[U-Boot] [PATCH v2] arm: socfpga: Fixes: Rename CONFIG_SPL_RESET_SUPPORT to CONFIG_SPL_DM_RESET
Commit bfc6bae8fa1f2d8a9c51548767b02f1a1e0ffe52
This commit rename CONFIG_SPL_RESET_SUPPORT to CONFIG_SPL_DM_RESET. Update with new CONFIG name.
Signed-off-by: Ley Foon Tan ley.foon.tan@intel.com Acked-by: Marek Vasut marex@denx.de
--- v2: - Rename commit title, add "Fixes:" tag - Add Acked-by from Marek --- arch/arm/Kconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 35b6ea2..4c60538 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -754,6 +754,7 @@ config ARCH_SOCFPGA select DM_SERIAL select ENABLE_ARM_SOC_BOOT0_HOOK if TARGET_SOCFPGA_GEN5 || TARGET_SOCFPGA_ARRIA10 select OF_CONTROL + select SPL_DM_RESET select SPL_LIBCOMMON_SUPPORT select SPL_LIBDISK_SUPPORT select SPL_LIBGENERIC_SUPPORT @@ -762,7 +763,6 @@ config ARCH_SOCFPGA select SPL_OF_CONTROL select SPL_SERIAL_SUPPORT select SPL_DM_SERIAL - select SPL_RESET_SUPPORT select SPL_SPI_FLASH_SUPPORT if SPL_SPI_SUPPORT select SPL_SPI_SUPPORT if DM_SPI select SPL_WATCHDOG_SUPPORT
v2:
- select SPL_DM_RESET select SPL_LIBCOMMON_SUPPORT select SPL_LIBDISK_SUPPORT select SPL_LIBGENERIC_SUPPORT
Applied, thanks
v2:
This broke Arria10, dropped
arm: + socfpga_arria10 +arch/arm/dts/socfpga_arria10_socdk_sdmmc.dtb: Warning (avoid_unnecessary_addr_size): /clocks: unnecessary #address-cells/#size-cells without "ranges" or child "reg" property +drivers/built-in.o: In function `ns16550_serial_probe': +drivers/serial/ns16550.c:378: undefined reference to `reset_get_bulk' +drivers/serial/ns16550.c:380: undefined reference to `reset_deassert_bulk' +make[2]: *** [spl/u-boot-spl] Error 1 +make[1]: *** [spl/u-boot-spl] Error 2 +make: *** [sub-make] Error 2
Can you please at least do basic compile tests before submitting the patches ?
Ley Foon Tan
