revB_defconfig | 2 ++ drivers/block/Kconfig | 9 +++++++ drivers/block/sata_ceva.c | 41 +++++++++++++++++++++++++++-- include/configs/xilinx_zynqmp.h | 1 - include/configs/xilinx_zynqmp_ep.h | 1 - include/configs/xilinx_zynqmp_zcu102.h | 2 -- 10 files changed, 54 insertions(+), 19 deletions(-)
diff --git a/arch/arm/include/asm/arch-zynqmp/hardware.h b/arch/arm/include/asm/arch-zynqmp/hardware.h index e7738faaf896..d1970953e234 100644 --- a/arch/arm/include/asm/arch-zynqmp/hardware.h +++ b/arch/arm/include/asm/arch-zynqmp/hardware.h @@ -18,8 +18,6 @@
#define ARASAN_NAND_BASEADDR 0xFF100000
-#define ZYNQMP_SATA_BASEADDR 0xFD0C0000 - #define ZYNQMP_USB0_XHCI_BASEADDR 0xFE200000 #define ZYNQMP_USB1_XHCI_BASEADDR 0xFE300000
diff --git a/board/xilinx/zynqmp/zynqmp.c b/board/xilinx/zynqmp/zynqmp.c index cef1f6a13aee..a23c38acd99d 100644 --- a/board/xilinx/zynqmp/zynqmp.c +++ b/board/xilinx/zynqmp/zynqmp.c @@ -311,17 +311,6 @@ void reset_cpu(ulong addr) { }
-#ifdef CONFIG_SCSI_AHCI_PLAT -void scsi_init(void) -{ -#if defined(CONFIG_SATA_CEVA) - init_sata(0); -#endif - ahci_init((void __iomem *)ZYNQMP_SATA_BASEADDR); - scsi_scan(1); -} -#endif - int board_late_init(void) { u32 reg = 0; diff --git a/configs/xilinx_zynqmp_ep_defconfig b/configs/xilinx_zynqmp_ep_defconfig index f3cdf90c1f73..8d6a6cf5701e 100644 --- a/configs/xilinx_zynqmp_ep_defconfig +++ b/configs/xilinx_zynqmp_ep_defconfig @@ -49,6 +49,8 @@ CONFIG_OF_EMBED=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y +CONFIG_DM_SCSI=y +CONFIG_SATA_CEVA=y CONFIG_DFU_RAM=y CONFIG_FPGA_XILINX=y CONFIG_FPGA_ZYNQMPPL=y diff --git a/configs/xilinx_zynqmp_zcu102_defconfig b/configs/xilinx_zynqmp_zcu102_defconfig index fa6d6692040e..7e5e83fdc043 100644 --- a/configs/xilinx_zynqmp_zcu102_defconfig +++ b/configs/xilinx_zynqmp_zcu102_defconfig @@ -41,6 +41,8 @@ CONFIG_OF_EMBED=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y +CONFIG_DM_SCSI=y +CONFIG_SATA_CEVA=y CONFIG_DFU_RAM=y CONFIG_FPGA_XILINX=y CONFIG_FPGA_ZYNQMPPL=y diff --git a/configs/xilinx_zynqmp_zcu102_revB_defconfig b/configs/xilinx_zynqmp_zcu102_revB_defconfig index a4af8024e454..f57705b2cba9 100644 --- a/configs/xilinx_zynqmp_zcu102_revB_defconfig +++ b/configs/xilinx_zynqmp_zcu102_revB_defconfig @@ -41,6 +41,8 @@ CONFIG_OF_EMBED=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_DM=y CONFIG_SPL_DM_SEQ_ALIAS=y +CONFIG_DM_SCSI=y +CONFIG_SATA_CEVA=y CONFIG_DFU_RAM=y CONFIG_FPGA_XILINX=y CONFIG_FPGA_ZYNQMPPL=y diff --git a/drivers/block/Kconfig b/drivers/block/Kconfig index ecca1ef44636..0bbb377993bc 100644 --- a/drivers/block/Kconfig +++ b/drivers/block/Kconfig @@ -38,4 +38,13 @@ config BLOCK_CACHE
+config SATA_CEVA + bool "Ceva Sata controller" + depends on AHCI + depends on DM_SCSI + help + This option enables Ceva Sata controller hard IP available on Xilinx + ZynqMP. Support up to 2 external devices. Complient with SATA 3.1 and + AHCI 1.3 specifications with hot-plug detect feature. + endmenu diff --git a/drivers/block/sata_ceva.c b/drivers/block/sata_ceva.c index dcc3b90b17f1..9b5466483aa4 100644 --- a/drivers/block/sata_ceva.c +++ b/drivers/block/sata_ceva.c @@ -5,6 +5,7 @@ * SPDX-License-Identifier: GPL-2.0+ */ #include <common.h> +#include <dm.h> #include <netdev.h> #include <ahci.h> #include <scsi.h> @@ -73,10 +74,9 @@ #define DRV_NAME "ahci-ceva" #define CEVA_FLAG_BROKEN_GEN2 1
-int init_sata(int dev) +static int ceva_init_sata(ulong mmio) { ulong tmp; - ulong mmio = ZYNQMP_SATA_BASEADDR; int i;
/* @@ -111,3 +111,40 @@ int init_sata(int dev) } return 0; } + +static int sata_ceva_probe(struct udevice *dev) +{ + struct scsi_platdata *plat = dev_get_platdata(dev); + + ceva_init_sata(plat->base); + return 0; +} + +static const struct udevice_id sata_ceva_ids[] = { + { .compatible = "ceva,ahci-1v84" }, + { } +}; + +static int sata_ceva_ofdata_to_platdata(struct udevice *dev) +{ + struct scsi_platdata *plat = dev_get_platdata(dev); + + plat->base = dev_get_addr(dev); + if (plat->base == FDT_ADDR_T_NONE) + return -EINVAL; + + /* Hardcode number for ceva sata controller */ + plat->max_lun = 1; /* Actually two but untested */ + plat->max_id = 2; + + return 0; +} + +U_BOOT_DRIVER(ceva_host_blk) = { + .name = "ceva_sata", + .id = UCLASS_SCSI, + .of_match = sata_ceva_ids, + .probe = sata_ceva_probe, + .ofdata_to_platdata = sata_ceva_ofdata_to_platdata, + .platdata_auto_alloc_size = sizeof(struct scsi_platdata), +}; diff --git a/include/configs/xilinx_zynqmp.h b/include/configs/xilinx_zynqmp.h index 7452e92ff8da..dcb2b2c3a368 100644 --- a/include/configs/xilinx_zynqmp.h +++ b/include/configs/xilinx_zynqmp.h @@ -185,7 +185,6 @@ #ifdef CONFIG_SATA_CEVA #define CONFIG_LIBATA #define CONFIG_SCSI_AHCI -#define CONFIG_SCSI_AHCI_PLAT #define CONFIG_SYS_SCSI_MAX_SCSI_ID 2 #define CONFIG_SYS_SCSI_MAX_LUN 1 #define CONFIG_SYS_SCSI_MAX_DEVICE (CONFIG_SYS_SCSI_MAX_SCSI_ID * \ diff --git a/include/configs/xilinx_zynqmp_ep.h b/include/configs/xilinx_zynqmp_ep.h index d0ce768e6e14..3a572b7a6c2f 100644 --- a/include/configs/xilinx_zynqmp_ep.h +++ b/include/configs/xilinx_zynqmp_ep.h @@ -16,7 +16,6 @@ #define CONFIG_ZYNQ_SDHCI_MAX_FREQ 52000000 #define CONFIG_ZYNQ_SDHCI_MIN_FREQ (CONFIG_ZYNQ_SDHCI_MAX_FREQ >> 9) #define CONFIG_ZYNQ_EEPROM -#define CONFIG_SATA_CEVA #define CONFIG_ZYNQMP_XHCI_LIST {ZYNQMP_USB0_XHCI_BASEADDR, \ ZYNQMP_USB1_XHCI_BASEADDR}
diff --git a/include/configs/xilinx_zynqmp_zcu102.h b/include/configs/xilinx_zynqmp_zcu102.h index adf2321c5d4f..8d018da23e34 100644 --- a/include/configs/xilinx_zynqmp_zcu102.h +++ b/include/configs/xilinx_zynqmp_zcu102.h @@ -41,8 +41,6 @@ #define CONFIG_CMD_PCA953X #define CONFIG_CMD_PCA953X_INFO
-#define CONFIG_SATA_CEVA - #define CONFIG_ZYNQMP_XHCI_LIST {ZYNQMP_USB0_XHCI_BASEADDR}
#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1
Hi Michal,
Changes in v3:
Changes in v2:
- Extend platdata
With a few nits below.
Also, as mentioned we do need a test (in subsequent patches). For an example that is fairly close see:
test/dm/mmc.c drivers/mmc/sandbox_mmc.c
There is a sandbox_scsi.c but it is empty because there is no interface to the SCSI driver. From what I can tell your SCSI uclass needs to have an operations struct (perhaps with just an 'exec' method). The SCSI uclass can then implement the scsi_exec() call by calling this operation. Does that sound right?
- scsi_init_dev_desc - initialize all SCSI specific blk_desc properties
} +#endif
- scsi_detect_dev - Detect scsi device
- (re)-scan the scsi bus and reports scsi device info
- to the user if mode = 1
struct uclass *uc;
int ret;
if (mode == 1)
if (ret)
return ret;
if (ret)
return ret;
char str[10];
str, IF_TYPE_SCSI,
-1, 0, 0, &bdev);
if (ret) {
return ret;
bdesc->lun = lun;
if (ret) {
continue;
if (mode == 1) {
dev_print(bdesc);
One question here - how come only mode 1 devices are printed?
} /* if mode */
} /* next LUN */
+config DM_SCSI
depends on BLK
help
For every device configuration (IDs/LUNs) a block device is created
Also while you are are here can you please write out 'Small Computer System Interface' in full somewhere so it is clear what it stands for?
This diff is a bit confusing, but what I see in practice is this:
static void ahci_print_info(struct ahci_probe_ent *probe_ent) { #if !defined(CONFIG_SCSI_AHCI_PLAT) && !defined(CONFIG_DM_SCSI) # if defined(CONFIG_DM_PCI) || defined(CONFIG_DM_SCSI) struct udevice *dev = probe_ent->dev; # else pci_dev_t pdev = probe_ent->dev; # endif u16 cc; #endif
But if CONFIG_DM_SCSI is defined it will never reach the second #if. So I think:
should just be left as:
ahci_init_one(dev);
- Copyright (c) 2015 Google, Inc
- Written by Simon Glass sjg@chromium.org
- Copyright (c) 2016 Xilinx, Inc
- Written by Michal Simek
- Based on ahci-uclass.c
.id = UCLASS_SCSI,
.name = "scsi",
- functions residing inside cmd_scsi.c
- struct scsi_platdata - stores information about SCSI controller
- @base: Controller base address
- @max_lun: Maximum number of logical units
- @max_id: Maximum number of target ids
unsigned long base;
+}; +#endif
1.9.1
On 1.12.2016 03:20, Simon Glass wrote:
Hi Michal,
Changes in v3:
Changes in v2:
- Extend platdata
} +#endif
struct uclass *uc;
int ret;
if (mode == 1)
if (ret)
return ret;
if (ret)
return ret;
char str[10];
str, IF_TYPE_SCSI,
-1, 0, 0, &bdev);
if (ret) {
return ret;
bdesc->lun = lun;
if (ret) {
continue;
if (mode == 1) {
dev_print(bdesc);
Based on e887afc9da0fe the purpose of this flag was just print device status and I simply followed what was there before.
+/********************************************************************************* + * (re)-scan the scsi bus and reports scsi device info + * to the user if mode = 1 + */ +void scsi_scan(int mode)
If you look at the code someone wants to print this info someone not. SPL and FSL are only cases where mode is 0 not to print it. For platforms I can't see any reason not to print it - you probably want to be aware about it.
} /* if mode */
} /* next LUN */
+config DM_SCSI
depends on BLK
help
Fixed.
Fixed like.
This option enables the SCSI (Small Computer System Interface) uclass which supports SCSI and SATA HDDs. For every device configuration (IDs/LUNs) a block device is created with RAW read/write and filesystem support.
You are right second if CONFIG_DM_SCSI is not needed.
I hope when PCI code is cleanup that this will be handled differently.
Thanks, Michal
Michal Simek
