[PATCH 0/4] addition of configs for rockchip based roc-pc-rk3399 board
Patch 1/4 use preboot configuration to enable usb devices Patch 2/4 fix up USB support which can recognize any USB1.1 devices Patch 3/4 Enable crypto RNG support Patch 4/4 Set the maximum slave SPI speed to 30MHz
Manoj Sai (4): configs: roc-pc-rk3399 :Enable preboot config . configs: roc-pc-rk3399:fix up USB support . configs: roc-pc-rk3399 :Enable crypto RNG support. configs: roc-pc-rk3399:Set the maximum slave SPI speed and spi flash max frequency for environment to 30MHz.
configs/roc-pc-rk3399_defconfig | 8 ++++++++ 1 file changed, 8 insertions(+)
Signed-off-by: Manoj Sai abbaraju.manojsai@amarulasolutions.com Signed-off-by: Da Xue da.xue@libretech.co --- configs/roc-pc-rk3399_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/roc-pc-rk3399_defconfig b/configs/roc-pc-rk3399_defconfig index 4625e47537..84e82da3cf 100644 --- a/configs/roc-pc-rk3399_defconfig +++ b/configs/roc-pc-rk3399_defconfig @@ -20,6 +20,7 @@ CONFIG_DEBUG_UART=y CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x300000 # CONFIG_ANDROID_BOOT_IMAGE is not set +CONFIG_USE_PREBOOT=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-roc-pc.dtb" CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_SPL_MAX_SIZE=0x2e000
This Patch enables the following details of configs to rockchip based roc-rk3399-pc board :
1) Enable preboot configuration to enable usb devices .
2) Fix up USB config options so keyboards and other USB devices work and update the number of ports of the Usb root hub to configuration of CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS .
- with this addition the updated USB device Tree : USB device tree:
1 Hub (12 Mb/s, 0mA) U-Boot Root Hub 1 Hub (12 Mb/s, 0mA) | U-Boot Root Hub | +-2 Hub (12 Mb/s, 100mA) USB 2.0 Hub [MTT]
1 Hub (5 Gb/s, 0mA) U-Boot XHCI Host Controller
3) enable crypto RNG ( random number generator ) support
4) Set the maximum slave SPI speed to 30MHz : - This patch increases the maximum SPI slave device speed and SPI flash max frequency for environment from 10Mhz to 30MHz .
- difference in time of erase and update a region of SPI flash from memory with 10Mhz and 30Mhz frequencey range updation follows :-
with 10 Mhz frequency updation :- => sf update 0x300000 0x800000 0x400000 4194304 bytes written, 0 bytes skipped in 36.819s, speed 119837 B/s
with 30Mhz frequency updation :- => sf update 0x300000 0x800000 0x400000 4194304 bytes written, 0 bytes skipped in 20.319s, speed 220752 B/s
Signed-off-by: Manoj Sai abbaraju.manojsai@amarulasolutions.com Signed-off-by: Da Xue da.xue@libretech.co Signed-off-by: dsx724 da@lessconfused.com --- Changes for v2 :- - fixed prefix in commit message . - squash the all four patches into single patch . --- configs/roc-pc-rk3399_defconfig | 8 ++++++++ 1 file changed, 8 insertions(+)
diff --git a/configs/roc-pc-rk3399_defconfig b/configs/roc-pc-rk3399_defconfig index 4625e47537..7754cb8388 100644 --- a/configs/roc-pc-rk3399_defconfig +++ b/configs/roc-pc-rk3399_defconfig @@ -20,6 +20,7 @@ CONFIG_DEBUG_UART=y CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x300000 # CONFIG_ANDROID_BOOT_IMAGE is not set +CONFIG_USE_PREBOOT=y CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-roc-pc.dtb" CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_SPL_MAX_SIZE=0x2e000 @@ -44,6 +45,7 @@ CONFIG_CMD_TIME=y CONFIG_SPL_OF_CONTROL=y CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_ENV_SPI_MAX_HZ=30000000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_ROCKCHIP_GPIO=y @@ -54,6 +56,7 @@ CONFIG_MMC_DW_ROCKCHIP=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_ROCKCHIP=y CONFIG_SF_DEFAULT_BUS=1 +CONFIG_SF_DEFAULT_SPEED=30000000 CONFIG_SPI_FLASH_WINBOND=y CONFIG_ETH_DESIGNWARE=y CONFIG_GMAC_ROCKCHIP=y @@ -66,6 +69,8 @@ CONFIG_PWM_ROCKCHIP=y # CONFIG_RAM_ROCKCHIP_DEBUG is not set CONFIG_RAM_RK3399_LPDDR4=y CONFIG_DM_RESET=y +CONFIG_DM_RNG=y +CONFIG_RNG_ROCKCHIP=y CONFIG_BAUDRATE=1500000 CONFIG_DEBUG_UART_SHIFT=2 CONFIG_ROCKCHIP_SPI=y @@ -75,6 +80,9 @@ CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_GENERIC=y +CONFIG_USB_OHCI_HCD=y +CONFIG_USB_OHCI_GENERIC=y +CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS=2 CONFIG_USB_DWC3=y CONFIG_USB_DWC3_GENERIC=y CONFIG_USB_KEYBOARD=y
This patch enables the following:
1) use preboot configuration to enable usb devices.
2) Enable USB configs so keyboards and other USB devices work, update the number of ports of the usb root hub.
- with this addition the updated USB device Tree:
3) enable crypto RNG support.
4) Change SPI speed and frequency: - increase the maximum SPI slave device speed, SPI flash max frequency for the environment from 10Mhz to 30MHz.
- performance stats for speed update from 10MHz to 30MHz:
with 10Mhz speed update: => sf update 0x300000 0x800000 0x400000 4194304 bytes written, 0 bytes skipped in 36.819s, speed 119837 B/s
with 30Mhz speed update: => sf update 0x300000 0x800000 0x400000 4194304 bytes written, 0 bytes skipped in 20.319s, speed 220752 B/s
Signed-off-by: Manoj Sai abbaraju.manojsai@amarulasolutions.com Signed-off-by: Da Xue da.xue@libretech.co Signed-off-by: dsx724 da@lessconfused.com --- Changes for v3: - shortened the commit header. Changes for v2: - fixed prefix in the commit message. - squash all four patches into a single patch. --- configs/roc-pc-rk3399_defconfig | 8 ++++++++ 1 file changed, 8 insertions(+)
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
Changes for v3:
Changes for v2:
- Fix up USB config options so keyboards and other USB devices work .
- Update the number of ports of the Usb root hub to configuration of CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS .
USB device tree: 1 Hub (12 Mb/s, 0mA) U-Boot Root Hub 1 Hub (12 Mb/s, 0mA) | U-Boot Root Hub | +-2 Hub (12 Mb/s, 100mA) USB 2.0 Hub [MTT]
Signed-off-by: Manoj Sai abbaraju.manojsai@amarulasolutions.com Signed-off-by: Da Xue da.xue@libretech.co Signed-off-by: dsx724 da@lessconfused.com --- configs/roc-pc-rk3399_defconfig | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/configs/roc-pc-rk3399_defconfig b/configs/roc-pc-rk3399_defconfig index 84e82da3cf..ffd809687b 100644 --- a/configs/roc-pc-rk3399_defconfig +++ b/configs/roc-pc-rk3399_defconfig @@ -76,6 +76,9 @@ CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_GENERIC=y +CONFIG_USB_OHCI_HCD=y +CONFIG_USB_OHCI_GENERIC=y +CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS=2 CONFIG_USB_DWC3=y CONFIG_USB_DWC3_GENERIC=y CONFIG_USB_KEYBOARD=y
enable crypto RNG support for roc-pc-rk3399.
Signed-off-by: Manoj Sai abbaraju.manojsai@amarulasolutions.com Signed-off-by: Da Xue da.xue@libretech.co Signed-off-by: dsx724 <da@lessconfused.com --- configs/roc-pc-rk3399_defconfig | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/configs/roc-pc-rk3399_defconfig b/configs/roc-pc-rk3399_defconfig index ffd809687b..84e72e8b60 100644 --- a/configs/roc-pc-rk3399_defconfig +++ b/configs/roc-pc-rk3399_defconfig @@ -67,6 +67,8 @@ CONFIG_PWM_ROCKCHIP=y # CONFIG_RAM_ROCKCHIP_DEBUG is not set CONFIG_RAM_RK3399_LPDDR4=y CONFIG_DM_RESET=y +CONFIG_DM_RNG=y +CONFIG_RNG_ROCKCHIP=y CONFIG_BAUDRATE=1500000 CONFIG_DEBUG_UART_SHIFT=2 CONFIG_ROCKCHIP_SPI=y
-While the SPI controller speed is defined by DTS, the maximum slave speed (connected devices) is limited by the pre-defined configuration value CONFIG_SF_DEFAULT_SPEED from 10 MHz to 30Mhz.
-set the Value of SPI flash max frequency for environment to 30Mhz.
This patch increases this maximum SPI slave device speed and SPI flash max frequency for environment to 30MHz .
difference in time of erase and update a region of SPI flash from memory with 10Mhz and 30Mhz frequencey range updation :
with 10 Mhz frequency updation :- 4194304 bytes written, 0 bytes skipped in 36.819s, speed 119837 B/s
with 30Mhz frequency updation :- 4194304 bytes written, 0 bytes skipped in 20.319s, speed 220752 B/s
Signed-off-by: Manoj Sai abbaraju.manojsai@amarulasolutions.com Signed-off-by: Da Xue da.xue@libretech.co Signed-off-by: dsx724 da@lessconfused.com --- configs/roc-pc-rk3399_defconfig | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/configs/roc-pc-rk3399_defconfig b/configs/roc-pc-rk3399_defconfig index 84e72e8b60..7754cb8388 100644 --- a/configs/roc-pc-rk3399_defconfig +++ b/configs/roc-pc-rk3399_defconfig @@ -45,6 +45,7 @@ CONFIG_CMD_TIME=y CONFIG_SPL_OF_CONTROL=y CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_ENV_SPI_MAX_HZ=30000000 CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_ROCKCHIP_GPIO=y @@ -55,6 +56,7 @@ CONFIG_MMC_DW_ROCKCHIP=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_ROCKCHIP=y CONFIG_SF_DEFAULT_BUS=1 +CONFIG_SF_DEFAULT_SPEED=30000000 CONFIG_SPI_FLASH_WINBOND=y CONFIG_ETH_DESIGNWARE=y CONFIG_GMAC_ROCKCHIP=y
Hi Manoj,
Please use "rockchip: roc-rk3399-pc:" as prefix of these patches,
and I think one patch to squash all these four patch is OK for they all only modify the config of roc-pc board,
just make sure the commit message is clear enough.
Thanks,
- Kever
Kever Yang
Manoj Sai
