[PATCH v1] arch: meson: add helper for boot partitition flashing
Amlogic uses its own scheme for flashing bootloader partition. This patch adds helper function that can be used by Amlogic BootROM and custom protocols.
Signed-off-by: Alexey Romanov avromanov@salutedevices.com --- arch/arm/include/asm/arch-meson/nand.h | 88 ++++++++++++++++ arch/arm/mach-meson/Kconfig | 16 +++ arch/arm/mach-meson/Makefile | 2 +- arch/arm/mach-meson/nand.c | 133 +++++++++++++++++++++++++ 4 files changed, 238 insertions(+), 1 deletion(-) create mode 100644 arch/arm/include/asm/arch-meson/nand.h create mode 100644 arch/arm/mach-meson/nand.c
diff --git a/arch/arm/include/asm/arch-meson/nand.h b/arch/arm/include/asm/arch-meson/nand.h new file mode 100644 index 0000000000..5297d79dd6 --- /dev/null +++ b/arch/arm/include/asm/arch-meson/nand.h @@ -0,0 +1,88 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * (C) Copyright 2023 SaluteDevices, Inc. + */ + +#ifndef __MESON_NAND_H__ +#define __MESON_NAND_H__ + +#include <linux/mtd/mtd.h> + +#define BOOT_LOADER "bootloader" +#define BOOT_BL2 "bl2" +#define BOOT_SPL "spl" +#define BOOT_TPL "tpl" +#define BOOT_FIP "fip" + +#define BL2_COPY_NUM (CONFIG_MESON_BL2_COPY_NUM) +#define TPL_COPY_NUM (CONFIG_MESON_TPL_COPY_NUM) +#define BOOT_TOTAL_PAGES 1024 +#define TPL_SIZE_PER_COPY 0x200000 +#define BL2_SIZE (64 * 1024) + +struct meson_spi_nand_info_page { + char magic[8]; /* Magic header of info page. */ + /* Info page version, +1 when you update this struct. */ + u8 version; /* 1 for now. */ + u8 mode; /* 1 discrete, 0 compact. */ + u8 bl2_num; /* bl2 copy number. */ + u8 fip_num; /* fip copy number. */ + union { + struct { + u8 rd_max; /* spi nand max read io. */ + u8 oob_offset; /* User bytes offset. */ + u8 planes_per_lun; + u8 rsv; + u32 fip_start; /* Start pages. */ + u32 fip_pages; /* Pages per fip. */ + u32 page_size; /* spi nand page size (bytes). */ + u32 page_per_blk; /* Page number per block. */ + u32 oob_size; /* Valid oob size (bytes). */ + u32 bbt_start; /* BBT start pages. */ + u32 bbt_valid; /* BBT valid offset pages. */ + u32 bbt_size; /* BBT occupied bytes. */ + } __packed spinand; /* spi nand. */ + struct { + u32 reserved; + } emmc; + } dev; +} __packed; + +/** + * meson_bootloader_copy_num - get bootloader numbers of copies + * + * @part_name: partition name + * @return: number of copies of the specified bootloader partition + */ +int meson_bootloader_copy_num(const char *part_name); + +/** + * meson_bootloader_copy_size - get bootloader copy size in bytes + * + * @mtd: nand mtd instance + * @part_name: partition name + * @return: bootloader partition (fox example, BL2) copy size in bytes + */ +int meson_bootloader_copy_size(struct mtd_info *mtd, const char *part_name); + +/** + * meson_bootloader_write_info_pages - write bootloader metadata to nand + * + * @return: zero on success or error code on failure. + */ +int meson_bootloader_write_info_pages(void); + +/** + * meson_bootloader_write_bl2 - write bl2 to nand + * + * @mtd: nand mtd instance + * @buff: buffer to read from + * @offset: offset in flash + * @size: buffer length + * @flags: flags modifying the behaviour of the write to NAND + * @return: zero on success or error code on failure + */ +int meson_bootloader_write_bl2(struct mtd_info *mtd, void *buff, u32 offset, + size_t size, int flags); + +#endif diff --git a/arch/arm/mach-meson/Kconfig b/arch/arm/mach-meson/Kconfig index d6c8905806..7b75ed9a2b 100644 --- a/arch/arm/mach-meson/Kconfig +++ b/arch/arm/mach-meson/Kconfig @@ -96,4 +96,20 @@ config SYS_CONFIG_NAME Based on this option include/configs/<CONFIG_SYS_CONFIG_NAME>.h header will be used for board configuration.
+config MESON_BL2_COPY_NUM + depends on ADNL || FASTBOOT_FLASH + int "Number of BL2 copies written to storage" + default 0 + help + The ADNL / fastboot protocol writes several copies of BL2 bootloader + during firmware update process. + +config MESON_TPL_COPY_NUM + depends on ADNL || FASTBOOT_FLASH + int "Number of TPL copies written to storage" + default 0 + help + The ADNL / fastboot protocol writes several copies of TPL bootloader + during firmware update process. + endif diff --git a/arch/arm/mach-meson/Makefile b/arch/arm/mach-meson/Makefile index 535b0878b9..460626bca9 100644 --- a/arch/arm/mach-meson/Makefile +++ b/arch/arm/mach-meson/Makefile @@ -2,7 +2,7 @@ # # Copyright (c) 2016 Beniamino Galvani b.galvani@gmail.com
-obj-y += board-common.o sm.o board-info.o +obj-y += board-common.o sm.o board-info.o nand.o obj-$(CONFIG_MESON_GX) += board-gx.o obj-$(CONFIG_MESON_AXG) += board-axg.o obj-$(CONFIG_MESON_G12A) += board-g12a.o diff --git a/arch/arm/mach-meson/nand.c b/arch/arm/mach-meson/nand.c new file mode 100644 index 0000000000..29c10438a1 --- /dev/null +++ b/arch/arm/mach-meson/nand.c @@ -0,0 +1,133 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2023 SaluteDevices, Inc. + */ + +#include <nand.h> +#include <asm/arch/nand.h> +#include <linux/mtd/nand.h> +#include <linux/sizes.h> + +#define SPINAND_MAGIC "AMLIFPG" +#define SPINAND_INFO_VER 1 +#define NAND_RSV_BLOCK_NUM 48 + +int meson_bootloader_copy_num(const char *part_name) +{ + if (!strcmp(part_name, BOOT_BL2) || + !strcmp(part_name, BOOT_SPL)) + return BL2_COPY_NUM; + + if (!strcmp(part_name, BOOT_TPL) || + !strcmp(part_name, BOOT_FIP)) + return TPL_COPY_NUM; + + return -EINVAL; +} + +int meson_bootloader_copy_size(struct mtd_info *mtd, const char *part_name) +{ + if (!strcmp(part_name, BOOT_BL2) || + !strcmp(part_name, BOOT_SPL)) + return mtd->writesize * (BOOT_TOTAL_PAGES / BL2_COPY_NUM); + + if (!strcmp(part_name, BOOT_TPL) || + !strcmp(part_name, BOOT_FIP)) + return TPL_SIZE_PER_COPY; + + return -EINVAL; +} + +int meson_bootloader_write_info_pages(void) +{ + struct meson_spi_nand_info_page info_page; + struct nand_device *nand_dev; + struct mtd_info *mtd; + u32 page_per_blk; + size_t retlen; + int ret, page; + + mtd = get_mtd_device_nm(BOOT_LOADER); + if (IS_ERR_OR_NULL(mtd)) + return -ENODEV; + + if (mtd->writesize != SZ_2K) { + ret = -EINVAL; + goto out; + } + + if (!mtd->parent) { + ret = -ENODEV; + goto out; + } + + nand_dev = mtd_to_nanddev(mtd->parent); + if (!nand_dev) { + ret = -ENODEV; + goto out; + } + + page_per_blk = mtd->erasesize / mtd->writesize; + memset(&info_page, 0, sizeof(info_page)); + memcpy(info_page.magic, SPINAND_MAGIC, sizeof(info_page.magic)); + info_page.version = SPINAND_INFO_VER; + /* DISCRETE only */ + info_page.mode = 1; + info_page.bl2_num = BL2_COPY_NUM; + info_page.fip_num = TPL_COPY_NUM; + info_page.dev.spinand.rd_max = 2; + info_page.dev.spinand.fip_start = BOOT_TOTAL_PAGES + NAND_RSV_BLOCK_NUM * page_per_blk; + info_page.dev.spinand.fip_pages = TPL_SIZE_PER_COPY / mtd->writesize; + info_page.dev.spinand.page_size = mtd->writesize; + info_page.dev.spinand.page_per_blk = page_per_blk; + info_page.dev.spinand.oob_size = mtd->oobsize; + info_page.dev.spinand.oob_offset = 0; + info_page.dev.spinand.bbt_start = 0; + info_page.dev.spinand.bbt_valid = 0; + info_page.dev.spinand.bbt_size = 0; + info_page.dev.spinand.planes_per_lun = nand_dev->memorg.planes_per_lun; + + for (page = 0; page < BOOT_TOTAL_PAGES; page++) { + if (page % 128 != ((BL2_SIZE / mtd->writesize) - 1)) + continue; + + ret = mtd_write(mtd, (page + 1) * mtd->writesize, + sizeof(info_page), &retlen, + (u8 *)&info_page); + if (ret) + goto out; + } + +out: + put_mtd_device(mtd); + + return ret; +} + +int meson_bootloader_write_bl2(struct mtd_info *mtd, void *buff, u32 offset, + size_t size, int flags) +{ + loff_t off = offset; + size_t retlen; + size_t sz_write = SZ_2K; + int write_cnt = DIV_ROUND_UP(size, sz_write); + u64 size_per_copy = meson_bootloader_copy_size(mtd, BOOT_BL2); + int i; + + for (i = 0; i < write_cnt; i++) { + int ret; + size_t len = min(sz_write, (size - i * sz_write)); + + ret = nand_write_skip_bad(mtd, off, &len, &retlen, + offset + size_per_copy, + (buff + i * sz_write), flags); + if (ret) + return ret; + + off += mtd->writesize; + if (retlen > len) + off += (retlen - len); + } + + return 0; +}
Alexey Romanov
