[PATCH] mmc: Add SPL_MMC_PWRSEQ to fix link issue when building SPL
With MMC_PWRSEQ enabled the following link issue may happen when building SPL and SPL_PWRSEQ is not enabled.
aarch64-linux-gnu-ld.bfd: drivers/mmc/meson_gx_mmc.o: in function `meson_mmc_probe': drivers/mmc/meson_gx_mmc.c:295: undefined reference to `pwrseq_set_power'
Fix this by adding a SPL_MMC_PWRSEQ Kconfig option used to enable mmc pwrseq support in SPL.
Also add depends on DM_GPIO to fix following link issue:
aarch64-linux-gnu-ld.bfd: drivers/mmc/mmc-pwrseq.o: in function `mmc_pwrseq_set_power': drivers/mmc/mmc-pwrseq.c:26: undefined reference to `gpio_request_by_name' aarch64-linux-gnu-ld.bfd: drivers/mmc/mmc-pwrseq.c:29: undefined reference to `dm_gpio_set_value' aarch64-linux-gnu-ld.bfd: drivers/mmc/mmc-pwrseq.c:31: undefined reference to `dm_gpio_set_value'
Signed-off-by: Jonas Karlman jonas@kwiboo.se --- drivers/mmc/Kconfig | 10 +++++++++- drivers/mmc/Makefile | 2 +- drivers/mmc/meson_gx_mmc.c | 2 +- drivers/mmc/rockchip_dw_mmc.c | 2 +- include/mmc.h | 4 ++-- 5 files changed, 14 insertions(+), 6 deletions(-)
diff --git a/drivers/mmc/Kconfig b/drivers/mmc/Kconfig index de01b9687bad..a9931d39412d 100644 --- a/drivers/mmc/Kconfig +++ b/drivers/mmc/Kconfig @@ -20,11 +20,19 @@ config MMC_WRITE
config MMC_PWRSEQ bool "HW reset support for eMMC" - depends on PWRSEQ + depends on PWRSEQ && DM_GPIO help Ths select Hardware reset support aka pwrseq-emmc for eMMC devices.
+config SPL_MMC_PWRSEQ + bool "HW reset support for eMMC in SPL" + depends on SPL_PWRSEQ && SPL_DM_GPIO + default y if MMC_PWRSEQ + help + Ths select Hardware reset support aka pwrseq-emmc for eMMC + devices in SPL. + config MMC_BROKEN_CD bool "Poll for broken card detection case" help diff --git a/drivers/mmc/Makefile b/drivers/mmc/Makefile index 2c65c4765ab2..0a79dd058bef 100644 --- a/drivers/mmc/Makefile +++ b/drivers/mmc/Makefile @@ -11,7 +11,7 @@ obj-$(CONFIG_$(SPL_TPL_)BOOTSTD) += mmc_bootdev.o endif
obj-$(CONFIG_$(SPL_TPL_)MMC_WRITE) += mmc_write.o -obj-$(CONFIG_MMC_PWRSEQ) += mmc-pwrseq.o +obj-$(CONFIG_$(SPL_)MMC_PWRSEQ) += mmc-pwrseq.o obj-$(CONFIG_MMC_SDHCI_ADMA_HELPERS) += sdhci-adma.o
ifndef CONFIG_$(SPL_)BLK diff --git a/drivers/mmc/meson_gx_mmc.c b/drivers/mmc/meson_gx_mmc.c index fcf4f03d1e24..0825c0a2a838 100644 --- a/drivers/mmc/meson_gx_mmc.c +++ b/drivers/mmc/meson_gx_mmc.c @@ -288,7 +288,7 @@ static int meson_mmc_probe(struct udevice *dev)
mmc_set_clock(mmc, cfg->f_min, MMC_CLK_ENABLE);
-#ifdef CONFIG_MMC_PWRSEQ +#if CONFIG_IS_ENABLED(MMC_PWRSEQ) /* Enable power if needed */ ret = mmc_pwrseq_get_power(dev, cfg); if (!ret) { diff --git a/drivers/mmc/rockchip_dw_mmc.c b/drivers/mmc/rockchip_dw_mmc.c index 72c820ee6330..ad4529d6afa8 100644 --- a/drivers/mmc/rockchip_dw_mmc.c +++ b/drivers/mmc/rockchip_dw_mmc.c @@ -145,7 +145,7 @@ static int rockchip_dwmmc_probe(struct udevice *dev)
host->fifo_mode = priv->fifo_mode;
-#ifdef CONFIG_MMC_PWRSEQ +#if CONFIG_IS_ENABLED(MMC_PWRSEQ) /* Enable power if needed */ ret = mmc_pwrseq_get_power(dev, &plat->cfg); if (!ret) { diff --git a/include/mmc.h b/include/mmc.h index 1022db3ffa7c..9aef31ea5deb 100644 --- a/include/mmc.h +++ b/include/mmc.h @@ -590,7 +590,7 @@ struct mmc_config { uint f_max; uint b_max; unsigned char part_type; -#ifdef CONFIG_MMC_PWRSEQ +#if CONFIG_IS_ENABLED(MMC_PWRSEQ) struct udevice *pwr_dev; #endif }; @@ -808,7 +808,7 @@ int mmc_deinit(struct mmc *mmc); */ int mmc_of_parse(struct udevice *dev, struct mmc_config *cfg);
-#ifdef CONFIG_MMC_PWRSEQ +#if CONFIG_IS_ENABLED(MMC_PWRSEQ) /** * mmc_pwrseq_get_power() - get a power device from device tree *
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
- depends on PWRSEQ
- depends on PWRSEQ && DM_GPIO help Ths select Hardware reset support aka pwrseq-emmc for eMMC devices.
- bool "HW reset support for eMMC in SPL"
- depends on SPL_PWRSEQ && SPL_DM_GPIO
- default y if MMC_PWRSEQ
- help
devices in SPL.
- config MMC_BROKEN_CD bool "Poll for broken card detection case" help
- mmc_pwrseq_get_power() - get a power device from device tree
- depends on PWRSEQ
- help
devices in SPL.
Reviewed-by: Neil Armstrong neil.armstrong@linaro.org
This issue was discovered while working on SPL support for Amlogic devices (not upstream yet), which is why the errors are related to the `meson_gx_mmc.c` file. It doesn't seem to be an issue specific to meson_gx_mmc though.
Cheers.
- depends on PWRSEQ
- help
nit: 'Ths'->'This'
Seems to be the same earlier, in MMC_PWRSEQ
devices in SPL.
-- 2.42.0
Otherwise, looks good to me.
Acked-by: Ferass El Hafidi vitali64pmemail@protonmail.com
Ferass El Hafidi
Jonas Karlman
Kever Yang
Neil Armstrong
