[PATCH 1/7] board: rockchip: Add rk3588 evb board support
Add support for rk3588 evaluation board.
Signed-off-by: Joseph Chen chenjh@rock-chips.com --- board/rockchip/evb_rk3588/Kconfig | 15 ++++++ board/rockchip/evb_rk3588/MAINTAINERS | 6 +++ board/rockchip/evb_rk3588/Makefile | 7 +++ board/rockchip/evb_rk3588/evb_rk3588.c | 4 ++ configs/evb-rk3588_defconfig | 69 ++++++++++++++++++++++++++ include/configs/evb_rk3588.h | 15 ++++++ 6 files changed, 116 insertions(+) create mode 100644 board/rockchip/evb_rk3588/Kconfig create mode 100644 board/rockchip/evb_rk3588/MAINTAINERS create mode 100644 board/rockchip/evb_rk3588/Makefile create mode 100644 board/rockchip/evb_rk3588/evb_rk3588.c create mode 100644 configs/evb-rk3588_defconfig create mode 100644 include/configs/evb_rk3588.h
diff --git a/board/rockchip/evb_rk3588/Kconfig b/board/rockchip/evb_rk3588/Kconfig new file mode 100644 index 0000000000..d38efe61d8 --- /dev/null +++ b/board/rockchip/evb_rk3588/Kconfig @@ -0,0 +1,15 @@ +if TARGET_EVB_RK3588 + +config SYS_BOARD + default "evb_rk3588" + +config SYS_VENDOR + default "rockchip" + +config SYS_CONFIG_NAME + default "evb_rk3588" + +config BOARD_SPECIFIC_OPTIONS # dummy + def_bool y + +endif diff --git a/board/rockchip/evb_rk3588/MAINTAINERS b/board/rockchip/evb_rk3588/MAINTAINERS new file mode 100644 index 0000000000..1a9695458d --- /dev/null +++ b/board/rockchip/evb_rk3588/MAINTAINERS @@ -0,0 +1,6 @@ +EVB-RK3568 +M: Joseph Chen chenjh@rock-chips.com +S: Maintained +F: board/rockchip/evb_rk3588 +F: include/configs/evb_rk3588.h +F: configs/evb-rk3588_defconfig diff --git a/board/rockchip/evb_rk3588/Makefile b/board/rockchip/evb_rk3588/Makefile new file mode 100644 index 0000000000..3946c3565e --- /dev/null +++ b/board/rockchip/evb_rk3588/Makefile @@ -0,0 +1,7 @@ +# +# SPDX-License-Identifier: GPL-2.0+ +# +# Copyright (c) 2021 Rockchip Electronics Co., Ltd +# + +obj-y += evb_rk3588.o diff --git a/board/rockchip/evb_rk3588/evb_rk3588.c b/board/rockchip/evb_rk3588/evb_rk3588.c new file mode 100644 index 0000000000..c2fdf95d9a --- /dev/null +++ b/board/rockchip/evb_rk3588/evb_rk3588.c @@ -0,0 +1,4 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2021 Rockchip Electronics Co., Ltd + */ diff --git a/configs/evb-rk3588_defconfig b/configs/evb-rk3588_defconfig new file mode 100644 index 0000000000..83cddcf2b0 --- /dev/null +++ b/configs/evb-rk3588_defconfig @@ -0,0 +1,69 @@ +CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y +CONFIG_COUNTER_FREQUENCY=24000000 +CONFIG_ARCH_ROCKCHIP=y +CONFIG_TEXT_BASE=0x00200000 +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_NR_DRAM_BANKS=2 +CONFIG_DEFAULT_DEVICE_TREE="rk3588-evb" +CONFIG_ROCKCHIP_RK3588=y +CONFIG_SPL_ROCKCHIP_BACK_TO_BROM=y +CONFIG_SPL_ROCKCHIP_COMMON_BOARD=y +CONFIG_SPL_MMC=y +CONFIG_SPL_SERIAL=y +CONFIG_SPL_STACK_R_ADDR=0x600000 +CONFIG_TARGET_EVB_RK3588=y +CONFIG_DEBUG_UART_BASE=0xFEB50000 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_SYS_LOAD_ADDR=0x400800 +CONFIG_DEBUG_UART=y +CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y +CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x400000 +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_SPL_LOAD_FIT=y +CONFIG_DEFAULT_FDT_FILE="rockchip/rk3588-evb.dtb" +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_MAX_SIZE=0x20000 +CONFIG_SPL_PAD_TO=0x7f8000 +CONFIG_SPL_HAS_BSS_LINKER_SECTION=y +CONFIG_SPL_BSS_START_ADDR=0x4000000 +CONFIG_SPL_BSS_MAX_SIZE=0x4000 +# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set +# CONFIG_SPL_SHARES_INIT_SP_ADDR is not set +CONFIG_SPL_STACK=0x400000 +CONFIG_SPL_STACK_R=y +CONFIG_SPL_ATF=y +CONFIG_CMD_GPT=y +CONFIG_CMD_MMC=y +# CONFIG_CMD_SETEXPR is not set +# CONFIG_SPL_DOS_PARTITION is not set +CONFIG_SPL_OF_CONTROL=y +CONFIG_OF_LIVE=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_SPL_REGMAP=y +CONFIG_SPL_SYSCON=y +CONFIG_SPL_CLK=y +CONFIG_ROCKCHIP_GPIO=y +CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_MISC=y +CONFIG_SUPPORT_EMMC_RPMB=y +CONFIG_MMC_DW=y +CONFIG_MMC_DW_ROCKCHIP=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_SDMA=y +CONFIG_MMC_SDHCI_ROCKCHIP=y +CONFIG_ETH_DESIGNWARE=y +CONFIG_GMAC_ROCKCHIP=y +CONFIG_REGULATOR_PWM=y +CONFIG_PWM_ROCKCHIP=y +CONFIG_SPL_RAM=y +CONFIG_DM_RESET=y +CONFIG_BAUDRATE=1500000 +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_SYS_NS16550_MEM32=y +CONFIG_SYSRESET=y +# CONFIG_BINMAN_FDT is not set +CONFIG_ERRNO_STR=y diff --git a/include/configs/evb_rk3588.h b/include/configs/evb_rk3588.h new file mode 100644 index 0000000000..13411c9609 --- /dev/null +++ b/include/configs/evb_rk3588.h @@ -0,0 +1,15 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * (C) Copyright 2016 Rockchip Electronics Co., Ltd + */ + +#ifndef __CONFIGS_RK3588_EVB_H +#define __CONFIGS_RK3588_EVB_H + +#include <configs/rk3588_common.h> + +#define ROCKCHIP_DEVICE_SETTINGS \ + "stdout=serial,vidconsole\0" \ + "stderr=serial,vidconsole\0" + +#endif
Does it boot with BL31 (bin/rk35/rk3588_bl31_v1.27.elf) from rkbin master branch? I have tried with some information provided to Kever the BL31 seems not working from my side. Can you confirm which BL31 is working?
Thanks, Jagan.
fatorangecat@189.cn
Jagan Teki
