[U-Boot] Please pull u-boot-mmc.git
The following changes since commit 0a6deb3251a68b5be640ab1b848ca67e906b75ce:
Merge branch 'agust@denx.de' of git://git.denx.de/u-boot-staging (2012-04-30 18:19:28 +0200)
git://www.denx.de/git/u-boot-mmc.git master
Andreas Bießmann (1): include/mmc.h: remove struct mmc_csd
Dirk Behme (1): mmc: fsl_esdhc: Poll until card is not busy anymore
Grazvydas Ignotas (3): mmc: omap: follow TRM procedure to power on cards mmc: omap: improve stat wait message mmc: omap: handle controller errors properly
Jaehoon Chung (4): mmc: sdhci: add the quirk for broken r1b response mmc: add the quirk to use the sdhci for samsung-soc mmc: support the sdhci instead of s5p_mmc for samsung-soc ARM: SAMSUNG: support sdhci controller
Marek Vasut (1): i.MX28: Lower the amount of blocks transfered in one DMA cycle
Łukasz Majewski (1): mmc:fix: Set mmc width according to MMC host capabilities
arch/arm/include/asm/arch-exynos/mmc.h | 93 +++--- arch/arm/include/asm/arch-s5pc1xx/mmc.h | 93 +++--- drivers/mmc/Makefile | 2 +- drivers/mmc/fsl_esdhc.c | 39 +++- drivers/mmc/mmc.c | 4 +- drivers/mmc/mxsmmc.c | 2 +- drivers/mmc/omap_hsmmc.c | 55 +++- drivers/mmc/s5p_mmc.c | 490 ------------------------------- drivers/mmc/s5p_sdhci.c | 98 ++++++ drivers/mmc/sdhci.c | 24 ++ include/configs/origen.h | 7 +- include/configs/s5p_goni.h | 7 +- include/configs/s5pc210_universal.h | 7 +- include/configs/smdk5250.h | 3 +- include/configs/smdkv310.h | 7 +- include/configs/trats.h | 3 +- include/fsl_esdhc.h | 4 +- include/mmc.h | 53 +---- include/sdhci.h | 7 + 19 files changed, 339 insertions(+), 659 deletions(-) delete mode 100644 drivers/mmc/s5p_mmc.c create mode 100644 drivers/mmc/s5p_sdhci.c
Dear Andy Fleming,
In message 1336590428-7152-1-git-send-email-afleming@freescale.com you wrote:
The following changes since commit 0a6deb3251a68b5be640ab1b848ca67e906b75= ce:
Merge branch 'agust@denx.de' of git://git.denx.de/u-boot-staging (2012-= 04-30 18:19:28 +0200)
Andreas Bie=C3=9Fmann (1): include/mmc.h: remove struct mmc_csd
=C5=81ukasz Majewski (1): mmc:fix: Set mmc width according to MMC host capabilities
arch/arm/include/asm/arch-exynos/mmc.h | 93 +++--- arch/arm/include/asm/arch-s5pc1xx/mmc.h | 93 +++--- drivers/mmc/Makefile | 2 +- drivers/mmc/fsl_esdhc.c | 39 +++- drivers/mmc/mmc.c | 4 +- drivers/mmc/mxsmmc.c | 2 +- drivers/mmc/omap_hsmmc.c | 55 +++- drivers/mmc/s5p_mmc.c | 490 -------------------------=
Applied, thanks.
Andy Fleming
