[PATCH] tools: imx8mimage: Keep IVT reserved1 field zero always
Since fe8acf556c3 ("imx: HAB: Validate IVT before authenticating image") the U-Boot HAB implementation is checking whether reserved1 field in IVT is zero or not. In case the field is not zero, IVT validation fails. Stop setting IVT reserved1 field to non-zero in mkimage imx8m plugin, otherwise the validation cannot ever work.
Note that this only affects legacy boards which do not use binman.
Signed-off-by: Marek Vasut marex@denx.de Cc: Fabio Estevam festevam@denx.de Cc: Peng Fan peng.fan@nxp.com Cc: Stefano Babic sbabic@denx.de --- tools/imx8mimage.c | 8 -------- 1 file changed, 8 deletions(-)
diff --git a/tools/imx8mimage.c b/tools/imx8mimage.c index 4eed683396f..52baf4c9903 100644 --- a/tools/imx8mimage.c +++ b/tools/imx8mimage.c @@ -505,14 +505,6 @@ void build_image(int ofd) exit(EXIT_FAILURE); } else { sld_header_off = sld_src_off - rom_image_offset; - /* - * Record the second bootloader relative offset in - * image's IVT reserved1 - */ - if (rom_version == ROM_V1) { - imx_header[IMAGE_IVT_ID].fhdr.reserved1 = - sld_header_off - header_image_off; - } sld_fd = open(sld_img, O_RDONLY | O_BINARY); if (sld_fd < 0) { fprintf(stderr, "%s: Can't open: %s\n",
Since fe8acf556c3 ("imx: HAB: Validate IVT before authenticating image") the U-Boot HAB implementation is checking whether reserved1 field in IVT is zero or not. In case the field is not zero, IVT validation fails. Stop setting IVT reserved1 field to non-zero in mkimage imx8m plugin, otherwise the validation cannot ever work. Note that this only affects legacy boards which do not use binman. Signed-off-by: Marek Vasut marex@denx.de Cc: Fabio Estevam festevam@denx.de Cc: Peng Fan peng.fan@nxp.com Cc: Stefano Babic sbabic@denx.de
Best regards, Stefano Babic
sbabic@denx.de
