[U-Boot] [PATCHv2] armv8: fsl-layerscape: Fix a typo of Layerscape PCIe config entry
The correct config entry is CONFIG_PCIE_LAYERSCAPE, this typo result in skipping the fixup of Linux PCIe DT nodes.
Also enable the fixup when Layerscape Gen4 controller driver is enabled.
Fixes: 4da0e52c9dc0 (armv8: fsl-layerscape: fix config dependency for layerscape pci code) Signed-off-by: Hou Zhiqiang Zhiqiang.Hou@nxp.com --- V2: - Enable this fixup for Layerscape Gen4 controller driver.
arch/arm/cpu/armv8/fsl-layerscape/fdt.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/fdt.c b/arch/arm/cpu/armv8/fsl-layerscape/fdt.c index fabe0f0359..25b7afe064 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/fdt.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/fdt.c @@ -435,7 +435,7 @@ void ft_cpu_setup(void *blob, bd_t *bd) do_fixup_by_path_u32(blob, "/sysclk", "clock-frequency", CONFIG_SYS_CLK_FREQ, 1);
-#ifdef CONFIG_PCI_LAYERSCAPE +#if defined(CONFIG_PCIE_LAYERSCAPE) || defined(CONFIG_PCIE_LAYERSCAPE_GEN4) ft_pci_setup(blob, bd); #endif
nits: and this typo
results
V2:
After addressing the above, you can add my: Reviewed-by: Bin Meng bmeng.cn@gmail.com
Regards, Bin
Hi Bin,
Thanks a lot for your comments!
-----Original Message----- From: Bin Meng bmeng.cn@gmail.com Sent: 2019年8月26日 16:56 To: Z.q. Hou zhiqiang.hou@nxp.com Cc: u-boot@lists.denx.de; Prabhakar Kushwaha prabhakar.kushwaha@nxp.com; alexm.osslist@gmail.com Subject: Re: [U-Boot] [PATCHv2] armv8: fsl-layerscape: Fix a typo of Layerscape PCIe config entry
nits: and this typo
results
I'll fix my bad sentence in v3 :).
V2:
Thanks a lot for your review!
B.R, Zhiqiang
Regards, Bin
Bin Meng
Z.q. Hou
