[PATCH v3 00/12] MIPS: Boston: Various enhancements
Hi all,
This is a huge series which promoted MIPS/Boston target into a usable state, with fixes to drivers and general framework issues I found in this process.
I also converted the target to OF_UPSTREAM.
This target is covered by QEMU, to test on QEMU: ``` make boston64r6el_defconfig make qemu-system-mips64el -M boston -cpu I6500 -bios ./u-boot.bin -nographic ```
This is my first u-boot contribution, please kindly advise if you have any comments.
Thanks
Signed-off-by: Jiaxun Yang jiaxun.yang@flygoat.com --- Changes in v3: - Slight change in clk_boston probe order (Jonas) - Link to v2: https://lore.kernel.org/r/20240516-boston-v2-0-77938800d1dd@flygoat.com
Changes in v2: - Drop "[PATCH 09/13] syscon: Probe device first in syscon_get_regmap" in flavour of fixing the driver device life cycle (Jonas) - Link to v1: https://lore.kernel.org/r/20240513-boston-v1-0-fac96938417e@flygoat.com
--- Jiaxun Yang (12): pci: xilinx: Handle size of ecam region properly pci: auto: Reduce bridge mem alignment boundary for boston pci: Enable PCI_MAP_SYSTEM_MEMORY when ARCH_MAP_SYSMEM is not set ahci: DMA addressing fixes ahci: dwc_ahsata: Generalize the driver MIPS: Provide dummy acpi_table.h MIPS: boston: Imply various options MIPS: boston: Provide default env vars clk: boston: Allow to get regmap from parent device dts/upstream: Add Makefile for MIPS MIPS: boston: Migrate to OF_UPSTREAM mailmap: Update email for Paul Burton
.mailmap | 3 +- arch/mips/Kconfig | 28 +++++ arch/mips/dts/Makefile | 1 - arch/mips/dts/boston-u-boot.dtsi | 10 ++ arch/mips/dts/img,boston.dts | 222 ------------------------------------- arch/mips/include/asm/acpi_table.h | 10 ++ board/imgtec/boston/Kconfig | 4 + board/imgtec/boston/MAINTAINERS | 3 +- board/imgtec/boston/boston.env | 9 ++ board/imgtec/malta/MAINTAINERS | 2 +- configs/boston32r2_defconfig | 2 +- configs/boston32r2el_defconfig | 2 +- configs/boston32r6_defconfig | 2 +- configs/boston32r6el_defconfig | 2 +- configs/boston64r2_defconfig | 2 +- configs/boston64r2el_defconfig | 2 +- configs/boston64r6_defconfig | 2 +- configs/boston64r6el_defconfig | 2 +- drivers/ata/ahci.c | 34 +++--- drivers/ata/dwc_ahsata.c | 82 +++++++++----- drivers/ata/dwc_ahsata_priv.h | 2 - drivers/clk/clk_boston.c | 19 ++-- drivers/pci/Kconfig | 10 ++ drivers/pci/pci_auto.c | 16 +-- drivers/pci/pcie_xilinx.c | 53 ++++++--- dts/upstream/src/mips/Makefile | 14 +++ include/ahci.h | 4 +- 27 files changed, 232 insertions(+), 310 deletions(-) --- base-commit: c8ffd1356d42223cbb8c86280a083cc3c93e6426 change-id: 20240513-boston-45ef6edc219f
Probe size of ecam from devicetree properly and cap accessible bus number accorading to ecam region size to ensure we don't go beyond hardware address space.
Also disable all interrupts to ensure errors are handled silently.
Signed-off-by: Jiaxun Yang jiaxun.yang@flygoat.com --- drivers/pci/pcie_xilinx.c | 53 +++++++++++++++++++++++++++++++++++------------ 1 file changed, 40 insertions(+), 13 deletions(-)
diff --git a/drivers/pci/pcie_xilinx.c b/drivers/pci/pcie_xilinx.c index a674ab04beee..63058e8e7c5d 100644 --- a/drivers/pci/pcie_xilinx.c +++ b/drivers/pci/pcie_xilinx.c @@ -18,14 +18,19 @@ */ struct xilinx_pcie { void *cfg_base; + pci_size_t size; + int first_busno; };
/* Register definitions */ -#define XILINX_PCIE_REG_PSCR 0x144 -#define XILINX_PCIE_REG_PSCR_LNKUP BIT(11) -#define XILINX_PCIE_REG_RPSC 0x148 -#define XILINX_PCIE_REG_RPSC_BEN BIT(0) - +#define XILINX_PCIE_REG_BRIDGE_INFO 0x130 +#define XILINX_PCIE_REG_BRIDGE_INFO_ECAMSZ_SHIFT 16 +#define XILINX_PCIE_REG_BRIDGE_INFO_ECAMSZ_MASK (0x7 << 16) +#define XILINX_PCIE_REG_INT_MASK 0x13c +#define XILINX_PCIE_REG_PSCR 0x144 +#define XILINX_PCIE_REG_PSCR_LNKUP BIT(11) +#define XILINX_PCIE_REG_RPSC 0x148 +#define XILINX_PCIE_REG_RPSC_BEN BIT(0) /** * pcie_xilinx_link_up() - Check whether the PCIe link is up * @pcie: Pointer to the PCI controller state @@ -61,14 +66,18 @@ static int pcie_xilinx_config_address(const struct udevice *udev, pci_dev_t bdf, uint offset, void **paddress) { struct xilinx_pcie *pcie = dev_get_priv(udev); - unsigned int bus = PCI_BUS(bdf); + unsigned int bus = PCI_BUS(bdf) - pcie->first_busno; unsigned int dev = PCI_DEV(bdf); unsigned int func = PCI_FUNC(bdf); + int num_buses = DIV_ROUND_UP(pcie->size, 1 << 16); void *addr;
if ((bus > 0) && !pcie_xilinx_link_up(pcie)) return -ENODEV;
+ if (bus > num_buses) + return -ENODEV; + /* * Busses 0 (host-PCIe bridge) & 1 (its immediate child) are * limited to a single device each. @@ -142,20 +151,37 @@ static int pcie_xilinx_of_to_plat(struct udevice *dev) struct xilinx_pcie *pcie = dev_get_priv(dev); fdt_addr_t addr; fdt_size_t size; - u32 rpsc;
addr = dev_read_addr_size(dev, &size); if (addr == FDT_ADDR_T_NONE) return -EINVAL;
- pcie->cfg_base = devm_ioremap(dev, addr, size); - if (IS_ERR(pcie->cfg_base)) - return PTR_ERR(pcie->cfg_base); + pcie->cfg_base = map_physmem(addr, size, MAP_NOCACHE); + if (!pcie->cfg_base) + return -ENOMEM; + pcie->size = size; + return 0; +}
- /* Enable the Bridge enable bit */ - rpsc = __raw_readl(pcie->cfg_base + XILINX_PCIE_REG_RPSC); +static int pci_xilinx_probe(struct udevice *dev) +{ + struct xilinx_pcie *pcie = dev_get_priv(dev); + u32 rpsc; + int num_buses = DIV_ROUND_UP(pcie->size, 1 << 16); + + pcie->first_busno = dev_seq(dev); + + /* Disable all interrupts */ + writel(0, pcie->cfg_base + XILINX_PCIE_REG_INT_MASK); + + /* Enable the bridge */ + rpsc = readl(pcie->cfg_base + XILINX_PCIE_REG_RPSC); rpsc |= XILINX_PCIE_REG_RPSC_BEN; - __raw_writel(rpsc, pcie->cfg_base + XILINX_PCIE_REG_RPSC); + writel(rpsc, pcie->cfg_base + XILINX_PCIE_REG_RPSC); + + /* Enable access to all possible subordinate buses */ + writel((0 << 0) | (1 << 8) | (num_buses << 16), + pcie->cfg_base + PCI_PRIMARY_BUS);
return 0; } @@ -176,5 +202,6 @@ U_BOOT_DRIVER(pcie_xilinx) = { .of_match = pcie_xilinx_ids, .ops = &pcie_xilinx_ops, .of_to_plat = pcie_xilinx_of_to_plat, + .probe = pci_xilinx_probe, .priv_auto = sizeof(struct xilinx_pcie), };
Reviewed-by: Daniel Schwierzeck daniel.schwierzeck@gmail.com
Boston has a very limited memory range for PCI controllers, where 1MB can't easily fit into it.
Make alignment boundary of PCI memory resource allocation a Kconfig option and default to 0x10000 for boston.
Signed-off-by: Jiaxun Yang jiaxun.yang@flygoat.com --- drivers/pci/Kconfig | 9 +++++++++ drivers/pci/pci_auto.c | 16 ++++++++-------- 2 files changed, 17 insertions(+), 8 deletions(-)
diff --git a/drivers/pci/Kconfig b/drivers/pci/Kconfig index 8d02ab82ad9f..289d1deb38b6 100644 --- a/drivers/pci/Kconfig +++ b/drivers/pci/Kconfig @@ -75,6 +75,15 @@ config PCI_MAP_SYSTEM_MEMORY This should only be required on MIPS where CFG_SYS_SDRAM_BASE is still being used as virtual address.
+config PCI_BRIDGE_MEM_ALIGNMENT + hex "Alignment boundary of PCI memory resource allocation" + default 0x10000 if TARGET_BOSTON + default 0x100000 + help + Specify a boundary for alignment of PCI memory resource allocation, + this is normally 0x100000 (1MB) but can be reduced to accommodate + hardware with tight bridge range if hardware allows. + config PCI_SRIOV bool "Enable Single Root I/O Virtualization support for PCI" help diff --git a/drivers/pci/pci_auto.c b/drivers/pci/pci_auto.c index 90f818864457..b2c76b25801a 100644 --- a/drivers/pci/pci_auto.c +++ b/drivers/pci/pci_auto.c @@ -372,8 +372,8 @@ void dm_pciauto_prescan_setup_bridge(struct udevice *dev, int sub_bus) dm_pci_write_config8(dev, PCI_SUBORDINATE_BUS, 0xff);
if (pci_mem) { - /* Round memory allocator to 1MB boundary */ - pciauto_region_align(pci_mem, 0x100000); + /* Round memory allocator */ + pciauto_region_align(pci_mem, CONFIG_PCI_BRIDGE_MEM_ALIGNMENT);
/* * Set up memory and I/O filter limits, assume 32-bit @@ -387,8 +387,8 @@ void dm_pciauto_prescan_setup_bridge(struct udevice *dev, int sub_bus) }
if (pci_prefetch) { - /* Round memory allocator to 1MB boundary */ - pciauto_region_align(pci_prefetch, 0x100000); + /* Round memory allocator */ + pciauto_region_align(pci_prefetch, CONFIG_PCI_BRIDGE_MEM_ALIGNMENT);
/* * Set up memory and I/O filter limits, assume 32-bit @@ -465,8 +465,8 @@ void dm_pciauto_postscan_setup_bridge(struct udevice *dev, int sub_bus) dm_pci_write_config8(dev, PCI_SUBORDINATE_BUS, sub_bus - dev_seq(ctlr));
dm_pci_write_config16(dev, PCI_MEMORY_LIMIT, ((pci_mem->bus_lower - 1) >> 16) & @@ -480,8 +480,8 @@ void dm_pciauto_postscan_setup_bridge(struct udevice *dev, int sub_bus) &prefechable_64); prefechable_64 &= PCI_PREF_RANGE_TYPE_MASK;
dm_pci_write_config16(dev, PCI_PREF_MEMORY_LIMIT, (((pci_prefetch->bus_lower - 1) >> 16) &
For MIPS we are always looking gd->dram in virtual address so PCI_MAP_SYSTEM_MEMORY should always be enabled.
If in future we ever want to make it physical we have to set ARCH_MAP_SYSMEM.
Signed-off-by: Jiaxun Yang jiaxun.yang@flygoat.com --- drivers/pci/Kconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/drivers/pci/Kconfig b/drivers/pci/Kconfig index 289d1deb38b6..14f6067fa29b 100644 --- a/drivers/pci/Kconfig +++ b/drivers/pci/Kconfig @@ -67,6 +67,7 @@ config PCI_CONFIG_HOST_BRIDGE config PCI_MAP_SYSTEM_MEMORY bool "Map local system memory from a virtual base address" depends on MIPS + default y if !ARCH_MAP_SYSMEM help Say Y if base address of system memory is being used as a virtual address instead of a physical address (e.g. on MIPS). The PCI core will then remap
Ensure that we are using correct physical/virtual address for DMA buffer write and hardware register settings.
The convention is: in ahci_ioports all pointers are virtual, that will be converted to physical address when writing to hardware registers or into sg/cmd_tbl.
Also fixed 64bit physical address support for dwc_ahsata, ensure higher bits are written into registers/sg properly.
Use memalign for allocating aligned buffer in dwc_ahsata so we don't have to do our own alignment in driver.
Signed-off-by: Jiaxun Yang jiaxun.yang@flygoat.com --- drivers/ata/ahci.c | 34 ++++++++++++++++----------------- drivers/ata/dwc_ahsata.c | 44 +++++++++++++++++++++++-------------------- drivers/ata/dwc_ahsata_priv.h | 2 -- include/ahci.h | 4 ++-- 4 files changed, 42 insertions(+), 42 deletions(-)
diff --git a/drivers/ata/ahci.c b/drivers/ata/ahci.c index ac869296d525..21b13fedac50 100644 --- a/drivers/ata/ahci.c +++ b/drivers/ata/ahci.c @@ -421,7 +421,7 @@ static int ahci_fill_sg(struct ahci_uc_priv *uc_priv, u8 port,
static void ahci_fill_cmd_slot(struct ahci_ioports *pp, u32 opts) { - phys_addr_t pa = virt_to_phys((void *)pp->cmd_tbl); + phys_addr_t pa = virt_to_phys(pp->cmd_tbl);
pp->cmd_slot->opts = cpu_to_le32(opts); pp->cmd_slot->status = 0; @@ -450,7 +450,7 @@ static int ahci_port_start(struct ahci_uc_priv *uc_priv, u8 port) { struct ahci_ioports *pp = &(uc_priv->port[port]); void __iomem *port_mmio = pp->port_mmio; - u64 dma_addr; + phys_addr_t dma_addr; u32 port_status; void __iomem *mem;
@@ -474,34 +474,32 @@ static int ahci_port_start(struct ahci_uc_priv *uc_priv, u8 port) * First item in chunk of DMA memory: 32-slot command table, * 32 bytes each in size */ - pp->cmd_slot = - (struct ahci_cmd_hdr *)(uintptr_t)virt_to_phys((void *)mem); - debug("cmd_slot = %p\n", pp->cmd_slot); - mem += (AHCI_CMD_SLOT_SZ + 224); + pp->cmd_slot = (struct ahci_cmd_hdr *)mem; + mem += AHCI_CMD_SLOT_SZ * AHCI_MAX_CMD_SLOT;
/* * Second item: Received-FIS area */ - pp->rx_fis = virt_to_phys((void *)mem); + pp->rx_fis = mem; mem += AHCI_RX_FIS_SZ;
/* * Third item: data area for storing a single command * and its scatter-gather table */ - pp->cmd_tbl = virt_to_phys((void *)mem); - debug("cmd_tbl_dma = %lx\n", pp->cmd_tbl); + pp->cmd_tbl = mem;
mem += AHCI_CMD_TBL_HDR; - pp->cmd_tbl_sg = - (struct ahci_sg *)(uintptr_t)virt_to_phys((void *)mem); - - dma_addr = (ulong)pp->cmd_slot; - writel_with_flush(dma_addr, port_mmio + PORT_LST_ADDR); - writel_with_flush(dma_addr >> 32, port_mmio + PORT_LST_ADDR_HI); - dma_addr = (ulong)pp->rx_fis; - writel_with_flush(dma_addr, port_mmio + PORT_FIS_ADDR); - writel_with_flush(dma_addr >> 32, port_mmio + PORT_FIS_ADDR_HI); + pp->cmd_tbl_sg = (struct ahci_sg *)(mem); + + dma_addr = virt_to_phys(pp->cmd_slot); + debug("cmd_slot_dma = 0x%08llx\n", (u64)dma_addr); + writel_with_flush(lower_32_bits(dma_addr), port_mmio + PORT_LST_ADDR); + writel_with_flush(upper_32_bits(dma_addr), port_mmio + PORT_LST_ADDR_HI); + dma_addr = virt_to_phys(pp->rx_fis); + debug("rx_fis_dma = 0x%08llx\n", (u64)dma_addr); + writel_with_flush(lower_32_bits(dma_addr), port_mmio + PORT_FIS_ADDR); + writel_with_flush(upper_32_bits(dma_addr), port_mmio + PORT_FIS_ADDR_HI);
#ifdef CONFIG_SUNXI_AHCI sunxi_dma_init(port_mmio); diff --git a/drivers/ata/dwc_ahsata.c b/drivers/ata/dwc_ahsata.c index a29d641343ed..c2cde48c0b55 100644 --- a/drivers/ata/dwc_ahsata.c +++ b/drivers/ata/dwc_ahsata.c @@ -329,6 +329,7 @@ static int ahci_fill_sg(struct ahci_uc_priv *uc_priv, u8 port, { struct ahci_ioports *pp = &uc_priv->port[port]; struct ahci_sg *ahci_sg = pp->cmd_tbl_sg; + phys_addr_t pa = virt_to_phys(buf); u32 sg_count, max_bytes; int i;
@@ -340,9 +341,8 @@ static int ahci_fill_sg(struct ahci_uc_priv *uc_priv, u8 port, }
for (i = 0; i < sg_count; i++) { - ahci_sg->addr = - cpu_to_le32((u32)buf + i * max_bytes); - ahci_sg->addr_hi = 0; + ahci_sg->addr = cpu_to_le32(lower_32_bits(pa)); + ahci_sg->addr_hi = cpu_to_le32(upper_32_bits(pa)); ahci_sg->flags_size = cpu_to_le32(0x3fffff & (buf_len < max_bytes ? (buf_len - 1) @@ -358,14 +358,14 @@ static void ahci_fill_cmd_slot(struct ahci_ioports *pp, u32 cmd_slot, u32 opts) { struct ahci_cmd_hdr *cmd_hdr = (struct ahci_cmd_hdr *)(pp->cmd_slot + AHCI_CMD_SLOT_SZ * cmd_slot); + phys_addr_t pa = virt_to_phys(pp->cmd_tbl);
memset(cmd_hdr, 0, AHCI_CMD_SLOT_SZ); cmd_hdr->opts = cpu_to_le32(opts); cmd_hdr->status = 0; - pp->cmd_slot->tbl_addr = cpu_to_le32((u32)pp->cmd_tbl & 0xffffffff); + pp->cmd_slot->tbl_addr = cpu_to_le32(lower_32_bits(pa)); #ifdef CONFIG_PHYS_64BIT - pp->cmd_slot->tbl_addr_hi = - cpu_to_le32((u32)(((pp->cmd_tbl) >> 16) >> 16)); + pp->cmd_slot->tbl_addr_hi = cpu_to_le32(upper_32_bits(pa)); #endif }
@@ -403,7 +403,7 @@ static int ahci_exec_ata_cmd(struct ahci_uc_priv *uc_priv, u8 port, } ahci_fill_cmd_slot(pp, cmd_slot, opts);
- flush_cache((int)(pp->cmd_slot), AHCI_PORT_PRIV_DMA_SZ); + flush_cache((ulong)(pp->cmd_slot), AHCI_PORT_PRIV_DMA_SZ); writel_with_flush(1 << cmd_slot, &port_mmio->ci);
if (waiting_for_cmd_completed((u8 *)&port_mmio->ci, 10000, @@ -411,8 +411,8 @@ static int ahci_exec_ata_cmd(struct ahci_uc_priv *uc_priv, u8 port, printf("timeout exit!\n"); return -1; } - invalidate_dcache_range((int)(pp->cmd_slot), - (int)(pp->cmd_slot)+AHCI_PORT_PRIV_DMA_SZ); + invalidate_dcache_range((ulong)(pp->cmd_slot), + (ulong)(pp->cmd_slot) + AHCI_PORT_PRIV_DMA_SZ); debug("ahci_exec_ata_cmd: %d byte transferred.\n", pp->cmd_slot->status); if (!is_write) @@ -440,8 +440,9 @@ static int ahci_port_start(struct ahci_uc_priv *uc_priv, u8 port) { struct ahci_ioports *pp = &uc_priv->port[port]; struct sata_port_regs *port_mmio = pp->port_mmio; + phys_addr_t dma_addr; u32 port_status; - u32 mem; + void *mem; int timeout = 10000000;
debug("Enter start port: %d\n", port); @@ -452,22 +453,20 @@ static int ahci_port_start(struct ahci_uc_priv *uc_priv, u8 port) return -1; }
- mem = (u32)malloc(AHCI_PORT_PRIV_DMA_SZ + 1024); + mem = memalign(2048, AHCI_PORT_PRIV_DMA_SZ); if (!mem) { printf("No mem for table!\n"); return -ENOMEM; }
- mem = (mem + 0x400) & (~0x3ff); /* Aligned to 1024-bytes */ - memset((u8 *)mem, 0, AHCI_PORT_PRIV_DMA_SZ); + memset(mem, 0, AHCI_PORT_PRIV_DMA_SZ);
/* * First item in chunk of DMA memory: 32-slot command table, * 32 bytes each in size */ pp->cmd_slot = (struct ahci_cmd_hdr *)mem; - debug("cmd_slot = 0x%x\n", (unsigned int) pp->cmd_slot); - mem += (AHCI_CMD_SLOT_SZ * DWC_AHSATA_MAX_CMD_SLOTS); + mem += AHCI_CMD_SLOT_SZ * AHCI_MAX_CMD_SLOT;
/* * Second item: Received-FIS area, 256-Byte aligned @@ -480,14 +479,19 @@ static int ahci_port_start(struct ahci_uc_priv *uc_priv, u8 port) * and its scatter-gather table */ pp->cmd_tbl = mem; - debug("cmd_tbl_dma = 0x%lx\n", pp->cmd_tbl); - mem += AHCI_CMD_TBL_HDR; + pp->cmd_tbl_sg = (struct ahci_sg *)mem;
writel_with_flush(0x00004444, &port_mmio->dmacr); - pp->cmd_tbl_sg = (struct ahci_sg *)mem; - writel_with_flush((u32)pp->cmd_slot, &port_mmio->clb); - writel_with_flush(pp->rx_fis, &port_mmio->fb); + dma_addr = virt_to_phys(pp->cmd_slot); + debug("cmd_slot_dma = 0x%08llx\n", (u64)dma_addr); + writel_with_flush(lower_32_bits(dma_addr), &port_mmio->clb); + writel_with_flush(upper_32_bits(dma_addr), &port_mmio->clbu); + dma_addr = virt_to_phys(pp->cmd_slot); + debug("rx_fis_slot_dma = 0x%08llx\n", (u64)dma_addr); + writel_with_flush(lower_32_bits(dma_addr), &port_mmio->fb); + writel_with_flush(upper_32_bits(dma_addr), &port_mmio->fbu); +
/* Enable FRE */ writel_with_flush((SATA_PORT_CMD_FRE | readl(&port_mmio->cmd)), diff --git a/drivers/ata/dwc_ahsata_priv.h b/drivers/ata/dwc_ahsata_priv.h index 5b0579ae1159..0c2cd5446b57 100644 --- a/drivers/ata/dwc_ahsata_priv.h +++ b/drivers/ata/dwc_ahsata_priv.h @@ -7,8 +7,6 @@ #ifndef __DWC_AHSATA_PRIV_H__ #define __DWC_AHSATA_PRIV_H__
-#define DWC_AHSATA_MAX_CMD_SLOTS 32 - /* Max host controller numbers */ #define SATA_HC_MAX_NUM 4 /* Max command queue depth per host controller */ diff --git a/include/ahci.h b/include/ahci.h index d4f0f3ce0e71..eb05cc687f64 100644 --- a/include/ahci.h +++ b/include/ahci.h @@ -137,8 +137,8 @@ struct ahci_ioports { void __iomem *port_mmio; struct ahci_cmd_hdr *cmd_slot; struct ahci_sg *cmd_tbl_sg; - ulong cmd_tbl; - u32 rx_fis; + void *cmd_tbl; + void *rx_fis; };
Remove hard dependencies to arch headers, get clock from clk subsystem if arch clock function is not available, align compatible strings with devicetree binding.
No functional change on existing platforms, just get it build on other platforms.
Signed-off-by: Jiaxun Yang jiaxun.yang@flygoat.com --- drivers/ata/dwc_ahsata.c | 38 ++++++++++++++++++++++++++++++++------ 1 file changed, 32 insertions(+), 6 deletions(-)
diff --git a/drivers/ata/dwc_ahsata.c b/drivers/ata/dwc_ahsata.c index c2cde48c0b55..27c24228ef89 100644 --- a/drivers/ata/dwc_ahsata.c +++ b/drivers/ata/dwc_ahsata.c @@ -6,6 +6,7 @@
#include <ahci.h> #include <blk.h> +#include <clk.h> #include <cpu_func.h> #include <dm.h> #include <dwc_ahsata.h> @@ -18,9 +19,11 @@ #include <sata.h> #include <asm/cache.h> #include <asm/io.h> +#if IS_ENABLED(CONFIG_ARCH_MX5) || IS_ENABLED(CONFIG_ARCH_MX6) #include <asm/arch/clock.h> #include <asm/arch/sys_proto.h> #include <asm/mach-imx/sata.h> +#endif #include <linux/bitops.h> #include <linux/ctype.h> #include <linux/delay.h> @@ -115,13 +118,12 @@ static int ahci_setup_oobr(struct ahci_uc_priv *uc_priv, int clk) return 0; }
-static int ahci_host_init(struct ahci_uc_priv *uc_priv) +static int ahci_host_init(struct ahci_uc_priv *uc_priv, int clk) { u32 tmp, cap_save, num_ports; int i, j, timeout = 1000; struct sata_port_regs *port_mmio = NULL; struct sata_host_regs *host_mmio = uc_priv->mmio_base; - int clk = mxc_get_clock(MXC_SATA_CLK);
cap_save = readl(&host_mmio->cap); cap_save |= SATA_HOST_CAP_SSS; @@ -909,17 +911,41 @@ int dwc_ahsata_scan(struct udevice *dev) int dwc_ahsata_probe(struct udevice *dev) { struct ahci_uc_priv *uc_priv = dev_get_uclass_priv(dev); + struct clk_bulk clk_bulk __maybe_unused; + struct clk clk __maybe_unused; + int sataclk; int ret;
-#if defined(CONFIG_MX6) +#if IS_ENABLED(CONFIG_MX6) setup_sata(); #endif +#if IS_ENABLED(CONFIG_MX5) || IS_ENABLED(CONFIG_MX6) + sataclk = mxc_get_clock(MXC_SATA_CLK); +#else + ret = clk_get_bulk(dev, &clk_bulk); + if (ret) + return ret; + + ret = clk_enable_bulk(&clk_bulk); + if (ret) + return ret; + + ret = clk_get_by_name(dev, "sata", &clk); + if (ret) + return ret; + + sataclk = clk_get_rate(&clk); +#endif + if (IS_ERR_VALUE(sataclk)) { + log_err("Unable to get SATA clock rate\n"); + return -EINVAL; + } uc_priv->host_flags = ATA_FLAG_SATA | ATA_FLAG_NO_LEGACY | ATA_FLAG_MMIO | ATA_FLAG_PIO_DMA | ATA_FLAG_NO_ATAPI; uc_priv->mmio_base = dev_read_addr_ptr(dev);
/* initialize adapter */ - ret = ahci_host_init(uc_priv); + ret = ahci_host_init(uc_priv, sataclk); if (ret) return ret;
@@ -961,7 +987,6 @@ U_BOOT_DRIVER(dwc_ahsata_blk) = { .ops = &dwc_ahsata_blk_ops, };
-#if CONFIG_IS_ENABLED(DWC_AHSATA_AHCI) struct ahci_ops dwc_ahsata_ahci_ops = { .port_status = dwc_ahsata_port_status, .reset = dwc_ahsata_bus_reset, @@ -969,7 +994,9 @@ struct ahci_ops dwc_ahsata_ahci_ops = { };
static const struct udevice_id dwc_ahsata_ahci_ids[] = { + { .compatible = "fsl,imx53-ahci" }, { .compatible = "fsl,imx6q-ahci" }, + { .compatible = "fsl,imx6qp-ahci" }, { } };
@@ -980,4 +1007,3 @@ U_BOOT_DRIVER(dwc_ahsata_ahci) = { .ops = &dwc_ahsata_ahci_ops, .probe = dwc_ahsata_probe, }; -#endif
Some drivers need this header. Provide this dummy header as riscv did.
Signed-off-by: Jiaxun Yang jiaxun.yang@flygoat.com --- arch/mips/include/asm/acpi_table.h | 10 ++++++++++ 1 file changed, 10 insertions(+)
diff --git a/arch/mips/include/asm/acpi_table.h b/arch/mips/include/asm/acpi_table.h new file mode 100644 index 000000000000..b4139d0ba328 --- /dev/null +++ b/arch/mips/include/asm/acpi_table.h @@ -0,0 +1,10 @@ +/* SPDX-License-Identifier: GPL-2.0-or-later */ + +#ifndef __ASM_ACPI_TABLE_H__ +#define __ASM_ACPI_TABLE_H__ + +/* + * This file is needed by some drivers. + */ + +#endif /* __ASM_ACPI_TABLE_H__ */
This is a PC-like platform board. Enable drivers for most on-board devices to make it useful.
Signed-off-by: Jiaxun Yang jiaxun.yang@flygoat.com --- arch/mips/Kconfig | 27 +++++++++++++++++++++++++++ 1 file changed, 27 insertions(+)
diff --git a/arch/mips/Kconfig b/arch/mips/Kconfig index eb7f3ad23762..748b5175b2eb 100644 --- a/arch/mips/Kconfig +++ b/arch/mips/Kconfig @@ -146,7 +146,34 @@ config TARGET_BOSTON select SUPPORTS_CPU_MIPS64_R2 select SUPPORTS_CPU_MIPS64_R6 select SUPPORTS_LITTLE_ENDIAN + imply BOOTSTD_FULL + imply CLK + imply CLK_BOSTON imply CMD_DM + imply AHCI + imply AHCI_PCI + imply CFI_FLASH + imply MTD_NOR_FLASH + imply MMC + imply MMC_PCI + imply MMC_SDHCI + imply MMC_SDHCI_SDMA + imply PCH_GBE + imply PCI + imply PCI_XILINX + imply PCI_INIT_R + imply SCSI + imply SCSI_AHCI + imply SYS_NS16550 + imply SYSRESET + imply SYSRESET_CMD_POWEROFF + imply SYSRESET_SYSCON + imply USB + imply USB_EHCI_HCD + imply USB_EHCI_PCI + imply USB_XHCI_HCD + imply USB_XHCI_PCI + imply CMD_USB
config TARGET_XILFPGA bool "Support Imagination Xilfpga"
Provide default environment variables on image loading address to make the board useful.
Signed-off-by: Jiaxun Yang jiaxun.yang@flygoat.com --- board/imgtec/boston/Kconfig | 4 ++++ board/imgtec/boston/boston.env | 9 +++++++++ 2 files changed, 13 insertions(+)
diff --git a/board/imgtec/boston/Kconfig b/board/imgtec/boston/Kconfig index 5537788001a3..965847d9650d 100644 --- a/board/imgtec/boston/Kconfig +++ b/board/imgtec/boston/Kconfig @@ -9,6 +9,10 @@ config SYS_VENDOR config SYS_CONFIG_NAME default "boston"
+ +config ENV_SOURCE_FILE + default "boston" + config TEXT_BASE default 0x9fc00000 if 32BIT default 0xffffffff9fc00000 if 64BIT diff --git a/board/imgtec/boston/boston.env b/board/imgtec/boston/boston.env new file mode 100644 index 000000000000..796e0fd6bf98 --- /dev/null +++ b/board/imgtec/boston/boston.env @@ -0,0 +1,9 @@ +#ifdef CONFIG_64BIT +fdt_addr_r=0xffffffff80001000 +kernel_addr_r=0xffffffff88000000 +ramdisk_addr_r=0xffffffff8b000000 +#else +fdt_addr_r=0x80001000 +kernel_addr_r=0x88000000 +ramdisk_addr_r=0x8b000000 +#endif
In upstream devicetree, clk_boston is a child of syscon node and there is no "regmap" property for clk_boston node.
Try to check parent device first to look for syscon.
Signed-off-by: Jiaxun Yang jiaxun.yang@flygoat.com --- v2: Move syscon_get_regmap to probe v3: Move syscon detection code to probe to ensure parent is probbed before syscon_get_regmap. --- drivers/clk/clk_boston.c | 19 ++++++++++++------- 1 file changed, 12 insertions(+), 7 deletions(-)
diff --git a/drivers/clk/clk_boston.c b/drivers/clk/clk_boston.c index 030ff7cc58ec..71e030f463e1 100644 --- a/drivers/clk/clk_boston.c +++ b/drivers/clk/clk_boston.c @@ -58,17 +58,21 @@ const struct clk_ops clk_boston_ops = { .get_rate = clk_boston_get_rate, };
-static int clk_boston_of_to_plat(struct udevice *dev) +static int clk_boston_probe(struct udevice *dev) { struct clk_boston *state = dev_get_plat(dev); struct udevice *syscon; int err;
- err = uclass_get_device_by_phandle(UCLASS_SYSCON, dev, - "regmap", &syscon); - if (err) { - pr_err("unable to find syscon device\n"); - return err; + if (dev->parent && device_get_uclass_id(dev->parent) == UCLASS_SYSCON) { + syscon = dev->parent; + } else { + err = uclass_get_device_by_phandle(UCLASS_SYSCON, dev, + "regmap", &syscon); + if (err) { + pr_err("unable to find syscon device\n"); + return err; + } }
state->regmap = syscon_get_regmap(syscon); @@ -91,7 +95,8 @@ U_BOOT_DRIVER(clk_boston) = { .name = "boston_clock", .id = UCLASS_CLK, .of_match = clk_boston_match, - .of_to_plat = clk_boston_of_to_plat, + .probe = clk_boston_probe, .plat_auto = sizeof(struct clk_boston), .ops = &clk_boston_ops, + .flags = DM_FLAG_PRE_RELOC, };
It is required to make OF_UPSTREAM work.
Reviewed-by: Sumit Garg sumit.garg@linaro.org Signed-off-by: Jiaxun Yang jiaxun.yang@flygoat.com --- dts/upstream/src/mips/Makefile | 14 ++++++++++++++ 1 file changed, 14 insertions(+)
diff --git a/dts/upstream/src/mips/Makefile b/dts/upstream/src/mips/Makefile new file mode 100644 index 000000000000..9a8f6aa35846 --- /dev/null +++ b/dts/upstream/src/mips/Makefile @@ -0,0 +1,14 @@ +# SPDX-License-Identifier: GPL-2.0+ + +include $(srctree)/scripts/Makefile.dts + +targets += $(dtb-y) + +# Add any required device tree compiler flags here +DTC_FLAGS += -a 0x8 + +PHONY += dtbs +dtbs: $(addprefix $(obj)/, $(dtb-y)) + @: + +clean-files := */*.dtb */*.dtbo
We can now boot with upstream devicetree.
Reviewed-by: Sumit Garg sumit.garg@linaro.org Signed-off-by: Jiaxun Yang jiaxun.yang@flygoat.com --- arch/mips/Kconfig | 1 + arch/mips/dts/Makefile | 1 - arch/mips/dts/boston-u-boot.dtsi | 10 ++ arch/mips/dts/img,boston.dts | 222 --------------------------------------- board/imgtec/boston/MAINTAINERS | 1 + configs/boston32r2_defconfig | 2 +- configs/boston32r2el_defconfig | 2 +- configs/boston32r6_defconfig | 2 +- configs/boston32r6el_defconfig | 2 +- configs/boston64r2_defconfig | 2 +- configs/boston64r2el_defconfig | 2 +- configs/boston64r6_defconfig | 2 +- configs/boston64r6el_defconfig | 2 +- 13 files changed, 20 insertions(+), 231 deletions(-)
diff --git a/arch/mips/Kconfig b/arch/mips/Kconfig index 748b5175b2eb..733a8de4fb83 100644 --- a/arch/mips/Kconfig +++ b/arch/mips/Kconfig @@ -146,6 +146,7 @@ config TARGET_BOSTON select SUPPORTS_CPU_MIPS64_R2 select SUPPORTS_CPU_MIPS64_R6 select SUPPORTS_LITTLE_ENDIAN + imply OF_UPSTREAM imply BOOTSTD_FULL imply CLK imply CLK_BOSTON diff --git a/arch/mips/dts/Makefile b/arch/mips/dts/Makefile index 14fbce597b9e..5478dcd8d025 100644 --- a/arch/mips/dts/Makefile +++ b/arch/mips/dts/Makefile @@ -3,7 +3,6 @@ dtb-$(CONFIG_TARGET_AP121) += ap121.dtb dtb-$(CONFIG_TARGET_AP143) += ap143.dtb dtb-$(CONFIG_TARGET_AP152) += ap152.dtb -dtb-$(CONFIG_TARGET_BOSTON) += img,boston.dtb dtb-$(CONFIG_TARGET_MALTA) += mti,malta.dtb dtb-$(CONFIG_TARGET_PIC32MZDASK) += pic32mzda_sk.dtb dtb-$(CONFIG_TARGET_XILFPGA) += nexys4ddr.dtb diff --git a/arch/mips/dts/boston-u-boot.dtsi b/arch/mips/dts/boston-u-boot.dtsi new file mode 100644 index 000000000000..1b0c0a289613 --- /dev/null +++ b/arch/mips/dts/boston-u-boot.dtsi @@ -0,0 +1,10 @@ +// SPDX-License-Identifier: GPL-2.0+ + +&plat_regs { + compatible = "img,boston-platform-regs", "syscon", "simple-mfd"; + bootph-all; +}; + +&clk_boston { + bootph-all; +}; diff --git a/arch/mips/dts/img,boston.dts b/arch/mips/dts/img,boston.dts deleted file mode 100644 index c1a73963037d..000000000000 --- a/arch/mips/dts/img,boston.dts +++ /dev/null @@ -1,222 +0,0 @@ -/dts-v1/; - -#include <dt-bindings/clock/boston-clock.h> -#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/interrupt-controller/irq.h> -#include <dt-bindings/interrupt-controller/mips-gic.h> - -/ { - #address-cells = <1>; - #size-cells = <1>; - compatible = "img,boston"; - - chosen { - stdout-path = &uart0; - }; - - cpus { - #address-cells = <1>; - #size-cells = <0>; - - cpu@0 { - device_type = "cpu"; - compatible = "img,mips"; - reg = <0>; - clocks = <&clk_boston BOSTON_CLK_CPU>; - }; - }; - - memory@0 { - device_type = "memory"; - reg = <0x00000000 0x10000000>; - }; - - gic: interrupt-controller { - compatible = "mti,gic"; - - interrupt-controller; - #interrupt-cells = <3>; - - timer { - compatible = "mti,gic-timer"; - interrupts = <GIC_LOCAL 1 IRQ_TYPE_NONE>; - clocks = <&clk_boston BOSTON_CLK_CPU>; - }; - }; - - pci0: pci@10000000 { - status = "disabled"; - compatible = "xlnx,axi-pcie-host-1.00.a"; - device_type = "pci"; - reg = <0x10000000 0x2000000>; - - #address-cells = <3>; - #size-cells = <2>; - #interrupt-cells = <1>; - - interrupt-parent = <&gic>; - interrupts = <GIC_SHARED 2 IRQ_TYPE_LEVEL_HIGH>; - - ranges = <0x02000000 0 0x40000000 - 0x40000000 0 0x40000000>; - - interrupt-map-mask = <0 0 0 7>; - interrupt-map = <0 0 0 1 &pci0_intc 0>, - <0 0 0 2 &pci0_intc 1>, - <0 0 0 3 &pci0_intc 2>, - <0 0 0 4 &pci0_intc 3>; - - pci0_intc: interrupt-controller { - interrupt-controller; - #address-cells = <0>; - #interrupt-cells = <1>; - }; - }; - - pci1: pci@12000000 { - status = "disabled"; - compatible = "xlnx,axi-pcie-host-1.00.a"; - device_type = "pci"; - reg = <0x12000000 0x2000000>; - - #address-cells = <3>; - #size-cells = <2>; - #interrupt-cells = <1>; - - interrupt-parent = <&gic>; - interrupts = <GIC_SHARED 1 IRQ_TYPE_LEVEL_HIGH>; - - ranges = <0x02000000 0 0x20000000 - 0x20000000 0 0x20000000>; - - interrupt-map-mask = <0 0 0 7>; - interrupt-map = <0 0 0 1 &pci1_intc 0>, - <0 0 0 2 &pci1_intc 1>, - <0 0 0 3 &pci1_intc 2>, - <0 0 0 4 &pci1_intc 3>; - - pci1_intc: interrupt-controller { - interrupt-controller; - #address-cells = <0>; - #interrupt-cells = <1>; - }; - }; - - pci2: pci@14000000 { - compatible = "xlnx,axi-pcie-host-1.00.a"; - device_type = "pci"; - reg = <0x14000000 0x2000000>; - - #address-cells = <3>; - #size-cells = <2>; - #interrupt-cells = <1>; - - interrupt-parent = <&gic>; - interrupts = <GIC_SHARED 0 IRQ_TYPE_LEVEL_HIGH>; - - ranges = <0x02000000 0 0x16000000 - 0x16000000 0 0x100000>; - - interrupt-map-mask = <0 0 0 7>; - interrupt-map = <0 0 0 1 &pci2_intc 0>, - <0 0 0 2 &pci2_intc 1>, - <0 0 0 3 &pci2_intc 2>, - <0 0 0 4 &pci2_intc 3>; - - pci2_intc: interrupt-controller { - interrupt-controller; - #address-cells = <0>; - #interrupt-cells = <1>; - }; - - pci2_root@0,0,0 { - compatible = "pci10ee,7021"; - reg = <0x00000000 0 0 0 0>; - - #address-cells = <3>; - #size-cells = <2>; - #interrupt-cells = <1>; - - eg20t_bridge@1,0,0 { - compatible = "pci8086,8800"; - reg = <0x00010000 0 0 0 0>; - - #address-cells = <3>; - #size-cells = <2>; - #interrupt-cells = <1>; - - eg20t_mac@2,0,1 { - compatible = "pci8086,8802"; - reg = <0x00020100 0 0 0 0>; - phy-reset-gpios = <&eg20t_gpio 6 GPIO_ACTIVE_LOW>; - }; - - eg20t_gpio: eg20t_gpio@2,0,2 { - compatible = "pci8086,8803"; - reg = <0x00020200 0 0 0 0>; - - gpio-controller; - #gpio-cells = <2>; - }; - - eg20t_i2c@2,12,2 { - compatible = "pci8086,8817"; - reg = <0x00026200 0 0 0 0>; - - #address-cells = <1>; - #size-cells = <0>; - - rtc@0x68 { - compatible = "st,m41t81s"; - reg = <0x68>; - }; - }; - }; - }; - }; - - plat_regs: system-controller@17ffd000 { - compatible = "img,boston-platform-regs", "syscon"; - reg = <0x17ffd000 0x1000>; - bootph-all; - }; - - clk_boston: clock { - compatible = "img,boston-clock"; - #clock-cells = <1>; - regmap = <&plat_regs>; - bootph-all; - }; - - reboot: syscon-reboot { - compatible = "syscon-reboot"; - regmap = <&plat_regs>; - offset = <0x10>; - mask = <0x10>; - }; - - uart0: uart@17ffe000 { - compatible = "ns16550a"; - reg = <0x17ffe000 0x1000>; - reg-shift = <2>; - reg-io-width = <4>; - - interrupt-parent = <&gic>; - interrupts = <GIC_SHARED 3 IRQ_TYPE_LEVEL_HIGH>; - - clocks = <&clk_boston BOSTON_CLK_SYS>; - - bootph-all; - }; - - lcd: lcd@17fff000 { - compatible = "img,boston-lcd"; - reg = <0x17fff000 0x8>; - }; - - flash@18000000 { - compatible = "cfi-flash"; - reg = <0x18000000 0x8000000>; - bank-width = <2>; - }; -}; diff --git a/board/imgtec/boston/MAINTAINERS b/board/imgtec/boston/MAINTAINERS index 07f6156ffcbe..12e1652858bb 100644 --- a/board/imgtec/boston/MAINTAINERS +++ b/board/imgtec/boston/MAINTAINERS @@ -1,6 +1,7 @@ BOSTON BOARD M: Paul Burton paul.burton@mips.com S: Maintained +F: arch/mips/dts/boston-u-boot.dtsi F: board/imgtec/boston/ F: include/configs/boston.h F: configs/boston32r2_defconfig diff --git a/configs/boston32r2_defconfig b/configs/boston32r2_defconfig index 6f0024a6663d..cb5898c3cafa 100644 --- a/configs/boston32r2_defconfig +++ b/configs/boston32r2_defconfig @@ -4,7 +4,7 @@ CONFIG_SYS_MALLOC_LEN=0x40000 CONFIG_SYS_MALLOC_F_LEN=0x400 CONFIG_ENV_SIZE=0x20000 CONFIG_ENV_SECT_SIZE=0x20000 -CONFIG_DEFAULT_DEVICE_TREE="img,boston" +CONFIG_DEFAULT_DEVICE_TREE="img/boston" CONFIG_SYS_LOAD_ADDR=0x88000000 CONFIG_ENV_ADDR=0xBFFE0000 CONFIG_TARGET_BOSTON=y diff --git a/configs/boston32r2el_defconfig b/configs/boston32r2el_defconfig index 71926429b051..4c603b69df7b 100644 --- a/configs/boston32r2el_defconfig +++ b/configs/boston32r2el_defconfig @@ -4,7 +4,7 @@ CONFIG_SYS_MALLOC_LEN=0x40000 CONFIG_SYS_MALLOC_F_LEN=0x400 CONFIG_ENV_SIZE=0x20000 CONFIG_ENV_SECT_SIZE=0x20000 -CONFIG_DEFAULT_DEVICE_TREE="img,boston" +CONFIG_DEFAULT_DEVICE_TREE="img/boston" CONFIG_SYS_LOAD_ADDR=0x88000000 CONFIG_ENV_ADDR=0xBFFE0000 CONFIG_TARGET_BOSTON=y diff --git a/configs/boston32r6_defconfig b/configs/boston32r6_defconfig index 4335d04b39eb..17f7c4364a03 100644 --- a/configs/boston32r6_defconfig +++ b/configs/boston32r6_defconfig @@ -4,7 +4,7 @@ CONFIG_SYS_MALLOC_LEN=0x40000 CONFIG_SYS_MALLOC_F_LEN=0x400 CONFIG_ENV_SIZE=0x20000 CONFIG_ENV_SECT_SIZE=0x20000 -CONFIG_DEFAULT_DEVICE_TREE="img,boston" +CONFIG_DEFAULT_DEVICE_TREE="img/boston" CONFIG_SYS_LOAD_ADDR=0x88000000 CONFIG_ENV_ADDR=0xBFFE0000 CONFIG_TARGET_BOSTON=y diff --git a/configs/boston32r6el_defconfig b/configs/boston32r6el_defconfig index b859a4f198ba..e662d167fe3d 100644 --- a/configs/boston32r6el_defconfig +++ b/configs/boston32r6el_defconfig @@ -4,7 +4,7 @@ CONFIG_SYS_MALLOC_LEN=0x40000 CONFIG_SYS_MALLOC_F_LEN=0x400 CONFIG_ENV_SIZE=0x20000 CONFIG_ENV_SECT_SIZE=0x20000 -CONFIG_DEFAULT_DEVICE_TREE="img,boston" +CONFIG_DEFAULT_DEVICE_TREE="img/boston" CONFIG_SYS_LOAD_ADDR=0x88000000 CONFIG_ENV_ADDR=0xBFFE0000 CONFIG_TARGET_BOSTON=y diff --git a/configs/boston64r2_defconfig b/configs/boston64r2_defconfig index 70354f117169..bf5a3ead3646 100644 --- a/configs/boston64r2_defconfig +++ b/configs/boston64r2_defconfig @@ -4,7 +4,7 @@ CONFIG_SYS_MALLOC_LEN=0x40000 CONFIG_SYS_MALLOC_F_LEN=0x400 CONFIG_ENV_SIZE=0x20000 CONFIG_ENV_SECT_SIZE=0x20000 -CONFIG_DEFAULT_DEVICE_TREE="img,boston" +CONFIG_DEFAULT_DEVICE_TREE="img/boston" CONFIG_SYS_LOAD_ADDR=0xffffffff88000000 CONFIG_ENV_ADDR=0xFFFFFFFFBFFE0000 CONFIG_TARGET_BOSTON=y diff --git a/configs/boston64r2el_defconfig b/configs/boston64r2el_defconfig index eafb8c67ba7a..de22344b5bb6 100644 --- a/configs/boston64r2el_defconfig +++ b/configs/boston64r2el_defconfig @@ -4,7 +4,7 @@ CONFIG_SYS_MALLOC_LEN=0x40000 CONFIG_SYS_MALLOC_F_LEN=0x400 CONFIG_ENV_SIZE=0x20000 CONFIG_ENV_SECT_SIZE=0x20000 -CONFIG_DEFAULT_DEVICE_TREE="img,boston" +CONFIG_DEFAULT_DEVICE_TREE="img/boston" CONFIG_SYS_LOAD_ADDR=0xffffffff88000000 CONFIG_ENV_ADDR=0xFFFFFFFFBFFE0000 CONFIG_TARGET_BOSTON=y diff --git a/configs/boston64r6_defconfig b/configs/boston64r6_defconfig index a6c89278512a..bb339cfd5dbe 100644 --- a/configs/boston64r6_defconfig +++ b/configs/boston64r6_defconfig @@ -4,7 +4,7 @@ CONFIG_SYS_MALLOC_LEN=0x40000 CONFIG_SYS_MALLOC_F_LEN=0x400 CONFIG_ENV_SIZE=0x20000 CONFIG_ENV_SECT_SIZE=0x20000 -CONFIG_DEFAULT_DEVICE_TREE="img,boston" +CONFIG_DEFAULT_DEVICE_TREE="img/boston" CONFIG_SYS_LOAD_ADDR=0xffffffff88000000 CONFIG_ENV_ADDR=0xFFFFFFFFBFFE0000 CONFIG_TARGET_BOSTON=y diff --git a/configs/boston64r6el_defconfig b/configs/boston64r6el_defconfig index 6cc227600df1..260f6dfb3583 100644 --- a/configs/boston64r6el_defconfig +++ b/configs/boston64r6el_defconfig @@ -4,7 +4,7 @@ CONFIG_SYS_MALLOC_LEN=0x40000 CONFIG_SYS_MALLOC_F_LEN=0x400 CONFIG_ENV_SIZE=0x20000 CONFIG_ENV_SECT_SIZE=0x20000 -CONFIG_DEFAULT_DEVICE_TREE="img,boston" +CONFIG_DEFAULT_DEVICE_TREE="img/boston" CONFIG_SYS_LOAD_ADDR=0xffffffff88000000 CONFIG_ENV_ADDR=0xFFFFFFFFBFFE0000 CONFIG_TARGET_BOSTON=y
- imply OF_UPSTREAM
should be 'select' because the switch to upstream DTS is permanent and it does not make sense for the user to be able to deselect this option
+&plat_regs {
- compatible = "img,boston-platform-regs", "syscon", "simple-mfd";
- bootph-all;
+&clk_boston {
- bootph-all;
- chosen {
- cpus {
#size-cells = <0>;
cpu@0 {
reg = <0>;
- memory@0 {
timer {
#size-cells = <2>;
#size-cells = <2>;
#size-cells = <2>;
pci2_root@0,0,0 {
#size-cells = <2>;
#size-cells = <2>;
eg20t_mac@2,0,1 {
gpio-controller;
#gpio-cells = <2>;
eg20t_i2c@2,12,2 {
#size-cells = <0>;
rtc@0x68 {
reg = <0x68>;
bootph-all;
#clock-cells = <1>;
bootph-all;
offset = <0x10>;
mask = <0x10>;
reg-shift = <2>;
reg-io-width = <4>;
bootph-all;
- flash@18000000 {
bank-width = <2>;
在2024年5月19日五月 下午7:20,Daniel Schwierzeck写道:
Hi Daniel,
Thanks for reviewing the series.
Do you want me to send another version or are you going to fix it as you apply the patch?
Thanks
Hi Daniel,
So, in the case of OF_UPTREAM, it's "imply OF_UPSTREAM" everywhere else and while there's a case to be made it should be select instead, that's probably a future clean-up for all users.
Hi Daniel,
I think it depends on whether OF_UPSTREAM is enabled for a SoC (with multiple board variants) or a single target board (I suppose that's the case here). For the former case, "imply" would be preferred since we can't enforce a policy at SoC level where new boards are coming up which have to opt out of OF_UPSTREAM. For the latter case, "select" would be preferred. However, I agree that it can be a future cleanup patch.
-Sumit
-- Tom
Paul had left MIPS a couple of years ago, his email address is no longer valid.
Replace it with his kenrel.org email, which has been used in kernel and QEMU, in case we still want to reach him.
Signed-off-by: Jiaxun Yang jiaxun.yang@flygoat.com --- .mailmap | 3 ++- board/imgtec/boston/MAINTAINERS | 2 +- board/imgtec/malta/MAINTAINERS | 2 +- 3 files changed, 4 insertions(+), 3 deletions(-)
diff --git a/.mailmap b/.mailmap index 8049856d41c3..bb7c1c3869ab 100644 --- a/.mailmap +++ b/.mailmap @@ -87,7 +87,8 @@ This contributor prefers not to receive mails noreply@example.com <pali@kernel This contributor prefers not to receive mails noreply@example.com pali.rohar@gmail.com Patrice Chotard patrice.chotard@foss.st.com patrice.chotard@st.com Patrick Delaunay patrick.delaunay@foss.st.com patrick.delaunay@st.com -Paul Burton paul.burton@mips.com paul.burton@imgtec.com +Paul Burton paulburton@kernel.org paul.burton@imgtec.com +Paul Burton paulburton@kernel.org paul.burton@mips.com Piyush Mehta piyush.mehta@amd.com piyush.mehta@xilinx.com Prabhakar Kushwaha prabhakar@freescale.com Punnaiah Choudary Kalluri punnaiah.choudary.kalluri@amd.com punnaiah.choudary.kalluri@xilinx.com diff --git a/board/imgtec/boston/MAINTAINERS b/board/imgtec/boston/MAINTAINERS index 12e1652858bb..b03a6487db29 100644 --- a/board/imgtec/boston/MAINTAINERS +++ b/board/imgtec/boston/MAINTAINERS @@ -1,5 +1,5 @@ BOSTON BOARD -M: Paul Burton paul.burton@mips.com +M: Paul Burton paulburton@kernel.org S: Maintained F: arch/mips/dts/boston-u-boot.dtsi F: board/imgtec/boston/ diff --git a/board/imgtec/malta/MAINTAINERS b/board/imgtec/malta/MAINTAINERS index b1cf297f4fac..252c5e45ab56 100644 --- a/board/imgtec/malta/MAINTAINERS +++ b/board/imgtec/malta/MAINTAINERS @@ -1,5 +1,5 @@ MALTA BOARD -M: Paul Burton paul.burton@mips.com +M: Paul Burton paulburton@kernel.org S: Maintained F: board/imgtec/malta/ F: include/configs/malta.h
在2024年5月18日五月 上午2:14,Jiaxun Yang写道:
Hi all,
Ping for apply :-)
Thanks
Changes in v3:
- Link to v2:
Changes in v2:
- Link to v1:
participants (5)
Daniel Schwierzeck
Jiaxun Yang
Maciej W. Rozycki
Sumit Garg
