[U-Boot-Users] [PATCH] 85xx: expose cpu identification
The current cpu identification code is used just to return the name of the processor at boot. There are some other locations that the name is useful (device tree setup). Expose the functionality to other bits of code.
Also, drop the 'E' suffix and add it on by looking at the SVR version when we print this out. This is mainly to allow the most flexible use of the name. The device tree code tends to not care about the 'E' suffix.
Signed-off-by: Kumar Gala galak@kernel.crashing.org ---
Reworked and dropped the flags idea and just use SVR to determine the 'E' bit. At this point he HW guys will now break the convention of using the particular bit we test to determine if we have crypto or not.
- k
cpu/mpc85xx/cpu.c | 76 ++++++++++++++++++++++-------------------- include/asm-ppc/processor.h | 11 ++++++ 2 files changed, 51 insertions(+), 36 deletions(-)
diff --git a/cpu/mpc85xx/cpu.c b/cpu/mpc85xx/cpu.c index 58d23f4..d585e87 100644 --- a/cpu/mpc85xx/cpu.c +++ b/cpu/mpc85xx/cpu.c @@ -32,38 +32,41 @@
DECLARE_GLOBAL_DATA_PTR;
-struct cpu_type { - char name[15]; - u32 soc_ver; +struct cpu_type cpu_type_list [] = { + CPU_TYPE_ENTRY(8533, 8533), + CPU_TYPE_ENTRY(8533, 8533_E), + CPU_TYPE_ENTRY(8540, 8540), + CPU_TYPE_ENTRY(8541, 8541), + CPU_TYPE_ENTRY(8541, 8541_E), + CPU_TYPE_ENTRY(8543, 8543), + CPU_TYPE_ENTRY(8543, 8543_E), + CPU_TYPE_ENTRY(8544, 8544), + CPU_TYPE_ENTRY(8544, 8544_E), + CPU_TYPE_ENTRY(8545, 8545), + CPU_TYPE_ENTRY(8545, 8545_E), + CPU_TYPE_ENTRY(8547, 8547_E), + CPU_TYPE_ENTRY(8548, 8548), + CPU_TYPE_ENTRY(8548, 8548_E), + CPU_TYPE_ENTRY(8555, 8555), + CPU_TYPE_ENTRY(8555, 8555_E), + CPU_TYPE_ENTRY(8560, 8560), + CPU_TYPE_ENTRY(8567, 8567), + CPU_TYPE_ENTRY(8567, 8567_E), + CPU_TYPE_ENTRY(8568, 8568), + CPU_TYPE_ENTRY(8568, 8568_E), + CPU_TYPE_ENTRY(8572, 8572), + CPU_TYPE_ENTRY(8572, 8572_E), };
-#define CPU_TYPE_ENTRY(x) {#x, SVR_##x} +struct cpu_type *identify_cpu(uint ver) +{ + int i; + for (i = 0; i < ARRAY_SIZE(cpu_type_list); i++) + if (cpu_type_list[i].soc_ver == ver) + return &cpu_type_list[i];
-struct cpu_type cpu_type_list [] = { - CPU_TYPE_ENTRY(8533), - CPU_TYPE_ENTRY(8533_E), - CPU_TYPE_ENTRY(8540), - CPU_TYPE_ENTRY(8541), - CPU_TYPE_ENTRY(8541_E), - CPU_TYPE_ENTRY(8543), - CPU_TYPE_ENTRY(8543_E), - CPU_TYPE_ENTRY(8544), - CPU_TYPE_ENTRY(8544_E), - CPU_TYPE_ENTRY(8545), - CPU_TYPE_ENTRY(8545_E), - CPU_TYPE_ENTRY(8547_E), - CPU_TYPE_ENTRY(8548), - CPU_TYPE_ENTRY(8548_E), - CPU_TYPE_ENTRY(8555), - CPU_TYPE_ENTRY(8555_E), - CPU_TYPE_ENTRY(8560), - CPU_TYPE_ENTRY(8567), - CPU_TYPE_ENTRY(8567_E), - CPU_TYPE_ENTRY(8568), - CPU_TYPE_ENTRY(8568_E), - CPU_TYPE_ENTRY(8572), - CPU_TYPE_ENTRY(8572_E), -}; + return NULL; +}
int checkcpu (void) { @@ -74,7 +77,7 @@ int checkcpu (void) uint fam; uint ver; uint major, minor; - int i; + struct cpu_type *cpu; #ifdef CONFIG_DDR_CLK_FREQ volatile ccsr_gur_t *gur = (void *)(CFG_MPC85xx_GUTS_ADDR); u32 ddr_ratio = ((gur->porpllsr) & 0x00003e00) >> 9; @@ -89,14 +92,15 @@ int checkcpu (void)
puts("CPU: ");
- for (i = 0; i < ARRAY_SIZE(cpu_type_list); i++) - if (cpu_type_list[i].soc_ver == ver) { - puts(cpu_type_list[i].name); - break; - } + cpu = identify_cpu(ver); + if (cpu) { + puts(cpu->name);
- if (i == ARRAY_SIZE(cpu_type_list)) + if (svr & 0x80000) + puts("E"); + } else { puts("Unknown"); + }
printf(", Version: %d.%d, (0x%08x)\n", major, minor, svr);
diff --git a/include/asm-ppc/processor.h b/include/asm-ppc/processor.h index 8bdfb9d..61a0d05 100644 --- a/include/asm-ppc/processor.h +++ b/include/asm-ppc/processor.h @@ -960,6 +960,17 @@ n: #define SR15 15
#ifndef __ASSEMBLY__ + +struct cpu_type { + char name[15]; + u32 soc_ver; +}; + +struct cpu_type *identify_cpu(uint ver); + +#define CPU_TYPE_ENTRY(n, v) \ + { .name = #n, .soc_ver = SVR_##v, } + #ifndef CONFIG_MACH_SPECIFIC extern int _machine; extern int have_of;
Kumar Gala
