[PATCH 0/4] clk: imx: add i.MX93 CCF driver
This series adds i.MX93 CCF driver, modifed from Linux kernel 6.5-rc2 and adapted for U-Boot.
Patches 2 and 3 come from NXP U-Boot.
A boot log and a dump of the clock tree are available at the following URL: https://pastebin.com/7WbubSXK
Alice Guo (1): arm: dts: imx93: add a per clock for LPUART1
Sébastien Szymanski (2): clk: imx: add i.MX93 CCF driver imx93_evk: defconfig: enable clock driver
Ye Li (1): serial: lpuart: Enable IPG clock
arch/arm/dts/imx93-11x11-evk-u-boot.dtsi | 23 ++ arch/arm/dts/imx93.dtsi | 4 +- board/freescale/imx93_evk/imx93_evk.c | 2 - configs/imx93_11x11_evk_defconfig | 2 + drivers/clk/imx/Kconfig | 18 ++ drivers/clk/imx/Makefile | 2 + drivers/clk/imx/clk-composite-93.c | 142 +++++++++ drivers/clk/imx/clk-fracn-gppll.c | 382 +++++++++++++++++++++++ drivers/clk/imx/clk-gate-93.c | 148 +++++++++ drivers/clk/imx/clk-imx93.c | 343 ++++++++++++++++++++ drivers/clk/imx/clk.h | 42 +++ drivers/serial/serial_lpuart.c | 14 +- include/dt-bindings/clock/imx93-clock.h | 6 +- 13 files changed, 1122 insertions(+), 6 deletions(-) create mode 100644 drivers/clk/imx/clk-composite-93.c create mode 100644 drivers/clk/imx/clk-fracn-gppll.c create mode 100644 drivers/clk/imx/clk-gate-93.c create mode 100644 drivers/clk/imx/clk-imx93.c
Add i.MX93 CCF driver support. Modifed from Linux Kernel v6.5-rc2 and adapted for U-Boot.
Signed-off-by: Sébastien Szymanski sebastien.szymanski@armadeus.com --- drivers/clk/imx/Kconfig | 18 ++ drivers/clk/imx/Makefile | 2 + drivers/clk/imx/clk-composite-93.c | 142 +++++++++ drivers/clk/imx/clk-fracn-gppll.c | 382 ++++++++++++++++++++++++ drivers/clk/imx/clk-gate-93.c | 148 +++++++++ drivers/clk/imx/clk-imx93.c | 343 +++++++++++++++++++++ drivers/clk/imx/clk.h | 42 +++ include/dt-bindings/clock/imx93-clock.h | 6 +- 8 files changed, 1082 insertions(+), 1 deletion(-) create mode 100644 drivers/clk/imx/clk-composite-93.c create mode 100644 drivers/clk/imx/clk-fracn-gppll.c create mode 100644 drivers/clk/imx/clk-gate-93.c create mode 100644 drivers/clk/imx/clk-imx93.c
diff --git a/drivers/clk/imx/Kconfig b/drivers/clk/imx/Kconfig index abcb19ce6d5c..56d893e05799 100644 --- a/drivers/clk/imx/Kconfig +++ b/drivers/clk/imx/Kconfig @@ -89,6 +89,24 @@ config CLK_IMX8MQ help This enables support clock driver for i.MX8MQ platforms.
+config SPL_CLK_IMX93 + bool "SPL clock support for i.MX93" + depends on ARCH_IMX9 && SPL + select SPL_CLK + select SPL_CLK_CCF + select SPL_CLK_COMPOSITE_CCF + help + This enables SPL DM/DTS support for clock driver in i.MX93 + +config CLK_IMX93 + bool "Clock support for i.MX93" + depends on ARCH_IMX9 + select CLK + select CLK_CCF + select CLK_COMPOSITE_CCF + help + This enables support for clock driver in i.MX93 + config SPL_CLK_IMXRT1020 bool "SPL clock support for i.MXRT1020" depends on ARCH_IMXRT && SPL diff --git a/drivers/clk/imx/Makefile b/drivers/clk/imx/Makefile index b9c197f952ea..6d4bcd357143 100644 --- a/drivers/clk/imx/Makefile +++ b/drivers/clk/imx/Makefile @@ -18,6 +18,8 @@ obj-$(CONFIG_$(SPL_TPL_)CLK_IMX8MP) += clk-imx8mp.o clk-pll14xx.o \ clk-composite-8m.o obj-$(CONFIG_$(SPL_TPL_)CLK_IMX8MQ) += clk-imx8mq.o clk-pll14xx.o \ clk-composite-8m.o +obj-$(CONFIG_$(SPL_TPL_)CLK_IMX93) += clk-imx93.o clk-fracn-gppll.o \ + clk-gate-93.o clk-composite-93.o
obj-$(CONFIG_$(SPL_TPL_)CLK_IMXRT1020) += clk-imxrt1020.o obj-$(CONFIG_$(SPL_TPL_)CLK_IMXRT1050) += clk-imxrt1050.o diff --git a/drivers/clk/imx/clk-composite-93.c b/drivers/clk/imx/clk-composite-93.c new file mode 100644 index 000000000000..6d71c0c03ffe --- /dev/null +++ b/drivers/clk/imx/clk-composite-93.c @@ -0,0 +1,142 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2021 NXP + * + * Peng Fan peng.fan@nxp.com + */ +#include <common.h> +#include <log.h> +#include <asm/io.h> +#include <malloc.h> +#include <clk-uclass.h> +#include <dm/device.h> +#include <dm/devres.h> +#include <linux/iopoll.h> +#include <linux/clk-provider.h> +#include <clk.h> +#include "clk.h" +#include <linux/err.h> + +#define TIMEOUT_US 500U + +#define CCM_DIV_SHIFT 0 +#define CCM_DIV_WIDTH 8 +#define CCM_MUX_SHIFT 8 +#define CCM_MUX_MASK 3 +#define CCM_OFF_SHIFT 24 +#define CCM_BUSY_SHIFT 28 + +#define STAT_OFFSET 0x4 +#define AUTHEN_OFFSET 0x30 +#define TZ_NS_SHIFT 9 +#define TZ_NS_MASK BIT(9) + +#define WHITE_LIST_SHIFT 16 + +#define readl_poll_timeout_atomic readl_poll_timeout + +static int imx93_clk_composite_wait_ready(struct clk *clk, void __iomem *reg) +{ + int ret; + u32 val; + + ret = readl_poll_timeout_atomic(reg + STAT_OFFSET, val, !(val & BIT(CCM_BUSY_SHIFT)), + TIMEOUT_US); + if (ret) + pr_err("Slice[%s] busy timeout\n", "TODO"); + + return ret; +} + +static void imx93_clk_composite_gate_endisable(struct clk *clk, int enable) +{ + struct clk_gate *gate = to_clk_gate(clk); + u32 reg; + + reg = readl(gate->reg); + + if (enable) + reg &= ~BIT(gate->bit_idx); + else + reg |= BIT(gate->bit_idx); + + writel(reg, gate->reg); + + imx93_clk_composite_wait_ready(clk, gate->reg); +} + +static int imx93_clk_composite_gate_enable(struct clk *clk) +{ + imx93_clk_composite_gate_endisable(clk, 1); + + return 0; +} + +static int imx93_clk_composite_gate_disable(struct clk *clk) +{ + imx93_clk_composite_gate_endisable(clk, 0); + + return 0; +} + +static const struct clk_ops imx93_clk_composite_gate_ops = { + .enable = imx93_clk_composite_gate_enable, + .disable = imx93_clk_composite_gate_disable, +}; + +struct clk *imx93_clk_composite_flags(const char *name, + const char * const *parent_names, + int num_parents, void __iomem *reg, u32 domain_id, + unsigned long flags) +{ + struct clk *clk = ERR_PTR(-ENOMEM); + struct clk_divider *div = NULL; + struct clk_gate *gate = NULL; + struct clk_mux *mux = NULL; + + mux = kzalloc(sizeof(*mux), GFP_KERNEL); + if (!mux) + goto fail; + + mux->reg = reg; + mux->shift = CCM_MUX_SHIFT; + mux->mask = CCM_MUX_MASK; + mux->num_parents = num_parents; + mux->parent_names = parent_names; + mux->flags = flags; + + div = kzalloc(sizeof(*div), GFP_KERNEL); + if (!div) + goto fail; + + div->reg = reg; + div->shift = CCM_DIV_SHIFT; + div->width = CCM_DIV_WIDTH; + div->flags = CLK_DIVIDER_ROUND_CLOSEST | flags; + + gate = kzalloc(sizeof(*gate), GFP_KERNEL); + if (!gate) + goto fail; + + gate->reg = reg; + gate->bit_idx = CCM_OFF_SHIFT; + gate->flags = flags; + + clk = clk_register_composite(NULL, name, + parent_names, num_parents, + &mux->clk, &clk_mux_ops, + &div->clk, &clk_divider_ops, + &gate->clk, &imx93_clk_composite_gate_ops, + flags); + + if (IS_ERR(clk)) + goto fail; + + return clk; + +fail: + kfree(gate); + kfree(div); + kfree(mux); + return ERR_CAST(clk); +} diff --git a/drivers/clk/imx/clk-fracn-gppll.c b/drivers/clk/imx/clk-fracn-gppll.c new file mode 100644 index 000000000000..9228f279e27d --- /dev/null +++ b/drivers/clk/imx/clk-fracn-gppll.c @@ -0,0 +1,382 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright 2021 NXP + */ + +#include <common.h> +#include <asm/io.h> +#include <malloc.h> +#include <clk-uclass.h> +#include <dm/device.h> +#include <dm/devres.h> +#include <linux/bitfield.h> +#include <linux/bitops.h> +#include <linux/clk-provider.h> +#include <linux/delay.h> +#include <linux/err.h> +#include <linux/iopoll.h> +#include <clk.h> +#include <div64.h> + +#include "clk.h" + +#define UBOOT_DM_CLK_IMX_FRACN_GPPLL "imx_clk_fracn_gppll" + +#define PLL_CTRL 0x0 +#define HW_CTRL_SEL BIT(16) +#define CLKMUX_BYPASS BIT(2) +#define CLKMUX_EN BIT(1) +#define POWERUP_MASK BIT(0) + +#define PLL_ANA_PRG 0x10 +#define PLL_SPREAD_SPECTRUM 0x30 + +#define PLL_NUMERATOR 0x40 +#define PLL_MFN_MASK GENMASK(31, 2) + +#define PLL_DENOMINATOR 0x50 +#define PLL_MFD_MASK GENMASK(29, 0) + +#define PLL_DIV 0x60 +#define PLL_MFI_MASK GENMASK(24, 16) +#define PLL_RDIV_MASK GENMASK(15, 13) +#define PLL_ODIV_MASK GENMASK(7, 0) + +#define PLL_DFS_CTRL(x) (0x70 + (x) * 0x10) + +#define PLL_STATUS 0xF0 +#define LOCK_STATUS BIT(0) + +#define DFS_STATUS 0xF4 + +#define LOCK_TIMEOUT_US 200 + +#define PLL_FRACN_GP(_rate, _mfi, _mfn, _mfd, _rdiv, _odiv) \ + { \ + .rate = (_rate), \ + .mfi = (_mfi), \ + .mfn = (_mfn), \ + .mfd = (_mfd), \ + .rdiv = (_rdiv), \ + .odiv = (_odiv), \ + } + +#define PLL_FRACN_GP_INTEGER(_rate, _mfi, _rdiv, _odiv) \ + { \ + .rate = (_rate), \ + .mfi = (_mfi), \ + .mfn = 0, \ + .mfd = 0, \ + .rdiv = (_rdiv), \ + .odiv = (_odiv), \ + } + +struct clk_fracn_gppll { + struct clk clk; + void __iomem *base; + const struct imx_fracn_gppll_rate_table *rate_table; + int rate_count; + u32 flags; +}; + +/* + * Fvco = (Fref / rdiv) * (MFI + MFN / MFD) + * Fout = Fvco / odiv + * The (Fref / rdiv) should be in range 20MHz to 40MHz + * The Fvco should be in range 2.5Ghz to 5Ghz + */ +static const struct imx_fracn_gppll_rate_table fracn_tbl[] = { + PLL_FRACN_GP(650000000U, 162, 50, 100, 0, 6), + PLL_FRACN_GP(594000000U, 198, 0, 1, 0, 8), + PLL_FRACN_GP(560000000U, 140, 0, 1, 0, 6), + PLL_FRACN_GP(498000000U, 166, 0, 1, 0, 8), + PLL_FRACN_GP(484000000U, 121, 0, 1, 0, 6), + PLL_FRACN_GP(445333333U, 167, 0, 1, 0, 9), + PLL_FRACN_GP(400000000U, 200, 0, 1, 0, 12), + PLL_FRACN_GP(393216000U, 163, 84, 100, 0, 10), + PLL_FRACN_GP(300000000U, 150, 0, 1, 0, 12) +}; + +struct imx_fracn_gppll_clk imx_fracn_gppll = { + .rate_table = fracn_tbl, + .rate_count = ARRAY_SIZE(fracn_tbl), +}; + +/* + * Fvco = (Fref / rdiv) * MFI + * Fout = Fvco / odiv + * The (Fref / rdiv) should be in range 20MHz to 40MHz + * The Fvco should be in range 2.5Ghz to 5Ghz + */ +static const struct imx_fracn_gppll_rate_table int_tbl[] = { + PLL_FRACN_GP_INTEGER(1700000000U, 141, 1, 2), + PLL_FRACN_GP_INTEGER(1400000000U, 175, 1, 3), + PLL_FRACN_GP_INTEGER(900000000U, 150, 1, 4), +}; + +struct imx_fracn_gppll_clk imx_fracn_gppll_integer = { + .rate_table = int_tbl, + .rate_count = ARRAY_SIZE(int_tbl), +}; + +#define to_clk_fracn_gppll(_clk) container_of(_clk, struct clk_fracn_gppll, clk) + +static const struct imx_fracn_gppll_rate_table * +imx_get_pll_settings(struct clk_fracn_gppll *pll, unsigned long rate) +{ + const struct imx_fracn_gppll_rate_table *rate_table = pll->rate_table; + int i; + + for (i = 0; i < pll->rate_count; i++) + if (rate == rate_table[i].rate) + return &rate_table[i]; + + return NULL; +} + +static unsigned long clk_fracn_gppll_round_rate(struct clk *clk, unsigned long rate) +{ + struct clk_fracn_gppll *pll = to_clk_fracn_gppll(clk); + const struct imx_fracn_gppll_rate_table *rate_table = pll->rate_table; + int i; + + /* Assuming rate_table is in descending order */ + for (i = 0; i < pll->rate_count; i++) + if (rate >= rate_table[i].rate) + return rate_table[i].rate; + + /* return minimum supported value */ + return rate_table[pll->rate_count - 1].rate; +} + +static unsigned long clk_fracn_gppll_recalc_rate(struct clk *clk) +{ + struct clk_fracn_gppll *pll = to_clk_fracn_gppll(clk); + const struct imx_fracn_gppll_rate_table *rate_table = pll->rate_table; + u32 pll_numerator, pll_denominator, pll_div; + u32 mfi, mfn, mfd, rdiv, odiv; + u64 fvco = clk_get_parent_rate(clk); + long rate = 0; + int i; + + pll_numerator = readl_relaxed(pll->base + PLL_NUMERATOR); + mfn = FIELD_GET(PLL_MFN_MASK, pll_numerator); + + pll_denominator = readl_relaxed(pll->base + PLL_DENOMINATOR); + mfd = FIELD_GET(PLL_MFD_MASK, pll_denominator); + + pll_div = readl_relaxed(pll->base + PLL_DIV); + mfi = FIELD_GET(PLL_MFI_MASK, pll_div); + + rdiv = FIELD_GET(PLL_RDIV_MASK, pll_div); + odiv = FIELD_GET(PLL_ODIV_MASK, pll_div); + + /* + * Sometimes, the recalculated rate has deviation due to + * the frac part. So find the accurate pll rate from the table + * first, if no match rate in the table, use the rate calculated + * from the equation below. + */ + for (i = 0; i < pll->rate_count; i++) { + if (rate_table[i].mfn == mfn && rate_table[i].mfi == mfi && + rate_table[i].mfd == mfd && rate_table[i].rdiv == rdiv && + rate_table[i].odiv == odiv) + rate = rate_table[i].rate; + } + + if (rate) + return (unsigned long)rate; + + if (!rdiv) + rdiv = rdiv + 1; + + switch (odiv) { + case 0: + odiv = 2; + break; + case 1: + odiv = 3; + break; + default: + break; + } + + if (pll->flags & CLK_FRACN_GPPLL_INTEGER) { + /* Fvco = (Fref / rdiv) * MFI */ + fvco = fvco * mfi; + do_div(fvco, rdiv * odiv); + } else { + /* Fvco = (Fref / rdiv) * (MFI + MFN / MFD) */ + fvco = fvco * mfi * mfd + fvco * mfn; + do_div(fvco, mfd * rdiv * odiv); + } + + return (unsigned long)fvco; +} + +static int clk_fracn_gppll_wait_lock(struct clk_fracn_gppll *pll) +{ + u32 val; + + return readl_poll_timeout(pll->base + PLL_STATUS, val, + val & LOCK_STATUS, LOCK_TIMEOUT_US); +} + +static ulong clk_fracn_gppll_set_rate(struct clk *clk, unsigned long drate) +{ + struct clk_fracn_gppll *pll = to_clk_fracn_gppll(clk); + const struct imx_fracn_gppll_rate_table *rate; + u32 tmp, pll_div, ana_mfn; + int ret; + + rate = imx_get_pll_settings(pll, drate); + + /* Hardware control select disable. PLL is control by register */ + tmp = readl_relaxed(pll->base + PLL_CTRL); + tmp &= ~HW_CTRL_SEL; + writel_relaxed(tmp, pll->base + PLL_CTRL); + + /* Disable output */ + tmp = readl_relaxed(pll->base + PLL_CTRL); + tmp &= ~CLKMUX_EN; + writel_relaxed(tmp, pll->base + PLL_CTRL); + + /* Power Down */ + tmp &= ~POWERUP_MASK; + writel_relaxed(tmp, pll->base + PLL_CTRL); + + /* Disable BYPASS */ + tmp &= ~CLKMUX_BYPASS; + writel_relaxed(tmp, pll->base + PLL_CTRL); + + pll_div = FIELD_PREP(PLL_RDIV_MASK, rate->rdiv) | rate->odiv | + FIELD_PREP(PLL_MFI_MASK, rate->mfi); + writel_relaxed(pll_div, pll->base + PLL_DIV); + if (pll->flags & CLK_FRACN_GPPLL_FRACN) { + writel_relaxed(rate->mfd, pll->base + PLL_DENOMINATOR); + writel_relaxed(FIELD_PREP(PLL_MFN_MASK, rate->mfn), pll->base + PLL_NUMERATOR); + } + + /* Wait for 5us according to fracn mode pll doc */ + udelay(5); + + /* Enable Powerup */ + tmp |= POWERUP_MASK; + writel_relaxed(tmp, pll->base + PLL_CTRL); + + /* Wait Lock */ + ret = clk_fracn_gppll_wait_lock(pll); + if (ret) + return ret; + + /* Enable output */ + tmp |= CLKMUX_EN; + writel_relaxed(tmp, pll->base + PLL_CTRL); + + ana_mfn = readl_relaxed(pll->base + PLL_STATUS); + ana_mfn = FIELD_GET(PLL_MFN_MASK, ana_mfn); + + WARN(ana_mfn != rate->mfn, "ana_mfn != rate->mfn\n"); + + return 0; +} + +static int clk_fracn_gppll_prepare(struct clk *clk) +{ + struct clk_fracn_gppll *pll = to_clk_fracn_gppll(clk); + u32 val; + int ret; + + val = readl_relaxed(pll->base + PLL_CTRL); + if (val & POWERUP_MASK) + return 0; + + val |= CLKMUX_BYPASS; + writel_relaxed(val, pll->base + PLL_CTRL); + + val |= POWERUP_MASK; + writel_relaxed(val, pll->base + PLL_CTRL); + + val |= CLKMUX_EN; + writel_relaxed(val, pll->base + PLL_CTRL); + + ret = clk_fracn_gppll_wait_lock(pll); + if (ret) + return ret; + + val &= ~CLKMUX_BYPASS; + writel_relaxed(val, pll->base + PLL_CTRL); + + return 0; +} + +static int clk_fracn_gppll_unprepare(struct clk *clk) +{ + struct clk_fracn_gppll *pll = to_clk_fracn_gppll(dev_get_clk_ptr(clk->dev)); + u32 val; + + val = readl_relaxed(pll->base + PLL_CTRL); + val &= ~POWERUP_MASK; + writel_relaxed(val, pll->base + PLL_CTRL); + + return 0; +} + +static const struct clk_ops clk_fracn_gppll_ops = { + .enable = clk_fracn_gppll_prepare, + .disable = clk_fracn_gppll_unprepare, + .get_rate = clk_fracn_gppll_recalc_rate, + .set_rate = clk_fracn_gppll_set_rate, + .round_rate = clk_fracn_gppll_round_rate, +}; + +static struct clk *_imx_clk_fracn_gppll(const char *name, const char *parent_name, + void __iomem *base, + const struct imx_fracn_gppll_clk *pll_clk, + u32 pll_flags) +{ + struct clk_fracn_gppll *pll; + struct clk *clk; + int ret; + + pll = kzalloc(sizeof(*pll), GFP_KERNEL); + if (!pll) + return ERR_PTR(-ENOMEM); + + pll->base = base; + pll->rate_table = pll_clk->rate_table; + pll->rate_count = pll_clk->rate_count; + pll->flags = pll_flags; + + clk = &pll->clk; + + ret = clk_register(clk, UBOOT_DM_CLK_IMX_FRACN_GPPLL, + name, parent_name); + if (ret) { + pr_err("%s: failed to register pll %s %d\n", __func__, name, ret); + kfree(pll); + return ERR_PTR(ret); + } + + return clk; +} + +struct clk *imx_clk_fracn_gppll(const char *name, const char *parent_name, void __iomem *base, + const struct imx_fracn_gppll_clk *pll_clk) +{ + return _imx_clk_fracn_gppll(name, parent_name, base, pll_clk, CLK_FRACN_GPPLL_FRACN); +} + +struct clk *imx_clk_fracn_gppll_integer(const char *name, const char *parent_name, + void __iomem *base, + const struct imx_fracn_gppll_clk *pll_clk) +{ + return _imx_clk_fracn_gppll(name, parent_name, base, pll_clk, CLK_FRACN_GPPLL_INTEGER); +} + +U_BOOT_DRIVER(clk_fracn_gppll) = { + .name = UBOOT_DM_CLK_IMX_FRACN_GPPLL, + .id = UCLASS_CLK, + .ops = &clk_fracn_gppll_ops, + .flags = DM_FLAG_PRE_RELOC, +}; diff --git a/drivers/clk/imx/clk-gate-93.c b/drivers/clk/imx/clk-gate-93.c new file mode 100644 index 000000000000..bc8574137137 --- /dev/null +++ b/drivers/clk/imx/clk-gate-93.c @@ -0,0 +1,148 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright 2022 NXP + * + * Peng Fan peng.fan@nxp.com + */ + +#include <common.h> +#include <asm/io.h> +#include <malloc.h> +#include <clk-uclass.h> +#include <dm/device.h> +#include <dm/devres.h> +#include <linux/bug.h> +#include <linux/clk-provider.h> +#include <clk.h> +#include "clk.h" +#include <linux/err.h> + +#define UBOOT_DM_CLK_IMX_GATE93 "imx_clk_gate93" + +#define DIRECT_OFFSET 0x0 + +/* + * 0b000 - LPCG will be OFF in any CPU mode. + * 0b100 - LPCG will be ON in any CPU mode. + */ +#define LPM_SETTING_OFF 0x0 +#define LPM_SETTING_ON 0x4 + +#define LPM_CUR_OFFSET 0x1c + +#define AUTHEN_OFFSET 0x30 +#define CPULPM_EN BIT(2) +#define TZ_NS_SHIFT 9 +#define TZ_NS_MASK BIT(9) + +#define WHITE_LIST_SHIFT 16 + +struct imx93_clk_gate { + struct clk clk; + void __iomem *reg; + u32 bit_idx; + u32 val; + u32 mask; + unsigned int *share_count; +}; + +#define to_imx93_clk_gate(_clk) container_of(_clk, struct imx93_clk_gate, clk) + +static void imx93_clk_gate_do_hardware(struct clk *clk, bool enable) +{ + struct imx93_clk_gate *gate = to_imx93_clk_gate(clk); + u32 val; + + val = readl(gate->reg + AUTHEN_OFFSET); + if (val & CPULPM_EN) { + val = enable ? LPM_SETTING_ON : LPM_SETTING_OFF; + writel(val, gate->reg + LPM_CUR_OFFSET); + } else { + val = readl(gate->reg + DIRECT_OFFSET); + val &= ~(gate->mask << gate->bit_idx); + if (enable) + val |= (gate->val & gate->mask) << gate->bit_idx; + writel(val, gate->reg + DIRECT_OFFSET); + } +} + +static int imx93_clk_gate_enable(struct clk *clk) +{ + struct imx93_clk_gate *gate = to_imx93_clk_gate(clk); + + if (gate->share_count && (*gate->share_count)++ > 0) + return 0; + + imx93_clk_gate_do_hardware(clk, true); + + return 0; +} + +static int imx93_clk_gate_disable(struct clk *clk) +{ + struct imx93_clk_gate *gate = to_imx93_clk_gate(clk); + + if (gate->share_count) { + if (WARN_ON(*gate->share_count == 0)) + return 0; + else if (--(*gate->share_count) > 0) + return 0; + } + + imx93_clk_gate_do_hardware(clk, false); + + return 0; +} + +static ulong imx93_clk_set_rate(struct clk *clk, ulong rate) +{ + struct clk *parent = clk_get_parent(clk); + + if (parent) + return clk_set_rate(parent, rate); + + return -ENODEV; +} + +static const struct clk_ops imx93_clk_gate_ops = { + .enable = imx93_clk_gate_enable, + .disable = imx93_clk_gate_disable, + .get_rate = clk_generic_get_rate, + .set_rate = imx93_clk_set_rate, +}; + +struct clk *imx93_clk_gate(struct device *dev, const char *name, const char *parent_name, + unsigned long flags, void __iomem *reg, u32 bit_idx, u32 val, + u32 mask, u32 domain_id, unsigned int *share_count) +{ + struct imx93_clk_gate *gate; + struct clk *clk; + int ret; + + gate = kzalloc(sizeof(*gate), GFP_KERNEL); + if (!gate) + return ERR_PTR(-ENOMEM); + + gate->reg = reg; + gate->bit_idx = bit_idx; + gate->val = val; + gate->mask = mask; + gate->share_count = share_count; + + clk = &gate->clk; + + ret = clk_register(clk, UBOOT_DM_CLK_IMX_GATE93, name, parent_name); + if (ret) { + kfree(gate); + return ERR_PTR(ret); + } + + return clk; +} + +U_BOOT_DRIVER(clk_gate93) = { + .name = UBOOT_DM_CLK_IMX_GATE93, + .id = UCLASS_CLK, + .ops = &imx93_clk_gate_ops, + .flags = DM_FLAG_PRE_RELOC, +}; diff --git a/drivers/clk/imx/clk-imx93.c b/drivers/clk/imx/clk-imx93.c new file mode 100644 index 000000000000..ce10d7953162 --- /dev/null +++ b/drivers/clk/imx/clk-imx93.c @@ -0,0 +1,343 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright 2021 NXP. + */ + +#include <common.h> +#include <clk.h> +#include <clk-uclass.h> +#include <dm.h> +#include <log.h> +#include <asm/arch/clock.h> +#include <asm/arch/imx-regs.h> +#include <dt-bindings/clock/imx93-clock.h> + +#include "clk.h" + +enum clk_sel { + LOW_SPEED_IO_SEL, + NON_IO_SEL, + FAST_SEL, + AUDIO_SEL, + VIDEO_SEL, + TPM_SEL, + CKO1_SEL, + CKO2_SEL, + MISC_SEL, + MAX_SEL +}; + +static u32 share_count_sai1; +static u32 share_count_sai2; +static u32 share_count_sai3; +static u32 share_count_mub; + +static const char * const a55_core_sels[] = {"a55_alt", "arm_pll"}; +static const char *parent_names[MAX_SEL][4] = { + {"clock-osc-24m", "sys_pll_pfd0_div2", "sys_pll_pfd1_div2", "video_pll"}, + {"clock-osc-24m", "sys_pll_pfd0_div2", "sys_pll_pfd1_div2", "sys_pll_pfd2_div2"}, + {"clock-osc-24m", "sys_pll_pfd0", "sys_pll_pfd1", "sys_pll_pfd2"}, + {"clock-osc-24m", "audio_pll", "video_pll", "clk_ext1"}, + {"clock-osc-24m", "audio_pll", "video_pll", "sys_pll_pfd0"}, + {"clock-osc-24m", "sys_pll_pfd0", "audio_pll", "clk_ext1"}, + {"clock-osc-24m", "sys_pll_pfd0", "sys_pll_pfd1", "audio_pll"}, + {"clock-osc-24m", "sys_pll_pfd0", "sys_pll_pfd1", "video_pll"}, + {"clock-osc-24m", "audio_pll", "video_pll", "sys_pll_pfd2"}, +}; + +static const struct imx93_clk_root { + u32 clk; + char *name; + u32 off; + enum clk_sel sel; + unsigned long flags; +} root_array[] = { + /* a55/m33/bus critical clk for system run */ + { IMX93_CLK_A55_PERIPH, "a55_periph_root", 0x0000, FAST_SEL, CLK_IS_CRITICAL }, + { IMX93_CLK_A55_MTR_BUS, "a55_mtr_bus_root", 0x0080, LOW_SPEED_IO_SEL, CLK_IS_CRITICAL }, + { IMX93_CLK_A55, "a55_alt_root", 0x0100, FAST_SEL, CLK_IS_CRITICAL }, + { IMX93_CLK_M33, "m33_root", 0x0180, LOW_SPEED_IO_SEL, CLK_IS_CRITICAL }, + { IMX93_CLK_BUS_WAKEUP, "bus_wakeup_root", 0x0280, LOW_SPEED_IO_SEL, CLK_IS_CRITICAL }, + { IMX93_CLK_BUS_AON, "bus_aon_root", 0x0300, LOW_SPEED_IO_SEL, CLK_IS_CRITICAL }, + { IMX93_CLK_WAKEUP_AXI, "wakeup_axi_root", 0x0380, FAST_SEL, CLK_IS_CRITICAL }, + { IMX93_CLK_SWO_TRACE, "swo_trace_root", 0x0400, LOW_SPEED_IO_SEL, }, + { IMX93_CLK_M33_SYSTICK, "m33_systick_root", 0x0480, LOW_SPEED_IO_SEL, }, + { IMX93_CLK_FLEXIO1, "flexio1_root", 0x0500, LOW_SPEED_IO_SEL, }, + { IMX93_CLK_FLEXIO2, "flexio2_root", 0x0580, LOW_SPEED_IO_SEL, }, + { IMX93_CLK_LPTMR1, "lptmr1_root", 0x0700, LOW_SPEED_IO_SEL, }, + { IMX93_CLK_LPTMR2, "lptmr2_root", 0x0780, LOW_SPEED_IO_SEL, }, + { IMX93_CLK_TPM2, "tpm2_root", 0x0880, TPM_SEL, }, + { IMX93_CLK_TPM4, "tpm4_root", 0x0980, TPM_SEL, }, + { IMX93_CLK_TPM5, "tpm5_root", 0x0a00, TPM_SEL, }, + { IMX93_CLK_TPM6, "tpm6_root", 0x0a80, TPM_SEL, }, + { IMX93_CLK_FLEXSPI1, "flexspi1_root", 0x0b00, FAST_SEL, }, + { IMX93_CLK_CAN1, "can1_root", 0x0b80, LOW_SPEED_IO_SEL, }, + { IMX93_CLK_CAN2, "can2_root", 0x0c00, LOW_SPEED_IO_SEL, }, + { IMX93_CLK_LPUART1, "lpuart1_root", 0x0c80, LOW_SPEED_IO_SEL, }, + { IMX93_CLK_LPUART2, "lpuart2_root", 0x0d00, LOW_SPEED_IO_SEL, }, + { IMX93_CLK_LPUART3, "lpuart3_root", 0x0d80, LOW_SPEED_IO_SEL, }, + { IMX93_CLK_LPUART4, "lpuart4_root", 0x0e00, LOW_SPEED_IO_SEL, }, + { IMX93_CLK_LPUART5, "lpuart5_root", 0x0e80, LOW_SPEED_IO_SEL, }, + { IMX93_CLK_LPUART6, "lpuart6_root", 0x0f00, LOW_SPEED_IO_SEL, }, + { IMX93_CLK_LPUART7, "lpuart7_root", 0x0f80, LOW_SPEED_IO_SEL, }, + { IMX93_CLK_LPUART8, "lpuart8_root", 0x1000, LOW_SPEED_IO_SEL, }, + { IMX93_CLK_LPI2C1, "lpi2c1_root", 0x1080, LOW_SPEED_IO_SEL, }, + { IMX93_CLK_LPI2C2, "lpi2c2_root", 0x1100, LOW_SPEED_IO_SEL, }, + { IMX93_CLK_LPI2C3, "lpi2c3_root", 0x1180, LOW_SPEED_IO_SEL, }, + { IMX93_CLK_LPI2C4, "lpi2c4_root", 0x1200, LOW_SPEED_IO_SEL, }, + { IMX93_CLK_LPI2C5, "lpi2c5_root", 0x1280, LOW_SPEED_IO_SEL, }, + { IMX93_CLK_LPI2C6, "lpi2c6_root", 0x1300, LOW_SPEED_IO_SEL, }, + { IMX93_CLK_LPI2C7, "lpi2c7_root", 0x1380, LOW_SPEED_IO_SEL, }, + { IMX93_CLK_LPI2C8, "lpi2c8_root", 0x1400, LOW_SPEED_IO_SEL, }, + { IMX93_CLK_LPSPI1, "lpspi1_root", 0x1480, LOW_SPEED_IO_SEL, }, + { IMX93_CLK_LPSPI2, "lpspi2_root", 0x1500, LOW_SPEED_IO_SEL, }, + { IMX93_CLK_LPSPI3, "lpspi3_root", 0x1580, LOW_SPEED_IO_SEL, }, + { IMX93_CLK_LPSPI4, "lpspi4_root", 0x1600, LOW_SPEED_IO_SEL, }, + { IMX93_CLK_LPSPI5, "lpspi5_root", 0x1680, LOW_SPEED_IO_SEL, }, + { IMX93_CLK_LPSPI6, "lpspi6_root", 0x1700, LOW_SPEED_IO_SEL, }, + { IMX93_CLK_LPSPI7, "lpspi7_root", 0x1780, LOW_SPEED_IO_SEL, }, + { IMX93_CLK_LPSPI8, "lpspi8_root", 0x1800, LOW_SPEED_IO_SEL, }, + { IMX93_CLK_I3C1, "i3c1_root", 0x1880, LOW_SPEED_IO_SEL, }, + { IMX93_CLK_I3C2, "i3c2_root", 0x1900, LOW_SPEED_IO_SEL, }, + { IMX93_CLK_USDHC1, "usdhc1_root", 0x1980, FAST_SEL, }, + { IMX93_CLK_USDHC2, "usdhc2_root", 0x1a00, FAST_SEL, }, + { IMX93_CLK_USDHC3, "usdhc3_root", 0x1a80, FAST_SEL, }, + { IMX93_CLK_SAI1, "sai1_root", 0x1b00, AUDIO_SEL, }, + { IMX93_CLK_SAI2, "sai2_root", 0x1b80, AUDIO_SEL, }, + { IMX93_CLK_SAI3, "sai3_root", 0x1c00, AUDIO_SEL, }, + { IMX93_CLK_CCM_CKO1, "ccm_cko1_root", 0x1c80, CKO1_SEL, }, + { IMX93_CLK_CCM_CKO2, "ccm_cko2_root", 0x1d00, CKO2_SEL, }, + { IMX93_CLK_CCM_CKO3, "ccm_cko3_root", 0x1d80, CKO1_SEL, }, + { IMX93_CLK_CCM_CKO4, "ccm_cko4_root", 0x1e00, CKO2_SEL, }, + /* + * Critical because clk is used for handshake between HSIOMIX and NICMIX when + * NICMIX power down/on during system suspend/resume + */ + { IMX93_CLK_HSIO, "hsio_root", 0x1e80, LOW_SPEED_IO_SEL, CLK_IS_CRITICAL}, + { IMX93_CLK_HSIO_USB_TEST_60M, "hsio_usb_test_60m_root", 0x1f00, LOW_SPEED_IO_SEL, }, + { IMX93_CLK_HSIO_ACSCAN_80M, "hsio_acscan_80m_root", 0x1f80, LOW_SPEED_IO_SEL, }, + { IMX93_CLK_HSIO_ACSCAN_480M, "hsio_acscan_480m_root", 0x2000, MISC_SEL, }, + { IMX93_CLK_NIC_AXI, "nic_axi_root", 0x2080, FAST_SEL, CLK_IS_CRITICAL, }, + { IMX93_CLK_ML_APB, "ml_apb_root", 0x2180, LOW_SPEED_IO_SEL, }, + { IMX93_CLK_ML, "ml_root", 0x2200, FAST_SEL, }, + { IMX93_CLK_MEDIA_AXI, "media_axi_root", 0x2280, FAST_SEL, }, + { IMX93_CLK_MEDIA_APB, "media_apb_root", 0x2300, LOW_SPEED_IO_SEL, }, + { IMX93_CLK_MEDIA_LDB, "media_ldb_root", 0x2380, VIDEO_SEL, }, + { IMX93_CLK_MEDIA_DISP_PIX, "media_disp_pix_root", 0x2400, VIDEO_SEL, }, + { IMX93_CLK_CAM_PIX, "cam_pix_root", 0x2480, VIDEO_SEL, }, + { IMX93_CLK_MIPI_TEST_BYTE, "mipi_test_byte_root", 0x2500, VIDEO_SEL, }, + { IMX93_CLK_MIPI_PHY_CFG, "mipi_phy_cfg_root", 0x2580, VIDEO_SEL, }, + { IMX93_CLK_ADC, "adc_root", 0x2700, LOW_SPEED_IO_SEL, }, + { IMX93_CLK_PDM, "pdm_root", 0x2780, AUDIO_SEL, }, + { IMX93_CLK_TSTMR1, "tstmr1_root", 0x2800, LOW_SPEED_IO_SEL, }, + { IMX93_CLK_TSTMR2, "tstmr2_root", 0x2880, LOW_SPEED_IO_SEL, }, + { IMX93_CLK_MQS1, "mqs1_root", 0x2900, AUDIO_SEL, }, + { IMX93_CLK_MQS2, "mqs2_root", 0x2980, AUDIO_SEL, }, + { IMX93_CLK_AUDIO_XCVR, "audio_xcvr_root", 0x2a00, NON_IO_SEL, }, + { IMX93_CLK_SPDIF, "spdif_root", 0x2a80, AUDIO_SEL, }, + { IMX93_CLK_ENET, "enet_root", 0x2b00, NON_IO_SEL, }, + { IMX93_CLK_ENET_TIMER1, "enet_timer1_root", 0x2b80, LOW_SPEED_IO_SEL, }, + { IMX93_CLK_ENET_TIMER2, "enet_timer2_root", 0x2c00, LOW_SPEED_IO_SEL, }, + { IMX93_CLK_ENET_REF, "enet_ref_root", 0x2c80, NON_IO_SEL, }, + { IMX93_CLK_ENET_REF_PHY, "enet_ref_phy_root", 0x2d00, LOW_SPEED_IO_SEL, }, + { IMX93_CLK_I3C1_SLOW, "i3c1_slow_root", 0x2d80, LOW_SPEED_IO_SEL, }, + { IMX93_CLK_I3C2_SLOW, "i3c2_slow_root", 0x2e00, LOW_SPEED_IO_SEL, }, + { IMX93_CLK_USB_PHY_BURUNIN, "usb_phy_root", 0x2e80, LOW_SPEED_IO_SEL, }, + { IMX93_CLK_PAL_CAME_SCAN, "pal_came_scan_root", 0x2f00, MISC_SEL, } +}; + +static const struct imx93_clk_ccgr { + u32 clk; + char *name; + char *parent_name; + u32 off; + unsigned long flags; + u32 *shared_count; +} ccgr_array[] = { + { IMX93_CLK_A55_GATE, "a55_alt", "a55_alt_root", 0x8000, }, + /* M33 critical clk for system run */ + { IMX93_CLK_CM33_GATE, "cm33", "m33_root", 0x8040, CLK_IS_CRITICAL }, + { IMX93_CLK_ADC1_GATE, "adc1", "adc_root", 0x82c0, }, + { IMX93_CLK_WDOG1_GATE, "wdog1", "clock-osc-24m", 0x8300, }, + { IMX93_CLK_WDOG2_GATE, "wdog2", "clock-osc-24m", 0x8340, }, + { IMX93_CLK_WDOG3_GATE, "wdog3", "clock-osc-24m", 0x8380, }, + { IMX93_CLK_WDOG4_GATE, "wdog4", "clock-osc-24m", 0x83c0, }, + { IMX93_CLK_WDOG5_GATE, "wdog5", "clock-osc-24m", 0x8400, }, + { IMX93_CLK_SEMA1_GATE, "sema1", "bus_aon_root", 0x8440, }, + { IMX93_CLK_SEMA2_GATE, "sema2", "bus_wakeup_root", 0x8480, }, + { IMX93_CLK_MU1_A_GATE, "mu1_a", "bus_aon_root", 0x84c0, CLK_IGNORE_UNUSED }, + { IMX93_CLK_MU2_A_GATE, "mu2_a", "bus_wakeup_root", 0x84c0, CLK_IGNORE_UNUSED }, + { IMX93_CLK_MU1_B_GATE, "mu1_b", "bus_aon_root", 0x8500, 0, &share_count_mub }, + { IMX93_CLK_MU2_B_GATE, "mu2_b", "bus_wakeup_root", 0x8500, 0, &share_count_mub }, + { IMX93_CLK_EDMA1_GATE, "edma1", "m33_root", 0x8540, }, + { IMX93_CLK_EDMA2_GATE, "edma2", "wakeup_axi_root", 0x8580, }, + { IMX93_CLK_FLEXSPI1_GATE, "flexspi1", "flexspi1_root", 0x8640, }, + { IMX93_CLK_GPIO1_GATE, "gpio1", "m33_root", 0x8880, }, + { IMX93_CLK_GPIO2_GATE, "gpio2", "bus_wakeup_root", 0x88c0, }, + { IMX93_CLK_GPIO3_GATE, "gpio3", "bus_wakeup_root", 0x8900, }, + { IMX93_CLK_GPIO4_GATE, "gpio4", "bus_wakeup_root", 0x8940, }, + { IMX93_CLK_FLEXIO1_GATE, "flexio1", "flexio1_root", 0x8980, }, + { IMX93_CLK_FLEXIO2_GATE, "flexio2", "flexio2_root", 0x89c0, }, + { IMX93_CLK_LPIT1_GATE, "lpit1", "bus_aon_root", 0x8a00, }, + { IMX93_CLK_LPIT2_GATE, "lpit2", "bus_wakeup_root", 0x8a40, }, + { IMX93_CLK_LPTMR1_GATE, "lptmr1", "lptmr1_root", 0x8a80, }, + { IMX93_CLK_LPTMR2_GATE, "lptmr2", "lptmr2_root", 0x8ac0, }, + { IMX93_CLK_TPM1_GATE, "tpm1", "bus_aon_root", 0x8b00, }, + { IMX93_CLK_TPM2_GATE, "tpm2", "tpm2_root", 0x8b40, }, + { IMX93_CLK_TPM3_GATE, "tpm3", "bus_wakeup_root", 0x8b80, }, + { IMX93_CLK_TPM4_GATE, "tpm4", "tpm4_root", 0x8bc0, }, + { IMX93_CLK_TPM5_GATE, "tpm5", "tpm5_root", 0x8c00, }, + { IMX93_CLK_TPM6_GATE, "tpm6", "tpm6_root", 0x8c40, }, + { IMX93_CLK_CAN1_GATE, "can1", "can1_root", 0x8c80, }, + { IMX93_CLK_CAN2_GATE, "can2", "can2_root", 0x8cc0, }, + { IMX93_CLK_LPUART1_GATE, "lpuart1", "lpuart1_root", 0x8d00, }, + { IMX93_CLK_LPUART2_GATE, "lpuart2", "lpuart2_root", 0x8d40, }, + { IMX93_CLK_LPUART3_GATE, "lpuart3", "lpuart3_root", 0x8d80, }, + { IMX93_CLK_LPUART4_GATE, "lpuart4", "lpuart4_root", 0x8dc0, }, + { IMX93_CLK_LPUART5_GATE, "lpuart5", "lpuart5_root", 0x8e00, }, + { IMX93_CLK_LPUART6_GATE, "lpuart6", "lpuart6_root", 0x8e40, }, + { IMX93_CLK_LPUART7_GATE, "lpuart7", "lpuart7_root", 0x8e80, }, + { IMX93_CLK_LPUART8_GATE, "lpuart8", "lpuart8_root", 0x8ec0, }, + { IMX93_CLK_LPI2C1_GATE, "lpi2c1", "lpi2c1_root", 0x8f00, }, + { IMX93_CLK_LPI2C2_GATE, "lpi2c2", "lpi2c2_root", 0x8f40, }, + { IMX93_CLK_LPI2C3_GATE, "lpi2c3", "lpi2c3_root", 0x8f80, }, + { IMX93_CLK_LPI2C4_GATE, "lpi2c4", "lpi2c4_root", 0x8fc0, }, + { IMX93_CLK_LPI2C5_GATE, "lpi2c5", "lpi2c5_root", 0x9000, }, + { IMX93_CLK_LPI2C6_GATE, "lpi2c6", "lpi2c6_root", 0x9040, }, + { IMX93_CLK_LPI2C7_GATE, "lpi2c7", "lpi2c7_root", 0x9080, }, + { IMX93_CLK_LPI2C8_GATE, "lpi2c8", "lpi2c8_root", 0x90c0, }, + { IMX93_CLK_LPSPI1_GATE, "lpspi1", "lpspi1_root", 0x9100, }, + { IMX93_CLK_LPSPI2_GATE, "lpspi2", "lpspi2_root", 0x9140, }, + { IMX93_CLK_LPSPI3_GATE, "lpspi3", "lpspi3_root", 0x9180, }, + { IMX93_CLK_LPSPI4_GATE, "lpspi4", "lpspi4_root", 0x91c0, }, + { IMX93_CLK_LPSPI5_GATE, "lpspi5", "lpspi5_root", 0x9200, }, + { IMX93_CLK_LPSPI6_GATE, "lpspi6", "lpspi6_root", 0x9240, }, + { IMX93_CLK_LPSPI7_GATE, "lpspi7", "lpspi7_root", 0x9280, }, + { IMX93_CLK_LPSPI8_GATE, "lpspi8", "lpspi8_root", 0x92c0, }, + { IMX93_CLK_I3C1_GATE, "i3c1", "i3c1_root", 0x9300, }, + { IMX93_CLK_I3C2_GATE, "i3c2", "i3c2_root", 0x9340, }, + { IMX93_CLK_USDHC1_GATE, "usdhc1", "usdhc1_root", 0x9380, }, + { IMX93_CLK_USDHC2_GATE, "usdhc2", "usdhc2_root", 0x93c0, }, + { IMX93_CLK_USDHC3_GATE, "usdhc3", "usdhc3_root", 0x9400, }, + { IMX93_CLK_SAI1_GATE, "sai1", "sai1_root", 0x9440, 0, &share_count_sai1}, + { IMX93_CLK_SAI1_IPG, "sai1_ipg_clk", "bus_aon_root", 0x9440, 0, &share_count_sai1}, + { IMX93_CLK_SAI2_GATE, "sai2", "sai2_root", 0x9480, 0, &share_count_sai2}, + { IMX93_CLK_SAI2_IPG, "sai2_ipg_clk", "bus_wakeup_root", 0x9480, 0, &share_count_sai2}, + { IMX93_CLK_SAI3_GATE, "sai3", "sai3_root", 0x94c0, 0, &share_count_sai3}, + { IMX93_CLK_SAI3_IPG, "sai3_ipg_clk", "bus_wakeup_root", 0x94c0, 0, &share_count_sai3}, + { IMX93_CLK_MIPI_CSI_GATE, "mipi_csi", "media_apb_root", 0x9580, }, + { IMX93_CLK_MIPI_DSI_GATE, "mipi_dsi", "media_apb_root", 0x95c0, }, + { IMX93_CLK_LVDS_GATE, "lvds", "media_ldb_root", 0x9600, }, + { IMX93_CLK_LCDIF_GATE, "lcdif", "media_apb_root", 0x9640, }, + { IMX93_CLK_PXP_GATE, "pxp", "media_apb_root", 0x9680, }, + { IMX93_CLK_ISI_GATE, "isi", "media_apb_root", 0x96c0, }, + { IMX93_CLK_NIC_MEDIA_GATE, "nic_media", "media_axi_root", 0x9700, }, + { IMX93_CLK_USB_CONTROLLER_GATE, "usb_controller", "hsio_root", 0x9a00, }, + { IMX93_CLK_USB_TEST_60M_GATE, "usb_test_60m", "hsio_usb_test_60m_root", 0x9a40, }, + { IMX93_CLK_HSIO_TROUT_24M_GATE, "hsio_trout_24m", "clock-osc-24m", 0x9a80, }, + { IMX93_CLK_PDM_GATE, "pdm", "pdm_root", 0x9ac0, }, + { IMX93_CLK_MQS1_GATE, "mqs1", "sai1_root", 0x9b00, }, + { IMX93_CLK_MQS2_GATE, "mqs2", "sai3_root", 0x9b40, }, + { IMX93_CLK_AUD_XCVR_GATE, "aud_xcvr", "audio_xcvr_root", 0x9b80, }, + { IMX93_CLK_SPDIF_GATE, "spdif", "spdif_root", 0x9c00, }, + { IMX93_CLK_HSIO_32K_GATE, "hsio_32k", "clock-osc-24m", 0x9dc0, }, + { IMX93_CLK_ENET1_GATE, "enet1", "wakeup_axi_root", 0x9e00, }, + { IMX93_CLK_ENET_QOS_GATE, "enet_qos", "wakeup_axi_root", 0x9e40, }, + /* Critical because clk accessed during CPU idle */ + { IMX93_CLK_SYS_CNT_GATE, "sys_cnt", "clock-osc-24m", 0x9e80, CLK_IS_CRITICAL}, + { IMX93_CLK_TSTMR1_GATE, "tstmr1", "bus_aon_root", 0x9ec0, }, + { IMX93_CLK_TSTMR2_GATE, "tstmr2", "bus_wakeup_root", 0x9f00, }, + { IMX93_CLK_TMC_GATE, "tmc", "clock-osc-24m", 0x9f40, }, + { IMX93_CLK_PMRO_GATE, "pmro", "clock-osc-24m", 0x9f80, } +}; + +static int imx93_clk_probe(struct udevice *dev) +{ + const struct imx93_clk_root *root; + const struct imx93_clk_ccgr *ccgr; + struct clk osc_24m_clk, osc_32k_clk, ext1_clk; + void __iomem *base, *anatop_base; + int i, ret; + + clk_dm(IMX93_CLK_DUMMY, clk_register_fixed_rate(NULL, "dummy", 0UL)); + + ret = clk_get_by_name(dev, "osc_24m", &osc_24m_clk); + if (ret) + return ret; + clk_dm(IMX93_CLK_24M, dev_get_clk_ptr(osc_24m_clk.dev)); + + ret = clk_get_by_name(dev, "osc_32k", &osc_32k_clk); + if (ret) + return ret; + clk_dm(IMX93_CLK_32K, dev_get_clk_ptr(osc_32k_clk.dev)); + + ret = clk_get_by_name(dev, "clk_ext1", &ext1_clk); + if (ret) + return ret; + clk_dm(IMX93_CLK_EXT1, dev_get_clk_ptr(ext1_clk.dev)); + + clk_dm(IMX93_CLK_SYS_PLL_PFD0, + clk_register_fixed_rate(NULL, "sys_pll_pfd0", 1000000000)); + clk_dm(IMX93_CLK_SYS_PLL_PFD0_DIV2, + imx_clk_fixed_factor("sys_pll_pfd0_div2", "sys_pll_pfd0", 1, 2)); + clk_dm(IMX93_CLK_SYS_PLL_PFD1, + clk_register_fixed_rate(NULL, "sys_pll_pfd1", 800000000)); + clk_dm(IMX93_CLK_SYS_PLL_PFD1_DIV2, + imx_clk_fixed_factor("sys_pll_pfd1_div2", "sys_pll_pfd1", 1, 2)); + clk_dm(IMX93_CLK_SYS_PLL_PFD2, + clk_register_fixed_rate(NULL, "sys_pll_pfd2", 625000000)); + clk_dm(IMX93_CLK_SYS_PLL_PFD2_DIV2, + imx_clk_fixed_factor("sys_pll_pfd2_div2", "sys_pll_pfd2", 1, 2)); + + base = (void *)ANATOP_BASE_ADDR; + + clk_dm(IMX93_CLK_ARM_PLL, + imx_clk_fracn_gppll_integer("arm_pll", "clock-osc-24m", + anatop_base + 0x1000, + &imx_fracn_gppll_integer)); + clk_dm(IMX93_CLK_AUDIO_PLL, + imx_clk_fracn_gppll("audio_pll", "clock-osc-24m", + anatop_base + 0x1200, &imx_fracn_gppll)); + clk_dm(IMX93_CLK_VIDEO_PLL, + imx_clk_fracn_gppll("video_pll", "clock-osc-24m", + anatop_base + 0x1400, &imx_fracn_gppll)); + + base = dev_read_addr_ptr(dev); + if (!base) + return -EINVAL; + + for (i = 0; i < ARRAY_SIZE(root_array); i++) { + root = &root_array[i]; + clk_dm(root->clk, imx93_clk_composite_flags(root->name, + parent_names[root->sel], + 4, base + root->off, 3, + root->flags)); + } + + for (i = 0; i < ARRAY_SIZE(ccgr_array); i++) { + ccgr = &ccgr_array[i]; + clk_dm(ccgr->clk, imx93_clk_gate(NULL, ccgr->name, ccgr->parent_name, + ccgr->flags, base + ccgr->off, 0, 1, 1, 3, + ccgr->shared_count)); + } + + clk_dm(IMX93_CLK_A55_SEL, + imx_clk_mux2("a55_sel", base + 0x4820, 0, 1, + a55_core_sels, ARRAY_SIZE(a55_core_sels))); + + return 0; +} + +static const struct udevice_id imx93_clk_ids[] = { + { .compatible = "fsl,imx93-ccm" }, + { /* Sentinel */ }, +}; + +U_BOOT_DRIVER(imx93_clk) = { + .name = "clk_imx93", + .id = UCLASS_CLK, + .of_match = imx93_clk_ids, + .ops = &ccf_clk_ops, + .probe = imx93_clk_probe, + .flags = DM_FLAG_PRE_RELOC, +}; diff --git a/drivers/clk/imx/clk.h b/drivers/clk/imx/clk.h index 11f5dca1175b..27a53ae5583f 100644 --- a/drivers/clk/imx/clk.h +++ b/drivers/clk/imx/clk.h @@ -46,6 +46,34 @@ extern struct imx_pll14xx_clk imx_1416x_pll; extern struct imx_pll14xx_clk imx_1443x_pll; extern struct imx_pll14xx_clk imx_1443x_dram_pll;
+#define CLK_FRACN_GPPLL_INTEGER BIT(0) +#define CLK_FRACN_GPPLL_FRACN BIT(1) + +/* NOTE: Rate table should be kept sorted in descending order. */ +struct imx_fracn_gppll_rate_table { + unsigned int rate; + unsigned int mfi; + unsigned int mfn; + unsigned int mfd; + unsigned int rdiv; + unsigned int odiv; +}; + +struct imx_fracn_gppll_clk { + const struct imx_fracn_gppll_rate_table *rate_table; + int rate_count; + int flags; +}; + +struct clk *imx_clk_fracn_gppll(const char *name, const char *parent_name, void __iomem *base, + const struct imx_fracn_gppll_clk *pll_clk); +struct clk *imx_clk_fracn_gppll_integer(const char *name, const char *parent_name, + void __iomem *base, + const struct imx_fracn_gppll_clk *pll_clk); + +extern struct imx_fracn_gppll_clk imx_fracn_gppll; +extern struct imx_fracn_gppll_clk imx_fracn_gppll_integer; + struct clk *imx_clk_pll14xx(const char *name, const char *parent_name, void __iomem *base, const struct imx_pll14xx_clk *pll_clk); @@ -224,4 +252,18 @@ struct clk *imx8m_clk_composite_flags(const char *name, #define imx8m_clk_composite_critical(name, parent_names, reg) \ __imx8m_clk_composite(name, parent_names, reg, CLK_IS_CRITICAL)
+struct clk *imx93_clk_composite_flags(const char *name, + const char * const *parent_names, + int num_parents, + void __iomem *reg, + u32 domain_id, + unsigned long flags); +#define imx93_clk_composite(name, parent_names, num_parents, reg, domain_id) \ + imx93_clk_composite_flags(name, parent_names, num_parents, reg, domain_id \ + CLK_SET_RATE_NO_REPARENT | CLK_OPS_PARENT_ENABLE) + +struct clk *imx93_clk_gate(struct device *dev, const char *name, const char *parent_name, + unsigned long flags, void __iomem *reg, u32 bit_idx, u32 val, + u32 mask, u32 domain_id, unsigned int *share_count); + #endif /* __MACH_IMX_CLK_H */ diff --git a/include/dt-bindings/clock/imx93-clock.h b/include/dt-bindings/clock/imx93-clock.h index 8e02859d8ce2..35a1f62053a5 100644 --- a/include/dt-bindings/clock/imx93-clock.h +++ b/include/dt-bindings/clock/imx93-clock.h @@ -199,6 +199,10 @@ #define IMX93_CLK_MU1_B_GATE 194 #define IMX93_CLK_MU2_A_GATE 195 #define IMX93_CLK_MU2_B_GATE 196 -#define IMX93_CLK_END 197 +#define IMX93_CLK_NIC_AXI 197 +#define IMX93_CLK_ARM_PLL 198 +#define IMX93_CLK_A55_SEL 199 +#define IMX93_CLK_A55_CORE 200 +#define IMX93_CLK_END 201
#endif
When CLK is enabled, get_lpuart_clk_rate() needs to get a per clock of lpuart, so that add a per clock for lpuart1.
Signed-off-by: Alice Guo alice.guo@nxp.com Reviewed-by: Ye Li ye.li@nxp.com Signed-off-by: Sébastien Szymanski sebastien.szymanski@armadeus.com ---
This commit comes from downstream U-Boot: https://github.com/nxp-imx/uboot-imx/commit/6cc90f4e65d5803f5e15765602febee8...
arch/arm/dts/imx93.dtsi | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/arm/dts/imx93.dtsi b/arch/arm/dts/imx93.dtsi index 13cf32d4b277..90de635481f9 100644 --- a/arch/arm/dts/imx93.dtsi +++ b/arch/arm/dts/imx93.dtsi @@ -254,8 +254,8 @@ compatible = "fsl,imx93-lpuart", "fsl,imx7ulp-lpuart"; reg = <0x44380000 0x1000>; interrupts = <GIC_SPI 19 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&clk IMX93_CLK_LPUART1_GATE>; - clock-names = "ipg"; + clocks = <&clk IMX93_CLK_LPUART1_GATE>, <&clk IMX93_CLK_LPUART1_GATE>; + clock-names = "ipg", "per"; status = "disabled"; };
Current codes only ennable the PER clock. However on iMX8 the LPUART also needs IPG clock which is an LPCG. Should not depend on the default LPCG setting.
Signed-off-by: Ye Li ye.li@nxp.com Reviewed-by: Peng Fan peng.fan@nxp.com Signed-off-by: Sébastien Szymanski sebastien.szymanski@armadeus.com ---
This commit comes from downstream U-Boot: https://github.com/nxp-imx/uboot-imx/commit/16aa73211a260c6f04d489ff8aa3476c...
drivers/serial/serial_lpuart.c | 14 +++++++++++++- 1 file changed, 13 insertions(+), 1 deletion(-)
diff --git a/drivers/serial/serial_lpuart.c b/drivers/serial/serial_lpuart.c index 51e66abdbc15..ce08a6b4486c 100644 --- a/drivers/serial/serial_lpuart.c +++ b/drivers/serial/serial_lpuart.c @@ -480,18 +480,30 @@ static int lpuart_serial_probe(struct udevice *dev) { #if CONFIG_IS_ENABLED(CLK) struct clk per_clk; + struct clk ipg_clk; int ret;
ret = clk_get_by_name(dev, "per", &per_clk); if (!ret) { ret = clk_enable(&per_clk); if (ret) { - dev_err(dev, "Failed to get per clk: %d\n", ret); + dev_err(dev, "Failed to enable per clk: %d\n", ret); return ret; } } else { debug("%s: Failed to get per clk: %d\n", __func__, ret); } + + ret = clk_get_by_name(dev, "ipg", &ipg_clk); + if (!ret) { + ret = clk_enable(&ipg_clk); + if (ret) { + dev_err(dev, "Failed to enable ipg clk: %d\n", ret); + return ret; + } + } else { + debug("%s: Failed to get ipg clk: %d\n", __func__, ret); + } #endif
if (is_lpuart32(dev))
Add clocks nodes in u-boot.dtsi file. Remove init_uart_clk() call.
Signed-off-by: Sébastien Szymanski sebastien.szymanski@armadeus.com --- arch/arm/dts/imx93-11x11-evk-u-boot.dtsi | 23 +++++++++++++++++++++++ board/freescale/imx93_evk/imx93_evk.c | 2 -- configs/imx93_11x11_evk_defconfig | 2 ++ 3 files changed, 25 insertions(+), 2 deletions(-)
diff --git a/arch/arm/dts/imx93-11x11-evk-u-boot.dtsi b/arch/arm/dts/imx93-11x11-evk-u-boot.dtsi index 5b465e2dbd9d..93b4d91e4c39 100644 --- a/arch/arm/dts/imx93-11x11-evk-u-boot.dtsi +++ b/arch/arm/dts/imx93-11x11-evk-u-boot.dtsi @@ -126,3 +126,26 @@ bootph-pre-ram; status = "okay"; }; + +&clk { + bootph-all; + bootph-pre-ram; + /delete-property/ assigned-clocks; + /delete-property/ assigned-clock-rates; + /delete-property/ assigned-clock-parents; +}; + +&osc_32k { + bootph-all; + bootph-pre-ram; +}; + +&osc_24m { + bootph-all; + bootph-pre-ram; +}; + +&clk_ext1 { + bootph-all; + bootph-pre-ram; +}; diff --git a/board/freescale/imx93_evk/imx93_evk.c b/board/freescale/imx93_evk/imx93_evk.c index e73a498733be..f4297f8fd4d4 100644 --- a/board/freescale/imx93_evk/imx93_evk.c +++ b/board/freescale/imx93_evk/imx93_evk.c @@ -33,8 +33,6 @@ int board_early_init_f(void) { imx_iomux_v3_setup_multiple_pads(uart_pads, ARRAY_SIZE(uart_pads));
- init_uart_clk(LPUART1_CLK_ROOT); - return 0; }
diff --git a/configs/imx93_11x11_evk_defconfig b/configs/imx93_11x11_evk_defconfig index a480a71246b7..38c645ce733e 100644 --- a/configs/imx93_11x11_evk_defconfig +++ b/configs/imx93_11x11_evk_defconfig @@ -83,6 +83,8 @@ CONFIG_REGMAP=y CONFIG_SYSCON=y CONFIG_ADC=y CONFIG_ADC_IMX93=y +CONFIG_SPL_CLK_IMX93=y +CONFIG_CLK_IMX93=y CONFIG_CPU=y CONFIG_CPU_IMX=y CONFIG_IMX_RGPIO2P=y
Hello,
gentle ping. Maybe someone at NXP can help review this patchset?
Regards,
Sébastien Szymanski
