Re: [PATCH] rpi: copy the eMMC controller configuration from firmware-supplied DT
Ilya K me@0upti.me 於 2022年10月27日 週四 晚上7:48寫道:
FWIW, my vote is for the revised series. Also, we've been shipping both patches downstream in NixOS for a while now, and had no issues with either.
27.10.2022, 09:27, "Peter Robinson" pbrobinson@gmail.com:
Adding Matthias as the RPi maintainer.
There was also this patch series which fixed it and a few other things from the firmware DT [1] which is likely a better fix TBH.
Either way Matthias can we get one of these upstream as even the RPi4 Model B has moved to the newer rev of the SoCs so it's not a nice experience for users if they're not aware of the differences/problems.
Peter
[1] https://lists.denx.de/pipermail/u-boot/2022-August/491455.html
Great! This patch series looks nice, too.
Jian-Hong Pan
On Wed, Oct 26, 2022 at 12:23 PM Jian-Hong Pan jhp@endlessos.org wrote:
The RPi firmware adjusts the onboard eMMC controller's DMA mapping ranges of the FDT for each BCM2711 SoC revisions on the Pi 4 and RPi 400 automatically.
If the following kernel does not boot with the correct eMMC controller's DMA mapping ranges, the system on the SD card will boot failed and show these error messages:
mmc1: invalid bus width mmc1: error -22 whilst initialising SD card
This patch carries the adjustment from RPi firmware to the new loaded FDT for the following kernel.
Link: https://lists.denx.de/pipermail/u-boot/2021-September/462006.html Fixed: https://bugzilla.kernel.org/show_bug.cgi?id=213753 Signed-off-by: Ilya Katsnelson me@0upti.me Signed-off-by: Jian-Hong Pan jhp@endlessos.org
The code of this patch comes from "[RFC PATCH] rpi: copy the EMMC controller configuration from firmware-supplied DT" [1] basically. I only add the message and some modifcation:
- Fix the build failed error:
board/raspberrypi/rpi/rpi.c: In function 'copy_emmc_config': board/raspberrypi/rpi/rpi.c:553:9: warning: dereferencing 'void *' pointer 553 | *fw_value = fdt_getprop(fw_fdt, fw_emmc_node, "dma-ranges", &length); | ^~~~~~~~~ board/raspberrypi/rpi/rpi.c:553:19: error: invalid use of void expression 553 | *fw_value = fdt_getprop(fw_fdt, fw_emmc_node, "dma-ranges", &length); | ^ make[1]: *** [scripts/Makefile.build:258: board/raspberrypi/rpi/rpi.o] Error 1
Replace "EMMC" to "eMMC".
Replace the printf with log_[levels].
So, I keep "Ilya Katsnelson me@0upti.me" as the author.
board/raspberrypi/rpi/rpi.c | 63 +++++++++++++++++++++++++++++++++++++ 1 file changed, 63 insertions(+)
diff --git a/board/raspberrypi/rpi/rpi.c b/board/raspberrypi/rpi/rpi.c index 00afb352bd..d7ff8e269e 100644 --- a/board/raspberrypi/rpi/rpi.c +++ b/board/raspberrypi/rpi/rpi.c @@ -504,6 +504,67 @@ void *board_fdt_blob_setup(int *err) return (void *)fw_dtb_pointer; }
+void copy_emmc_config(void *our_fdt) +{
- As of 2021-09-28, the Pi 4 has two different revisions, one using a
- B0 stepping of the BCM2711 SoC, and one using a C0 stepping.
- The two SoC versions have different, incompatible DMA mappings for
- the on-board eMMC controller, which would normally make them require
- two different DTs.
- Unfortunately for us, the different revisions don't actually _use_
- different DTs - instead, the proprietary stage0 bootloader reads the DT,
- patches it in-memory, then passes the corrected DT to the OS.
- In our case, the OS is actually U-Boot, and U-Boot can choose to
- completely disregard the firmware-supplied DT and load a custom one
- instead, which is used by, e.g., NixOS.
- When that happens, the DT patches applied by the firmware are also
- thrown out, which leads to BCM2711C0 boards being unable to boot
- due to them trying to use the hardcoded DMA mappings in the DT
- (which are for the B0 revision).
- Work around that by manually copying the DMA region setup from the
- firmware-provided DT into whatever DT we're actually being asked
- to load.
- void *fw_fdt = (void *)fw_dtb_pointer;
- int fw_emmc_node;
- int our_emmc_node;
- int length;
- const void *fw_value;
- int result;
- fw_emmc_node = fdt_path_offset(fw_fdt, "emmc2bus");
- if (fw_emmc_node < 0) {
- log_info("RPi: Failed to find eMMC config in FW DT: %d\n", fw_emmc_node);
- return;
- our_emmc_node = fdt_path_offset(our_fdt, "emmc2bus");
- if (our_emmc_node < 0) {
- log_info("RPi: Failed to find eMMC config in our DT: %d\n", our_emmc_node);
- return;
- fw_value = fdt_getprop(fw_fdt, fw_emmc_node, "dma-ranges", &length);
- if (!fw_value) {
- log_info("RPi: Failed to get eMMC DMA ranges property from FW DT: %d\n", length);
- return;
- result = fdt_setprop(our_fdt, our_emmc_node, "dma-ranges", fw_value, length);
- if (result != 0) {
- log_warning("RPi: Failed to set eMMC DMA ranges property in our DT: %d\n", result);
- return;
- log_debug("RPi: successfully copied FW DT eMMC configuration to our DT!\n");
int ft_board_setup(void *blob, struct bd_info *bd) { int node; @@ -518,5 +579,7 @@ int ft_board_setup(void *blob, struct bd_info *bd) EFI_RESERVED_MEMORY_TYPE); #endif
- copy_emmc_config(blob);
2.38.1
Jian-Hong Pan
