[PATCH] arm: dts: ls1043ardb: configure the RGMII ports with rgmii-id
The RGMII ports on LS1043ARDB platforms require both RX and TX internal delays to be enabled. The device tree reports only the TX ID because the RX ID used to be enabled by default.
With the addition of RX ID support for the Realtek 8211F PHY driver in commit e32e4d0f58cb ("net: phy: realtek: add rx delay support for RTL8211F"), the RX ID is disabled by the driver if not reported explicitly. This causes the RX to no longer work.
Change the phy-connection-type for the RGMII ports to "rgmii-id" in order to enable both RX and TX internal delays.
Fixes: be1d75896996 ("ARM: dts: add QorIQ DPAA 1 FMan v3 to LS1043ARDB") Signed-off-by: Camelia Groza camelia.groza@nxp.com --- arch/arm/dts/fsl-ls1043a-rdb.dts | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/arch/arm/dts/fsl-ls1043a-rdb.dts b/arch/arm/dts/fsl-ls1043a-rdb.dts index 6e4ea5b40c78..9e7c79fd2b98 100644 --- a/arch/arm/dts/fsl-ls1043a-rdb.dts +++ b/arch/arm/dts/fsl-ls1043a-rdb.dts @@ -3,7 +3,7 @@ * Device Tree Include file for Freescale Layerscape-1043A family SoC. * * Copyright (C) 2015, Freescale Semiconductor - * Copyright 2020 NXP + * Copyright 2020-2021 NXP * * Mingkai Hu Mingkai.hu@freescale.com */ @@ -117,13 +117,13 @@
ethernet@e4000 { phy-handle = <&rgmii_phy1>; - phy-connection-type = "rgmii-txid"; + phy-connection-type = "rgmii-id"; status = "okay"; };
ethernet@e6000 { phy-handle = <&rgmii_phy2>; - phy-connection-type = "rgmii-txid"; + phy-connection-type = "rgmii-id"; status = "okay"; };
Camelia Groza
