[PATCH] arm64: rk3399: Add support NanoPi R4s
NanoPi R4s is SBC base on Rockchip RK3399 hexa-core processor with dual-Core Cortex-A72 and Mali-T864 GPU with 4GiB(LPDDR4) of RAM, SD card support, including 2 gigabit ethernet(RTL8211E 1Gbps - RTL8111H 1Gbps) and 2 USB 3.0 port. port.It also has two GPIO headers which allows further peripherals to be used.
The devicetree file is taken of the rk3399 nanopi4 Linux kernel [1].
[1] https://github.com/torvalds/linux/commit/e7a095908227fb3ccc86d001d9e13c9ae2b...
Signed-off-by: xiaobo peterwillcn@gmail.com --- arch/arm/dts/Makefile | 1 + arch/arm/dts/rk3399-nanopi-r4s-u-boot.dtsi | 17 +++ arch/arm/dts/rk3399-nanopi-r4s.dts | 138 +++++++++++++++++++++ board/rockchip/evb_rk3399/MAINTAINERS | 6 + configs/nanopi-r4s-rk3399_defconfig | 62 +++++++++ 5 files changed, 224 insertions(+) create mode 100644 arch/arm/dts/rk3399-nanopi-r4s-u-boot.dtsi create mode 100644 arch/arm/dts/rk3399-nanopi-r4s.dts create mode 100644 configs/nanopi-r4s-rk3399_defconfig
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 858b79ac97..528dfe069e 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -92,6 +92,7 @@ dtb-$(CONFIG_ROCKCHIP_RK3288) += \ rk3288-evb.dtb \ rk3288-firefly.dtb \ rk3288-miqi.dtb \ + rk3399-nanopi-r4s.dtb \ rk3288-phycore-rdk.dtb \ rk3288-popmetal.dtb \ rk3288-rock2-square.dtb \ diff --git a/arch/arm/dts/rk3399-nanopi-r4s-u-boot.dtsi b/arch/arm/dts/rk3399-nanopi-r4s-u-boot.dtsi new file mode 100644 index 0000000000..3f97867cc5 --- /dev/null +++ b/arch/arm/dts/rk3399-nanopi-r4s-u-boot.dtsi @@ -0,0 +1,17 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * RK3399-based FriendlyElec boards device tree source + * + * Copyright (c) 2016 Fuzhou Rockchip Electronics Co., Ltd + * + * Copyright (c) 2018 FriendlyElec Computer Tech. Co., Ltd. + * (http://www.friendlyarm.com) + * + * Copyright (c) 2018 Collabora Ltd. + * Copyright (c) 2019 Arm Ltd. + * Copyright (C) 2020 Xiaobo peterwillcn@gmail.com + */ + +#include "rk3399-nanopi4-u-boot.dtsi" +#include "rk3399-sdram-lpddr4-100.dtsi" +#include "rk3399-sdram-ddr3-1866.dtsi" diff --git a/arch/arm/dts/rk3399-nanopi-r4s.dts b/arch/arm/dts/rk3399-nanopi-r4s.dts new file mode 100644 index 0000000000..6f2cf17bf1 --- /dev/null +++ b/arch/arm/dts/rk3399-nanopi-r4s.dts @@ -0,0 +1,138 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2016 Fuzhou Rockchip Electronics Co., Ltd + * + * Copyright (c) 2018 FriendlyElec Computer Tech. Co., Ltd. + * (http://www.friendlyarm.com) + * + * Copyright (c) 2018 Collabora Ltd. + * Copyright (c) 2019 Arm Ltd. + * Copyright (C) 2020 Xiaobo peterwillcn@gmail.com + */ + +/dts-v1/; +#include "rk3399-nanopi4.dtsi" + +/ { + model = "FriendlyElec NanoPi R4S"; + compatible = "friendlyarm,nanopi-r4s", "rockchip,rk3399"; + + aliases { + ethernet1 = &r8169; + }; + + vdd_5v: vdd-5v { + compatible = "regulator-fixed"; + regulator-name = "vdd_5v"; + regulator-always-on; + regulator-boot-on; + }; + + fan: pwm-fan { + compatible = "pwm-fan"; + cooling-levels = <0 12 18 255>; + #cooling-cells = <2>; + fan-supply = <&vdd_5v>; + pwms = <&pwm1 0 50000 0>; + }; +}; + +&cpu_thermal { + trips { + cpu_warm: cpu_warm { + temperature = <55000>; + hysteresis = <2000>; + type = "active"; + }; + + cpu_hot: cpu_hot { + temperature = <65000>; + hysteresis = <2000>; + type = "active"; + }; + }; + + cooling-maps { + map2 { + trip = <&cpu_warm>; + cooling-device = <&fan THERMAL_NO_LIMIT 1>; + }; + + map3 { + trip = <&cpu_hot>; + cooling-device = <&fan 2 THERMAL_NO_LIMIT>; + }; + }; +}; + +&emmc_phy { + status = "disabled"; +}; + +&fusb0 { + status = "disabled"; +}; + +&leds { + lan_led: led-1 { + gpios = <&gpio1 RK_PA1 GPIO_ACTIVE_HIGH>; + label = "nanopi-r4s:green:lan"; + }; + + wan_led: led-2 { + gpios = <&gpio1 RK_PA0 GPIO_ACTIVE_HIGH>; + label = "nanopi-r4s:green:wan"; + }; +}; + +&leds_gpio { + rockchip,pins = + <0 RK_PB5 RK_FUNC_GPIO &pcfg_pull_none>, + <1 RK_PA0 RK_FUNC_GPIO &pcfg_pull_none>, + <1 RK_PA1 RK_FUNC_GPIO &pcfg_pull_none>; +}; + +&pcie0 { + max-link-speed = <1>; + num-lanes = <1>; + vpcie3v3-supply = <&vcc3v3_sys>; + + pcie@0 { + reg = <0x00000000 0 0 0 0>; + #address-cells = <3>; + #size-cells = <2>; + + r8169: pcie@0,0 { + reg = <0x000000 0 0 0 0>; + local-mac-address = [ 00 00 00 00 00 00 ]; + }; + }; +}; + +&sdhci { + status = "disabled"; +}; + +&sdio0 { + status = "disabled"; +}; + +&sdmmc { + host-index-min = <1>; +}; + +&u2phy0_host { + phy-supply = <&vdd_5v>; +}; + +&u2phy1_host { + status = "disabled"; +}; + +&usbdrd_dwc3_0 { + dr_mode = "host"; +}; + +&vcc3v3_sys { + vin-supply = <&vcc5v0_sys>; +}; diff --git a/board/rockchip/evb_rk3399/MAINTAINERS b/board/rockchip/evb_rk3399/MAINTAINERS index 4c889e06a6..3b9d60eccd 100644 --- a/board/rockchip/evb_rk3399/MAINTAINERS +++ b/board/rockchip/evb_rk3399/MAINTAINERS @@ -55,6 +55,12 @@ S: Maintained F: configs/nanopi-neo4-rk3399_defconfig F: arch/arm/dts/rk3399-nanopi-neo4-u-boot.dtsi
+NANOPI-R4S +M: Xiaobo Tian peterwillcn@gmail.com +S: Maintained +F: configs/nanopi-r4s-rk3399_defconfig +F: arch/arm/dts/rk3399-nanopi-r4s-u-boot.dtsi + ORANGEPI-RK3399 M: Jagan Teki jagan@amarulasolutions.com S: Maintained diff --git a/configs/nanopi-r4s-rk3399_defconfig b/configs/nanopi-r4s-rk3399_defconfig new file mode 100644 index 0000000000..0a3c28b012 --- /dev/null +++ b/configs/nanopi-r4s-rk3399_defconfig @@ -0,0 +1,62 @@ +CONFIG_ARM=y +CONFIG_ARCH_ROCKCHIP=y +CONFIG_SYS_TEXT_BASE=0x00200000 +CONFIG_ENV_OFFSET=0x3F8000 +CONFIG_ROCKCHIP_RK3399=y +CONFIG_TARGET_EVB_RK3399=y +CONFIG_NR_DRAM_BANKS=1 +CONFIG_DEBUG_UART_BASE=0xFF1A0000 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_DEBUG_UART=y +CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-nanopi-r4s.dtb" +CONFIG_DISPLAY_BOARDINFO_LATE=y +# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set +CONFIG_SPL_STACK_R=y +CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x10000 +CONFIG_TPL=y +CONFIG_CMD_BOOTZ=y +CONFIG_CMD_GPT=y +CONFIG_CMD_MMC=y +CONFIG_CMD_USB=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_TIME=y +CONFIG_SPL_OF_CONTROL=y +CONFIG_DEFAULT_DEVICE_TREE="rk3399-nanopi-r4s" +CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" +CONFIG_ENV_IS_IN_MMC=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_ROCKCHIP_GPIO=y +CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_MMC_DW=y +CONFIG_MMC_DW_ROCKCHIP=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_ROCKCHIP=y +CONFIG_DM_ETH=y +CONFIG_ETH_DESIGNWARE=y +CONFIG_GMAC_ROCKCHIP=y +CONFIG_PMIC_RK8XX=y +CONFIG_REGULATOR_PWM=y +CONFIG_REGULATOR_RK8XX=y +CONFIG_PWM_ROCKCHIP=y +CONFIG_RAM_RK3399_LPDDR4=y +CONFIG_BAUDRATE=1500000 +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_SYSRESET=y +CONFIG_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_EHCI_GENERIC=y +CONFIG_USB_KEYBOARD=y +CONFIG_USB_HOST_ETHER=y +CONFIG_USB_ETHER_ASIX=y +CONFIG_USB_ETHER_ASIX88179=y +CONFIG_USB_ETHER_MCS7830=y +CONFIG_USB_ETHER_RTL8152=y +CONFIG_USB_ETHER_SMSC95XX=y +CONFIG_DM_VIDEO=y +CONFIG_DISPLAY=y +CONFIG_VIDEO_ROCKCHIP=y +CONFIG_DISPLAY_ROCKCHIP_HDMI=y +CONFIG_SPL_TINY_MEMSET=y +CONFIG_ERRNO_STR=y
Am Mon, Feb 08, 2021 at 04:56:35PM +0800 schrieb xiaobo:
- rk3399-nanopi-r4s.dtb \
This is in the wrong list. You need to put it into the RK3399 list, not RK3288.
- RK3399-based FriendlyElec boards device tree source
- Copyright (c) 2016 Fuzhou Rockchip Electronics Co., Ltd
- Copyright (c) 2018 FriendlyElec Computer Tech. Co., Ltd.
- Copyright (c) 2018 Collabora Ltd.
- Copyright (c) 2019 Arm Ltd.
- Copyright (C) 2020 Xiaobo peterwillcn@gmail.com
This is wrong as well. I think there can only be lpddr4 *or* ddr3. I think the last one has precedence. I have a 4G machine, and it doesn't work with this. If I remove the ddr3 (since 4G machine has lpddr4), it works.
- model = "FriendlyElec NanoPi R4S";
- compatible = "friendlyarm,nanopi-r4s", "rockchip,rk3399";
- aliases {
ethernet1 = &r8169;
- vdd_5v: vdd-5v {
regulator-boot-on;
- fan: pwm-fan {
+&cpu_thermal {
- trips {
type = "active";
cpu_hot: cpu_hot {
type = "active";
- cooling-maps {
map2 {
trip = <&cpu_warm>;
map3 {
trip = <&cpu_hot>;
+&emmc_phy {
- status = "disabled";
+&fusb0 {
+&leds {
- lan_led: led-1 {
- wan_led: led-2 {
+&leds_gpio {
- rockchip,pins =
+&pcie0 {
- max-link-speed = <1>;
- num-lanes = <1>;
- vpcie3v3-supply = <&vcc3v3_sys>;
- pcie@0 {
#size-cells = <2>;
r8169: pcie@0,0 {
+&sdhci {
+&sdio0 {
+&sdmmc {
- host-index-min = <1>;
+&u2phy0_host {
- phy-supply = <&vdd_5v>;
+&u2phy1_host {
+&usbdrd_dwc3_0 {
- dr_mode = "host";
+&vcc3v3_sys {
- vin-supply = <&vcc5v0_sys>;
+CONFIG_ERRNO_STR=y
2.30.0
Am Fri, Feb 26, 2021 at 09:37:58PM +0100 schrieb Patrick Wildt:
- aliases {
ethernet1 = &r8169;
- vdd_5v: vdd-5v {
regulator-boot-on;
- fan: pwm-fan {
+&cpu_thermal {
- trips {
type = "active";
cpu_hot: cpu_hot {
type = "active";
- cooling-maps {
map2 {
trip = <&cpu_warm>;
map3 {
trip = <&cpu_hot>;
+&emmc_phy {
+&fusb0 {
+&leds {
- lan_led: led-1 {
- wan_led: led-2 {
+&leds_gpio {
- rockchip,pins =
+&pcie0 {
- num-lanes = <1>;
- pcie@0 {
#size-cells = <2>;
r8169: pcie@0,0 {
+&sdhci {
+&sdio0 {
+&sdmmc {
Also I can't find any user of this property.
+&u2phy0_host {
+&u2phy1_host {
+&usbdrd_dwc3_0 {
- dr_mode = "host";
+&vcc3v3_sys {
+CONFIG_ERRNO_STR=y
2.30.0
Patrick Wildt
xiaobo
