[PATCH 1/2] x86: tsc: Rename X86_TSC_TIMER_EARLY_FREQ to X86_TSC_TIMER_FREQ
Currently there are two places to specify the x86 TSC timer frequency with one in Kconfig used for early timer and the other one in device tree used when the frequency cannot be determined from hardware.
This may potentially create an inconsistent config where the 2 values do not match. Let's use the one specified in Kconfig in the device tree as well.
Signed-off-by: Bin Meng bmeng.cn@gmail.com ---
arch/x86/cpu/quark/Kconfig | 4 ++-- arch/x86/dts/galileo.dts | 2 +- drivers/timer/Kconfig | 8 ++++---- drivers/timer/tsc_timer.c | 5 +++-- 4 files changed, 10 insertions(+), 9 deletions(-)
diff --git a/arch/x86/cpu/quark/Kconfig b/arch/x86/cpu/quark/Kconfig index 430cce184d..61bb5792c8 100644 --- a/arch/x86/cpu/quark/Kconfig +++ b/arch/x86/cpu/quark/Kconfig @@ -130,8 +130,8 @@ config SYS_CAR_SIZE Space in bytes in eSRAM used as Cache-As-ARM (CAR). Note this size must not exceed eSRAM's total size.
-config X86_TSC_TIMER_EARLY_FREQ +config X86_TSC_TIMER_FREQ int - default 400 + default 400000000
endif diff --git a/arch/x86/dts/galileo.dts b/arch/x86/dts/galileo.dts index 501047124e..b5ba1181dd 100644 --- a/arch/x86/dts/galileo.dts +++ b/arch/x86/dts/galileo.dts @@ -42,7 +42,7 @@ };
tsc-timer { - clock-frequency = <400000000>; + clock-frequency = <CONFIG_X86_TSC_TIMER_FREQ>; };
mrc { diff --git a/drivers/timer/Kconfig b/drivers/timer/Kconfig index ee81dfa776..8913142654 100644 --- a/drivers/timer/Kconfig +++ b/drivers/timer/Kconfig @@ -124,12 +124,12 @@ config RENESAS_OSTM_TIMER Enables support for the Renesas OSTM Timer driver. This timer is present on Renesas RZ/A1 R7S72100 SoCs.
-config X86_TSC_TIMER_EARLY_FREQ - int "x86 TSC timer frequency in MHz when used as the early timer" +config X86_TSC_TIMER_FREQ + int "x86 TSC timer frequency in Hz" depends on X86_TSC_TIMER - default 1000 + default 1000000000 help - Sets the estimated CPU frequency in MHz when TSC is used as the + Sets the estimated CPU frequency in Hz when TSC is used as the early timer and the frequency can neither be calibrated via some hardware ways, nor got from device tree at the time when device tree is not available yet. diff --git a/drivers/timer/tsc_timer.c b/drivers/timer/tsc_timer.c index 7d19a99622..adef50c374 100644 --- a/drivers/timer/tsc_timer.c +++ b/drivers/timer/tsc_timer.c @@ -425,12 +425,13 @@ static void tsc_timer_ensure_setup(bool early) goto done;
if (early) - fast_calibrate = CONFIG_X86_TSC_TIMER_EARLY_FREQ; + gd->arch.clock_rate = CONFIG_X86_TSC_TIMER_FREQ; else return;
done: - gd->arch.clock_rate = fast_calibrate * 1000000; + if (!gd->arch.clock_rate) + gd->arch.clock_rate = fast_calibrate * 1000000; } gd->arch.tsc_inited = true; }
If for some reason, TSC timer frequency cannot be determined from hardware, nor is it specified in the device tree, U-Boot will panic resulting in endless reset during boot.
Let's define a default TSC timer frequency using the Kconfig value CONFIG_X86_TSC_TIMER_FREQ (note: #include must be used instead of /include/ otherwise the macro is not pre-processed).
arch/x86/dts/bayleybay.dts | 2 +- arch/x86/dts/baytrail_som-db5800-som-6867.dts | 2 +- arch/x86/dts/cherryhill.dts | 2 +- arch/x86/dts/chromebook_coral.dts | 3 ++- arch/x86/dts/chromebook_link.dts | 2 +- arch/x86/dts/chromebook_samus.dts | 2 +- arch/x86/dts/chromebox_panther.dts | 2 +- arch/x86/dts/conga-qeval20-qa3-e3845.dts | 2 +- arch/x86/dts/coreboot.dts | 7 ++----- arch/x86/dts/cougarcanyon2.dts | 2 +- arch/x86/dts/crownbay.dts | 2 +- arch/x86/dts/edison.dts | 2 +- arch/x86/dts/efi-x86_app.dts | 7 ++----- arch/x86/dts/efi-x86_payload.dts | 7 ++----- arch/x86/dts/galileo.dts | 7 ++----- arch/x86/dts/minnowmax.dts | 2 +- arch/x86/dts/qemu-x86_i440fx.dts | 6 +----- arch/x86/dts/qemu-x86_q35.dts | 6 +----- arch/x86/dts/slimbootloader.dts | 2 +- arch/x86/dts/tsc_timer.dtsi | 1 + 20 files changed, 25 insertions(+), 43 deletions(-)
diff --git a/arch/x86/dts/bayleybay.dts b/arch/x86/dts/bayleybay.dts index 70e5798403..828b851773 100644 --- a/arch/x86/dts/bayleybay.dts +++ b/arch/x86/dts/bayleybay.dts @@ -14,8 +14,8 @@ /include/ "serial.dtsi" /include/ "reset.dtsi" /include/ "rtc.dtsi" -/include/ "tsc_timer.dtsi"
+#include "tsc_timer.dtsi" #include "smbios.dtsi"
/ { diff --git a/arch/x86/dts/baytrail_som-db5800-som-6867.dts b/arch/x86/dts/baytrail_som-db5800-som-6867.dts index a7dc03b645..f5d1a28c09 100644 --- a/arch/x86/dts/baytrail_som-db5800-som-6867.dts +++ b/arch/x86/dts/baytrail_som-db5800-som-6867.dts @@ -14,8 +14,8 @@ /include/ "serial.dtsi" /include/ "reset.dtsi" /include/ "rtc.dtsi" -/include/ "tsc_timer.dtsi"
/ { diff --git a/arch/x86/dts/cherryhill.dts b/arch/x86/dts/cherryhill.dts index 2ce7f1aa91..99d137e321 100644 --- a/arch/x86/dts/cherryhill.dts +++ b/arch/x86/dts/cherryhill.dts @@ -12,8 +12,8 @@ /include/ "serial.dtsi" /include/ "reset.dtsi" /include/ "rtc.dtsi" -/include/ "tsc_timer.dtsi"
/ { diff --git a/arch/x86/dts/chromebook_coral.dts b/arch/x86/dts/chromebook_coral.dts index 66c31efb6c..ea879c0300 100644 --- a/arch/x86/dts/chromebook_coral.dts +++ b/arch/x86/dts/chromebook_coral.dts @@ -8,7 +8,8 @@ /include/ "keyboard.dtsi" /include/ "reset.dtsi" /include/ "rtc.dtsi" -/include/ "tsc_timer.dtsi" + +#include "tsc_timer.dtsi"
#if defined(CONFIG_CHROMEOS_VBOOT) && defined(CONFIG_ROM_SIZE) #include "chromeos-x86.dtsi" diff --git a/arch/x86/dts/chromebook_link.dts b/arch/x86/dts/chromebook_link.dts index e529c4b63e..4367fab651 100644 --- a/arch/x86/dts/chromebook_link.dts +++ b/arch/x86/dts/chromebook_link.dts @@ -9,8 +9,8 @@ /include/ "serial.dtsi" /include/ "reset.dtsi" /include/ "rtc.dtsi" -/include/ "tsc_timer.dtsi"
/ { diff --git a/arch/x86/dts/chromebook_samus.dts b/arch/x86/dts/chromebook_samus.dts index ad35ab2e3f..0f0dcdcc5f 100644 --- a/arch/x86/dts/chromebook_samus.dts +++ b/arch/x86/dts/chromebook_samus.dts @@ -7,8 +7,8 @@ /include/ "serial.dtsi" /include/ "reset.dtsi" /include/ "rtc.dtsi" -/include/ "tsc_timer.dtsi"
#if defined(CONFIG_CHROMEOS_VBOOT) && defined(CONFIG_ROM_SIZE) diff --git a/arch/x86/dts/chromebox_panther.dts b/arch/x86/dts/chromebox_panther.dts index 77b6ac9ab9..0169c427a1 100644 --- a/arch/x86/dts/chromebox_panther.dts +++ b/arch/x86/dts/chromebox_panther.dts @@ -4,8 +4,8 @@ /include/ "serial.dtsi" /include/ "reset.dtsi" /include/ "rtc.dtsi" -/include/ "tsc_timer.dtsi"
/ { diff --git a/arch/x86/dts/conga-qeval20-qa3-e3845.dts b/arch/x86/dts/conga-qeval20-qa3-e3845.dts index bbea99da2c..31eacc2d48 100644 --- a/arch/x86/dts/conga-qeval20-qa3-e3845.dts +++ b/arch/x86/dts/conga-qeval20-qa3-e3845.dts @@ -14,8 +14,8 @@ /include/ "serial.dtsi" /include/ "reset.dtsi" /include/ "rtc.dtsi" -/include/ "tsc_timer.dtsi"
/ { diff --git a/arch/x86/dts/coreboot.dts b/arch/x86/dts/coreboot.dts index 38ddaafa19..d21978d6e0 100644 --- a/arch/x86/dts/coreboot.dts +++ b/arch/x86/dts/coreboot.dts @@ -12,7 +12,8 @@ /include/ "pcspkr.dtsi" /include/ "reset.dtsi" /include/ "rtc.dtsi" -/include/ "tsc_timer.dtsi" + +#include "tsc_timer.dtsi"
/ { model = "coreboot x86 payload"; @@ -30,10 +31,6 @@ stdout-path = "/serial"; };
- tsc-timer { - clock-frequency = <1000000000>; - }; - pci { compatible = "pci-x86"; u-boot,dm-pre-reloc; diff --git a/arch/x86/dts/cougarcanyon2.dts b/arch/x86/dts/cougarcanyon2.dts index 602523333e..f850becaaa 100644 --- a/arch/x86/dts/cougarcanyon2.dts +++ b/arch/x86/dts/cougarcanyon2.dts @@ -12,8 +12,8 @@ /include/ "keyboard.dtsi" /include/ "reset.dtsi" /include/ "rtc.dtsi" -/include/ "tsc_timer.dtsi"
/ { diff --git a/arch/x86/dts/crownbay.dts b/arch/x86/dts/crownbay.dts index a7166a9749..5768352531 100644 --- a/arch/x86/dts/crownbay.dts +++ b/arch/x86/dts/crownbay.dts @@ -13,8 +13,8 @@ /include/ "pcspkr.dtsi" /include/ "reset.dtsi" /include/ "rtc.dtsi" -/include/ "tsc_timer.dtsi"
/ { diff --git a/arch/x86/dts/edison.dts b/arch/x86/dts/edison.dts index 8d245bffc2..64b6228363 100644 --- a/arch/x86/dts/edison.dts +++ b/arch/x86/dts/edison.dts @@ -10,8 +10,8 @@
/include/ "skeleton.dtsi" /include/ "rtc.dtsi" -/include/ "tsc_timer.dtsi"
/ { diff --git a/arch/x86/dts/efi-x86_app.dts b/arch/x86/dts/efi-x86_app.dts index 20150f6ede..04e044a07a 100644 --- a/arch/x86/dts/efi-x86_app.dts +++ b/arch/x86/dts/efi-x86_app.dts @@ -6,7 +6,8 @@ /dts-v1/;
/include/ "skeleton.dtsi" -/include/ "tsc_timer.dtsi" + +#include "tsc_timer.dtsi"
/ { model = "EFI x86 Application"; @@ -16,10 +17,6 @@ stdout-path = &serial; };
- tsc-timer { - clock-frequency = <1000000000>; - }; - serial: serial { compatible = "efi,uart"; }; diff --git a/arch/x86/dts/efi-x86_payload.dts b/arch/x86/dts/efi-x86_payload.dts index 5ccb986774..087865f225 100644 --- a/arch/x86/dts/efi-x86_payload.dts +++ b/arch/x86/dts/efi-x86_payload.dts @@ -12,7 +12,8 @@ /include/ "keyboard.dtsi" /include/ "reset.dtsi" /include/ "rtc.dtsi" -/include/ "tsc_timer.dtsi" + +#include "tsc_timer.dtsi"
/ { model = "EFI x86 Payload"; @@ -30,10 +31,6 @@ stdout-path = "/serial"; };
- tsc-timer { - clock-frequency = <1000000000>; - }; - pci { compatible = "pci-x86"; u-boot,dm-pre-reloc; diff --git a/arch/x86/dts/galileo.dts b/arch/x86/dts/galileo.dts index b5ba1181dd..4120e8f5c4 100644 --- a/arch/x86/dts/galileo.dts +++ b/arch/x86/dts/galileo.dts @@ -11,7 +11,8 @@ /include/ "skeleton.dtsi" /include/ "reset.dtsi" /include/ "rtc.dtsi" -/include/ "tsc_timer.dtsi" + +#include "tsc_timer.dtsi"
/ { model = "Intel Galileo"; @@ -41,10 +42,6 @@ }; };
- tsc-timer { - clock-frequency = <CONFIG_X86_TSC_TIMER_FREQ>; - }; - mrc { compatible = "intel,quark-mrc"; flags = <MRC_FLAG_SCRAMBLE_EN>; diff --git a/arch/x86/dts/minnowmax.dts b/arch/x86/dts/minnowmax.dts index 133d55bc20..110450bb55 100644 --- a/arch/x86/dts/minnowmax.dts +++ b/arch/x86/dts/minnowmax.dts @@ -13,8 +13,8 @@ /include/ "serial.dtsi" /include/ "reset.dtsi" /include/ "rtc.dtsi" -/include/ "tsc_timer.dtsi"
/ { diff --git a/arch/x86/dts/qemu-x86_i440fx.dts b/arch/x86/dts/qemu-x86_i440fx.dts index c33a11d593..6556e9ebcd 100644 --- a/arch/x86/dts/qemu-x86_i440fx.dts +++ b/arch/x86/dts/qemu-x86_i440fx.dts @@ -12,8 +12,8 @@ /include/ "keyboard.dtsi" /include/ "reset.dtsi" /include/ "rtc.dtsi" -/include/ "tsc_timer.dtsi"
/ { @@ -42,10 +42,6 @@ }; };
- tsc-timer { - clock-frequency = <1000000000>; - }; - pci { compatible = "pci-x86"; #address-cells = <3>; diff --git a/arch/x86/dts/qemu-x86_q35.dts b/arch/x86/dts/qemu-x86_q35.dts index 9faae7fb56..d0830892e8 100644 --- a/arch/x86/dts/qemu-x86_q35.dts +++ b/arch/x86/dts/qemu-x86_q35.dts @@ -22,8 +22,8 @@ /include/ "keyboard.dtsi" /include/ "reset.dtsi" /include/ "rtc.dtsi" -/include/ "tsc_timer.dtsi"
/ { @@ -53,10 +53,6 @@ }; };
- tsc-timer { - clock-frequency = <1000000000>; - }; - pci { compatible = "pci-x86"; #address-cells = <3>; diff --git a/arch/x86/dts/slimbootloader.dts b/arch/x86/dts/slimbootloader.dts index d04095c4f8..9b581c8489 100644 --- a/arch/x86/dts/slimbootloader.dts +++ b/arch/x86/dts/slimbootloader.dts @@ -7,7 +7,7 @@
/include/ "skeleton.dtsi" /include/ "reset.dtsi" -/include/ "tsc_timer.dtsi" +#include "tsc_timer.dtsi"
/ { model = "slimbootloader x86 payload"; diff --git a/arch/x86/dts/tsc_timer.dtsi b/arch/x86/dts/tsc_timer.dtsi index 4f5021d96f..4df8e9d7fc 100644 --- a/arch/x86/dts/tsc_timer.dtsi +++ b/arch/x86/dts/tsc_timer.dtsi @@ -1,6 +1,7 @@ / { tsc-timer { compatible = "x86,tsc-timer"; + clock-frequency = <CONFIG_X86_TSC_TIMER_FREQ>; u-boot,dm-pre-reloc; }; };
applied to u-boot-x86, thanks!
Hi Simon,
Looks you reviewed the 2nd patch but not this one.
And there are other 2 patches related to x86 rom build. Could you please take a look?
Regards, Bin
Bin Meng
