[U-Boot] [PATCH] board: ti: am57xx: Update EMIF SDRAM 1 and 3 Timings
Update EMIF data based on recommendations from the now standard TI EMIF tool version 1.1.1 based on 256MBx16 DDR3L Kingston D2516EC4BXGGB data sheet
Update T_RRD from 5 to 6 based on AM57xx TRM - Minimum number of DDR cycles from activate to ativate for a different bank, minus 1.
Update T_CKESR from 4 to 3 based on AM57xx TRM - Minimum number of DDR clocks cycles for which SDRAM must remain in self refresh, minus 1.
Signed-off-by: Schuyler Patton spatton@ti.com Signed-off-by: Nishanth Menon nm@ti.com --- X15 BOM: https://github.com/beagleboard/beagleboard-x15/blob/master/BeagleBoard-X15_R...
AM5728 Data sheet: http://www.ti.com/product/AM5728/datasheet
board/ti/am57xx/board.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/board/ti/am57xx/board.c b/board/ti/am57xx/board.c index 18416ef64ad9..fda0ed59c6b7 100644 --- a/board/ti/am57xx/board.c +++ b/board/ti/am57xx/board.c @@ -131,9 +131,9 @@ static const struct emif_regs beagle_x15_emif2_ddr3_532mhz_emif_regs = { .sdram_config2 = 0x08000000, .ref_ctrl = 0x000040F1, .ref_ctrl_final = 0x00001035, - .sdram_tim1 = 0xcccf36ab, + .sdram_tim1 = 0xcccf36b3, .sdram_tim2 = 0x308f7fda, - .sdram_tim3 = 0x409f88a8, + .sdram_tim3 = 0x407f88a8, .read_idle_ctrl = 0x00050000, .zq_config = 0x5007190b, .temp_alert_config = 0x00000000,
Reviewed-by: Lokesh Vutla lokeshvutla@ti.com
Thanks and regards, Lokesh
Signed-off-by: Schuyler Patton spatton@ti.com Signed-off-by: Nishanth Menon nm@ti.com Reviewed-by: Lokesh Vutla lokeshvutla@ti.com Reviewed-by: Tom Rini trini@konsulko.com
Lokesh Vutla
Nishanth Menon
