[U-Boot] Pull request: u-boot-net.git master
Hi Tom,
The few checkpatch alerts were checked to be exceptions. All passed travis. Thanks!
The following changes since commit 0a60a81ba3860946551cb79aa6486aa076e357f3:
Kconfig: sandbox: enable cmd_avb and dependencies (2018-10-07 13:34:19 -0400)
git://git.denx.de/u-boot-net.git master
for you to fetch changes up to 1a048cd65645338069d591108031fa4ebe96d53f:
driver: net: fsl-mc: Add support of multiple phys for dpmac (2018-10-10 12:45:28 -0500)
---------------------------------------------------------------- Bin Meng (7): linux/mii.h: Sync with Linux kernel v4.17 linux/mdio.h: Sync with Linux kernel v4.17 linux/compat.h: Add netdev_### log macros net: pch_gbe: Make probe/remove static linux/if_ether.h: Initial import from Linux kernel v4.17 net.h: Include linux/if_ether.h to avoid duplication linux/if_ether.h: Add VLAN related macros
Duncan Hare (1): net: Consolidate UDP header functions
Janine Hagemann (3): net: phy: ti: Add lane swapping support in the DP83867 TI's PHY driver net: phy: ti: Recover from "port mirroring" N/A MODE4 net: phy: ti: Add binding for the CLK_OUT pin muxing
Joe Hershberger (10): net: sandbox: Move disabled flag into priv struct net: sandbox: Refactor sandbox send function net: sandbox: Make the fake eth driver response configurable net: sandbox: Share the priv structure with tests net: sandbox: Allow fake eth to handle more than 1 packet response net: Add an accessor to know if waiting for ARP net: sandbox: Add a priv ptr for tests to use test: eth: Add a test for ARP requests test: eth: Add a test for the target being pinged net: Don't overwrite waiting packets with asynchronous replies
Pankaj Bansal (6): driver: net: fsl-mc: modify the label name driver: net: fsl-mc: remove unused strcture elements driver: net: fsl-mc: fix error handing in init_phy driver: net: fsl-mc: Modify the dpmac link detection method driver: net: fsl-mc: initialize dpmac irrespective of phy driver: net: fsl-mc: Add support of multiple phys for dpmac
Priyanka Jain (1): phy: Add 25G_AUI, XLAUI, CAUI2, CAUI4 related macros
arch/sandbox/include/asm/eth.h | 93 +++++++ board/Synology/ds414/cmd_syno.c | 1 - board/freescale/ls1088a/eth_ls1088aqds.c | 18 +- board/freescale/ls1088a/eth_ls1088ardb.c | 21 +- board/freescale/ls2080aqds/eth.c | 26 +- board/freescale/ls2080ardb/eth_ls2080rdb.c | 24 +- doc/device-tree-bindings/net/ti,dp83867.txt | 8 + drivers/net/dc2114x.c | 1 - drivers/net/eepro100.c | 2 - drivers/net/fsl-mc/mc.c | 6 +- drivers/net/ldpaa_eth/ldpaa_eth.c | 171 +++++++----- drivers/net/ldpaa_eth/ldpaa_eth.h | 1 - drivers/net/ldpaa_eth/ldpaa_wriop.c | 69 +++-- drivers/net/mvneta.c | 8 - drivers/net/mvpp2.c | 13 - drivers/net/natsemi.c | 1 - drivers/net/ns8382x.c | 1 - drivers/net/pch_gbe.c | 4 +- drivers/net/phy/ti.c | 93 ++++++- drivers/net/rtl8139.c | 4 - drivers/net/rtl8169.c | 4 - drivers/net/sandbox.c | 417 +++++++++++++++++++++------- drivers/usb/eth/lan7x.h | 2 +- drivers/usb/gadget/ether.c | 9 +- drivers/usb/gadget/rndis.c | 6 - include/dt-bindings/net/ti-dp83867.h | 15 + include/fsl-mc/ldpaa_wriop.h | 46 +-- include/linux/compat.h | 19 ++ include/linux/if_ether.h | 178 ++++++++++++ include/linux/mdio.h | 34 ++- include/linux/mii.h | 126 +++++---- include/net.h | 16 +- include/phy_interface.h | 8 + include/usb_ether.h | 10 - net/arp.c | 20 +- net/arp.h | 1 + net/net.c | 43 ++- net/ping.c | 14 +- test/dm/eth.c | 170 ++++++++++++ 39 files changed, 1294 insertions(+), 409 deletions(-) create mode 100644 include/linux/if_ether.h
Thanks! -Joe
On Thu, Oct 11, 2018 at 02:23:38PM -0500, Joe Hershberger wrote:
Hi Tom,
Joe Hershberger
