[U-Boot] [PATCHv3 00/13] mmc: exynos: code cleanup and support DDR mode
If card and host are supported DDR mode, then it can be used the DDR mode. This patch-set has dependency about beomho's patch-set. (Based-on u-boot-samsung repository)
It's result for loading image.
sdhci controller ->5260488 bytes read in 259 ms (19.4 MiB/s) dwmmc controller without DDR mode -> 5260488 bytes read in 202 ms (24.8 MiB/s) dwmmc controller with DDR mode -> 5260488 bytes read in 118 ms (42.5 MiB/s)
Download the 400M image with lthor. sdhci controller -> 59.4sec (Avg 6.95 MB/s) dwmmc controller without DDR mode -> 61.6sec (Avg 6.72MB/s) dwmmc controller with DDR mode -> 60.4sec (Avg 6.85MB/s)
Beomho Seo (3): arm: exynos: pinmux: add sdmmc4 gpio configratuion arm: exynos: clock: Remove exynos4x12_set_mmc_clk function board: trats2: Enable device tree on Trats2
Jaehoon Chung (10): ARM: exynos: board: change the mmc/sd init sequence ARM: exynos: clock: modify the set_mmc_clk for exynos4 mmc: exynos_dw_mmc: restore the property into host mmc: remove the unnecessary define and fix the wrong bit control mmc: support the DDR mode for eMMC mmc: dw_mmc: support the DDR mode ARM: dts: exnyos: enable dw-mmc controller mmc: exynos_dw_mmc: enable the DDR mode ARM: exynos4: enable the dwmmc configuration mmc: s5p_sdhci: add the s5p_sdhci_core_init function
arch/arm/cpu/armv7/exynos/clock.c | 45 ++----- arch/arm/cpu/armv7/exynos/pinmux.c | 18 ++- arch/arm/dts/exynos4.dtsi | 8 ++ arch/arm/dts/exynos4412-trats2.dts | 12 ++ arch/arm/include/asm/arch-exynos/clk.h | 5 + board/samsung/common/board.c | 13 +- drivers/mmc/dw_mmc.c | 12 +- drivers/mmc/exynos_dw_mmc.c | 209 ++++++++++++++++++++------------ drivers/mmc/mmc.c | 16 ++- drivers/mmc/s5p_sdhci.c | 42 +++---- include/configs/exynos4-dt.h | 3 + include/dwmmc.h | 5 + include/mmc.h | 25 ++-- 13 files changed, 250 insertions(+), 163 deletions(-)
For use dwmmc controller at exynos4, add SDMMC4 gpio configuration. In case SDMMC2, do not use 8 bit mode at exynos4.
Signed-off-by: Beomho Seo beomho.seo@samsung.com Signed-off-by: Jaehoon Chung jh80.chung@samsung.com Tested-by: Piotr Wilczek p.wilczek@samsung.com Cc: Lukasz Majewski l.majewski@samsung.com Cc: Piotr Wilczek p.wilczek@samsung.com Cc: Minkyu Kang mk7.kang@samsung.com --- arch/arm/cpu/armv7/exynos/pinmux.c | 18 +++++++++++++++--- 1 file changed, 15 insertions(+), 3 deletions(-)
diff --git a/arch/arm/cpu/armv7/exynos/pinmux.c b/arch/arm/cpu/armv7/exynos/pinmux.c index 9edb475..55c1c95 100644 --- a/arch/arm/cpu/armv7/exynos/pinmux.c +++ b/arch/arm/cpu/armv7/exynos/pinmux.c @@ -632,16 +632,27 @@ static int exynos4_mmc_config(int peripheral, int flags) struct exynos4_gpio_part2 *gpio2 = (struct exynos4_gpio_part2 *)samsung_get_base_gpio_part2(); struct s5p_gpio_bank *bank, *bank_ext; + unsigned int func, func_ext; int i;
switch (peripheral) { case PERIPH_ID_SDMMC0: bank = &gpio2->k0; bank_ext = &gpio2->k1; + func = GPIO_FUNC(0x2); + func_ext = GPIO_FUNC(0x3); break; case PERIPH_ID_SDMMC2: bank = &gpio2->k2; bank_ext = &gpio2->k3; + func = GPIO_FUNC(0x2); + func_ext = GPIO_FUNC(0x3); + break; + case PERIPH_ID_SDMMC4: + bank = &gpio2->k0; + bank_ext = &gpio2->k1; + func = GPIO_FUNC(0x3); + func_ext = GPIO_FUNC(0x4); break; default: return -1; @@ -649,13 +660,14 @@ static int exynos4_mmc_config(int peripheral, int flags) for (i = 0; i < 7; i++) { if (i == 2) continue; - s5p_gpio_cfg_pin(bank, i, GPIO_FUNC(0x2)); + s5p_gpio_cfg_pin(bank, i, func); s5p_gpio_set_pull(bank, i, GPIO_PULL_NONE); s5p_gpio_set_drv(bank, i, GPIO_DRV_4X); } + /* SDMMC2 do not use 8bit mode at exynos4 */ if (flags & PINMUX_FLAG_8BIT_MODE) { for (i = 3; i < 7; i++) { - s5p_gpio_cfg_pin(bank_ext, i, GPIO_FUNC(0x3)); + s5p_gpio_cfg_pin(bank_ext, i, func_ext); s5p_gpio_set_pull(bank_ext, i, GPIO_PULL_NONE); s5p_gpio_set_drv(bank_ext, i, GPIO_DRV_4X); } @@ -722,10 +734,10 @@ static int exynos4_pinmux_config(int peripheral, int flags) break; case PERIPH_ID_SDMMC0: case PERIPH_ID_SDMMC2: + case PERIPH_ID_SDMMC4: return exynos4_mmc_config(peripheral, flags); case PERIPH_ID_SDMMC1: case PERIPH_ID_SDMMC3: - case PERIPH_ID_SDMMC4: debug("SDMMC device %d not implemented\n", peripheral); return -1; default:
Dear Beonho and Jaehoon,
break;
bank = &gpio2->k0;
s5p_gpio_set_pull(bank, i, GPIO_PULL_NONE); s5p_gpio_set_drv(bank, i, GPIO_DRV_4X); }s5p_gpio_cfg_pin(bank, i, func);
- /* SDMMC2 do not use 8bit mode at exynos4 */ if (flags & PINMUX_FLAG_8BIT_MODE) { for (i = 3; i < 7; i++) {
}s5p_gpio_cfg_pin(bank_ext, i, func_ext); s5p_gpio_set_pull(bank_ext, i, GPIO_PULL_NONE); s5p_gpio_set_drv(bank_ext, i, GPIO_DRV_4X);
- case PERIPH_ID_SDMMC4: return exynos4_mmc_config(peripheral, flags); case PERIPH_ID_SDMMC1: case PERIPH_ID_SDMMC3:
Since GIPO API was changed, please rebase this patch.
Thanks, Minkyu Kang.
exynos4x12_set_mmc_clk function have been removed. Because, exynos4x12_clock and exynos4_clock return same div_fsys* value.
Signed-off-by: Beomho Seo beomho.seo@samsung.com Signed-off-by: Jaehoon Chung jh80.chung@samsung.com Tested-by: Piotr Wilczek p.wilczek@samsung.com Cc: Lukasz Majewski l.majewski@samsung.com Cc: Piotr Wilczek p.wilczek@samsung.com Cc: Minkyu Kang mk7.kang@samsung.com --- arch/arm/cpu/armv7/exynos/clock.c | 29 +---------------------------- 1 file changed, 1 insertion(+), 28 deletions(-)
diff --git a/arch/arm/cpu/armv7/exynos/clock.c b/arch/arm/cpu/armv7/exynos/clock.c index 1fea4d6..2c2029a 100644 --- a/arch/arm/cpu/armv7/exynos/clock.c +++ b/arch/arm/cpu/armv7/exynos/clock.c @@ -893,30 +893,6 @@ static void exynos4_set_mmc_clk(int dev_index, unsigned int div) (div & 0xff) << ((dev_index << 4) + 8)); }
-/* exynos4x12: set the mmc clock */ -static void exynos4x12_set_mmc_clk(int dev_index, unsigned int div) -{ - struct exynos4x12_clock *clk = - (struct exynos4x12_clock *)samsung_get_base_clock(); - unsigned int addr; - - /* - * CLK_DIV_FSYS1 - * MMC0_PRE_RATIO [15:8], MMC1_PRE_RATIO [31:24] - * CLK_DIV_FSYS2 - * MMC2_PRE_RATIO [15:8], MMC3_PRE_RATIO [31:24] - */ - if (dev_index < 2) { - addr = (unsigned int)&clk->div_fsys1; - } else { - addr = (unsigned int)&clk->div_fsys2; - dev_index -= 2; - } - - clrsetbits_le32(addr, 0xff << ((dev_index << 4) + 8), - (div & 0xff) << ((dev_index << 4) + 8)); -} - /* exynos5: set the mmc clock */ static void exynos5_set_mmc_clk(int dev_index, unsigned int div) { @@ -1612,10 +1588,7 @@ void set_mmc_clk(int dev_index, unsigned int div) else exynos5_set_mmc_clk(dev_index, div); } else { - if (proid_is_exynos4412()) - exynos4x12_set_mmc_clk(dev_index, div); - else - exynos4_set_mmc_clk(dev_index, div); + exynos4_set_mmc_clk(dev_index, div); } }
This patch add dwmmc emmc controller node on exynos4 and exynos4412 device tree.
Signed-off-by: Beomho Seo beomho.seo@samsung.com Signed-off-by: Jaehoon Chung jh80.chung@samsung.com Tested-by: Piotr Wilczek p.wilczek@samsung.com Cc: Lukasz Majewski l.majewski@samsung.com Cc: Piotr Wilczek p.wilczek@samsung.com Cc: Minkyu Kang mk7.kang@samsung.com --- arch/arm/dts/exynos4.dtsi | 8 ++++++++ arch/arm/dts/exynos4412-trats2.dts | 8 ++++++++ 2 files changed, 16 insertions(+)
diff --git a/arch/arm/dts/exynos4.dtsi b/arch/arm/dts/exynos4.dtsi index 71dc7eb..110eb43 100644 --- a/arch/arm/dts/exynos4.dtsi +++ b/arch/arm/dts/exynos4.dtsi @@ -128,6 +128,14 @@ interrupts = <0 78 0>; };
+ dwmmc@12550000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "samsung,exynos-dwmmc"; + reg = <0x12550000 0x1000>; + interrupts = <0 131 0>; + }; + gpio: gpio { gpio-controller; #gpio-cells = <2>; diff --git a/arch/arm/dts/exynos4412-trats2.dts b/arch/arm/dts/exynos4412-trats2.dts index 7d32067..438e70e 100644 --- a/arch/arm/dts/exynos4412-trats2.dts +++ b/arch/arm/dts/exynos4412-trats2.dts @@ -31,6 +31,7 @@ console = "/serial@13820000"; mmc0 = "sdhci@12510000"; mmc2 = "sdhci@12530000"; + mmc4 = "dwmmc@12550000"; };
i2c@138d0000 { @@ -431,4 +432,11 @@ sdhci@12540000 { status = "disabled"; }; + + dwmmc@12550000 { + samsung,bus-width = <8>; + samsung,timing = <0 1 0>; + pwr-gpios = <&gpio 0x2004002 0>; + index = <4>; + }; };
Exynos4 can be used the dwmmc controller for eMMC. Then it needs to check dwmmc_init() at first.
Signed-off-by: Jaehoon Chung jh80.chung@samsung.com Reviewed-by: Lukasz Majewski l.majewski@samsung.com Tested-by: Lukasz Majewski l.majewski@samsung.com Acked-by: Lukasz Majewski l.majewski@samsung.com --- board/samsung/common/board.c | 13 ++++++------- 1 file changed, 6 insertions(+), 7 deletions(-)
diff --git a/board/samsung/common/board.c b/board/samsung/common/board.c index de154e0..9dc7c83 100644 --- a/board/samsung/common/board.c +++ b/board/samsung/common/board.c @@ -243,13 +243,6 @@ int board_eth_init(bd_t *bis) int board_mmc_init(bd_t *bis) { int ret; - -#ifdef CONFIG_SDHCI - /* mmc initializattion for available channels */ - ret = exynos_mmc_init(gd->fdt_blob); - if (ret) - debug("mmc init failed\n"); -#endif #ifdef CONFIG_DWMMC /* dwmmc initializattion for available channels */ ret = exynos_dwmmc_init(gd->fdt_blob); @@ -257,6 +250,12 @@ int board_mmc_init(bd_t *bis) debug("dwmmc init failed\n"); #endif
+#ifdef CONFIG_SDHCI + /* mmc initializattion for available channels */ + ret = exynos_mmc_init(gd->fdt_blob); + if (ret) + debug("mmc init failed\n"); +#endif return ret; } #endif
Modified the mmc_set_clock for eynos4. The goal of this patch is that fsys-div register should be reset. And retore the div-value, not using the value of lowlevel_init. (For using SDMMC4, this patch is needs)
Signed-off-by: Jaehoon Chung jh80.chung@samsung.com Tested-by: Lukasz Majewski l.majewski@samsung.com Acked-by: Lukasz Majewski l.majewski@samsung.com --- arch/arm/cpu/armv7/exynos/clock.c | 16 +++++++++++----- arch/arm/include/asm/arch-exynos/clk.h | 5 +++++ 2 files changed, 16 insertions(+), 5 deletions(-)
diff --git a/arch/arm/cpu/armv7/exynos/clock.c b/arch/arm/cpu/armv7/exynos/clock.c index 2c2029a..400d134 100644 --- a/arch/arm/cpu/armv7/exynos/clock.c +++ b/arch/arm/cpu/armv7/exynos/clock.c @@ -869,7 +869,7 @@ static void exynos4_set_mmc_clk(int dev_index, unsigned int div) { struct exynos4_clock *clk = (struct exynos4_clock *)samsung_get_base_clock(); - unsigned int addr; + unsigned int addr, clear_bit, set_bit;
/* * CLK_DIV_FSYS1 @@ -877,20 +877,26 @@ static void exynos4_set_mmc_clk(int dev_index, unsigned int div) * CLK_DIV_FSYS2 * MMC2_PRE_RATIO [15:8], MMC3_PRE_RATIO [31:24] * CLK_DIV_FSYS3 - * MMC4_PRE_RATIO [15:8] + * MMC4_RATIO [3:0] */ if (dev_index < 2) { addr = (unsigned int)&clk->div_fsys1; - } else if (dev_index == 4) { + clear_bit = MASK_PRE_RATIO(dev_index); + set_bit = SET_PRE_RATIO(dev_index, div); + } else if (dev_index == 4) { addr = (unsigned int)&clk->div_fsys3; dev_index -= 4; + /* MMC4 is controlled with the MMC4_RATIO value */ + clear_bit = MASK_RATIO(dev_index); + set_bit = SET_RATIO(dev_index, div); } else { addr = (unsigned int)&clk->div_fsys2; dev_index -= 2; + clear_bit = MASK_PRE_RATIO(dev_index); + set_bit = SET_PRE_RATIO(dev_index, div); }
- clrsetbits_le32(addr, 0xff << ((dev_index << 4) + 8), - (div & 0xff) << ((dev_index << 4) + 8)); + clrsetbits_le32(addr, clear_bit, set_bit); }
/* exynos5: set the mmc clock */ diff --git a/arch/arm/include/asm/arch-exynos/clk.h b/arch/arm/include/asm/arch-exynos/clk.h index cdeef32..ffbc07e 100644 --- a/arch/arm/include/asm/arch-exynos/clk.h +++ b/arch/arm/include/asm/arch-exynos/clk.h @@ -16,6 +16,11 @@ #define BPLL 5 #define RPLL 6
+#define MASK_PRE_RATIO(x) (0xff << ((x << 4) + 8)) +#define MASK_RATIO(x) (0xf << (x << 4)) +#define SET_PRE_RATIO(x, y) ((y & 0xff) << ((x << 4) + 8)) +#define SET_RATIO(x, y) ((y & 0xf) << (x << 4)) + enum pll_src_bit { EXYNOS_SRC_MPLL = 6, EXYNOS_SRC_EPLL,
Restore the platdata(property of dt) into host struct. Then data's information is maintained and reused anywhere.
Signed-off-by: Jaehoon Chung jh80.chung@samsung.com Tested-by: Lukasz Majewski l.majewski@samsung.com Acked-by: Lukasz Majewski l.majewski@samsung.com --- drivers/mmc/exynos_dw_mmc.c | 208 +++++++++++++++++++++++++++---------------- include/dwmmc.h | 2 + 2 files changed, 132 insertions(+), 78 deletions(-)
diff --git a/drivers/mmc/exynos_dw_mmc.c b/drivers/mmc/exynos_dw_mmc.c index e9d00e7..131ff72 100644 --- a/drivers/mmc/exynos_dw_mmc.c +++ b/drivers/mmc/exynos_dw_mmc.c @@ -14,6 +14,7 @@ #include <asm/arch/clk.h> #include <asm/arch/pinmux.h> #include <asm/gpio.h> +#include <asm-generic/errno.h>
#define DWMMC_MAX_CH_NUM 4 #define DWMMC_MAX_FREQ 52000000 @@ -45,6 +46,13 @@ unsigned int exynos_dwmci_get_clk(struct dwmci_host *host) & DWMCI_DIVRATIO_MASK) + 1; sclk = get_mmc_clk(host->dev_index);
+ /* + * Assume to know divider value. + * When clock unit is broken, need to set "host->div" + */ + if (host->div) + sclk /= (host->div + 1); + return sclk / clk_div; }
@@ -61,26 +69,17 @@ static void exynos_dwmci_board_init(struct dwmci_host *host) } }
-/* - * This function adds the mmc channel to be registered with mmc core. - * index - mmc channel number. - * regbase - register base address of mmc channel specified in 'index'. - * bus_width - operating bus width of mmc channel specified in 'index'. - * clksel - value to be written into CLKSEL register in case of FDT. - * NULL in case od non-FDT. - */ -int exynos_dwmci_add_port(int index, u32 regbase, int bus_width, u32 clksel) +static int exynos_dwmci_core_init(struct dwmci_host *host, int index) { - struct dwmci_host *host = NULL; unsigned int div; unsigned long freq, sclk; - host = malloc(sizeof(struct dwmci_host)); - if (!host) { - printf("dwmci_host malloc fail!\n"); - return 1; - } + + if (host->bus_hz) + freq = host->bus_hz; + else + freq = DWMMC_MAX_FREQ; + /* request mmc clock vlaue of 52MHz. */ - freq = 52000000; sclk = get_mmc_clk(index);
/* @@ -94,19 +93,15 @@ int exynos_dwmci_add_port(int index, u32 regbase, int bus_width, u32 clksel) set_mmc_clk(index, div);
host->name = "EXYNOS DWMMC"; - host->ioaddr = (void *)regbase; - host->buswidth = bus_width; #ifdef CONFIG_EXYNOS5420 host->quirks = DWMCI_QUIRK_DISABLE_SMU; #endif host->board_init = exynos_dwmci_board_init;
- if (clksel) { - host->clksel_val = clksel; - } else { - if (0 == index) + if (!host->clksel_val) { + if (index == 0) host->clksel_val = DWMMC_MMC0_CLKSEL_VAL; - if (2 == index) + if (index == 2) host->clksel_val = DWMMC_MMC2_CLKSEL_VAL; }
@@ -121,77 +116,134 @@ int exynos_dwmci_add_port(int index, u32 regbase, int bus_width, u32 clksel) return 0; }
+/* + * This function adds the mmc channel to be registered with mmc core. + * index - mmc channel number. + * regbase - register base address of mmc channel specified in 'index'. + * bus_width - operating bus width of mmc channel specified in 'index'. + * clksel - value to be written into CLKSEL register in case of FDT. + * NULL in case od non-FDT. + */ +int exynos_dwmci_add_port(int index, u32 regbase, int bus_width, u32 clksel) +{ + struct dwmci_host *host = NULL; + + host = malloc(sizeof(struct dwmci_host)); + if (!host) { + error("dwmci_host malloc fail!\n"); + return -ENOMEM; + } + + host->ioaddr = (void *)regbase; + host->buswidth = bus_width; + + if (clksel) + host->clksel_val = clksel; + + return exynos_dwmci_core_init(host, index); +} + #ifdef CONFIG_OF_CONTROL -int exynos_dwmmc_init(const void *blob) +struct dwmci_host dwmci_host[DWMMC_MAX_CH_NUM]; + +static int do_dwmci_init(struct dwmci_host *host) { - int index, bus_width; - int node_list[DWMMC_MAX_CH_NUM]; - int err = 0, dev_id, flag, count, i, compat_id; - u32 clksel_val, base, timing[3]; + int index, flag = 0, err = 0;
- compat_id = COMPAT_SAMSUNG_EXYNOS_DWMMC; + index = host->dev_index;
- count = fdtdec_find_aliases_for_id(blob, "mmc", - compat_id, node_list, DWMMC_MAX_CH_NUM); + flag = host->buswidth == 8 ? PINMUX_FLAG_8BIT_MODE : PINMUX_FLAG_NONE; + err = exynos_pinmux_config(host->dev_id, flag); + if (err) { + debug("DWMMC not configure\n"); + return err; + }
- for (i = 0; i < count; i++) { - int node = node_list[i]; - struct fdt_gpio_state pwr_gpio; + return exynos_dwmci_core_init(host, index); +}
- if (node <= 0) - continue; +static int exynos_dwmci_get_config(const void *blob, int node, + struct dwmci_host *host) +{ + int err = 0; + u32 base, clksel_val, timing[3];
- /* Extract device id for each mmc channel */ - dev_id = pinmux_decode_periph_id(blob, node); + /* Extract device id for each mmc channel */ + host->dev_id = pinmux_decode_periph_id(blob, node);
- /* Get the bus width from the device node */ - bus_width = fdtdec_get_int(blob, node, "samsung,bus-width", 0); - if (bus_width <= 0) { - debug("DWMMC: Can't get bus-width\n"); - return -1; - } - if (8 == bus_width) - flag = PINMUX_FLAG_8BIT_MODE; - else - flag = PINMUX_FLAG_NONE; + /* Get the bus width from the device node */ + host->buswidth = fdtdec_get_int(blob, node, "samsung,bus-width", 0); + if (host->buswidth <= 0) { + debug("DWMMC: Can't get bus-width\n"); + return -EINVAL; + }
- fdtdec_decode_gpio(blob, node, "pwr-gpios", &pwr_gpio); - if (fdt_gpio_isvalid(&pwr_gpio)) - gpio_direction_output(pwr_gpio.gpio, 1); + host->dev_index = fdtdec_get_int(blob, node, "index", host->dev_id); + if (host->dev_index == host->dev_id) + host->dev_index = host->dev_id - PERIPH_ID_SDMMC0;
- /* config pinmux for each mmc channel */ - err = exynos_pinmux_config(dev_id, flag); - if (err) { - debug("DWMMC not configured\n"); - return err; - } + /* Set the base address from the device node */ + base = fdtdec_get_addr(blob, node, "reg"); + if (!base) { + debug("DWMMC: Can't get base address\n"); + return -EINVAL; + } + host->ioaddr = (void *)base;
- index = fdtdec_get_int(blob, node, "index", dev_id); - if (index == dev_id) - index = dev_id - PERIPH_ID_SDMMC0; + /* Extract the timing info from the node */ + err = fdtdec_get_int_array(blob, node, "samsung,timing", timing, 3); + if (err) { + debug("Can't get sdr-timings for devider\n"); + return -EINVAL; + }
- /* Get the base address from the device node */ - base = fdtdec_get_addr(blob, node, "reg"); - if (!base) { - debug("DWMMC: Can't get base address\n"); - return -1; - } - /* Extract the timing info from the node */ - err = fdtdec_get_int_array(blob, node, "samsung,timing", - timing, 3); + clksel_val = (DWMCI_SET_SAMPLE_CLK(timing[0]) | + DWMCI_SET_DRV_CLK(timing[1]) | + DWMCI_SET_DIV_RATIO(timing[2])); + if (clksel_val) + host->clksel_val = clksel_val; + + host->fifoth_val = fdtdec_get_int(blob, node, "fifoth_val", 0); + host->bus_hz = fdtdec_get_int(blob, node, "bus_hz", 0); + host->div = fdtdec_get_int(blob, node, "div", 0); + + return 0; +} + +static int exynos_dwmci_process_node(const void *blob, + int node_list[], int count) +{ + struct dwmci_host *host; + int i, node, err; + + for (i = 0; i < count; i++) { + node = node_list[i]; + if (node <= 0) + continue; + host = &dwmci_host[i]; + err = exynos_dwmci_get_config(blob, node, host); if (err) { - debug("Can't get sdr-timings for divider\n"); - return -1; + debug("%s: failed to decode dev %d\n", __func__, i); + return err; }
- clksel_val = (DWMCI_SET_SAMPLE_CLK(timing[0]) | - DWMCI_SET_DRV_CLK(timing[1]) | - DWMCI_SET_DIV_RATIO(timing[2])); - /* Initialise each mmc channel */ - err = exynos_dwmci_add_port(index, base, bus_width, clksel_val); - if (err) - debug("dwmmc Channel-%d init failed\n", index); + do_dwmci_init(host); } return 0; } + +int exynos_dwmmc_init(const void *blob) +{ + int compat_id; + int node_list[DWMMC_MAX_CH_NUM]; + int err = 0, count; + + compat_id = COMPAT_SAMSUNG_EXYNOS_DWMMC; + + count = fdtdec_find_aliases_for_id(blob, "mmc", + compat_id, node_list, DWMMC_MAX_CH_NUM); + err = exynos_dwmci_process_node(blob, node_list, count); + + return err; +} #endif diff --git a/include/dwmmc.h b/include/dwmmc.h index c9bdf51..14c7db8 100644 --- a/include/dwmmc.h +++ b/include/dwmmc.h @@ -134,7 +134,9 @@ struct dwmci_host { unsigned int version; unsigned int clock; unsigned int bus_hz; + unsigned int div; int dev_index; + int dev_id; int buswidth; u32 clksel_val; u32 fifoth_val;
Signed-off-by: Jaehoon Chung jh80.chung@samsung.com Reviewed-by: Lukasz Majeski l.majewski@samsung.com Tested-by: Lukasz Majewski l.majewski@samsung.com Acked-by: Lukasz Majewski l.majewski@samsung.com --- drivers/mmc/mmc.c | 2 +- include/mmc.h | 18 ++++++------------ 2 files changed, 7 insertions(+), 13 deletions(-)
diff --git a/drivers/mmc/mmc.c b/drivers/mmc/mmc.c index 16051e5..dd6a6ef 100644 --- a/drivers/mmc/mmc.c +++ b/drivers/mmc/mmc.c @@ -514,7 +514,7 @@ static int mmc_change_freq(struct mmc *mmc) return 0;
/* High Speed is set, there are two types: 52MHz and 26MHz */ - if (cardtype & MMC_HS_52MHZ) + if (cardtype & EXT_CSD_CARD_TYPE_52) mmc->card_caps |= MMC_MODE_HS_52MHz | MMC_MODE_HS; else mmc->card_caps |= MMC_MODE_HS; diff --git a/include/mmc.h b/include/mmc.h index 42d0125..da9f812 100644 --- a/include/mmc.h +++ b/include/mmc.h @@ -31,15 +31,12 @@ #define MMC_VERSION_4_41 (MMC_VERSION_MMC | 0x429) #define MMC_VERSION_4_5 (MMC_VERSION_MMC | 0x405)
-#define MMC_MODE_HS 0x001 -#define MMC_MODE_HS_52MHz 0x010 -#define MMC_MODE_4BIT 0x100 -#define MMC_MODE_8BIT 0x200 -#define MMC_MODE_SPI 0x400 -#define MMC_MODE_HC 0x800 - -#define MMC_MODE_MASK_WIDTH_BITS (MMC_MODE_4BIT | MMC_MODE_8BIT) -#define MMC_MODE_WIDTH_BITS_SHIFT 8 +#define MMC_MODE_HS (1 << 0) +#define MMC_MODE_HS_52MHz (1 << 1) +#define MMC_MODE_4BIT (1 << 2) +#define MMC_MODE_8BIT (1 << 3) +#define MMC_MODE_SPI (1 << 4) +#define MMC_MODE_HC (1 << 5)
#define SD_DATA_4BIT 0x00040000
@@ -97,9 +94,6 @@ #define SD_HIGHSPEED_BUSY 0x00020000 #define SD_HIGHSPEED_SUPPORTED 0x00020000
-#define MMC_HS_TIMING 0x00000100 -#define MMC_HS_52MHZ 0x2 - #define OCR_BUSY 0x80000000 #define OCR_HCS 0x40000000 #define OCR_VOLTAGE_MASK 0x007FFF80
Signed-off-by: Jaehoon Chung jh80.chung@samsung.com Tested-by: Lukasz Majewski l.majewski@samsung.com Acked-by: Lukasz Majewski l.majewski@samsung.com --- drivers/mmc/mmc.c | 16 +++++++++++++--- include/mmc.h | 7 +++++++ 2 files changed, 20 insertions(+), 3 deletions(-)
diff --git a/drivers/mmc/mmc.c b/drivers/mmc/mmc.c index dd6a6ef..08187d5 100644 --- a/drivers/mmc/mmc.c +++ b/drivers/mmc/mmc.c @@ -158,6 +158,9 @@ int mmc_set_blocklen(struct mmc *mmc, int len) { struct mmc_cmd cmd;
+ if (mmc->card_caps & MMC_MODE_DDR_52MHz) + return 0; + cmd.cmdidx = MMC_CMD_SET_BLOCKLEN; cmd.resp_type = MMC_RSP_R1; cmd.cmdarg = len; @@ -514,10 +517,13 @@ static int mmc_change_freq(struct mmc *mmc) return 0;
/* High Speed is set, there are two types: 52MHz and 26MHz */ - if (cardtype & EXT_CSD_CARD_TYPE_52) + if (cardtype & EXT_CSD_CARD_TYPE_52) { + if (cardtype & EXT_CSD_CARD_TYPE_DDR_52) + mmc->card_caps |= MMC_MODE_DDR_52MHz; mmc->card_caps |= MMC_MODE_HS_52MHz | MMC_MODE_HS; - else + } else { mmc->card_caps |= MMC_MODE_HS; + }
return 0; } @@ -1054,6 +1060,8 @@ static int mmc_startup(struct mmc *mmc)
/* An array of possible bus widths in order of preference */ static unsigned ext_csd_bits[] = { + EXT_CSD_DDR_BUS_WIDTH_8, + EXT_CSD_DDR_BUS_WIDTH_4, EXT_CSD_BUS_WIDTH_8, EXT_CSD_BUS_WIDTH_4, EXT_CSD_BUS_WIDTH_1, @@ -1061,13 +1069,15 @@ static int mmc_startup(struct mmc *mmc)
/* An array to map CSD bus widths to host cap bits */ static unsigned ext_to_hostcaps[] = { + [EXT_CSD_DDR_BUS_WIDTH_4] = MMC_MODE_DDR_52MHz, + [EXT_CSD_DDR_BUS_WIDTH_8] = MMC_MODE_DDR_52MHz, [EXT_CSD_BUS_WIDTH_4] = MMC_MODE_4BIT, [EXT_CSD_BUS_WIDTH_8] = MMC_MODE_8BIT, };
/* An array to map chosen bus width to an integer */ static unsigned widths[] = { - 8, 4, 1, + 8, 4, 8, 4, 1, };
for (idx=0; idx < ARRAY_SIZE(ext_csd_bits); idx++) { diff --git a/include/mmc.h b/include/mmc.h index da9f812..40efb56 100644 --- a/include/mmc.h +++ b/include/mmc.h @@ -37,6 +37,7 @@ #define MMC_MODE_8BIT (1 << 3) #define MMC_MODE_SPI (1 << 4) #define MMC_MODE_HC (1 << 5) +#define MMC_MODE_DDR_52MHz (1 << 6)
@@ -168,10 +169,16 @@
#define EXT_CSD_CARD_TYPE_26 (1 << 0) /* Card can run at 26MHz */ #define EXT_CSD_CARD_TYPE_52 (1 << 1) /* Card can run at 52MHz */ +#define EXT_CSD_CARD_TYPE_DDR_1_8V (1 << 2) +#define EXT_CSD_CARD_TYPE_DDR_1_2V (1 << 3) +#define EXT_CSD_CARD_TYPE_DDR_52 (EXT_CSD_CARD_TYPE_DDR_1_8V \ + | EXT_CSD_CARD_TYPE_DDR_1_2V)
#define EXT_CSD_BUS_WIDTH_1 0 /* Card is in 1 bit mode */ #define EXT_CSD_BUS_WIDTH_4 1 /* Card is in 4 bit mode */ #define EXT_CSD_BUS_WIDTH_8 2 /* Card is in 8 bit mode */ +#define EXT_CSD_DDR_BUS_WIDTH_4 5 /* Card is in 4 bit DDR mode */ +#define EXT_CSD_DDR_BUS_WIDTH_8 6 /* Card is in 8 bit DDR mode */
#define EXT_CSD_BOOT_ACK_ENABLE (1 << 6) #define EXT_CSD_BOOT_PARTITION_ENABLE (1 << 3)
Support the DDR mode at dw-mmc controller
Signed-off-by: Jaehoon Chung jh80.chung@samsung.com Tested-by: Lukasz Majewski l.majewski@samsung.com Acked-by: Lukasz Majewski l.majewski@samsung.com --- drivers/mmc/dw_mmc.c | 12 ++++++++++-- include/dwmmc.h | 3 +++ 2 files changed, 13 insertions(+), 2 deletions(-)
diff --git a/drivers/mmc/dw_mmc.c b/drivers/mmc/dw_mmc.c index eb4e2be..5bf36a0 100644 --- a/drivers/mmc/dw_mmc.c +++ b/drivers/mmc/dw_mmc.c @@ -284,8 +284,8 @@ static int dwmci_setup_bus(struct dwmci_host *host, u32 freq)
static void dwmci_set_ios(struct mmc *mmc) { - struct dwmci_host *host = mmc->priv; - u32 ctype; + struct dwmci_host *host = (struct dwmci_host *)mmc->priv; + u32 ctype, regs;
debug("Buswidth = %d, clock: %d\n",mmc->bus_width, mmc->clock);
@@ -304,6 +304,14 @@ static void dwmci_set_ios(struct mmc *mmc)
dwmci_writel(host, DWMCI_CTYPE, ctype);
+ regs = dwmci_readl(host, DWMCI_UHS_REG); + if (mmc->card_caps & MMC_MODE_DDR_52MHz) + regs |= DWMCI_DDR_MODE; + else + regs &= DWMCI_DDR_MODE; + + dwmci_writel(host, DWMCI_UHS_REG, regs); + if (host->clksel) host->clksel(host); } diff --git a/include/dwmmc.h b/include/dwmmc.h index 14c7db8..b67f11b 100644 --- a/include/dwmmc.h +++ b/include/dwmmc.h @@ -123,6 +123,9 @@ #define DWMCI_BMOD_IDMAC_FB (1 << 1) #define DWMCI_BMOD_IDMAC_EN (1 << 7)
+/* UHS register */ +#define DWMCI_DDR_MODE (1 << 16) + /* quirks */ #define DWMCI_QUIRK_DISABLE_SMU (1 << 0)
Enabled the dw-mmc controller.
Signed-off-by: Jaehoon Chung jh80.chung@samsung.com Tested-by: Lukasz Majewski l.majewski@samsung.com Acked-by: Lukasz Majewski l.majewski@samsung.com --- arch/arm/dts/exynos4412-trats2.dts | 6 +++++- 1 file changed, 5 insertions(+), 1 deletion(-)
diff --git a/arch/arm/dts/exynos4412-trats2.dts b/arch/arm/dts/exynos4412-trats2.dts index 438e70e..d27f2bc 100644 --- a/arch/arm/dts/exynos4412-trats2.dts +++ b/arch/arm/dts/exynos4412-trats2.dts @@ -417,6 +417,7 @@ samsung,bus-width = <8>; samsung,timing = <1 3 3>; pwr-gpios = <&gpio 0x2004002 0>; + status = "disabled"; };
sdhci@12520000 { @@ -435,7 +436,10 @@
dwmmc@12550000 { samsung,bus-width = <8>; - samsung,timing = <0 1 0>; + samsung,timing = <2 1 0>; + fifoth_val = <0x203f0040>; + bus_hz = <400000000>; + div = <0x3>; pwr-gpios = <&gpio 0x2004002 0>; index = <4>; };
Set the ddr mode capability by default.
Signed-off-by: Jaehoon Chung jh80.chung@samsung.com Tested-by: Lukasz Majewski l.majewski@samsung.com Acked-by: Lukasz Majewski l.majewski@samsung.com --- drivers/mmc/exynos_dw_mmc.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/mmc/exynos_dw_mmc.c b/drivers/mmc/exynos_dw_mmc.c index 131ff72..96b5ab6 100644 --- a/drivers/mmc/exynos_dw_mmc.c +++ b/drivers/mmc/exynos_dw_mmc.c @@ -105,6 +105,7 @@ static int exynos_dwmci_core_init(struct dwmci_host *host, int index) host->clksel_val = DWMMC_MMC2_CLKSEL_VAL; }
+ host->caps = MMC_MODE_DDR_52MHz; host->clksel = exynos_dwmci_clksel; host->dev_index = index; host->get_mmc_clk = exynos_dwmci_get_clk;
Signed-off-by: Jaehoon Chung jh80.chung@samsung.com Tested-by: Lukasz Majewski l.majewski@samsung.com Acked-by: Lukasz Majewski l.majewski@samsung.com --- include/configs/exynos4-dt.h | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/include/configs/exynos4-dt.h b/include/configs/exynos4-dt.h index 2040bf7..7710bae 100644 --- a/include/configs/exynos4-dt.h +++ b/include/configs/exynos4-dt.h @@ -44,6 +44,9 @@ #define CONFIG_S5P_SDHCI #define CONFIG_SDHCI #define CONFIG_MMC_SDMA +#define CONFIG_DWMMC +#define CONFIG_EXYNOS_DWMMC +#define CONFIG_BOUNCE_BUFFER #define CONFIG_MMC_DEFAULT_DEV 0
/* PWM */
To reuse the code, added the s5p_sdhci_core_init function. Before applied this patch, didn't use the 8-bit mode at exynos baord. Because it didn't set "MMC_MODE_8BIT".
Signed-off-by: Jaehoon Chung jh80.chung@samsung.com Tested-by: Lukasz Majewski l.majewski@samsung.com Acked-by: Lukasz Majewski l.majewski@samsung.com --- drivers/mmc/s5p_sdhci.c | 42 +++++++++++++++++------------------------- 1 file changed, 17 insertions(+), 25 deletions(-)
diff --git a/drivers/mmc/s5p_sdhci.c b/drivers/mmc/s5p_sdhci.c index ccae4cc..2ff0ec2 100644 --- a/drivers/mmc/s5p_sdhci.c +++ b/drivers/mmc/s5p_sdhci.c @@ -65,17 +65,9 @@ static void s5p_sdhci_set_control_reg(struct sdhci_host *host) sdhci_writel(host, ctrl, SDHCI_CONTROL2); }
-int s5p_sdhci_init(u32 regbase, int index, int bus_width) +static int s5p_sdhci_core_init(struct sdhci_host *host) { - struct sdhci_host *host = NULL; - host = (struct sdhci_host *)malloc(sizeof(struct sdhci_host)); - if (!host) { - printf("sdhci__host malloc fail!\n"); - return 1; - } - host->name = S5P_NAME; - host->ioaddr = (void *)regbase;
host->quirks = SDHCI_QUIRK_NO_HISPD_BIT | SDHCI_QUIRK_BROKEN_VOLTAGE | SDHCI_QUIRK_BROKEN_R1B | SDHCI_QUIRK_32BIT_DMA_ADDR | @@ -85,15 +77,28 @@ int s5p_sdhci_init(u32 regbase, int index, int bus_width)
host->set_control_reg = &s5p_sdhci_set_control_reg; host->set_clock = set_mmc_clk; - host->index = index;
host->host_caps = MMC_MODE_HC; - if (bus_width == 8) + if (host->bus_width == 8) host->host_caps |= MMC_MODE_8BIT;
return add_sdhci(host, 52000000, 400000); }
+int s5p_sdhci_init(u32 regbase, int index, int bus_width) +{ + struct sdhci_host *host = malloc(sizeof(struct sdhci_host)); + if (!host) { + printf("sdhci__host malloc fail!\n"); + return 1; + } + host->ioaddr = (void *)regbase; + host->index = index; + host->bus_width = bus_width; + + return s5p_sdhci_core_init(host); +} + #ifdef CONFIG_OF_CONTROL struct sdhci_host sdhci_host[SDHCI_MAX_HOSTS];
@@ -126,20 +131,7 @@ static int do_sdhci_init(struct sdhci_host *host) } }
- host->name = S5P_NAME; - - host->quirks = SDHCI_QUIRK_NO_HISPD_BIT | SDHCI_QUIRK_BROKEN_VOLTAGE | - SDHCI_QUIRK_BROKEN_R1B | SDHCI_QUIRK_32BIT_DMA_ADDR | - SDHCI_QUIRK_WAIT_SEND_CMD; - host->voltages = MMC_VDD_32_33 | MMC_VDD_33_34 | MMC_VDD_165_195; - host->version = sdhci_readw(host, SDHCI_HOST_VERSION); - - host->set_control_reg = &s5p_sdhci_set_control_reg; - host->set_clock = set_mmc_clk; - - host->host_caps = MMC_MODE_HC; - - return add_sdhci(host, 52000000, 400000); + return s5p_sdhci_core_init(host); }
static int sdhci_get_config(const void *blob, int node, struct sdhci_host *host)
Dear, All.
Did you have any comment?
Best Regards, Jaehoon Chung
Hi, All.
If didn't have any other comment, could you apply this patch? I want to merge this patch at mainline.
On 04/29/2014 01:06 PM, Jaehoon Chung wrote:
Dear, All.
Dear Pantelis Antoniou,
On 07/05/14 12:40, Jaehoon Chung wrote:
Hi, All.
If you are OK then, I want to pick up this patchset to samsung tree. This patchset has been including samsung related features.
Jaehoon Chung
Minkyu Kang
