[U-Boot] [PATCH v7 10/21] sf: Remove spansion_s25fss_disable_4KB_erase
In spansion S25FS-S family the physical sectors are grouped as normal and parameter sectors. Parameter sectors are 4kB in size with 8 set located at the bottom or top address of a device. Normal sectors are similar to other flash family with sizes of 64kB or 32 kB.
To erase whole flash using sector erase(D8h or DCh) won't effect the parameter sectors, so in order to erase these we must use 4K sector erase commands (20h or 21h) separately.
So better to erase the whole flash using 4K sector erase instead of detecting these family parts again and do two different erase operations.
For this: - Removed spansion_s25fss_disable_4KB_erase code - Add SECT_4K for S25FS512S chip
Cc: Yunhui Cui yunhui.cui@nxp.com Cc: Bin Meng bmeng.cn@gmail.com Cc: York Sun york.sun@nxp.com Cc: Vignesh R vigneshr@ti.com Cc: Mugunthan V N mugunthanvnm@ti.com Cc: Michal Simek michal.simek@xilinx.com Cc: Michael Trimarchi michael@amarulasolutions.com Cc: Siva Durga Prasad Paladugu sivadur@xilinx.com Signed-off-by: Jagan Teki jagan@openedev.com Reviewed-by: Simon Glass sjg@chromium.org Reviewed-by: Jagan Teki jagan@openedev.com --- Changes for v7: - Add SECT_4K S25FS512S
drivers/mtd/spi/sf_internal.h | 6 ---- drivers/mtd/spi/sf_params.c | 2 +- drivers/mtd/spi/spi_flash.c | 79 ------------------------------------------- 3 files changed, 1 insertion(+), 86 deletions(-)
diff --git a/drivers/mtd/spi/sf_internal.h b/drivers/mtd/spi/sf_internal.h index cbed6e8..6a39cdd 100644 --- a/drivers/mtd/spi/sf_internal.h +++ b/drivers/mtd/spi/sf_internal.h @@ -98,12 +98,6 @@ int sst_write_bp(struct spi_flash *flash, u32 offset, size_t len, const void *buf); #endif
-#ifdef CONFIG_SPI_FLASH_SPANSION -/* Used for Spansion S25FS-S family flash only. */ -#define CMD_SPANSION_RDAR 0x65 /* Read any device register */ -#define CMD_SPANSION_WRAR 0x71 /* Write any device register */ -#endif - #define JEDEC_MFR(info) ((info)->id[0]) #define JEDEC_ID(info) (((info)->id[1]) << 8 | ((info)->id[2])) #define JEDEC_EXT(info) (((info)->id[3]) << 8 | ((info)->id[4])) diff --git a/drivers/mtd/spi/sf_params.c b/drivers/mtd/spi/sf_params.c index 6157e29..7b9e5ef 100644 --- a/drivers/mtd/spi/sf_params.c +++ b/drivers/mtd/spi/sf_params.c @@ -99,7 +99,7 @@ const struct spi_flash_info spi_flash_ids[] = { {"S25FL256S_256K", INFO(0x010219, 0x4d00, 256 * 1024, 128, RD_FULL | WR_QPP) }, {"S25FL256S_64K", INFO(0x010219, 0x4d01, 64 * 1024, 512, RD_FULL | WR_QPP) }, {"S25FS256S_64K", INFO6(0x010219, 0x4d0181, 64 * 1024, 512, RD_FULL | WR_QPP | SECT_4K) }, - {"S25FS512S", INFO(0x010220, 0x4D00, 128 * 1024, 512, RD_FULL | WR_QPP) }, + {"S25FS512S", INFO(0x010220, 0x4D00, 128 * 1024, 512, RD_FULL | WR_QPP | SECT_4K) }, {"S25FL512S_256K", INFO(0x010220, 0x4d00, 256 * 1024, 256, RD_FULL | WR_QPP) }, {"S25FL512S_64K", INFO(0x010220, 0x4d01, 64 * 1024, 1024, RD_FULL | WR_QPP) }, {"S25FL512S_512K", INFO(0x010220, 0x4f00, 256 * 1024, 256, RD_FULL | WR_QPP) }, diff --git a/drivers/mtd/spi/spi_flash.c b/drivers/mtd/spi/spi_flash.c index 9430424..b126a21 100644 --- a/drivers/mtd/spi/spi_flash.c +++ b/drivers/mtd/spi/spi_flash.c @@ -999,43 +999,6 @@ int spi_flash_decode_fdt(const void *blob, struct spi_flash *flash) } #endif /* CONFIG_IS_ENABLED(OF_CONTROL) */
-#ifdef CONFIG_SPI_FLASH_SPANSION -static int spansion_s25fss_disable_4KB_erase(struct spi_slave *spi) -{ - u8 cmd[4]; - u32 offset = 0x800004; /* CR3V register offset */ - u8 cr3v; - int ret; - - cmd[0] = CMD_SPANSION_RDAR; - cmd[1] = offset >> 16; - cmd[2] = offset >> 8; - cmd[3] = offset >> 0; - - ret = spi_flash_cmd_read(spi, cmd, 4, &cr3v, 1); - if (ret) - return -EIO; - /* CR3V bit3: 4-KB Erase */ - if (cr3v & 0x8) - return 0; - - cmd[0] = CMD_SPANSION_WRAR; - cr3v |= 0x8; - ret = spi_flash_cmd_write(spi, cmd, 4, &cr3v, 1); - if (ret) - return -EIO; - - cmd[0] = CMD_SPANSION_RDAR; - ret = spi_flash_cmd_read(spi, cmd, 4, &cr3v, 1); - if (ret) - return -EIO; - if (!(cr3v & 0x8)) - return -EFAULT; - - return 0; -} -#endif - int spi_flash_scan(struct spi_flash *flash) { struct spi_slave *spi = flash->spi; @@ -1046,48 +1009,6 @@ int spi_flash_scan(struct spi_flash *flash) if (IS_ERR_OR_NULL(info)) return -ENOENT;
-#ifdef CONFIG_SPI_FLASH_SPANSION - /* - * The S25FS-S family physical sectors may be configured as a - * hybrid combination of eight 4-kB parameter sectors - * at the top or bottom of the address space with all - * but one of the remaining sectors being uniform size. - * The Parameter Sector Erase commands (20h or 21h) must - * be used to erase the 4-kB parameter sectors individually. - * The Sector (uniform sector) Erase commands (D8h or DCh) - * must be used to erase any of the remaining - * sectors, including the portion of highest or lowest address - * sector that is not overlaid by the parameter sectors. - * The uniform sector erase command has no effect on parameter sectors. - */ - if ((JEDEC_ID(info) == 0x0219 || (JEDEC_ID(info) == 0x0220)) && - (JEDEC_EXT(info) & 0xff00) == 0x4d00) { - int ret; - u8 idcode[5]; - u8 id[6]; - - /* Read the ID codes again, 5 bytes */ - ret = spi_flash_cmd(flash->spi, CMD_READ_ID, idcode, sizeof(idcode)); - if (ret) - return -EIO; - - /* Read the ID codes again, 6 bytes */ - ret = spi_flash_cmd(flash->spi, CMD_READ_ID, id, sizeof(id)); - if (ret) - return -EIO; - - ret = memcmp(id, idcode, 5); - if (ret) - return -EIO; - - /* 0x81: S25FS-S family 0x80: S25FL-S family */ - if (id[5] == 0x81) { - ret = spansion_s25fss_disable_4KB_erase(spi); - if (ret) - return ret; - } - } -#endif /* Flash powers up read-only, so clear BP# bits */ if (JEDEC_MFR(info) == SPI_FLASH_CFI_MFR_ATMEL || JEDEC_MFR(info) == SPI_FLASH_CFI_MFR_MACRONIX ||
For this:
Changes for v7:
Applied to u-boot-spi/master
thanks!
Jagan Teki
