[U-Boot] [PATCH 1/4] Add snoop disable for slave port 0, port 1 and port 2
Disable the snoop for slave interface 0, 1 and 2 to avoid the interleaving on the CCI400 BUS.
Signed-off-by: Jason Jin Jason.Jin@freescale.com Signed-off-by: Minghuan Lian Minghuan.Lian@freescale.com --- arch/arm/include/asm/arch-ls102xa/immap_ls102xa.h | 1 + board/freescale/ls1021aqds/ls1021aqds.c | 7 +++++++ board/freescale/ls1021atwr/ls1021atwr.c | 10 ++++++++++ 3 files changed, 18 insertions(+)
diff --git a/arch/arm/include/asm/arch-ls102xa/immap_ls102xa.h b/arch/arm/include/asm/arch-ls102xa/immap_ls102xa.h index 7995fe2..a1f4fdb 100644 --- a/arch/arm/include/asm/arch-ls102xa/immap_ls102xa.h +++ b/arch/arm/include/asm/arch-ls102xa/immap_ls102xa.h @@ -448,6 +448,7 @@ struct ccsr_ddr {
#define CCI400_CTRLORD_TERM_BARRIER 0x00000008 #define CCI400_CTRLORD_EN_BARRIER 0 +#define CCI400_SHAORD_NON_SHAREABLE 0x00000002
/* CCI-400 registers */ struct ccsr_cci400 { diff --git a/board/freescale/ls1021aqds/ls1021aqds.c b/board/freescale/ls1021aqds/ls1021aqds.c index 12e83f7..e32dbeb 100644 --- a/board/freescale/ls1021aqds/ls1021aqds.c +++ b/board/freescale/ls1021aqds/ls1021aqds.c @@ -220,6 +220,13 @@ int board_init(void) /* Set CCI-400 control override register to * enable barrier transaction */ out_le32(&cci->ctrl_ord, CCI400_CTRLORD_EN_BARRIER); + /* + * Set CCI-400 Slave interface S0, S1, S2 Shareable Override Register + * All transactions are treated as non-shareable + */ + out_le32(&cci->slave[0].sha_ord, CCI400_SHAORD_NON_SHAREABLE); + out_le32(&cci->slave[1].sha_ord, CCI400_SHAORD_NON_SHAREABLE); + out_le32(&cci->slave[2].sha_ord, CCI400_SHAORD_NON_SHAREABLE);
select_i2c_ch_pca9547(I2C_MUX_CH_DEFAULT);
diff --git a/board/freescale/ls1021atwr/ls1021atwr.c b/board/freescale/ls1021atwr/ls1021atwr.c index b522ff2..811c911 100644 --- a/board/freescale/ls1021atwr/ls1021atwr.c +++ b/board/freescale/ls1021atwr/ls1021atwr.c @@ -272,6 +272,16 @@ int board_early_init_f(void)
int board_init(void) { + struct ccsr_cci400 *cci = (struct ccsr_cci400 *)CONFIG_SYS_CCI400_ADDR; + + /* + * Set CCI-400 Slave interface S0, S1, S2 Shareable Override Register + * All transactions are treated as non-shareable + */ + out_le32(&cci->slave[0].sha_ord, CCI400_SHAORD_NON_SHAREABLE); + out_le32(&cci->slave[1].sha_ord, CCI400_SHAORD_NON_SHAREABLE); + out_le32(&cci->slave[2].sha_ord, CCI400_SHAORD_NON_SHAREABLE); + #ifndef CONFIG_SYS_FSL_NO_SERDES fsl_serdes_init(); config_serdes_mux();
SCFG_SCFGREVCR is SCFG bit reverse register. This register must be written with 0xFFFFFFFF before writing to any other SCFG register. Then other SCFG register could be written in big-endian mode.
Address: 157_0000h base + 200h offset = 157_0200h Bit 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15|16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 W/R SCFGREV Reset 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0-31 SCFGREV SCFG Bit Reverse Control Filed 32'h 0000_0000 - No bit reverse is applied 32'h FFFF_FFFF - Bit reverse is applied; so 31:0 will be stored/read as 0:31
This patch removes the bit reversing for SCFG registers in u-boot. It will be implemented through PBI commands in RCW .pbi write 0x570200, 0xffffffff .end So other SCFG register could be written in big-endian mode in u-boot or kernel directly.
Signed-off-by: Alison Wang alison.wang@freescale.com --- board/freescale/ls1021aqds/ls1021aqds.c | 2 -- board/freescale/ls1021atwr/ls1021atwr.c | 5 ----- 2 files changed, 7 deletions(-)
diff --git a/board/freescale/ls1021aqds/ls1021aqds.c b/board/freescale/ls1021aqds/ls1021aqds.c index e32dbeb..56028f8 100644 --- a/board/freescale/ls1021aqds/ls1021aqds.c +++ b/board/freescale/ls1021aqds/ls1021aqds.c @@ -136,9 +136,7 @@ int board_early_init_f(void) struct ccsr_cci400 *cci = (struct ccsr_cci400 *)CONFIG_SYS_CCI400_ADDR;
#ifdef CONFIG_TSEC_ENET - out_be32(&scfg->scfgrevcr, SCFG_SCFGREVCR_REV); out_be32(&scfg->etsecdmamcr, SCFG_ETSECDMAMCR_LE_BD_FR); - out_be32(&scfg->scfgrevcr, SCFG_SCFGREVCR_NOREV); #endif
#ifdef CONFIG_FSL_IFC diff --git a/board/freescale/ls1021atwr/ls1021atwr.c b/board/freescale/ls1021atwr/ls1021atwr.c index 811c911..ff7130e 100644 --- a/board/freescale/ls1021atwr/ls1021atwr.c +++ b/board/freescale/ls1021atwr/ls1021atwr.c @@ -250,11 +250,8 @@ int board_early_init_f(void) struct ccsr_scfg *scfg = (struct ccsr_scfg *)CONFIG_SYS_FSL_SCFG_ADDR;
#ifdef CONFIG_TSEC_ENET - out_be32(&scfg->scfgrevcr, SCFG_SCFGREVCR_REV); out_be32(&scfg->etsecdmamcr, SCFG_ETSECDMAMCR_LE_BD_FR); out_be32(&scfg->etsecmcr, SCFG_ETSECCMCR_GE2_CLK125); - udelay(10); - out_be32(&scfg->scfgrevcr, SCFG_SCFGREVCR_NOREV); #endif
#ifdef CONFIG_FSL_IFC @@ -262,9 +259,7 @@ int board_early_init_f(void) #endif
#ifdef CONFIG_FSL_DCU_FB - out_be32(&scfg->scfgrevcr, SCFG_SCFGREVCR_REV); out_be32(&scfg->pixclkcr, SCFG_PIXCLKCR_PXCKEN); - out_be32(&scfg->scfgrevcr, SCFG_SCFGREVCR_NOREV); #endif
If I understand correctly, below patch removes both setting 0xffffffff and 0x00000000. does re-setting of SCFG_SCFGREVCR not a requirement?
Just a suggestion: if SCFG_SCFGREVCR_REV and SCFG_SCFGREVCR_NOREV not required, remove the defines also.
udelay(10);
Hi, Prabhakar,
0
reverse
[Alison Wang] Re-setting is not required. It is preferred to remain the bits reversed for other SCFG Registers.
[Alison Wang] ok.
udelay(10);
Best Regards, Alison Wang
Add define CONFIG_SYS_WRITE_SWAPPED_DATA. For LS1021AQDS and LS1021QTWR nor flash read and write should swap the bytes when handle unaligned tail bytes.
Signed-off-by: Yuan Yao yao.yuan@freescale.com --- include/configs/ls1021aqds.h | 1 + include/configs/ls1021atwr.h | 1 + 2 files changed, 2 insertions(+)
diff --git a/include/configs/ls1021aqds.h b/include/configs/ls1021aqds.h index bb47813..7e78e78 100644 --- a/include/configs/ls1021aqds.h +++ b/include/configs/ls1021aqds.h @@ -109,6 +109,7 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_FLASH_QUIET_TEST #define CONFIG_FLASH_SHOW_PROGRESS 45 #define CONFIG_CFI_FLASH_USE_WEAK_ACCESSORS +#define CONFIG_SYS_WRITE_SWAPPED_DATA
#define CONFIG_SYS_MAX_FLASH_BANKS 2 /* number of banks */ #define CONFIG_SYS_MAX_FLASH_SECT 1024 /* sectors per device */ diff --git a/include/configs/ls1021atwr.h b/include/configs/ls1021atwr.h index 45b2272..2427f2e 100644 --- a/include/configs/ls1021atwr.h +++ b/include/configs/ls1021atwr.h @@ -93,6 +93,7 @@ #define CONFIG_SYS_FLASH_BANKS_LIST { CONFIG_SYS_FLASH_BASE_PHYS }
/* CPLD */
Subject and description of patch has mismatch. Subject say it is for "write" but description say for both read & write.
Regards, Prabhakar
SystemID information could be read through I2C1 from EEPROM on LS1021ATWR board.
As LS1 is a little-endian processor, getting the version ID by be32_to_cpu() is wrong. Fix it by using e.version directly. This change will be compatible for both ARM and PowerPC.
Signed-off-by: Alison Wang alison.wang@freescale.com --- board/freescale/common/sys_eeprom.c | 4 ++-- include/configs/ls1021atwr.h | 9 +++++++++ 2 files changed, 11 insertions(+), 2 deletions(-)
diff --git a/board/freescale/common/sys_eeprom.c b/board/freescale/common/sys_eeprom.c index 6144c53..3426b8a 100644 --- a/board/freescale/common/sys_eeprom.c +++ b/board/freescale/common/sys_eeprom.c @@ -90,7 +90,7 @@ static void show_eeprom(void) /* EEPROM tag ID, either CCID or NXID */ #ifdef CONFIG_SYS_I2C_EEPROM_NXID printf("ID: %c%c%c%c v%u\n", e.id[0], e.id[1], e.id[2], e.id[3], - be32_to_cpu(e.version)); + e.version); #else printf("ID: %c%c%c%c\n", e.id[0], e.id[1], e.id[2], e.id[3]); #endif @@ -485,7 +485,7 @@ int mac_read_from_eeprom(void)
#ifdef CONFIG_SYS_I2C_EEPROM_NXID printf("%c%c%c%c v%u\n", e.id[0], e.id[1], e.id[2], e.id[3], - be32_to_cpu(e.version)); + e.version); #else printf("%c%c%c%c\n", e.id[0], e.id[1], e.id[2], e.id[3]); #endif diff --git a/include/configs/ls1021atwr.h b/include/configs/ls1021atwr.h index 2427f2e..b02fda2 100644 --- a/include/configs/ls1021atwr.h +++ b/include/configs/ls1021atwr.h @@ -155,6 +155,15 @@ #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_MXC
+/* EEPROM */ +#define CONFIG_ID_EEPROM +#define CONFIG_SYS_I2C_EEPROM_NXID +#define CONFIG_SYS_EEPROM_BUS_NUM 1 +#define CONFIG_SYS_I2C_EEPROM_ADDR 0x53 +#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 +#define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 3 +#define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 5 + /* * MMC */
Hi Alison,
Please be more specific: this patch specifically targets arch ls102xa and some associated boards, but the subject/commit summary (and commit message) does not mention that, making it look like a very generic patch.
Amicalement,
Hi, Albert,
[Alison Wang] Yes, I will change it in v2. Thanks.
Albert ARIBAUD
Alison Wang
Huan Wang
Prabhakar Kushwaha
