[PATCH v1] imx: imx8qm: imx8qm_mek switch to binman
Signed-off-by: Oliver Graute oliver.graute@kococonnector.com --- arch/arm/dts/fsl-imx8qm-mek-u-boot.dtsi | 2 ++ arch/arm/mach-imx/imx8/Kconfig | 1 + board/freescale/imx8qm_mek/README | 2 +- board/freescale/imx8qm_mek/imximage.cfg | 2 +- configs/imx8qm_mek_defconfig | 2 ++ 5 files changed, 7 insertions(+), 2 deletions(-)
diff --git a/arch/arm/dts/fsl-imx8qm-mek-u-boot.dtsi b/arch/arm/dts/fsl-imx8qm-mek-u-boot.dtsi index a95209e141..eefdccf992 100644 --- a/arch/arm/dts/fsl-imx8qm-mek-u-boot.dtsi +++ b/arch/arm/dts/fsl-imx8qm-mek-u-boot.dtsi @@ -3,6 +3,8 @@ * Copyright 2018, 2021 NXP */
+#include "imx8qm-u-boot.dtsi" + &{/imx8qm-pm} {
u-boot,dm-spl; diff --git a/arch/arm/mach-imx/imx8/Kconfig b/arch/arm/mach-imx/imx8/Kconfig index 23a7fcf361..4ccbabf506 100644 --- a/arch/arm/mach-imx/imx8/Kconfig +++ b/arch/arm/mach-imx/imx8/Kconfig @@ -68,6 +68,7 @@ config TARGET_GIEDI
config TARGET_IMX8QM_MEK bool "Support i.MX8QM MEK board" + select BINMAN select BOARD_LATE_INIT select IMX8QM select FSL_CAAM diff --git a/board/freescale/imx8qm_mek/README b/board/freescale/imx8qm_mek/README index 570ed7e210..b1a4c6cc82 100644 --- a/board/freescale/imx8qm_mek/README +++ b/board/freescale/imx8qm_mek/README @@ -40,7 +40,7 @@ And copy the following firmwares to U-Boot folder: Build U-Boot ============ $ make imx8qm_mek_defconfig -$ make flash.bin +$ make
Flash the binary into the SD card ================================= diff --git a/board/freescale/imx8qm_mek/imximage.cfg b/board/freescale/imx8qm_mek/imximage.cfg index 71612678c9..46ca3bf817 100644 --- a/board/freescale/imx8qm_mek/imximage.cfg +++ b/board/freescale/imx8qm_mek/imximage.cfg @@ -5,7 +5,7 @@
/* Boot from SD, sector size 0x400 */ -BOOT_FROM SD 0x400 +BOOT_FROM sd /* SoC type IMX8QM */ SOC_TYPE IMX8QM /* Append seco container image */ diff --git a/configs/imx8qm_mek_defconfig b/configs/imx8qm_mek_defconfig index b973b809be..25b51cf1ec 100644 --- a/configs/imx8qm_mek_defconfig +++ b/configs/imx8qm_mek_defconfig @@ -23,6 +23,8 @@ CONFIG_SYS_LOAD_ADDR=0x80280000 CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x80200000 CONFIG_REMAKE_ELF=y +CONFIG_FIT=y +CONFIG_FIT_EXTERNAL_OFFSET=0x3000 CONFIG_OF_BOARD_SETUP=y CONFIG_OF_SYSTEM_SETUP=y CONFIG_BOOTDELAY=3
- Copyright 2018, 2021 NXP
I think the build system would automatically include this. Please correct if I am wrong.
&{/imx8qm-pm} {
- select BINMAN select BOARD_LATE_INIT select IMX8QM select FSL_CAAM
Why update this?
Regards, Peng.
*/ +#include "imx8qm-u-boot.dtsi"
That's not the case if I remove the include I run into following error:
make[1]: Für das Ziel „SPL“ ist nichts zu tun. BINMAN all binman: Device tree 'u-boot.dtb' does not have a 'binman' node Makefile:1109: recipe for target 'all' failed make: *** [all] Error 1
&{/imx8qm-pm} { u-boot,dm-spl; diff --git a/arch/arm/mach-imx/imx8/Kconfig b/arch/arm/mach-imx/imx8/Kconfig index 23a7fcf361..4ccbabf506 100644 --- a/arch/arm/mach-imx/imx8/Kconfig +++ b/arch/arm/mach-imx/imx8/Kconfig @@ -68,6 +68,7 @@ config TARGET_GIEDI config TARGET_IMX8QM_MEK bool "Support i.MX8QM MEK board"
diff --git a/board/freescale/imx8qm_mek/README b/board/freescale/imx8qm_mek/README index 570ed7e210..b1a4c6cc82 100644 --- a/board/freescale/imx8qm_mek/README +++ b/board/freescale/imx8qm_mek/README @@ -40,7 +40,7 @@ And copy the following firmwares to U-Boot folder: Build U-Boot ============ $ make imx8qm_mek_defconfig -$ make flash.bin +$ make Flash the binary into the SD card ================================= diff --git a/board/freescale/imx8qm_mek/imximage.cfg b/board/freescale/imx8qm_mek/imximage.cfg index 71612678c9..46ca3bf817 100644 --- a/board/freescale/imx8qm_mek/imximage.cfg +++ b/board/freescale/imx8qm_mek/imximage.cfg @@ -5,7 +5,7 @@ /* Boot from SD, sector size 0x400 */ -BOOT_FROM SD 0x400 +BOOT_FROM sd
Why update this?
you are right its unneccessary, will fix it in v2
Regards, Peng.
Best Regards,
Oliver
Oliver Graute
Oliver Graute
Peng Fan
