[U-Boot] [PATCH 1/2] configs: Add SPL Kconfig options
Add CONFIG_SPL_MMC_SUPPORT and CONFIG_SPL_NAND_SUPPORT for Kconfig selection.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com Signed-off-by: Shyam Saini shyam.saini@amarulasolutions.com --- configs/imx6dl_icore_nand_defconfig | 1 + configs/imx6dl_mamoj_defconfig | 1 + configs/imx6q_icore_nand_defconfig | 1 + configs/imx6q_logic_defconfig | 1 + configs/imx6qdl_icore_mipi_defconfig | 1 + configs/imx6qdl_icore_mmc_defconfig | 1 + configs/imx6qdl_icore_nand_defconfig | 1 + configs/imx6qdl_icore_rqs_defconfig | 1 + configs/imx6ul_geam_mmc_defconfig | 1 + configs/imx6ul_geam_nand_defconfig | 1 + configs/imx6ul_isiot_emmc_defconfig | 1 + configs/imx6ul_isiot_nand_defconfig | 1 + include/configs/imx6-engicam.h | 10 +--------- 13 files changed, 13 insertions(+), 9 deletions(-)
diff --git a/configs/imx6dl_icore_nand_defconfig b/configs/imx6dl_icore_nand_defconfig index 7b1f7abc4e..94c81b3e4a 100644 --- a/configs/imx6dl_icore_nand_defconfig +++ b/configs/imx6dl_icore_nand_defconfig @@ -13,6 +13,7 @@ CONFIG_NR_DRAM_BANKS=1 CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_FIT_VERBOSE=y +CONFIG_SPL_NAND_SUPPORT=y CONFIG_IMAGE_FORMAT_LEGACY=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" CONFIG_BOOTDELAY=3 diff --git a/configs/imx6dl_mamoj_defconfig b/configs/imx6dl_mamoj_defconfig index f3661c0a76..62a068c3c1 100644 --- a/configs/imx6dl_mamoj_defconfig +++ b/configs/imx6dl_mamoj_defconfig @@ -11,6 +11,7 @@ CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" CONFIG_BOOTDELAY=3 CONFIG_BOUNCE_BUFFER=y CONFIG_SPL_OS_BOOT=y +CONFIG_SPL_MMC_SUPPORT=y CONFIG_CRC32_VERIFY=y CONFIG_CMD_MEMTEST=y CONFIG_CMD_DFU=y diff --git a/configs/imx6q_icore_nand_defconfig b/configs/imx6q_icore_nand_defconfig index 1e26f7a8c9..58c4ccc66c 100644 --- a/configs/imx6q_icore_nand_defconfig +++ b/configs/imx6q_icore_nand_defconfig @@ -13,6 +13,7 @@ CONFIG_NR_DRAM_BANKS=1 CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_FIT_VERBOSE=y +CONFIG_SPL_NAND_SUPPORT=y CONFIG_IMAGE_FORMAT_LEGACY=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" CONFIG_BOOTDELAY=3 diff --git a/configs/imx6q_logic_defconfig b/configs/imx6q_logic_defconfig index 385efcec4e..33f9c3b19d 100644 --- a/configs/imx6q_logic_defconfig +++ b/configs/imx6q_logic_defconfig @@ -19,6 +19,7 @@ CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y CONFIG_BOUNCE_BUFFER=y CONFIG_SPL_RAW_IMAGE_SUPPORT=y CONFIG_SPL_SEPARATE_BSS=y +CONFIG_SPL_MMC_SUPPORT=y # CONFIG_TPL_BANNER_PRINT is not set # CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR is not set CONFIG_SPL_DMA_SUPPORT=y diff --git a/configs/imx6qdl_icore_mipi_defconfig b/configs/imx6qdl_icore_mipi_defconfig index 7a0e5169b6..8b30115b37 100644 --- a/configs/imx6qdl_icore_mipi_defconfig +++ b/configs/imx6qdl_icore_mipi_defconfig @@ -17,6 +17,7 @@ CONFIG_NR_DRAM_BANKS=1 CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_FIT_VERBOSE=y +CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_LOAD_FIT=y CONFIG_IMAGE_FORMAT_LEGACY=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" diff --git a/configs/imx6qdl_icore_mmc_defconfig b/configs/imx6qdl_icore_mmc_defconfig index 223f732207..8b8b382bf9 100644 --- a/configs/imx6qdl_icore_mmc_defconfig +++ b/configs/imx6qdl_icore_mmc_defconfig @@ -24,6 +24,7 @@ CONFIG_NR_DRAM_BANKS=1 CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_FIT_VERBOSE=y +CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_LOAD_FIT=y CONFIG_IMAGE_FORMAT_LEGACY=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" diff --git a/configs/imx6qdl_icore_nand_defconfig b/configs/imx6qdl_icore_nand_defconfig index 8702426561..5dfd276270 100644 --- a/configs/imx6qdl_icore_nand_defconfig +++ b/configs/imx6qdl_icore_nand_defconfig @@ -12,6 +12,7 @@ CONFIG_NR_DRAM_BANKS=1 CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_FIT_VERBOSE=y +CONFIG_SPL_NAND_SUPPORT=y CONFIG_IMAGE_FORMAT_LEGACY=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" CONFIG_BOOTDELAY=3 diff --git a/configs/imx6qdl_icore_rqs_defconfig b/configs/imx6qdl_icore_rqs_defconfig index a4766063ca..a56196b68a 100644 --- a/configs/imx6qdl_icore_rqs_defconfig +++ b/configs/imx6qdl_icore_rqs_defconfig @@ -14,6 +14,7 @@ CONFIG_NR_DRAM_BANKS=1 CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_FIT_VERBOSE=y +CONFIG_SPL_MMC_SUPPORT=y CONFIG_SPL_LOAD_FIT=y CONFIG_IMAGE_FORMAT_LEGACY=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" diff --git a/configs/imx6ul_geam_mmc_defconfig b/configs/imx6ul_geam_mmc_defconfig index 8a7f41b53c..4c328fac2f 100644 --- a/configs/imx6ul_geam_mmc_defconfig +++ b/configs/imx6ul_geam_mmc_defconfig @@ -14,6 +14,7 @@ CONFIG_NR_DRAM_BANKS=1 CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_FIT_VERBOSE=y +CONFIG_SPL_MMC_SUPPORT=y CONFIG_IMAGE_FORMAT_LEGACY=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" CONFIG_BOOTDELAY=3 diff --git a/configs/imx6ul_geam_nand_defconfig b/configs/imx6ul_geam_nand_defconfig index bf61f768ab..22b559b9ed 100644 --- a/configs/imx6ul_geam_nand_defconfig +++ b/configs/imx6ul_geam_nand_defconfig @@ -12,6 +12,7 @@ CONFIG_NR_DRAM_BANKS=1 CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_FIT_VERBOSE=y +CONFIG_SPL_NAND_SUPPORT=y CONFIG_IMAGE_FORMAT_LEGACY=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" CONFIG_BOOTDELAY=3 diff --git a/configs/imx6ul_isiot_emmc_defconfig b/configs/imx6ul_isiot_emmc_defconfig index abf1a93a98..b62f92f525 100644 --- a/configs/imx6ul_isiot_emmc_defconfig +++ b/configs/imx6ul_isiot_emmc_defconfig @@ -14,6 +14,7 @@ CONFIG_NR_DRAM_BANKS=1 CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_FIT_VERBOSE=y +CONFIG_SPL_MMC_SUPPORT=y CONFIG_IMAGE_FORMAT_LEGACY=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" CONFIG_BOOTDELAY=3 diff --git a/configs/imx6ul_isiot_nand_defconfig b/configs/imx6ul_isiot_nand_defconfig index 8961661a90..a01f61e7bf 100644 --- a/configs/imx6ul_isiot_nand_defconfig +++ b/configs/imx6ul_isiot_nand_defconfig @@ -12,6 +12,7 @@ CONFIG_NR_DRAM_BANKS=1 CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_FIT_VERBOSE=y +CONFIG_SPL_NAND_SUPPORT=y CONFIG_IMAGE_FORMAT_LEGACY=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" CONFIG_BOOTDELAY=3 diff --git a/include/configs/imx6-engicam.h b/include/configs/imx6-engicam.h index 571852d803..79dfe5955d 100644 --- a/include/configs/imx6-engicam.h +++ b/include/configs/imx6-engicam.h @@ -203,14 +203,6 @@ #endif
/* SPL */ -#ifdef CONFIG_SPL -# ifdef CONFIG_ENV_IS_IN_NAND -# define CONFIG_SPL_NAND_SUPPORT -# else -# define CONFIG_SPL_MMC_SUPPORT -# endif - -# include "imx6_spl.h" -#endif +#include "imx6_spl.h"
#endif /* __IMX6_ENGICAM_CONFIG_H */
Right now, i.MX6 supports single image variants like u-boot-with-spl.imx and u-boot-nand-with-spl.imx for MMC and NAND boots respectively.
But, it requires an explicit argument passing to 'make' to build these images, like 'make u-boot-with-spl.imx'
This patch would fix this by selecting BUILD_TARGET images with respective SPL variants MMC, NAND. This would eventually help us to get rid of explicit argument passing to 'make' to build these single images.
Tested-by: Shyam Saini shyam.saini@amarulasolutions.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com Signed-off-by: Shyam Saini shyam.saini@amarulasolutions.com --- Kconfig | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/Kconfig b/Kconfig index 7a5491bd67..05d1a19b1d 100644 --- a/Kconfig +++ b/Kconfig @@ -243,6 +243,8 @@ config BUILD_TARGET default "u-boot.itb" if SPL_LOAD_FIT && ARCH_SUNXI default "u-boot.kwb" if KIRKWOOD default "u-boot-with-spl.bin" if ARCH_AT91 && SPL_NAND_SUPPORT + default "u-boot-with-spl.imx" if ARCH_MX6 && SPL_MMC_SUPPORT + default "u-boot-with-nand-spl.imx" if ARCH_MX6 && SPL_NAND_SUPPORT help Some SoCs need special image types (e.g. U-Boot binary with a special header) as build targets. By defining
Shyam Saini
