[U-Boot] [PATCH v2 0/9] mtd: nand: mxs_nand: add device tree support
This patchset adds device tree support to the MXS NAND driver. This also allows to use fixed ECC strenght usingt he device tree properties nand-ecc-strength/nand-ecc-step-size and aligns behavior with the Linux GPMI NAND driver.
This is based on the "mtd: nand: mxs_nand: improve ECC support" patchset: https://patchwork.ozlabs.org/cover/897263/
Support for nand-ecc-strength/nand-ecc-step-size has recently been added in Linux, see: https://patchwork.kernel.org/patch/10257829/
This patchset has been tested with various ECC configurations on a Colibri iMX7.
This second version is rebased onto v4 of the "improve ECC support" patchset.
-- Stefan
Changes in v2: - Set base registers also in SPL init - Update function name also in SPL init - Move free of nand_info to board_nand_init - Rename patch title since there is already a header file
Stefan Agner (9): mtd: nand: mxs_nand: move register structs to driver data mtd: nand: mxs_nand: use more precise function name mtd: nand: mxs_nand: separate board/controller init mtd: nand: mxs_nand: add use_minimum_ecc to struct mtd: nand: mxs_nand: move structs into header file mtd: nand: mxs_nand: add device tree support mtd: nand: mxs_nand: add support for specific ECC strength arm: dts: imx7: sync with Linux arm: dts: imx7: colibri: add raw NAND support
arch/arm/dts/imx7-colibri.dts | 28 ++ arch/arm/dts/imx7s.dtsi | 491 +++++++++++++++--------- drivers/mtd/nand/Kconfig | 7 + drivers/mtd/nand/Makefile | 1 + drivers/mtd/nand/mxs_nand.c | 218 +++++------ drivers/mtd/nand/mxs_nand.h | 62 +++ drivers/mtd/nand/mxs_nand_dt.c | 86 +++++ include/dt-bindings/clock/imx7d-clock.h | 15 +- include/dt-bindings/power/imx7-power.h | 16 + 9 files changed, 625 insertions(+), 299 deletions(-) create mode 100644 drivers/mtd/nand/mxs_nand_dt.c create mode 100644 include/dt-bindings/power/imx7-power.h
Move GPMI and BCH register structs to the driver struct mxs_nand_info in prepartion for device tree support.
Signed-off-by: Stefan Agner stefan.agner@toradex.com ---
drivers/mtd/nand/mxs_nand.c | 34 +++++++++++++++++----------------- 1 file changed, 17 insertions(+), 17 deletions(-)
diff --git a/drivers/mtd/nand/mxs_nand.c b/drivers/mtd/nand/mxs_nand.c index 15d8bcb76b..65fed66309 100644 --- a/drivers/mtd/nand/mxs_nand.c +++ b/drivers/mtd/nand/mxs_nand.c @@ -84,6 +84,9 @@ struct mxs_nand_info { uint8_t marking_block_bad; uint8_t raw_oob_mode;
+ struct mxs_gpmi_regs *gpmi_regs; + struct mxs_bch_regs *bch_regs; + /* Functions with altered behaviour */ int (*hooked_read_oob)(struct mtd_info *mtd, loff_t from, struct mtd_oob_ops *ops); @@ -297,16 +300,15 @@ static inline int mxs_nand_calc_ecc_layout(struct bch_geometry *geo, /* * Wait for BCH complete IRQ and clear the IRQ */ -static int mxs_nand_wait_for_bch_complete(void) +static int mxs_nand_wait_for_bch_complete(struct mxs_nand_info *nand_info) { - struct mxs_bch_regs *bch_regs = (struct mxs_bch_regs *)MXS_BCH_BASE; int timeout = MXS_NAND_BCH_TIMEOUT; int ret;
- ret = mxs_wait_mask_set(&bch_regs->hw_bch_ctrl_reg, + ret = mxs_wait_mask_set(&nand_info->bch_regs->hw_bch_ctrl_reg, BCH_CTRL_COMPLETE_IRQ, timeout);
- writel(BCH_CTRL_COMPLETE_IRQ, &bch_regs->hw_bch_ctrl_clr); + writel(BCH_CTRL_COMPLETE_IRQ, &nand_info->bch_regs->hw_bch_ctrl_clr);
return ret; } @@ -404,11 +406,9 @@ static int mxs_nand_device_ready(struct mtd_info *mtd) { struct nand_chip *chip = mtd_to_nand(mtd); struct mxs_nand_info *nand_info = nand_get_controller_data(chip); - struct mxs_gpmi_regs *gpmi_regs = - (struct mxs_gpmi_regs *)MXS_GPMI_BASE; uint32_t tmp;
- tmp = readl(&gpmi_regs->hw_gpmi_stat); + tmp = readl(&nand_info->gpmi_regs->hw_gpmi_stat); tmp >>= (GPMI_STAT_READY_BUSY_OFFSET + nand_info->cur_chip);
return tmp & 1; @@ -705,7 +705,7 @@ static int mxs_nand_ecc_read_page(struct mtd_info *mtd, struct nand_chip *nand, goto rtn; }
- ret = mxs_nand_wait_for_bch_complete(); + ret = mxs_nand_wait_for_bch_complete(nand_info); if (ret) { printf("MXS NAND: BCH read timeout\n"); goto rtn; @@ -813,7 +813,7 @@ static int mxs_nand_ecc_write_page(struct mtd_info *mtd, goto rtn; }
- ret = mxs_nand_wait_for_bch_complete(); + ret = mxs_nand_wait_for_bch_complete(nand_info); if (ret) { printf("MXS NAND: BCH write timeout\n"); goto rtn; @@ -1038,7 +1038,7 @@ int mxs_nand_setup_ecc(struct mtd_info *mtd) struct nand_chip *nand = mtd_to_nand(mtd); struct mxs_nand_info *nand_info = nand_get_controller_data(nand); struct bch_geometry *geo = &nand_info->bch_geometry; - struct mxs_bch_regs *bch_regs = (struct mxs_bch_regs *)MXS_BCH_BASE; + struct mxs_bch_regs *bch_regs = nand_info->bch_regs; uint32_t tmp; int ret = -ENOTSUPP;
@@ -1139,10 +1139,6 @@ int mxs_nand_alloc_buffers(struct mxs_nand_info *nand_info) */ int mxs_nand_init(struct mxs_nand_info *info) { - struct mxs_gpmi_regs *gpmi_regs = - (struct mxs_gpmi_regs *)MXS_GPMI_BASE; - struct mxs_bch_regs *bch_regs = - (struct mxs_bch_regs *)MXS_BCH_BASE; int i = 0, j, ret = 0;
info->desc = malloc(sizeof(struct mxs_dma_desc *) * @@ -1171,14 +1167,14 @@ int mxs_nand_init(struct mxs_nand_info *info) }
/* Reset the GPMI block. */ - mxs_reset_block(&gpmi_regs->hw_gpmi_ctrl0_reg); - mxs_reset_block(&bch_regs->hw_bch_ctrl_reg); + mxs_reset_block(&info->gpmi_regs->hw_gpmi_ctrl0_reg); + mxs_reset_block(&info->bch_regs->hw_bch_ctrl_reg);
/* * Choose NAND mode, set IRQ polarity, disable write protection and * select BCH ECC. */ - clrsetbits_le32(&gpmi_regs->hw_gpmi_ctrl1, + clrsetbits_le32(&info->gpmi_regs->hw_gpmi_ctrl1, GPMI_CTRL1_GPMI_MODE, GPMI_CTRL1_ATA_IRQRDY_POLARITY | GPMI_CTRL1_DEV_RESET | GPMI_CTRL1_BCH_MODE); @@ -1210,6 +1206,8 @@ int mxs_nand_init_spl(struct nand_chip *nand) } memset(nand_info, 0, sizeof(struct mxs_nand_info));
+ nand_info->gpmi_regs = (struct mxs_gpmi_regs *)MXS_GPMI_BASE; + nand_info->bch_regs = (struct mxs_bch_regs *)MXS_BCH_BASE; err = mxs_nand_alloc_buffers(nand_info); if (err) return err; @@ -1253,6 +1251,8 @@ void board_nand_init(void) } memset(nand_info, 0, sizeof(struct mxs_nand_info));
+ nand_info->gpmi_regs = (struct mxs_gpmi_regs *)MXS_GPMI_BASE; + nand_info->bch_regs = (struct mxs_bch_regs *)MXS_BCH_BASE; nand = &nand_info->chip; mtd = nand_to_mtd(nand); err = mxs_nand_alloc_buffers(nand_info);
This function initializes DMA descriptors so mxs_nand_init_dma is more precise. It also frees up the rather generic name mxs_nand_init.
Changes in v2: - Update function name also in SPL init
drivers/mtd/nand/mxs_nand.c | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/drivers/mtd/nand/mxs_nand.c b/drivers/mtd/nand/mxs_nand.c index 65fed66309..6bd3cb12f9 100644 --- a/drivers/mtd/nand/mxs_nand.c +++ b/drivers/mtd/nand/mxs_nand.c @@ -1137,7 +1137,7 @@ int mxs_nand_alloc_buffers(struct mxs_nand_info *nand_info) /* * Initializes the NFC hardware. */ -int mxs_nand_init(struct mxs_nand_info *info) +int mxs_nand_init_dma(struct mxs_nand_info *info) { int i = 0, j, ret = 0;
@@ -1212,7 +1212,7 @@ int mxs_nand_init_spl(struct nand_chip *nand) if (err) return err;
- err = mxs_nand_init(nand_info); + err = mxs_nand_init_dma(nand_info); if (err) return err;
@@ -1259,7 +1259,7 @@ void board_nand_init(void) if (err) goto err1;
- err = mxs_nand_init(nand_info); + err = mxs_nand_init_dma(nand_info); if (err) goto err2;
In preparation for device tree support separate board init from controller init similar to other raw NAND drivers.
Changes in v2: - Move free of nand_info to board_nand_init
drivers/mtd/nand/mxs_nand.c | 54 ++++++++++++++++++++++--------------- 1 file changed, 33 insertions(+), 21 deletions(-)
diff --git a/drivers/mtd/nand/mxs_nand.c b/drivers/mtd/nand/mxs_nand.c index 6bd3cb12f9..bb40237362 100644 --- a/drivers/mtd/nand/mxs_nand.c +++ b/drivers/mtd/nand/mxs_nand.c @@ -1237,31 +1237,21 @@ int mxs_nand_init_spl(struct nand_chip *nand) return 0; }
-void board_nand_init(void) +int mxs_nand_init(struct mxs_nand_info *nand_info) { struct mtd_info *mtd; - struct mxs_nand_info *nand_info; struct nand_chip *nand; int err;
- nand_info = malloc(sizeof(struct mxs_nand_info)); - if (!nand_info) { - printf("MXS NAND: Failed to allocate private data\n"); - return; - } - memset(nand_info, 0, sizeof(struct mxs_nand_info)); - - nand_info->gpmi_regs = (struct mxs_gpmi_regs *)MXS_GPMI_BASE; - nand_info->bch_regs = (struct mxs_bch_regs *)MXS_BCH_BASE; nand = &nand_info->chip; mtd = nand_to_mtd(nand); err = mxs_nand_alloc_buffers(nand_info); if (err) - goto err1; + return err;
err = mxs_nand_init_dma(nand_info); if (err) - goto err2; + goto err_free_buffers;
memset(&fake_ecc_layout, 0, sizeof(fake_ecc_layout));
@@ -1285,10 +1275,10 @@ void board_nand_init(void)
/* first scan to find the device and get the page size */ if (nand_scan_ident(mtd, CONFIG_SYS_MAX_NAND_DEVICE, NULL)) - goto err2; + goto err_free_buffers;
if (mxs_nand_setup_ecc(mtd)) - goto err2; + goto err_free_buffers;
nand->ecc.read_page = mxs_nand_ecc_read_page; nand->ecc.write_page = mxs_nand_ecc_write_page; @@ -1303,18 +1293,40 @@ void board_nand_init(void) /* second phase scan */ err = nand_scan_tail(mtd); if (err) - goto err2; + goto err_free_buffers;
err = nand_register(0, mtd); if (err) - goto err2; + goto err_free_buffers;
- return; + return 0;
-err2: +err_free_buffers: free(nand_info->data_buf); free(nand_info->cmd_buf); -err1: - free(nand_info); + + return err; +} + +void board_nand_init(void) +{ + struct mxs_nand_info *nand_info; + + nand_info = malloc(sizeof(struct mxs_nand_info)); + if (!nand_info) { + printf("MXS NAND: Failed to allocate private data\n"); + return; + } + memset(nand_info, 0, sizeof(struct mxs_nand_info)); + + nand_info->gpmi_regs = (struct mxs_gpmi_regs *)MXS_GPMI_BASE; + nand_info->bch_regs = (struct mxs_bch_regs *)MXS_BCH_BASE; + + if (mxs_nand_init(nand_info) < 0) + goto err; + return; + +err: + free(nand_info); }
Add use_minimum_ecc as struct mxs_nand_info field in preparation for device tree support.
Changes in v2: None
drivers/mtd/nand/mxs_nand.c | 34 ++++++++++++++++++++-------------- 1 file changed, 20 insertions(+), 14 deletions(-)
diff --git a/drivers/mtd/nand/mxs_nand.c b/drivers/mtd/nand/mxs_nand.c index bb40237362..3c9ee07be5 100644 --- a/drivers/mtd/nand/mxs_nand.c +++ b/drivers/mtd/nand/mxs_nand.c @@ -71,6 +71,8 @@ struct bch_geometry {
struct mxs_nand_info { struct nand_chip chip; + unsigned int max_ecc_strength_supported; + bool use_minimum_ecc; int cur_chip;
uint32_t cmd_queue_len; @@ -215,19 +217,11 @@ static inline int mxs_nand_calc_mark_offset(struct bch_geometry *geo, return 0; }
-static inline unsigned int mxs_nand_max_ecc_strength_supported(void) -{ - /* Refer to Chapter 17 for i.MX6DQ, Chapter 18 for i.MX6SX */ - if (is_mx6sx() || is_mx7()) - return 62; - else - return 40; -} - static inline int mxs_nand_calc_ecc_layout_by_info(struct bch_geometry *geo, struct mtd_info *mtd) { struct nand_chip *chip = mtd_to_nand(mtd); + struct mxs_nand_info *nand_info = nand_get_controller_data(chip);
if (!(chip->ecc_strength_ds > 0 && chip->ecc_step_ds > 0)) return -ENOTSUPP; @@ -250,7 +244,7 @@ static inline int mxs_nand_calc_ecc_layout_by_info(struct bch_geometry *geo, if (geo->ecc_chunk_size < mtd->oobsize) return -EINVAL;
- if (geo->ecc_strength > mxs_nand_max_ecc_strength_supported()) + if (geo->ecc_strength > nand_info->max_ecc_strength_supported) return -EINVAL;
geo->ecc_chunk_count = mtd->writesize / geo->ecc_chunk_size; @@ -261,6 +255,9 @@ static inline int mxs_nand_calc_ecc_layout_by_info(struct bch_geometry *geo, static inline int mxs_nand_calc_ecc_layout(struct bch_geometry *geo, struct mtd_info *mtd) { + struct nand_chip *chip = mtd_to_nand(mtd); + struct mxs_nand_info *nand_info = nand_get_controller_data(chip); + /* The default for the length of Galois Field. */ geo->gf_len = 13;
@@ -292,7 +289,7 @@ static inline int mxs_nand_calc_ecc_layout(struct bch_geometry *geo, / (geo->gf_len * geo->ecc_chunk_count);
geo->ecc_strength = min(round_down(geo->ecc_strength, 2), - mxs_nand_max_ecc_strength_supported()); + nand_info->max_ecc_strength_supported);
return 0; } @@ -1042,9 +1039,8 @@ int mxs_nand_setup_ecc(struct mtd_info *mtd) uint32_t tmp; int ret = -ENOTSUPP;
-#ifdef CONFIG_NAND_MXS_USE_MINIMUM_ECC - ret = mxs_nand_calc_ecc_layout_by_info(geo, mtd); -#endif + if (nand_info->use_minimum_ecc) + ret = mxs_nand_calc_ecc_layout_by_info(geo, mtd);
if (ret == -ENOTSUPP) ret = mxs_nand_calc_ecc_layout(geo, mtd); @@ -1322,6 +1318,16 @@ void board_nand_init(void) nand_info->gpmi_regs = (struct mxs_gpmi_regs *)MXS_GPMI_BASE; nand_info->bch_regs = (struct mxs_bch_regs *)MXS_BCH_BASE;
+ /* Refer to Chapter 17 for i.MX6DQ, Chapter 18 for i.MX6SX */ + if (is_mx6sx() || is_mx7()) + nand_info->max_ecc_strength_supported = 62; + else + nand_info->max_ecc_strength_supported = 40; + +#ifdef CONFIG_NAND_MXS_USE_MINIMUM_ECC + nand_info->use_minimum_ecc = true; +#endif + if (mxs_nand_init(nand_info) < 0) goto err;
Move structs into header file so we can use a separate compile unit for device tree support.
Changes in v2: - Rename patch title since there is already a header file
drivers/mtd/nand/mxs_nand.c | 63 ++----------------------------------- drivers/mtd/nand/mxs_nand.h | 62 ++++++++++++++++++++++++++++++++++++ 2 files changed, 65 insertions(+), 60 deletions(-)
diff --git a/drivers/mtd/nand/mxs_nand.c b/drivers/mtd/nand/mxs_nand.c index 3c9ee07be5..8748c927c6 100644 --- a/drivers/mtd/nand/mxs_nand.c +++ b/drivers/mtd/nand/mxs_nand.c @@ -13,12 +13,11 @@ */
#include <common.h> -#include <linux/mtd/mtd.h> +#include <dm.h> #include <linux/mtd/rawnand.h> #include <linux/sizes.h> #include <linux/types.h> #include <malloc.h> -#include <nand.h> #include <linux/errno.h> #include <asm/io.h> #include <asm/arch/clock.h> @@ -26,7 +25,6 @@ #include <asm/mach-imx/regs-bch.h> #include <asm/mach-imx/regs-gpmi.h> #include <asm/arch/sys_proto.h> -#include <asm/mach-imx/dma.h> #include "mxs_nand.h"
#define MXS_NAND_DMA_DESCRIPTOR_COUNT 4 @@ -47,61 +45,6 @@
#define MXS_NAND_BCH_TIMEOUT 10000
-/** - * @gf_len: The length of Galois Field. (e.g., 13 or 14) - * @ecc_strength: A number that describes the strength of the ECC - * algorithm. - * @ecc_chunk_size: The size, in bytes, of a single ECC chunk. Note - * the first chunk in the page includes both data and - * metadata, so it's a bit larger than this value. - * @ecc_chunk_count: The number of ECC chunks in the page, - * @block_mark_byte_offset: The byte offset in the ECC-based page view at - * which the underlying physical block mark appears. - * @block_mark_bit_offset: The bit offset into the ECC-based page view at - * which the underlying physical block mark appears. - */ -struct bch_geometry { - unsigned int gf_len; - unsigned int ecc_strength; - unsigned int ecc_chunk_size; - unsigned int ecc_chunk_count; - unsigned int block_mark_byte_offset; - unsigned int block_mark_bit_offset; -}; - -struct mxs_nand_info { - struct nand_chip chip; - unsigned int max_ecc_strength_supported; - bool use_minimum_ecc; - int cur_chip; - - uint32_t cmd_queue_len; - uint32_t data_buf_size; - struct bch_geometry bch_geometry; - - uint8_t *cmd_buf; - uint8_t *data_buf; - uint8_t *oob_buf; - - uint8_t marking_block_bad; - uint8_t raw_oob_mode; - - struct mxs_gpmi_regs *gpmi_regs; - struct mxs_bch_regs *bch_regs; - - /* Functions with altered behaviour */ - int (*hooked_read_oob)(struct mtd_info *mtd, - loff_t from, struct mtd_oob_ops *ops); - int (*hooked_write_oob)(struct mtd_info *mtd, - loff_t to, struct mtd_oob_ops *ops); - int (*hooked_block_markbad)(struct mtd_info *mtd, - loff_t ofs); - - /* DMA descriptors */ - struct mxs_dma_desc **desc; - uint32_t desc_index; -}; - struct nand_ecclayout fake_ecc_layout;
/* @@ -1233,7 +1176,7 @@ int mxs_nand_init_spl(struct nand_chip *nand) return 0; }
-int mxs_nand_init(struct mxs_nand_info *nand_info) +int mxs_nand_init_ctrl(struct mxs_nand_info *nand_info) { struct mtd_info *mtd; struct nand_chip *nand; @@ -1328,7 +1271,7 @@ void board_nand_init(void) nand_info->use_minimum_ecc = true; #endif
- if (mxs_nand_init(nand_info) < 0) + if (mxs_nand_init_ctrl(nand_info) < 0) goto err;
return; diff --git a/drivers/mtd/nand/mxs_nand.h b/drivers/mtd/nand/mxs_nand.h index 379ed24f05..4bd65cded9 100644 --- a/drivers/mtd/nand/mxs_nand.h +++ b/drivers/mtd/nand/mxs_nand.h @@ -7,5 +7,67 @@ * Stefan Agner stefan.agner@toradex.com */
+#include <linux/mtd/mtd.h> +#include <asm/cache.h> +#include <nand.h> +#include <asm/mach-imx/dma.h> + +/** + * @gf_len: The length of Galois Field. (e.g., 13 or 14) + * @ecc_strength: A number that describes the strength of the ECC + * algorithm. + * @ecc_chunk_size: The size, in bytes, of a single ECC chunk. Note + * the first chunk in the page includes both data and + * metadata, so it's a bit larger than this value. + * @ecc_chunk_count: The number of ECC chunks in the page, + * @block_mark_byte_offset: The byte offset in the ECC-based page view at + * which the underlying physical block mark appears. + * @block_mark_bit_offset: The bit offset into the ECC-based page view at + * which the underlying physical block mark appears. + */ +struct bch_geometry { + unsigned int gf_len; + unsigned int ecc_strength; + unsigned int ecc_chunk_size; + unsigned int ecc_chunk_count; + unsigned int block_mark_byte_offset; + unsigned int block_mark_bit_offset; +}; + +struct mxs_nand_info { + struct nand_chip chip; + struct udevice *dev; + unsigned int max_ecc_strength_supported; + bool use_minimum_ecc; + int cur_chip; + + uint32_t cmd_queue_len; + uint32_t data_buf_size; + struct bch_geometry bch_geometry; + + uint8_t *cmd_buf; + uint8_t *data_buf; + uint8_t *oob_buf; + + uint8_t marking_block_bad; + uint8_t raw_oob_mode; + + struct mxs_gpmi_regs *gpmi_regs; + struct mxs_bch_regs *bch_regs; + + /* Functions with altered behaviour */ + int (*hooked_read_oob)(struct mtd_info *mtd, + loff_t from, struct mtd_oob_ops *ops); + int (*hooked_write_oob)(struct mtd_info *mtd, + loff_t to, struct mtd_oob_ops *ops); + int (*hooked_block_markbad)(struct mtd_info *mtd, + loff_t ofs); + + /* DMA descriptors */ + struct mxs_dma_desc **desc; + uint32_t desc_index; +}; + +int mxs_nand_init_ctrl(struct mxs_nand_info *nand_info); int mxs_nand_init_spl(struct nand_chip *nand); int mxs_nand_setup_ecc(struct mtd_info *mtd);
Support driver data from device tree. Also support fsl,use-minimal-ecc similar to Linux' GPMI NAND driver.
Changes in v2: None
drivers/mtd/nand/Kconfig | 7 +++ drivers/mtd/nand/Makefile | 1 + drivers/mtd/nand/mxs_nand.c | 5 ++ drivers/mtd/nand/mxs_nand_dt.c | 86 ++++++++++++++++++++++++++++++++++ 4 files changed, 99 insertions(+) create mode 100644 drivers/mtd/nand/mxs_nand_dt.c
diff --git a/drivers/mtd/nand/Kconfig b/drivers/mtd/nand/Kconfig index c039b9cc60..bdc272142e 100644 --- a/drivers/mtd/nand/Kconfig +++ b/drivers/mtd/nand/Kconfig @@ -154,6 +154,13 @@ config NAND_MXS
if NAND_MXS
+config NAND_MXS_DT + bool "Support MXS NAND controller as a DT device" + depends on OF_CONTROL && MTD + help + Enable the driver for MXS NAND flash on platforms using + device tree. + config NAND_MXS_USE_MINIMUM_ECC bool "Use minimum ECC strength supported by the controller" default false diff --git a/drivers/mtd/nand/Makefile b/drivers/mtd/nand/Makefile index e20ef07773..e00cbca0a9 100644 --- a/drivers/mtd/nand/Makefile +++ b/drivers/mtd/nand/Makefile @@ -55,6 +55,7 @@ obj-$(CONFIG_NAND_LPC32XX_SLC) += lpc32xx_nand_slc.o obj-$(CONFIG_NAND_VF610_NFC) += vf610_nfc.o obj-$(CONFIG_NAND_MXC) += mxc_nand.o obj-$(CONFIG_NAND_MXS) += mxs_nand.o +obj-$(CONFIG_NAND_MXS_DT) += mxs_nand_dt.o obj-$(CONFIG_NAND_PXA3XX) += pxa3xx_nand.o obj-$(CONFIG_NAND_SPEAR) += spr_nand.o obj-$(CONFIG_TEGRA_NAND) += tegra_nand.o diff --git a/drivers/mtd/nand/mxs_nand.c b/drivers/mtd/nand/mxs_nand.c index 8748c927c6..99f392ef5c 100644 --- a/drivers/mtd/nand/mxs_nand.c +++ b/drivers/mtd/nand/mxs_nand.c @@ -1201,6 +1201,9 @@ int mxs_nand_init_ctrl(struct mxs_nand_info *nand_info) nand_set_controller_data(nand, nand_info); nand->options |= NAND_NO_SUBPAGE_WRITE;
+ if (nand_info->dev) + nand->flash_node = dev_of_offset(nand_info->dev); + nand->cmd_ctrl = mxs_nand_cmd_ctrl;
nand->dev_ready = mxs_nand_device_ready; @@ -1247,6 +1250,7 @@ err_free_buffers: return err; }
+#ifndef CONFIG_NAND_MXS_DT void board_nand_init(void) { struct mxs_nand_info *nand_info; @@ -1279,3 +1283,4 @@ void board_nand_init(void) err: free(nand_info); } +#endif diff --git a/drivers/mtd/nand/mxs_nand_dt.c b/drivers/mtd/nand/mxs_nand_dt.c new file mode 100644 index 0000000000..f89eb091a9 --- /dev/null +++ b/drivers/mtd/nand/mxs_nand_dt.c @@ -0,0 +1,86 @@ +/* + * NXP GPMI NAND flash driver (DT initialization) + * + * Copyright (C) 2018 Toradex + * Authors: + * Stefan Agner stefan.agner@toradex.com + * + * Based on denali_dt.c + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <dm.h> +#include <linux/io.h> +#include <linux/ioport.h> +#include <linux/printk.h> + +#include "mxs_nand.h" + +struct mxs_nand_dt_data { + unsigned int max_ecc_strength_supported; +}; + +static const struct mxs_nand_dt_data mxs_nand_imx7d_data = { + .max_ecc_strength_supported = 62, +}; + +static const struct udevice_id mxs_nand_dt_ids[] = { + { + .compatible = "fsl,imx7d-gpmi-nand", + .data = (unsigned long)&mxs_nand_imx7d_data, + }, + { /* sentinel */ } +}; + +static int mxs_nand_dt_probe(struct udevice *dev) +{ + struct mxs_nand_info *info = dev_get_priv(dev); + const struct mxs_nand_dt_data *data; + struct resource res; + int ret; + + data = (void *)dev_get_driver_data(dev); + if (data) + info->max_ecc_strength_supported = data->max_ecc_strength_supported; + + info->dev = dev; + + ret = dev_read_resource_byname(dev, "gpmi-nand", &res); + if (ret) + return ret; + + info->gpmi_regs = devm_ioremap(dev, res.start, resource_size(&res)); + + + ret = dev_read_resource_byname(dev, "bch", &res); + if (ret) + return ret; + + info->bch_regs = devm_ioremap(dev, res.start, resource_size(&res)); + + info->use_minimum_ecc = dev_read_bool(dev, "fsl,use-minimum-ecc"); + + return mxs_nand_init_ctrl(info); +} + +U_BOOT_DRIVER(mxs_nand_dt) = { + .name = "mxs-nand-dt", + .id = UCLASS_MTD, + .of_match = mxs_nand_dt_ids, + .probe = mxs_nand_dt_probe, + .priv_auto_alloc_size = sizeof(struct mxs_nand_info), +}; + +void board_nand_init(void) +{ + struct udevice *dev; + int ret; + + ret = uclass_get_device_by_driver(UCLASS_MTD, + DM_GET_DRIVER(mxs_nand_dt), + &dev); + if (ret && ret != -ENODEV) + pr_err("Failed to initialize MXS NAND controller. (error %d)\n", + ret); +}
Add support for specified ECC strength/size using device tree properties nand-ecc-strength/nand-ecc-step-size.
This aligns behavior with the mainline driver, such that: - If fsl,use-minimal-ecc is requested it will use data from data sheet/ONFI. If this is not available the driver will fail. - If nand-ecc-strength/nand-ecc-step-size are specified those value will be used. - By default maximum possible ECC strength is used
Changes in v2: None
drivers/mtd/nand/mxs_nand.c | 44 +++++++++++++++++++++++++------------ 1 file changed, 30 insertions(+), 14 deletions(-)
diff --git a/drivers/mtd/nand/mxs_nand.c b/drivers/mtd/nand/mxs_nand.c index 99f392ef5c..e3341812a2 100644 --- a/drivers/mtd/nand/mxs_nand.c +++ b/drivers/mtd/nand/mxs_nand.c @@ -161,15 +161,14 @@ static inline int mxs_nand_calc_mark_offset(struct bch_geometry *geo, }
static inline int mxs_nand_calc_ecc_layout_by_info(struct bch_geometry *geo, - struct mtd_info *mtd) + struct mtd_info *mtd, + unsigned int ecc_strength, + unsigned int ecc_step) { struct nand_chip *chip = mtd_to_nand(mtd); struct mxs_nand_info *nand_info = nand_get_controller_data(chip);
- if (!(chip->ecc_strength_ds > 0 && chip->ecc_step_ds > 0)) - return -ENOTSUPP; - - switch (chip->ecc_step_ds) { + switch (ecc_step) { case SZ_512: geo->gf_len = 13; break; @@ -180,8 +179,8 @@ static inline int mxs_nand_calc_ecc_layout_by_info(struct bch_geometry *geo, return -EINVAL; }
- geo->ecc_chunk_size = chip->ecc_step_ds; - geo->ecc_strength = round_up(chip->ecc_strength_ds, 2); + geo->ecc_chunk_size = ecc_step; + geo->ecc_strength = round_up(ecc_strength, 2);
/* Keep the C >= O */ if (geo->ecc_chunk_size < mtd->oobsize) @@ -964,6 +963,28 @@ static int mxs_nand_block_bad(struct mtd_info *mtd, loff_t ofs) return 0; }
+static int mxs_nand_set_geometry(struct mtd_info *mtd, struct bch_geometry *geo) +{ + struct nand_chip *chip = mtd_to_nand(mtd); + struct nand_chip *nand = mtd_to_nand(mtd); + struct mxs_nand_info *nand_info = nand_get_controller_data(nand); + + if (chip->ecc.strength > 0 && chip->ecc.size > 0) + return mxs_nand_calc_ecc_layout_by_info(geo, mtd, + chip->ecc.strength, chip->ecc.size); + + if (nand_info->use_minimum_ecc || + mxs_nand_calc_ecc_layout(geo, mtd)) { + if (!(chip->ecc_strength_ds > 0 && chip->ecc_step_ds > 0)) + return -EINVAL; + + return mxs_nand_calc_ecc_layout_by_info(geo, mtd, + chip->ecc_strength_ds, chip->ecc_step_ds); + } + + return 0; +} + /* * At this point, the physical NAND Flash chips have been identified and * counted, so we know the physical geometry. This enables us to make some @@ -980,14 +1001,9 @@ int mxs_nand_setup_ecc(struct mtd_info *mtd) struct bch_geometry *geo = &nand_info->bch_geometry; struct mxs_bch_regs *bch_regs = nand_info->bch_regs; uint32_t tmp; - int ret = -ENOTSUPP; - - if (nand_info->use_minimum_ecc) - ret = mxs_nand_calc_ecc_layout_by_info(geo, mtd); - - if (ret == -ENOTSUPP) - ret = mxs_nand_calc_ecc_layout(geo, mtd); + int ret;
+ ret = mxs_nand_set_geometry(mtd, geo); if (ret) return ret;
Sync with Linux commit 60cc43fc8884 ("Linux 4.17-rc1").
Changes in v2: None
arch/arm/dts/imx7s.dtsi | 491 +++++++++++++++--------- include/dt-bindings/clock/imx7d-clock.h | 15 +- include/dt-bindings/power/imx7-power.h | 16 + 3 files changed, 341 insertions(+), 181 deletions(-) create mode 100644 include/dt-bindings/power/imx7-power.h
diff --git a/arch/arm/dts/imx7s.dtsi b/arch/arm/dts/imx7s.dtsi index a7d48e785d..4d42335c0d 100644 --- a/arch/arm/dts/imx7s.dtsi +++ b/arch/arm/dts/imx7s.dtsi @@ -42,6 +42,7 @@ */
#include <dt-bindings/clock/imx7d-clock.h> +#include <dt-bindings/power/imx7-power.h> #include <dt-bindings/gpio/gpio.h> #include <dt-bindings/input/input.h> #include <dt-bindings/interrupt-controller/arm-gic.h> @@ -57,7 +58,7 @@ * Also for U-Boot there must be a pre-existing /memory node. */ chosen {}; - memory { device_type = "memory"; reg = <0 0>; }; + memory { device_type = "memory"; };
aliases { gpio0 = &gpio1; @@ -115,11 +116,77 @@ clock-output-names = "osc"; };
+ usbphynop1: usbphynop1 { + compatible = "usb-nop-xceiv"; + clocks = <&clks IMX7D_USB_PHY1_CLK>; + clock-names = "main_clk"; + #phy-cells = <0>; + }; + + usbphynop3: usbphynop3 { + compatible = "usb-nop-xceiv"; + clocks = <&clks IMX7D_USB_HSIC_ROOT_CLK>; + clock-names = "main_clk"; + #phy-cells = <0>; + }; + + pmu { + compatible = "arm,cortex-a7-pmu"; + interrupt-parent = <&gpc>; + interrupts = <GIC_SPI 92 IRQ_TYPE_LEVEL_HIGH>; + interrupt-affinity = <&cpu0>; + }; + + replicator { + /* + * non-configurable replicators don't show up on the + * AMBA bus. As such no need to add "arm,primecell" + */ + compatible = "arm,coresight-replicator"; + + ports { + #address-cells = <1>; + #size-cells = <0>; + /* replicator output ports */ + port@0 { + reg = <0>; + replicator_out_port0: endpoint { + remote-endpoint = <&tpiu_in_port>; + }; + }; + + port@1 { + reg = <1>; + replicator_out_port1: endpoint { + remote-endpoint = <&etr_in_port>; + }; + }; + + /* replicator input port */ + port@2 { + reg = <0>; + replicator_in_port0: endpoint { + slave-mode; + remote-endpoint = <&etf_out_port>; + }; + }; + }; + }; + + timer { + compatible = "arm,armv7-timer"; + interrupt-parent = <&intc>; + interrupts = <GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>, + <GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>, + <GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>, + <GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>; + }; + soc { #address-cells = <1>; #size-cells = <1>; compatible = "simple-bus"; - interrupt-parent = <&intc>; + interrupt-parent = <&gpc>; ranges;
funnel@30041000 { @@ -259,62 +326,18 @@ }; };
- replicator { - /* - * non-configurable replicators don't show up on the - * AMBA bus. As such no need to add "arm,primecell" - */ - compatible = "arm,coresight-replicator"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - /* replicator output ports */ - port@0 { - reg = <0>; - replicator_out_port0: endpoint { - remote-endpoint = <&tpiu_in_port>; - }; - }; - - port@1 { - reg = <1>; - replicator_out_port1: endpoint { - remote-endpoint = <&etr_in_port>; - }; - }; - - /* replicator input port */ - port@2 { - reg = <0>; - replicator_in_port0: endpoint { - slave-mode; - remote-endpoint = <&etf_out_port>; - }; - }; - }; - }; - intc: interrupt-controller@31001000 { compatible = "arm,cortex-a7-gic"; interrupts = <GIC_PPI 9 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_HIGH)>; #interrupt-cells = <3>; interrupt-controller; + interrupt-parent = <&intc>; reg = <0x31001000 0x1000>, <0x31002000 0x2000>, <0x31004000 0x2000>, <0x31006000 0x2000>; };
- timer { - compatible = "arm,armv7-timer"; - interrupts = <GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>, - <GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>, - <GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>, - <GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>; - }; - aips1: aips-bus@30000000 { compatible = "fsl,aips-bus", "simple-bus"; #address-cells = <1>; @@ -482,20 +505,49 @@ status = "disabled"; };
+ kpp: kpp@30320000 { + compatible = "fsl,imx7d-kpp", "fsl,imx21-kpp"; + reg = <0x30320000 0x10000>; + interrupts = <GIC_SPI 80 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX7D_KPP_ROOT_CLK>; + status = "disabled"; + }; + iomuxc: iomuxc@30330000 { compatible = "fsl,imx7d-iomuxc"; reg = <0x30330000 0x10000>; };
gpr: iomuxc-gpr@30340000 { - compatible = "fsl,imx7d-iomuxc-gpr", "syscon"; + compatible = "fsl,imx7d-iomuxc-gpr", + "fsl,imx6q-iomuxc-gpr", "syscon"; reg = <0x30340000 0x10000>; };
ocotp: ocotp-ctrl@30350000 { + #address-cells = <1>; + #size-cells = <1>; compatible = "fsl,imx7d-ocotp", "syscon"; reg = <0x30350000 0x10000>; clocks = <&clks IMX7D_OCOTP_CLK>; + + tempmon_calib: calib@3c { + reg = <0x3c 0x4>; + }; + + tempmon_temp_grade: temp-grade@10 { + reg = <0x10 0x4>; + }; + }; + + tempmon: tempmon { + compatible = "fsl,imx7d-tempmon"; + interrupts = <GIC_SPI 49 IRQ_TYPE_LEVEL_HIGH>; + fsl,tempmon =<&anatop>; + nvmem-cells = <&tempmon_calib>, + <&tempmon_temp_grade>; + nvmem-cell-names = "calib", "temp_grade"; + clocks = <&clks IMX7D_PLL_SYS_MAIN_CLK>; };
anatop: anatop@30360000 { @@ -504,8 +556,11 @@ reg = <0x30360000 0x10000>; interrupts = <GIC_SPI 49 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 51 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>;
- reg_1p0d: regulator-vdd1p0d { + reg_1p0d: regulator-vdd1p0d@30360210 { + reg = <0x30360210>; compatible = "fsl,anatop-regulator"; regulator-name = "vdd1p0d"; regulator-min-microvolt = <800000>; @@ -516,6 +571,7 @@ anatop-min-bit-val = <8>; anatop-min-voltage = <800000>; anatop-max-voltage = <1200000>; + anatop-enable-bit = <0>; }; };
@@ -529,12 +585,15 @@ offset = <0x34>; interrupts = <GIC_SPI 19 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 20 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX7D_SNVS_CLK>; + clock-names = "snvs-rtc"; };
snvs_poweroff: snvs-poweroff { compatible = "syscon-poweroff"; regmap = <&snvs>; offset = <0x38>; + value = <0x60>; mask = <0x60>; };
@@ -558,11 +617,32 @@ };
src: src@30390000 { - compatible = "fsl,imx7d-src", "fsl,imx51-src", "syscon"; + compatible = "fsl,imx7d-src", "syscon"; reg = <0x30390000 0x10000>; interrupts = <GIC_SPI 89 IRQ_TYPE_LEVEL_HIGH>; #reset-cells = <1>; }; + + gpc: gpc@303a0000 { + compatible = "fsl,imx7d-gpc"; + reg = <0x303a0000 0x10000>; + interrupt-controller; + interrupts = <GIC_SPI 87 IRQ_TYPE_LEVEL_HIGH>; + #interrupt-cells = <3>; + interrupt-parent = <&intc>; + #power-domain-cells = <1>; + + pgc { + #address-cells = <1>; + #size-cells = <0>; + + pgc_pcie_phy: pgc-power-domain@1 { + #power-domain-cells = <0>; + reg = <1>; + power-supply = <®_1p0d>; + }; + }; + }; };
aips2: aips-bus@30400000 { @@ -609,7 +689,7 @@ clocks = <&clks IMX7D_PWM1_ROOT_CLK>, <&clks IMX7D_PWM1_ROOT_CLK>; clock-names = "ipg", "per"; - #pwm-cells = <2>; + #pwm-cells = <3>; status = "disabled"; };
@@ -620,7 +700,7 @@ clocks = <&clks IMX7D_PWM2_ROOT_CLK>, <&clks IMX7D_PWM2_ROOT_CLK>; clock-names = "ipg", "per"; - #pwm-cells = <2>; + #pwm-cells = <3>; status = "disabled"; };
@@ -631,7 +711,7 @@ clocks = <&clks IMX7D_PWM3_ROOT_CLK>, <&clks IMX7D_PWM3_ROOT_CLK>; clock-names = "ipg", "per"; - #pwm-cells = <2>; + #pwm-cells = <3>; status = "disabled"; };
@@ -642,7 +722,7 @@ clocks = <&clks IMX7D_PWM4_ROOT_CLK>, <&clks IMX7D_PWM4_ROOT_CLK>; clock-names = "ipg", "per"; - #pwm-cells = <2>; + #pwm-cells = <3>; status = "disabled"; };
@@ -664,118 +744,156 @@ reg = <0x30800000 0x400000>; ranges;
- ecspi1: ecspi@30820000 { + spba-bus@30800000 { + compatible = "fsl,spba-bus", "simple-bus"; #address-cells = <1>; - #size-cells = <0>; - compatible = "fsl,imx7d-ecspi", "fsl,imx51-ecspi"; - reg = <0x30820000 0x10000>; - interrupts = <GIC_SPI 31 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clks IMX7D_ECSPI1_ROOT_CLK>, - <&clks IMX7D_ECSPI1_ROOT_CLK>; - clock-names = "ipg", "per"; - status = "disabled"; - }; + #size-cells = <1>; + reg = <0x30800000 0x100000>; + ranges; + + ecspi1: ecspi@30820000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "fsl,imx7d-ecspi", "fsl,imx51-ecspi"; + reg = <0x30820000 0x10000>; + interrupts = <GIC_SPI 31 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX7D_ECSPI1_ROOT_CLK>, + <&clks IMX7D_ECSPI1_ROOT_CLK>; + clock-names = "ipg", "per"; + status = "disabled"; + };
- ecspi2: ecspi@30830000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "fsl,imx7d-ecspi", "fsl,imx51-ecspi"; - reg = <0x30830000 0x10000>; - interrupts = <GIC_SPI 32 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clks IMX7D_ECSPI2_ROOT_CLK>, - <&clks IMX7D_ECSPI2_ROOT_CLK>; - clock-names = "ipg", "per"; - status = "disabled"; - }; + ecspi2: ecspi@30830000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "fsl,imx7d-ecspi", "fsl,imx51-ecspi"; + reg = <0x30830000 0x10000>; + interrupts = <GIC_SPI 32 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX7D_ECSPI2_ROOT_CLK>, + <&clks IMX7D_ECSPI2_ROOT_CLK>; + clock-names = "ipg", "per"; + status = "disabled"; + };
- ecspi3: ecspi@30840000 { - #address-cells = <1>; - #size-cells = <0>; - compatible = "fsl,imx7d-ecspi", "fsl,imx51-ecspi"; - reg = <0x30840000 0x10000>; - interrupts = <GIC_SPI 33 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clks IMX7D_ECSPI3_ROOT_CLK>, - <&clks IMX7D_ECSPI3_ROOT_CLK>; - clock-names = "ipg", "per"; - status = "disabled"; - }; + ecspi3: ecspi@30840000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "fsl,imx7d-ecspi", "fsl,imx51-ecspi"; + reg = <0x30840000 0x10000>; + interrupts = <GIC_SPI 33 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX7D_ECSPI3_ROOT_CLK>, + <&clks IMX7D_ECSPI3_ROOT_CLK>; + clock-names = "ipg", "per"; + status = "disabled"; + };
- uart1: serial@30860000 { - compatible = "fsl,imx7d-uart", - "fsl,imx6q-uart"; - reg = <0x30860000 0x10000>; - interrupts = <GIC_SPI 26 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clks IMX7D_UART1_ROOT_CLK>, - <&clks IMX7D_UART1_ROOT_CLK>; - clock-names = "ipg", "per"; - status = "disabled"; - }; + uart1: serial@30860000 { + compatible = "fsl,imx7d-uart", + "fsl,imx6q-uart"; + reg = <0x30860000 0x10000>; + interrupts = <GIC_SPI 26 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX7D_UART1_ROOT_CLK>, + <&clks IMX7D_UART1_ROOT_CLK>; + clock-names = "ipg", "per"; + status = "disabled"; + };
- uart2: serial@30890000 { - compatible = "fsl,imx7d-uart", - "fsl,imx6q-uart"; - reg = <0x30890000 0x10000>; - interrupts = <GIC_SPI 27 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clks IMX7D_UART2_ROOT_CLK>, - <&clks IMX7D_UART2_ROOT_CLK>; - clock-names = "ipg", "per"; - status = "disabled"; - }; + uart2: serial@30890000 { + compatible = "fsl,imx7d-uart", + "fsl,imx6q-uart"; + reg = <0x30890000 0x10000>; + interrupts = <GIC_SPI 27 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX7D_UART2_ROOT_CLK>, + <&clks IMX7D_UART2_ROOT_CLK>; + clock-names = "ipg", "per"; + status = "disabled"; + };
- uart3: serial@30880000 { - compatible = "fsl,imx7d-uart", - "fsl,imx6q-uart"; - reg = <0x30880000 0x10000>; - interrupts = <GIC_SPI 28 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clks IMX7D_UART3_ROOT_CLK>, - <&clks IMX7D_UART3_ROOT_CLK>; - clock-names = "ipg", "per"; - status = "disabled"; - }; + uart3: serial@30880000 { + compatible = "fsl,imx7d-uart", + "fsl,imx6q-uart"; + reg = <0x30880000 0x10000>; + interrupts = <GIC_SPI 28 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX7D_UART3_ROOT_CLK>, + <&clks IMX7D_UART3_ROOT_CLK>; + clock-names = "ipg", "per"; + status = "disabled"; + };
- sai1: sai@308a0000 { - #sound-dai-cells = <0>; - compatible = "fsl,imx7d-sai", "fsl,imx6sx-sai"; - reg = <0x308a0000 0x10000>; - interrupts = <GIC_SPI 95 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clks IMX7D_SAI1_IPG_CLK>, - <&clks IMX7D_SAI1_ROOT_CLK>, - <&clks IMX7D_CLK_DUMMY>, - <&clks IMX7D_CLK_DUMMY>; - clock-names = "bus", "mclk1", "mclk2", "mclk3"; - dma-names = "rx", "tx"; - dmas = <&sdma 8 24 0>, <&sdma 9 24 0>; - status = "disabled"; - }; + sai1: sai@308a0000 { + #sound-dai-cells = <0>; + compatible = "fsl,imx7d-sai", "fsl,imx6sx-sai"; + reg = <0x308a0000 0x10000>; + interrupts = <GIC_SPI 95 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX7D_SAI1_IPG_CLK>, + <&clks IMX7D_SAI1_ROOT_CLK>, + <&clks IMX7D_CLK_DUMMY>, + <&clks IMX7D_CLK_DUMMY>; + clock-names = "bus", "mclk1", "mclk2", "mclk3"; + dma-names = "rx", "tx"; + dmas = <&sdma 8 24 0>, <&sdma 9 24 0>; + status = "disabled"; + };
- sai2: sai@308b0000 { - #sound-dai-cells = <0>; - compatible = "fsl,imx7d-sai", "fsl,imx6sx-sai"; - reg = <0x308b0000 0x10000>; - interrupts = <GIC_SPI 96 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clks IMX7D_SAI2_IPG_CLK>, - <&clks IMX7D_SAI2_ROOT_CLK>, - <&clks IMX7D_CLK_DUMMY>, - <&clks IMX7D_CLK_DUMMY>; - clock-names = "bus", "mclk1", "mclk2", "mclk3"; - dma-names = "rx", "tx"; - dmas = <&sdma 10 24 0>, <&sdma 11 24 0>; - status = "disabled"; + sai2: sai@308b0000 { + #sound-dai-cells = <0>; + compatible = "fsl,imx7d-sai", "fsl,imx6sx-sai"; + reg = <0x308b0000 0x10000>; + interrupts = <GIC_SPI 96 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX7D_SAI2_IPG_CLK>, + <&clks IMX7D_SAI2_ROOT_CLK>, + <&clks IMX7D_CLK_DUMMY>, + <&clks IMX7D_CLK_DUMMY>; + clock-names = "bus", "mclk1", "mclk2", "mclk3"; + dma-names = "rx", "tx"; + dmas = <&sdma 10 24 0>, <&sdma 11 24 0>; + status = "disabled"; + }; + + sai3: sai@308c0000 { + #sound-dai-cells = <0>; + compatible = "fsl,imx7d-sai", "fsl,imx6sx-sai"; + reg = <0x308c0000 0x10000>; + interrupts = <GIC_SPI 50 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX7D_SAI3_IPG_CLK>, + <&clks IMX7D_SAI3_ROOT_CLK>, + <&clks IMX7D_CLK_DUMMY>, + <&clks IMX7D_CLK_DUMMY>; + clock-names = "bus", "mclk1", "mclk2", "mclk3"; + dma-names = "rx", "tx"; + dmas = <&sdma 12 24 0>, <&sdma 13 24 0>; + status = "disabled"; + }; };
- sai3: sai@308c0000 { - #sound-dai-cells = <0>; - compatible = "fsl,imx7d-sai", "fsl,imx6sx-sai"; - reg = <0x308c0000 0x10000>; - interrupts = <GIC_SPI 50 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clks IMX7D_SAI3_IPG_CLK>, - <&clks IMX7D_SAI3_ROOT_CLK>, - <&clks IMX7D_CLK_DUMMY>, - <&clks IMX7D_CLK_DUMMY>; - clock-names = "bus", "mclk1", "mclk2", "mclk3"; - dma-names = "rx", "tx"; - dmas = <&sdma 12 24 0>, <&sdma 13 24 0>; - status = "disabled"; + crypto: caam@30900000 { + compatible = "fsl,sec-v4.0"; + #address-cells = <1>; + #size-cells = <1>; + reg = <0x30900000 0x40000>; + ranges = <0 0x30900000 0x40000>; + interrupts = <GIC_SPI 91 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&clks IMX7D_CAAM_CLK>, + <&clks IMX7D_AHB_CHANNEL_ROOT_CLK>; + clock-names = "ipg", "aclk"; + + sec_jr0: jr0@1000 { + compatible = "fsl,sec-v4.0-job-ring"; + reg = <0x1000 0x1000>; + interrupts = <GIC_SPI 105 IRQ_TYPE_LEVEL_HIGH>; + }; + + sec_jr1: jr1@2000 { + compatible = "fsl,sec-v4.0-job-ring"; + reg = <0x2000 0x1000>; + interrupts = <GIC_SPI 106 IRQ_TYPE_LEVEL_HIGH>; + }; + + sec_jr2: jr1@3000 { + compatible = "fsl,sec-v4.0-job-ring"; + reg = <0x3000 0x1000>; + interrupts = <GIC_SPI 114 IRQ_TYPE_LEVEL_HIGH>; + }; };
flexcan1: can@30a00000 { @@ -918,24 +1036,12 @@ reg = <0x30b30200 0x200>; };
- usbphynop1: usbphynop1 { - compatible = "usb-nop-xceiv"; - clocks = <&clks IMX7D_USB_PHY1_CLK>; - clock-names = "main_clk"; - }; - - usbphynop3: usbphynop3 { - compatible = "usb-nop-xceiv"; - clocks = <&clks IMX7D_USB_HSIC_ROOT_CLK>; - clock-names = "main_clk"; - }; - usdhc1: usdhc@30b40000 { compatible = "fsl,imx7d-usdhc", "fsl,imx6sl-usdhc"; reg = <0x30b40000 0x10000>; interrupts = <GIC_SPI 22 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clks IMX7D_CLK_DUMMY>, - <&clks IMX7D_CLK_DUMMY>, + clocks = <&clks IMX7D_IPG_ROOT_CLK>, + <&clks IMX7D_NAND_USDHC_BUS_ROOT_CLK>, <&clks IMX7D_USDHC1_ROOT_CLK>; clock-names = "ipg", "ahb", "per"; bus-width = <4>; @@ -946,8 +1052,8 @@ compatible = "fsl,imx7d-usdhc", "fsl,imx6sl-usdhc"; reg = <0x30b50000 0x10000>; interrupts = <GIC_SPI 23 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clks IMX7D_CLK_DUMMY>, - <&clks IMX7D_CLK_DUMMY>, + clocks = <&clks IMX7D_IPG_ROOT_CLK>, + <&clks IMX7D_NAND_USDHC_BUS_ROOT_CLK>, <&clks IMX7D_USDHC2_ROOT_CLK>; clock-names = "ipg", "ahb", "per"; bus-width = <4>; @@ -958,8 +1064,8 @@ compatible = "fsl,imx7d-usdhc", "fsl,imx6sl-usdhc"; reg = <0x30b60000 0x10000>; interrupts = <GIC_SPI 24 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clks IMX7D_CLK_DUMMY>, - <&clks IMX7D_CLK_DUMMY>, + clocks = <&clks IMX7D_IPG_ROOT_CLK>, + <&clks IMX7D_NAND_USDHC_BUS_ROOT_CLK>, <&clks IMX7D_USDHC3_ROOT_CLK>; clock-names = "ipg", "ahb", "per"; bus-width = <4>; @@ -980,9 +1086,11 @@ fec1: ethernet@30be0000 { compatible = "fsl,imx7d-fec", "fsl,imx6sx-fec"; reg = <0x30be0000 0x10000>; - interrupts = <GIC_SPI 118 IRQ_TYPE_LEVEL_HIGH>, + interrupt-names = "int0", "int1", "int2", "pps"; + interrupts = <GIC_SPI 120 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 118 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 119 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 120 IRQ_TYPE_LEVEL_HIGH>; + <GIC_SPI 121 IRQ_TYPE_LEVEL_HIGH>; clocks = <&clks IMX7D_ENET_AXI_ROOT_CLK>, <&clks IMX7D_ENET_AXI_ROOT_CLK>, <&clks IMX7D_ENET1_TIME_ROOT_CLK>, @@ -995,5 +1103,36 @@ status = "disabled"; }; }; + + dma_apbh: dma-apbh@33000000 { + compatible = "fsl,imx7d-dma-apbh", "fsl,imx28-dma-apbh"; + reg = <0x33000000 0x2000>; + interrupts = <GIC_SPI 12 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 12 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 12 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 12 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "gpmi0", "gpmi1", "gpmi2", "gpmi3"; + #dma-cells = <1>; + dma-channels = <4>; + clocks = <&clks IMX7D_NAND_USDHC_BUS_RAWNAND_CLK>; + }; + + gpmi: gpmi-nand@33002000{ + compatible = "fsl,imx7d-gpmi-nand"; + #address-cells = <1>; + #size-cells = <1>; + reg = <0x33002000 0x2000>, <0x33004000 0x4000>; + reg-names = "gpmi-nand", "bch"; + interrupts = <GIC_SPI 14 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "bch"; + clocks = <&clks IMX7D_NAND_RAWNAND_CLK>, + <&clks IMX7D_NAND_USDHC_BUS_RAWNAND_CLK>; + clock-names = "gpmi_io", "gpmi_bch_apb"; + dmas = <&dma_apbh 0>; + dma-names = "rx-tx"; + status = "disabled"; + assigned-clocks = <&clks IMX7D_NAND_ROOT_SRC>; + assigned-clock-parents = <&clks IMX7D_PLL_ENET_MAIN_500M_CLK>; + }; }; }; diff --git a/include/dt-bindings/clock/imx7d-clock.h b/include/dt-bindings/clock/imx7d-clock.h index a7a1a50f33..b2325d3e23 100644 --- a/include/dt-bindings/clock/imx7d-clock.h +++ b/include/dt-bindings/clock/imx7d-clock.h @@ -80,10 +80,10 @@ #define IMX7D_ARM_M4_ROOT_SRC 67 #define IMX7D_ARM_M4_ROOT_CG 68 #define IMX7D_ARM_M4_ROOT_DIV 69 -#define IMX7D_ARM_M0_ROOT_CLK 70 -#define IMX7D_ARM_M0_ROOT_SRC 71 -#define IMX7D_ARM_M0_ROOT_CG 72 -#define IMX7D_ARM_M0_ROOT_DIV 73 +#define IMX7D_ARM_M0_ROOT_CLK 70 /* unused */ +#define IMX7D_ARM_M0_ROOT_SRC 71 /* unused */ +#define IMX7D_ARM_M0_ROOT_CG 72 /* unused */ +#define IMX7D_ARM_M0_ROOT_DIV 73 /* unused */ #define IMX7D_MAIN_AXI_ROOT_CLK 74 #define IMX7D_MAIN_AXI_ROOT_SRC 75 #define IMX7D_MAIN_AXI_ROOT_CG 76 @@ -450,5 +450,10 @@ #define IMX7D_CLK_ARM 437 #define IMX7D_CKIL 438 #define IMX7D_OCOTP_CLK 439 -#define IMX7D_CLK_END 440 +#define IMX7D_NAND_RAWNAND_CLK 440 +#define IMX7D_NAND_USDHC_BUS_RAWNAND_CLK 441 +#define IMX7D_SNVS_CLK 442 +#define IMX7D_CAAM_CLK 443 +#define IMX7D_KPP_ROOT_CLK 444 +#define IMX7D_CLK_END 445 #endif /* __DT_BINDINGS_CLOCK_IMX7D_H */ diff --git a/include/dt-bindings/power/imx7-power.h b/include/dt-bindings/power/imx7-power.h new file mode 100644 index 0000000000..3a181e4105 --- /dev/null +++ b/include/dt-bindings/power/imx7-power.h @@ -0,0 +1,16 @@ +/* + * Copyright (C) 2017 Impinj + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License version 2 as + * published by the Free Software Foundation. + */ + +#ifndef __DT_BINDINGS_IMX7_POWER_H__ +#define __DT_BINDINGS_IMX7_POWER_H__ + +#define IMX7_POWER_DOMAIN_MIPI_PHY 0 +#define IMX7_POWER_DOMAIN_PCIE_PHY 1 +#define IMX7_POWER_DOMAIN_USB_HSIC_PHY 2 + +#endif
Changes in v2: None
arch/arm/dts/imx7-colibri.dts | 28 ++++++++++++++++++++++++++++ 1 file changed, 28 insertions(+)
diff --git a/arch/arm/dts/imx7-colibri.dts b/arch/arm/dts/imx7-colibri.dts index a2cade762a..dca501be25 100644 --- a/arch/arm/dts/imx7-colibri.dts +++ b/arch/arm/dts/imx7-colibri.dts @@ -16,6 +16,15 @@ }; };
+&gpmi { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_gpmi_nand>; + fsl,use-minimum-ecc; + nand-on-flash-bbt; + nand-ecc-mode = "hw"; + status = "okay"; +}; + &i2c1 { pinctrl-names = "default", "gpio"; pinctrl-0 = <&pinctrl_i2c1>; @@ -48,6 +57,25 @@ };
&iomuxc { + pinctrl_gpmi_nand: gpmi-nand-grp { + fsl,pins = < + MX7D_PAD_SD3_CLK__NAND_CLE 0x71 + MX7D_PAD_SD3_CMD__NAND_ALE 0x71 + MX7D_PAD_SAI1_TX_BCLK__NAND_CE0_B 0x71 + MX7D_PAD_SAI1_TX_DATA__NAND_READY_B 0x74 + MX7D_PAD_SD3_STROBE__NAND_RE_B 0x71 + MX7D_PAD_SD3_RESET_B__NAND_WE_B 0x71 + MX7D_PAD_SD3_DATA0__NAND_DATA00 0x71 + MX7D_PAD_SD3_DATA1__NAND_DATA01 0x71 + MX7D_PAD_SD3_DATA2__NAND_DATA02 0x71 + MX7D_PAD_SD3_DATA3__NAND_DATA03 0x71 + MX7D_PAD_SD3_DATA4__NAND_DATA04 0x71 + MX7D_PAD_SD3_DATA5__NAND_DATA05 0x71 + MX7D_PAD_SD3_DATA6__NAND_DATA06 0x71 + MX7D_PAD_SD3_DATA7__NAND_DATA07 0x71 + >; + }; + pinctrl_i2c4: i2c4-grp { fsl,pins = < MX7D_PAD_ENET1_RGMII_TD3__I2C4_SDA 0x4000007f
-- Stefan
Changes in v2:
As discussed previously: applied to u-boot-imx, thanks !
Best regards, Stefano Babic
Stefan Agner
Stefano Babic
