[U-Boot] [PATCH,v2] mips: rename mach-mt7620 to mach-mtmips
Currently mach-mt7620 contains only support for mt7628. To avoid confusion, rename mach-mt7620 to mach-mtmips, which means MediaTek MIPS platforms. MT7620 and MT7628 should be distinguished by SOC_MT7620 and SOC_MT7628 because they do not share the same lowlevel codes.
Dependencies of four drivers are changed to SOC_MT7628 as these drivers are only used by MT7628.
Reviewed-by: Stefan Roese sr@denx.de Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- Changes since v1: rename mach-mt7628 to mach-mtmips --- arch/mips/Kconfig | 6 +++--- arch/mips/Makefile | 2 +- arch/mips/dts/Makefile | 2 +- arch/mips/{mach-mt7620 => mach-mtmips}/Kconfig | 14 +++++++------- arch/mips/{mach-mt7620 => mach-mtmips}/Makefile | 0 arch/mips/{mach-mt7620 => mach-mtmips}/cpu.c | 0 .../{mach-mt7620 => mach-mtmips}/ddr_calibrate.c | 0 .../{mach-mt7620 => mach-mtmips}/lowlevel_init.S | 0 arch/mips/{mach-mt7620 => mach-mtmips}/mt76xx.h | 0 configs/gardena-smart-gateway-mt7688-ram_defconfig | 2 +- configs/gardena-smart-gateway-mt7688_defconfig | 2 +- configs/linkit-smart-7688-ram_defconfig | 2 +- configs/linkit-smart-7688_defconfig | 2 +- drivers/gpio/Kconfig | 2 +- drivers/net/Kconfig | 2 +- drivers/spi/Kconfig | 2 +- drivers/watchdog/Kconfig | 2 +- 17 files changed, 20 insertions(+), 20 deletions(-) rename arch/mips/{mach-mt7620 => mach-mtmips}/Kconfig (93%) rename arch/mips/{mach-mt7620 => mach-mtmips}/Makefile (100%) rename arch/mips/{mach-mt7620 => mach-mtmips}/cpu.c (100%) rename arch/mips/{mach-mt7620 => mach-mtmips}/ddr_calibrate.c (100%) rename arch/mips/{mach-mt7620 => mach-mtmips}/lowlevel_init.S (100%) rename arch/mips/{mach-mt7620 => mach-mtmips}/mt76xx.h (100%)
diff --git a/arch/mips/Kconfig b/arch/mips/Kconfig index 194f4f349e..9cf8e9800d 100644 --- a/arch/mips/Kconfig +++ b/arch/mips/Kconfig @@ -74,8 +74,8 @@ config ARCH_BMIPS select SYSRESET imply CMD_DM
-config ARCH_MT7620 - bool "Support MT7620/7688 SoCs" +config ARCH_MTMIPS + bool "Support MediaTek MIPS platforms" imply CMD_DM select DISPLAY_CPUINFO select DM @@ -153,7 +153,7 @@ source "arch/mips/mach-mscc/Kconfig" source "arch/mips/mach-bmips/Kconfig" source "arch/mips/mach-jz47xx/Kconfig" source "arch/mips/mach-pic32/Kconfig" -source "arch/mips/mach-mt7620/Kconfig" +source "arch/mips/mach-mtmips/Kconfig"
if MIPS
diff --git a/arch/mips/Makefile b/arch/mips/Makefile index 029d290f1e..af3f227436 100644 --- a/arch/mips/Makefile +++ b/arch/mips/Makefile @@ -15,7 +15,7 @@ machine-$(CONFIG_ARCH_ATH79) += ath79 machine-$(CONFIG_ARCH_BMIPS) += bmips machine-$(CONFIG_ARCH_JZ47XX) += jz47xx machine-$(CONFIG_MACH_PIC32) += pic32 -machine-$(CONFIG_ARCH_MT7620) += mt7620 +machine-$(CONFIG_ARCH_MTMIPS) += mtmips machine-$(CONFIG_ARCH_MSCC) += mscc
machdirs := $(patsubst %,arch/mips/mach-%/,$(machine-y)) diff --git a/arch/mips/dts/Makefile b/arch/mips/dts/Makefile index 3522e6cdc8..e2de1da147 100644 --- a/arch/mips/dts/Makefile +++ b/arch/mips/dts/Makefile @@ -1,6 +1,6 @@ # SPDX-License-Identifier: GPL-2.0+
-dtb-$(CONFIG_ARCH_MT7620) += \ +dtb-$(CONFIG_ARCH_MTMIPS) += \ gardena-smart-gateway-mt7688.dtb \ linkit-smart-7688.dtb dtb-$(CONFIG_TARGET_AP121) += ap121.dtb diff --git a/arch/mips/mach-mt7620/Kconfig b/arch/mips/mach-mtmips/Kconfig similarity index 93% rename from arch/mips/mach-mt7620/Kconfig rename to arch/mips/mach-mtmips/Kconfig index a983443999..4af2d54528 100644 --- a/arch/mips/mach-mt7620/Kconfig +++ b/arch/mips/mach-mtmips/Kconfig @@ -1,20 +1,20 @@ menu "MediaTek MIPS platforms" - depends on ARCH_MT7620 + depends on ARCH_MTMIPS
config SYS_MALLOC_F_LEN default 0x1000
config SYS_SOC - default "mt7620" if SOC_MT7620 + default "mt7628" if SOC_MT7628
choice prompt "MediaTek MIPS SoC select"
-config SOC_MT7620 - bool "MT7620/8" +config SOC_MT7628 + bool "MT7628" select MIPS_L1_CACHE_SHIFT_5 help - This supports MediaTek MIPS MT7620 family. + This supports MediaTek MT7628/MT7688.
endchoice
@@ -23,7 +23,7 @@ choice
config BOARD_GARDENA_SMART_GATEWAY_MT7688 bool "GARDENA smart Gateway" - depends on SOC_MT7620 + depends on SOC_MT7628 select BOARD_LATE_INIT select SUPPORTS_BOOT_RAM help @@ -32,7 +32,7 @@ config BOARD_GARDENA_SMART_GATEWAY_MT7688
config BOARD_LINKIT_SMART_7688 bool "LinkIt Smart 7688" - depends on SOC_MT7620 + depends on SOC_MT7628 select SUPPORTS_BOOT_RAM help Seeed LinkIt Smart 7688 boards have a MT7688 SoC with 128 MiB of RAM diff --git a/arch/mips/mach-mt7620/Makefile b/arch/mips/mach-mtmips/Makefile similarity index 100% rename from arch/mips/mach-mt7620/Makefile rename to arch/mips/mach-mtmips/Makefile diff --git a/arch/mips/mach-mt7620/cpu.c b/arch/mips/mach-mtmips/cpu.c similarity index 100% rename from arch/mips/mach-mt7620/cpu.c rename to arch/mips/mach-mtmips/cpu.c diff --git a/arch/mips/mach-mt7620/ddr_calibrate.c b/arch/mips/mach-mtmips/ddr_calibrate.c similarity index 100% rename from arch/mips/mach-mt7620/ddr_calibrate.c rename to arch/mips/mach-mtmips/ddr_calibrate.c diff --git a/arch/mips/mach-mt7620/lowlevel_init.S b/arch/mips/mach-mtmips/lowlevel_init.S similarity index 100% rename from arch/mips/mach-mt7620/lowlevel_init.S rename to arch/mips/mach-mtmips/lowlevel_init.S diff --git a/arch/mips/mach-mt7620/mt76xx.h b/arch/mips/mach-mtmips/mt76xx.h similarity index 100% rename from arch/mips/mach-mt7620/mt76xx.h rename to arch/mips/mach-mtmips/mt76xx.h diff --git a/configs/gardena-smart-gateway-mt7688-ram_defconfig b/configs/gardena-smart-gateway-mt7688-ram_defconfig index 7c8ae0f647..e09950637f 100644 --- a/configs/gardena-smart-gateway-mt7688-ram_defconfig +++ b/configs/gardena-smart-gateway-mt7688-ram_defconfig @@ -1,7 +1,7 @@ CONFIG_MIPS=y CONFIG_SYS_TEXT_BASE=0x80010000 CONFIG_NR_DRAM_BANKS=1 -CONFIG_ARCH_MT7620=y +CONFIG_ARCH_MTMIPS=y # CONFIG_MIPS_BOOT_ENV_LEGACY is not set CONFIG_MIPS_BOOT_FDT=y CONFIG_ENV_VARS_UBOOT_CONFIG=y diff --git a/configs/gardena-smart-gateway-mt7688_defconfig b/configs/gardena-smart-gateway-mt7688_defconfig index 8fd676025a..ad0db2e723 100644 --- a/configs/gardena-smart-gateway-mt7688_defconfig +++ b/configs/gardena-smart-gateway-mt7688_defconfig @@ -1,7 +1,7 @@ CONFIG_MIPS=y CONFIG_SYS_TEXT_BASE=0x9c000000 CONFIG_NR_DRAM_BANKS=1 -CONFIG_ARCH_MT7620=y +CONFIG_ARCH_MTMIPS=y CONFIG_BOOT_ROM=y CONFIG_ONBOARD_DDR2_SIZE_1024MBIT=y CONFIG_ONBOARD_DDR2_CHIP_WIDTH_16BIT=y diff --git a/configs/linkit-smart-7688-ram_defconfig b/configs/linkit-smart-7688-ram_defconfig index 6e9aa7adef..c2502b2713 100644 --- a/configs/linkit-smart-7688-ram_defconfig +++ b/configs/linkit-smart-7688-ram_defconfig @@ -1,7 +1,7 @@ CONFIG_MIPS=y CONFIG_SYS_TEXT_BASE=0x80010000 CONFIG_NR_DRAM_BANKS=1 -CONFIG_ARCH_MT7620=y +CONFIG_ARCH_MTMIPS=y CONFIG_BOARD_LINKIT_SMART_7688=y # CONFIG_MIPS_BOOT_ENV_LEGACY is not set CONFIG_MIPS_BOOT_FDT=y diff --git a/configs/linkit-smart-7688_defconfig b/configs/linkit-smart-7688_defconfig index 5660f41e8e..fba1bfd653 100644 --- a/configs/linkit-smart-7688_defconfig +++ b/configs/linkit-smart-7688_defconfig @@ -1,7 +1,7 @@ CONFIG_MIPS=y CONFIG_SYS_TEXT_BASE=0x9c000000 CONFIG_NR_DRAM_BANKS=1 -CONFIG_ARCH_MT7620=y +CONFIG_ARCH_MTMIPS=y CONFIG_BOARD_LINKIT_SMART_7688=y CONFIG_BOOT_ROM=y CONFIG_ONBOARD_DDR2_SIZE_1024MBIT=y diff --git a/drivers/gpio/Kconfig b/drivers/gpio/Kconfig index b3e4ecc50e..684ca9d868 100644 --- a/drivers/gpio/Kconfig +++ b/drivers/gpio/Kconfig @@ -351,7 +351,7 @@ config MPC8XXX_GPIO
config MT7621_GPIO bool "MediaTek MT7621 GPIO driver" - depends on DM_GPIO && ARCH_MT7620 + depends on DM_GPIO && SOC_MT7628 default y help Say yes here to support MediaTek MT7621 compatible GPIOs. diff --git a/drivers/net/Kconfig b/drivers/net/Kconfig index 6e436b56ab..64cdc58f92 100644 --- a/drivers/net/Kconfig +++ b/drivers/net/Kconfig @@ -269,7 +269,7 @@ config MACB_ZYNQ
config MT7628_ETH bool "MediaTek MT7628 Ethernet Interface" - depends on ARCH_MT7620 + depends on SOC_MT7628 help The MediaTek MT7628 ethernet interface is used on MT7628 and MT7688 based boards. diff --git a/drivers/spi/Kconfig b/drivers/spi/Kconfig index fb794adae7..2830f76587 100644 --- a/drivers/spi/Kconfig +++ b/drivers/spi/Kconfig @@ -133,7 +133,7 @@ config MPC8XX_SPI
config MT7621_SPI bool "MediaTek MT7621 SPI driver" - depends on ARCH_MT7620 + depends on SOC_MT7628 help Enable the MT7621 SPI driver. This driver can be used to access the SPI NOR flash on platforms embedding this Ralink / MediaTek diff --git a/drivers/watchdog/Kconfig b/drivers/watchdog/Kconfig index 3bce0aa0b8..8eca3f3ca9 100644 --- a/drivers/watchdog/Kconfig +++ b/drivers/watchdog/Kconfig @@ -143,7 +143,7 @@ config WDT_AT91
config WDT_MT7621 bool "MediaTek MT7621 watchdog timer support" - depends on WDT && ARCH_MT7620 + depends on WDT && SOC_MT7628 help Select this to enable Ralink / Mediatek watchdog timer, which can be found on some MediaTek chips.
Weijie Gao
