[PATCH 0/2] add and use reset_get_bulk_optional()
Nikita Yushchenko (2): reset: introduce reset_get_bulk_optional() spi: cadence_qspi: use reset_get_bulk_optional()
drivers/reset/reset-uclass.c | 10 ++++++++++ drivers/spi/cadence_qspi.c | 11 ++++++----- include/reset.h | 21 +++++++++++++++++++++ 3 files changed, 37 insertions(+), 5 deletions(-)
This is a version of reset_get_bulk() that does not treat no resets definition as an error.
Signed-off-by: Nikita Yushchenko nikita.yoush@cogentembedded.com --- drivers/reset/reset-uclass.c | 10 ++++++++++ include/reset.h | 21 +++++++++++++++++++++ 2 files changed, 31 insertions(+)
diff --git a/drivers/reset/reset-uclass.c b/drivers/reset/reset-uclass.c index ca9f00a8f2..5a66fe5aef 100644 --- a/drivers/reset/reset-uclass.c +++ b/drivers/reset/reset-uclass.c @@ -144,6 +144,16 @@ int reset_get_bulk(struct udevice *dev, struct reset_ctl_bulk *bulk) return __reset_get_bulk(dev, dev_ofnode(dev), bulk); }
+int reset_get_bulk_optional(struct udevice *dev, struct reset_ctl_bulk *bulk) +{ + int ret = reset_get_bulk(dev, bulk); + + if (ret == -ENODEV) + ret = 0; + + return ret; +} + int reset_get_by_name(struct udevice *dev, const char *name, struct reset_ctl *reset_ctl) { diff --git a/include/reset.h b/include/reset.h index 965f02e0ce..b61a2a765f 100644 --- a/include/reset.h +++ b/include/reset.h @@ -226,6 +226,21 @@ int reset_get_by_index_nodev(ofnode node, int index, */ int reset_get_bulk(struct udevice *dev, struct reset_ctl_bulk *bulk);
+/** + * reset_get_bulk_optional - Get/request all reset signals of a device, do not + * fail if resets are not defined. + * + * This is similar to reset_get_bulk(), but does not return error code when + * no resets are defined. Instead, bulk->count is set to zero; this turns + * reset_assert_bulk() / reset_deassert_bulk() / reset_release_bulk() into + * no-ops. + * + * @dev: The client device. + * @bulk A pointer to a reset control bulk struct to initialize. + * Return: 0 if OK, or a negative error code. + */ +int reset_get_bulk_optional(struct udevice *dev, struct reset_ctl_bulk *bulk); + /** * reset_get_by_name - Get/request a reset signal by name. * @@ -411,6 +426,12 @@ static inline int reset_get_bulk(struct udevice *dev, return -ENOTSUPP; }
+static inline int reset_get_bulk_optional(struct udevice *dev, + struct reset_ctl_bulk *bulk) +{ + return -ENOTSUPP; +} + static inline int reset_get_by_name(struct udevice *dev, const char *name, struct reset_ctl *reset_ctl) {
On Wed, Feb 16, 2022 at 1:24 AM Nikita Yushchenko nikita.yoush@cogentembedded.com wrote:
if (ret == -ENODEV)
Are you sure about this return type? I think it would be -ENODATA if I'm not wrong.
if (ret == -ENODEV)
It shall be -ENOENT on master. Oops.
It is a valid setup to have no resets, e.g. TI J721E uses such setup. Accept it without error messages.
And, error out if there is a real issue with getting resets.
Signed-off-by: Nikita Yushchenko nikita.yoush@cogentembedded.com --- drivers/spi/cadence_qspi.c | 11 ++++++----- 1 file changed, 6 insertions(+), 5 deletions(-)
diff --git a/drivers/spi/cadence_qspi.c b/drivers/spi/cadence_qspi.c index d1b3808c4d..76adee49bd 100644 --- a/drivers/spi/cadence_qspi.c +++ b/drivers/spi/cadence_qspi.c @@ -201,11 +201,12 @@ static int cadence_spi_probe(struct udevice *bus) } }
- ret = reset_get_bulk(bus, &priv->resets); - if (ret) - dev_warn(bus, "Can't get reset: %d\n", ret); - else - reset_deassert_bulk(&priv->resets); + ret = reset_get_bulk_optional(bus, &priv->resets); + if (ret) { + dev_err(bus, "Can't get reset: %d\n", ret); + return ret; + } + reset_deassert_bulk(&priv->resets);
if (!priv->qspi_is_init) { cadence_qspi_apb_controller_init(plat);
Jagan Teki
Nikita Yushchenko
