[U-Boot] [PATCH] zynqmp: configs: Add single nand flash mini u-boot configuration
This patch adds configuration for single nand flash mini u-boot.
Signed-off-by: T Karthik Reddy t.karthik.reddy@xilinx.com Signed-off-by: Siva Durga Prasad Paladugu siva.durga.paladugu@xilinx.com Signed-off-by: Michal Simek michal.simek@xilinx.com ---
.../xilinx_zynqmp_mini_nand_single_defconfig | 51 +++++++++++++++++++ 1 file changed, 51 insertions(+) create mode 100644 configs/xilinx_zynqmp_mini_nand_single_defconfig
diff --git a/configs/xilinx_zynqmp_mini_nand_single_defconfig b/configs/xilinx_zynqmp_mini_nand_single_defconfig new file mode 100644 index 000000000000..f2c2b175275d --- /dev/null +++ b/configs/xilinx_zynqmp_mini_nand_single_defconfig @@ -0,0 +1,51 @@ +CONFIG_ARM=y +CONFIG_SYS_CONFIG_NAME="xilinx_zynqmp_mini_nand" +CONFIG_SYS_ICACHE_OFF=y +CONFIG_ARCH_ZYNQMP=y +CONFIG_SYS_TEXT_BASE=0x10000 +CONFIG_ENV_SIZE=0x80 +CONFIG_NR_DRAM_BANKS=1 +# CONFIG_CMD_ZYNQMP is not set +CONFIG_FIT=y +CONFIG_SUPPORT_RAW_INITRD=y +# CONFIG_BOARD_LATE_INIT is not set +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_BOARD_EARLY_INIT_R=y +# CONFIG_CMDLINE_EDITING is not set +# CONFIG_AUTO_COMPLETE is not set +# CONFIG_SYS_LONGHELP is not set +# CONFIG_AUTOBOOT is not set +# CONFIG_CMD_BDI is not set +# CONFIG_CMD_CONSOLE is not set +# CONFIG_CMD_BOOTD is not set +# CONFIG_CMD_BOOTM is not set +# CONFIG_CMD_BOOTI is not set +# CONFIG_CMD_GO is not set +# CONFIG_CMD_RUN is not set +# CONFIG_CMD_IMI is not set +# CONFIG_CMD_XIMG is not set +# CONFIG_CMD_EXPORTENV is not set +# CONFIG_CMD_IMPORTENV is not set +# CONFIG_CMD_EDITENV is not set +# CONFIG_CMD_SAVEENV is not set +# CONFIG_CMD_ENV_EXISTS is not set +# CONFIG_CMD_CRC32 is not set +# CONFIG_CMD_DM is not set +# CONFIG_CMD_FLASH is not set +# CONFIG_CMD_LOADB is not set +# CONFIG_CMD_LOADS is not set +# CONFIG_CMD_ECHO is not set +# CONFIG_CMD_ITEST is not set +# CONFIG_CMD_SOURCE is not set +# CONFIG_CMD_SETEXPR is not set +# CONFIG_MP is not set +# CONFIG_PARTITIONS is not set +CONFIG_OF_EMBED=y +CONFIG_DEFAULT_DEVICE_TREE="zynqmp-mini-nand" +# CONFIG_NET is not set +# CONFIG_DM_WARN is not set +# CONFIG_DM_DEVICE_REMOVE is not set +# CONFIG_MMC is not set +CONFIG_NAND=y +CONFIG_NAND_ARASAN=y +# CONFIG_EFI_LOADER is not set
po 14. 10. 2019 v 15:01 odesÃlatel Michal Simek michal.simek@xilinx.com napsal:
2.17.1
Applied. M
Michal Simek
Michal Simek
