[U-Boot] [PATCH 0/5]
This patchset add support for rk3399 with ATF based on Rockchip miniloader as secondary bootloader instead of u-boot SPL.
Rockchip miniloader init the DRAM and load the ATF and u-boot to runing address, and then jump to ATF, ATM do some init and switch to EL2/EL1 mode before jump to next loader which is u-boot here.
Pls reference board/rockchip/evb_rk3399/README to setup the board.
Will migrate to SPL once its ready for ATF.
This patch set is based on below patch: "board: move all the rockchip board in one folder"
This patch set has been test on rk3399 evb board.
Kever Yang (5): dts: add support for rkchichip rk3399 soc ARM64: rockchip: add support for rk3399 SoC based evb-board config: add config file for evb-rk3399 mmc: rockchip: add SDHCI driver support for rockchip soc ARM64: evb-rk3399: add a README for this board setup
arch/arm/Kconfig | 3 - arch/arm/dts/Makefile | 3 +- arch/arm/dts/rk3399-evb.dts | 104 ++++ arch/arm/dts/rk3399.dtsi | 1028 ++++++++++++++++++++++++++++++++ arch/arm/mach-rockchip/Kconfig | 25 +- arch/arm/mach-rockchip/Makefile | 2 +- arch/arm/mach-rockchip/rk3399/Kconfig | 19 + arch/arm/mach-rockchip/rk3399/Makefile | 5 + board/rockchip/evb_rk3399/Kconfig | 15 + board/rockchip/evb_rk3399/MAINTAINERS | 0 board/rockchip/evb_rk3399/Makefile | 7 + board/rockchip/evb_rk3399/README | 73 +++ board/rockchip/evb_rk3399/evb-rk3399.c | 41 ++ configs/evb-rk3399_defconfig | 32 + drivers/mmc/Kconfig | 6 + drivers/mmc/Makefile | 1 + drivers/mmc/rockchip_sdhci.c | 58 ++ include/configs/evb_rk3399.h | 24 + include/configs/rk3399_common.h | 84 +++ include/dt-bindings/clock/rk3399-cru.h | 746 +++++++++++++++++++++++ 20 files changed, 2270 insertions(+), 6 deletions(-) create mode 100644 arch/arm/dts/rk3399-evb.dts create mode 100644 arch/arm/dts/rk3399.dtsi create mode 100644 arch/arm/mach-rockchip/rk3399/Kconfig create mode 100644 arch/arm/mach-rockchip/rk3399/Makefile create mode 100644 board/rockchip/evb_rk3399/Kconfig create mode 100644 board/rockchip/evb_rk3399/MAINTAINERS create mode 100644 board/rockchip/evb_rk3399/Makefile create mode 100644 board/rockchip/evb_rk3399/README create mode 100644 board/rockchip/evb_rk3399/evb-rk3399.c create mode 100644 configs/evb-rk3399_defconfig create mode 100644 drivers/mmc/rockchip_sdhci.c create mode 100644 include/configs/evb_rk3399.h create mode 100644 include/configs/rk3399_common.h create mode 100644 include/dt-bindings/clock/rk3399-cru.h
These files are from kernel upstream with some modification need by uboot: - chosen with stdout-path to uart2.
Signed-off-by: Kever Yang kever.yang@rock-chips.com ---
arch/arm/dts/Makefile | 3 +- arch/arm/dts/rk3399-evb.dts | 104 ++++ arch/arm/dts/rk3399.dtsi | 1028 ++++++++++++++++++++++++++++++++ include/dt-bindings/clock/rk3399-cru.h | 746 +++++++++++++++++++++++ 4 files changed, 1880 insertions(+), 1 deletion(-) create mode 100644 arch/arm/dts/rk3399-evb.dts create mode 100644 arch/arm/dts/rk3399.dtsi create mode 100644 include/dt-bindings/clock/rk3399-cru.h
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 0a41eb2..62173a4 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -27,7 +27,8 @@ dtb-$(CONFIG_ARCH_ROCKCHIP) += \ rk3288-firefly.dtb \ rk3288-jerry.dtb \ rk3288-rock2-square.dtb \ - rk3036-sdk.dtb + rk3036-sdk.dtb \ + rk3399-evb.dtb dtb-$(CONFIG_ARCH_MESON) += \ meson-gxbb-odroidc2.dtb dtb-$(CONFIG_TEGRA) += tegra20-harmony.dtb \ diff --git a/arch/arm/dts/rk3399-evb.dts b/arch/arm/dts/rk3399-evb.dts new file mode 100644 index 0000000..bbcfcd0 --- /dev/null +++ b/arch/arm/dts/rk3399-evb.dts @@ -0,0 +1,104 @@ +/* + * (C) Copyright 2016 Rockchip Electronics Co., Ltd + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +/dts-v1/; +#include <dt-bindings/pwm/pwm.h> +#include "rk3399.dtsi" + +/ { + model = "Rockchip RK3399 Evaluation Board"; + compatible = "rockchip,rk3399-evb", "rockchip,rk3399", + "google,rk3399evb-rev2"; + + chosen { + stdout-path = &uart2; + }; + + vdd_center: vdd-center { + compatible = "pwm-regulator"; + pwms = <&pwm3 0 25000 0>; + regulator-name = "vdd_center"; + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <1400000>; + regulator-always-on; + regulator-boot-on; + status = "okay"; + }; + + vcc3v3_sys: vcc3v3-sys { + compatible = "regulator-fixed"; + regulator-name = "vcc3v3_sys"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + }; + + vcc_phy: vcc-phy-regulator { + compatible = "regulator-fixed"; + regulator-name = "vcc_phy"; + regulator-always-on; + regulator-boot-on; + }; +}; + +&emmc_phy { + status = "okay"; +}; + +&pwm0 { + status = "okay"; +}; + +&pwm2 { + status = "okay"; +}; + +&pwm3 { + status = "okay"; +}; + +&sdhci { + bus-width = <8>; + mmc-hs400-1_8v; + mmc-hs400-enhanced-strobe; + non-removable; + status = "okay"; +}; + +&uart2 { + status = "okay"; +}; + +&usb_host0_ehci { + status = "okay"; +}; + +&usb_host0_ohci { + status = "okay"; +}; + +&usb_host1_ehci { + status = "okay"; +}; + +&usb_host1_ohci { + status = "okay"; +}; + +&pinctrl { + pmic { + pmic_int_l: pmic-int-l { + rockchip,pins = + <1 21 RK_FUNC_GPIO &pcfg_pull_up>; + }; + + pmic_dvs2: pmic-dvs2 { + rockchip,pins = + <1 18 RK_FUNC_GPIO &pcfg_pull_down>; + }; + }; +}; diff --git a/arch/arm/dts/rk3399.dtsi b/arch/arm/dts/rk3399.dtsi new file mode 100644 index 0000000..fb5af54 --- /dev/null +++ b/arch/arm/dts/rk3399.dtsi @@ -0,0 +1,1028 @@ +/* + * (C) Copyright 2016 Rockchip Electronics Co., Ltd + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <dt-bindings/clock/rk3399-cru.h> +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/interrupt-controller/arm-gic.h> +#include <dt-bindings/interrupt-controller/irq.h> +#include <dt-bindings/pinctrl/rockchip.h> + +/ { + compatible = "rockchip,rk3399"; + + interrupt-parent = <&gic>; + #address-cells = <2>; + #size-cells = <2>; + + aliases { + serial0 = &uart0; + serial1 = &uart1; + serial2 = &uart2; + serial3 = &uart3; + serial4 = &uart4; + }; + + cpus { + #address-cells = <2>; + #size-cells = <0>; + + cpu-map { + cluster0 { + core0 { + cpu = <&cpu_l0>; + }; + core1 { + cpu = <&cpu_l1>; + }; + core2 { + cpu = <&cpu_l2>; + }; + core3 { + cpu = <&cpu_l3>; + }; + }; + + cluster1 { + core0 { + cpu = <&cpu_b0>; + }; + core1 { + cpu = <&cpu_b1>; + }; + }; + }; + + cpu_l0: cpu@0 { + device_type = "cpu"; + compatible = "arm,cortex-a53", "arm,armv8"; + reg = <0x0 0x0>; + enable-method = "psci"; + #cooling-cells = <2>; /* min followed by max */ + clocks = <&cru ARMCLKL>; + }; + + cpu_l1: cpu@1 { + device_type = "cpu"; + compatible = "arm,cortex-a53", "arm,armv8"; + reg = <0x0 0x1>; + enable-method = "psci"; + clocks = <&cru ARMCLKL>; + }; + + cpu_l2: cpu@2 { + device_type = "cpu"; + compatible = "arm,cortex-a53", "arm,armv8"; + reg = <0x0 0x2>; + enable-method = "psci"; + clocks = <&cru ARMCLKL>; + }; + + cpu_l3: cpu@3 { + device_type = "cpu"; + compatible = "arm,cortex-a53", "arm,armv8"; + reg = <0x0 0x3>; + enable-method = "psci"; + clocks = <&cru ARMCLKL>; + }; + + cpu_b0: cpu@100 { + device_type = "cpu"; + compatible = "arm,cortex-a72", "arm,armv8"; + reg = <0x0 0x100>; + enable-method = "psci"; + #cooling-cells = <2>; /* min followed by max */ + clocks = <&cru ARMCLKB>; + }; + + cpu_b1: cpu@101 { + device_type = "cpu"; + compatible = "arm,cortex-a72", "arm,armv8"; + reg = <0x0 0x101>; + enable-method = "psci"; + clocks = <&cru ARMCLKB>; + }; + }; + + psci { + compatible = "arm,psci-1.0"; + method = "smc"; + }; + + timer { + compatible = "arm,armv8-timer"; + interrupts = <GIC_PPI 13 IRQ_TYPE_LEVEL_LOW>, + <GIC_PPI 14 IRQ_TYPE_LEVEL_LOW>, + <GIC_PPI 11 IRQ_TYPE_LEVEL_LOW>, + <GIC_PPI 10 IRQ_TYPE_LEVEL_LOW>; + }; + + xin24m: xin24m { + compatible = "fixed-clock"; + clock-frequency = <24000000>; + clock-output-names = "xin24m"; + #clock-cells = <0>; + }; + + amba { + compatible = "simple-bus"; + #address-cells = <2>; + #size-cells = <2>; + ranges; + + dmac_bus: dma-controller@ff6d0000 { + compatible = "arm,pl330", "arm,primecell"; + reg = <0x0 0xff6d0000 0x0 0x4000>; + interrupts = <GIC_SPI 5 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 6 IRQ_TYPE_LEVEL_HIGH>; + #dma-cells = <1>; + clocks = <&cru ACLK_DMAC0_PERILP>; + clock-names = "apb_pclk"; + }; + + dmac_peri: dma-controller@ff6e0000 { + compatible = "arm,pl330", "arm,primecell"; + reg = <0x0 0xff6e0000 0x0 0x4000>; + interrupts = <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH>; + #dma-cells = <1>; + clocks = <&cru ACLK_DMAC1_PERILP>; + clock-names = "apb_pclk"; + }; + }; + + sdio0: dwmmc@fe310000 { + compatible = "rockchip,rk3399-dw-mshc", + "rockchip,rk3288-dw-mshc"; + reg = <0x0 0xfe310000 0x0 0x4000>; + interrupts = <GIC_SPI 64 IRQ_TYPE_LEVEL_HIGH>; + clock-freq-min-max = <400000 150000000>; + clocks = <&cru HCLK_SDIO>, <&cru SCLK_SDIO>, + <&cru SCLK_SDIO_DRV>, <&cru SCLK_SDIO_SAMPLE>; + clock-names = "biu", "ciu", "ciu-drive", "ciu-sample"; + fifo-depth = <0x100>; + status = "disabled"; + }; + + sdmmc: dwmmc@fe320000 { + compatible = "rockchip,rk3399-dw-mshc", + "rockchip,rk3288-dw-mshc"; + reg = <0x0 0xfe320000 0x0 0x4000>; + interrupts = <GIC_SPI 65 IRQ_TYPE_LEVEL_HIGH>; + clock-freq-min-max = <400000 150000000>; + clocks = <&cru HCLK_SDMMC>, <&cru SCLK_SDMMC>, + <&cru SCLK_SDMMC_DRV>, <&cru SCLK_SDMMC_SAMPLE>; + clock-names = "biu", "ciu", "ciu-drive", "ciu-sample"; + fifo-depth = <0x100>; + status = "disabled"; + }; + + sdhci: sdhci@fe330000 { + compatible = "rockchip,rk3399-sdhci-5.1", "arasan,sdhci-5.1"; + reg = <0x0 0xfe330000 0x0 0x10000>; + interrupts = <GIC_SPI 11 IRQ_TYPE_LEVEL_HIGH>; + assigned-clocks = <&cru SCLK_EMMC>; + assigned-clock-rates = <200000000>; + clocks = <&cru SCLK_EMMC>, <&cru ACLK_EMMC>; + clock-names = "clk_xin", "clk_ahb"; + phys = <&emmc_phy>; + phy-names = "phy_arasan"; + status = "disabled"; + }; + + usb_host0_ehci: usb@fe380000 { + compatible = "generic-ehci"; + reg = <0x0 0xfe380000 0x0 0x20000>; + interrupts = <GIC_SPI 26 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cru HCLK_HOST0>, <&cru HCLK_HOST0_ARB>; + clock-names = "hclk_host0", "hclk_host0_arb"; + status = "disabled"; + }; + + usb_host0_ohci: usb@fe3a0000 { + compatible = "generic-ohci"; + reg = <0x0 0xfe3a0000 0x0 0x20000>; + interrupts = <GIC_SPI 28 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cru HCLK_HOST0>, <&cru HCLK_HOST0_ARB>; + clock-names = "hclk_host0", "hclk_host0_arb"; + status = "disabled"; + }; + + usb_host1_ehci: usb@fe3c0000 { + compatible = "generic-ehci"; + reg = <0x0 0xfe3c0000 0x0 0x20000>; + interrupts = <GIC_SPI 30 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cru HCLK_HOST1>, <&cru HCLK_HOST1_ARB>; + clock-names = "hclk_host1", "hclk_host1_arb"; + status = "disabled"; + }; + + usb_host1_ohci: usb@fe3e0000 { + compatible = "generic-ohci"; + reg = <0x0 0xfe3e0000 0x0 0x20000>; + interrupts = <GIC_SPI 32 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cru HCLK_HOST1>, <&cru HCLK_HOST1_ARB>; + clock-names = "hclk_host1", "hclk_host1_arb"; + status = "disabled"; + }; + + gic: interrupt-controller@fee00000 { + compatible = "arm,gic-v3"; + #interrupt-cells = <3>; + #address-cells = <2>; + #size-cells = <2>; + ranges; + interrupt-controller; + + reg = <0x0 0xfee00000 0 0x10000>, /* GICD */ + <0x0 0xfef00000 0 0xc0000>, /* GICR */ + <0x0 0xfff00000 0 0x10000>, /* GICC */ + <0x0 0xfff10000 0 0x10000>, /* GICH */ + <0x0 0xfff20000 0 0x10000>; /* GICV */ + interrupts = <GIC_PPI 9 IRQ_TYPE_LEVEL_HIGH>; + its: interrupt-controller@fee20000 { + compatible = "arm,gic-v3-its"; + msi-controller; + reg = <0x0 0xfee20000 0x0 0x20000>; + }; + }; + + uart0: serial@ff180000 { + compatible = "rockchip,rk3399-uart", "snps,dw-apb-uart"; + reg = <0x0 0xff180000 0x0 0x100>; + clocks = <&cru SCLK_UART0>, <&cru PCLK_UART0>; + clock-names = "baudclk", "apb_pclk"; + interrupts = <GIC_SPI 99 IRQ_TYPE_LEVEL_HIGH>; + reg-shift = <2>; + reg-io-width = <4>; + pinctrl-names = "default"; + pinctrl-0 = <&uart0_xfer>; + status = "disabled"; + }; + + uart1: serial@ff190000 { + compatible = "rockchip,rk3399-uart", "snps,dw-apb-uart"; + reg = <0x0 0xff190000 0x0 0x100>; + clocks = <&cru SCLK_UART1>, <&cru PCLK_UART1>; + clock-names = "baudclk", "apb_pclk"; + interrupts = <GIC_SPI 98 IRQ_TYPE_LEVEL_HIGH>; + reg-shift = <2>; + reg-io-width = <4>; + pinctrl-names = "default"; + pinctrl-0 = <&uart1_xfer>; + status = "disabled"; + }; + + uart2: serial@ff1a0000 { + compatible = "rockchip,rk3399-uart", "snps,dw-apb-uart"; + reg = <0x0 0xff1a0000 0x0 0x100>; + clocks = <&cru SCLK_UART2>, <&cru PCLK_UART2>; + clock-names = "baudclk", "apb_pclk"; + interrupts = <GIC_SPI 100 IRQ_TYPE_LEVEL_HIGH>; + clock-frequency = <24000000>; + reg-shift = <2>; + reg-io-width = <4>; + pinctrl-names = "default"; + pinctrl-0 = <&uart2c_xfer>; + status = "disabled"; + }; + + uart3: serial@ff1b0000 { + compatible = "rockchip,rk3399-uart", "snps,dw-apb-uart"; + reg = <0x0 0xff1b0000 0x0 0x100>; + clocks = <&cru SCLK_UART3>, <&cru PCLK_UART3>; + clock-names = "baudclk", "apb_pclk"; + interrupts = <GIC_SPI 101 IRQ_TYPE_LEVEL_HIGH>; + reg-shift = <2>; + reg-io-width = <4>; + pinctrl-names = "default"; + pinctrl-0 = <&uart3_xfer>; + status = "disabled"; + }; + + spi0: spi@ff1c0000 { + compatible = "rockchip,rk3399-spi", "rockchip,rk3066-spi"; + reg = <0x0 0xff1c0000 0x0 0x1000>; + clocks = <&cru SCLK_SPI0>, <&cru PCLK_SPI0>; + clock-names = "spiclk", "apb_pclk"; + interrupts = <GIC_SPI 68 IRQ_TYPE_LEVEL_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&spi0_clk &spi0_tx &spi0_rx &spi0_cs0>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + spi1: spi@ff1d0000 { + compatible = "rockchip,rk3399-spi", "rockchip,rk3066-spi"; + reg = <0x0 0xff1d0000 0x0 0x1000>; + clocks = <&cru SCLK_SPI1>, <&cru PCLK_SPI1>; + clock-names = "spiclk", "apb_pclk"; + interrupts = <GIC_SPI 53 IRQ_TYPE_LEVEL_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&spi1_clk &spi1_tx &spi1_rx &spi1_cs0>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + spi2: spi@ff1e0000 { + compatible = "rockchip,rk3399-spi", "rockchip,rk3066-spi"; + reg = <0x0 0xff1e0000 0x0 0x1000>; + clocks = <&cru SCLK_SPI2>, <&cru PCLK_SPI2>; + clock-names = "spiclk", "apb_pclk"; + interrupts = <GIC_SPI 52 IRQ_TYPE_LEVEL_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&spi2_clk &spi2_tx &spi2_rx &spi2_cs0>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + spi4: spi@ff1f0000 { + compatible = "rockchip,rk3399-spi", "rockchip,rk3066-spi"; + reg = <0x0 0xff1f0000 0x0 0x1000>; + clocks = <&cru SCLK_SPI4>, <&cru PCLK_SPI4>; + clock-names = "spiclk", "apb_pclk"; + interrupts = <GIC_SPI 67 IRQ_TYPE_LEVEL_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&spi4_clk &spi4_tx &spi4_rx &spi4_cs0>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + spi5: spi@ff200000 { + compatible = "rockchip,rk3399-spi", "rockchip,rk3066-spi"; + reg = <0x0 0xff200000 0x0 0x1000>; + clocks = <&cru SCLK_SPI5>, <&cru PCLK_SPI5>; + clock-names = "spiclk", "apb_pclk"; + interrupts = <GIC_SPI 132 IRQ_TYPE_LEVEL_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&spi5_clk &spi5_tx &spi5_rx &spi5_cs0>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + pmugrf: syscon@ff320000 { + compatible = "rockchip,rk3399-pmugrf", "syscon", "simple-mfd"; + reg = <0x0 0xff320000 0x0 0x1000>; + #address-cells = <1>; + #size-cells = <1>; + + pmu_io_domains: io-domains { + compatible = "rockchip,rk3399-pmu-io-voltage-domain"; + status = "disabled"; + }; + }; + + spi3: spi@ff350000 { + compatible = "rockchip,rk3399-spi", "rockchip,rk3066-spi"; + reg = <0x0 0xff350000 0x0 0x1000>; + clocks = <&pmucru SCLK_SPI3_PMU>, <&pmucru PCLK_SPI3_PMU>; + clock-names = "spiclk", "apb_pclk"; + interrupts = <GIC_SPI 60 IRQ_TYPE_LEVEL_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&spi3_clk &spi3_tx &spi3_rx &spi3_cs0>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + uart4: serial@ff370000 { + compatible = "rockchip,rk3399-uart", "snps,dw-apb-uart"; + reg = <0x0 0xff370000 0x0 0x100>; + clocks = <&pmucru SCLK_UART4_PMU>, <&pmucru PCLK_UART4_PMU>; + clock-names = "baudclk", "apb_pclk"; + interrupts = <GIC_SPI 102 IRQ_TYPE_LEVEL_HIGH>; + reg-shift = <2>; + reg-io-width = <4>; + pinctrl-names = "default"; + pinctrl-0 = <&uart4_xfer>; + status = "disabled"; + }; + + pwm0: pwm@ff420000 { + compatible = "rockchip,rk3399-pwm", "rockchip,rk3288-pwm"; + reg = <0x0 0xff420000 0x0 0x10>; + #pwm-cells = <3>; + pinctrl-names = "default"; + pinctrl-0 = <&pwm0_pin>; + clocks = <&pmucru PCLK_RKPWM_PMU>; + clock-names = "pwm"; + status = "disabled"; + }; + + pwm1: pwm@ff420010 { + compatible = "rockchip,rk3399-pwm", "rockchip,rk3288-pwm"; + reg = <0x0 0xff420010 0x0 0x10>; + #pwm-cells = <3>; + pinctrl-names = "default"; + pinctrl-0 = <&pwm1_pin>; + clocks = <&pmucru PCLK_RKPWM_PMU>; + clock-names = "pwm"; + status = "disabled"; + }; + + pwm2: pwm@ff420020 { + compatible = "rockchip,rk3399-pwm", "rockchip,rk3288-pwm"; + reg = <0x0 0xff420020 0x0 0x10>; + #pwm-cells = <3>; + pinctrl-names = "default"; + pinctrl-0 = <&pwm2_pin>; + clocks = <&pmucru PCLK_RKPWM_PMU>; + clock-names = "pwm"; + status = "disabled"; + }; + + pwm3: pwm@ff420030 { + compatible = "rockchip,rk3399-pwm", "rockchip,rk3288-pwm"; + reg = <0x0 0xff420030 0x0 0x10>; + #pwm-cells = <3>; + pinctrl-names = "default"; + pinctrl-0 = <&pwm3a_pin>; + clocks = <&pmucru PCLK_RKPWM_PMU>; + clock-names = "pwm"; + status = "disabled"; + }; + + pmucru: pmu-clock-controller@ff750000 { + compatible = "rockchip,rk3399-pmucru"; + reg = <0x0 0xff750000 0x0 0x1000>; + #clock-cells = <1>; + #reset-cells = <1>; + assigned-clocks = <&pmucru PLL_PPLL>; + assigned-clock-rates = <676000000>; + }; + + cru: clock-controller@ff760000 { + compatible = "rockchip,rk3399-cru"; + reg = <0x0 0xff760000 0x0 0x1000>; + #clock-cells = <1>; + #reset-cells = <1>; + assigned-clocks = + <&cru PLL_GPLL>, <&cru PLL_CPLL>, + <&cru PLL_NPLL>, + <&cru ACLK_PERIHP>, <&cru HCLK_PERIHP>, + <&cru PCLK_PERIHP>, + <&cru ACLK_PERILP0>, <&cru HCLK_PERILP0>, + <&cru PCLK_PERILP0>, + <&cru HCLK_PERILP1>, <&cru PCLK_PERILP1>; + assigned-clock-rates = + <594000000>, <800000000>, + <1000000000>, + <150000000>, <75000000>, + <37500000>, + <100000000>, <100000000>, + <50000000>, + <100000000>, <50000000>; + }; + + grf: syscon@ff770000 { + compatible = "rockchip,rk3399-grf", "syscon", "simple-mfd"; + reg = <0x0 0xff770000 0x0 0x10000>; + #address-cells = <1>; + #size-cells = <1>; + + io_domains: io-domains { + compatible = "rockchip,rk3399-io-voltage-domain"; + status = "disabled"; + }; + + emmc_phy: phy@f780 { + compatible = "rockchip,rk3399-emmc-phy"; + reg = <0xf780 0x24>; + #phy-cells = <0>; + status = "disabled"; + }; + }; + + watchdog@ff840000 { + compatible = "snps,dw-wdt"; + reg = <0x0 0xff840000 0x0 0x100>; + clocks = <&cru PCLK_WDT>; + interrupts = <GIC_SPI 120 IRQ_TYPE_LEVEL_HIGH>; + }; + + spdif: spdif@ff870000 { + compatible = "rockchip,rk3399-spdif"; + reg = <0x0 0xff870000 0x0 0x1000>; + interrupts = <GIC_SPI 66 IRQ_TYPE_LEVEL_HIGH>; + dmas = <&dmac_bus 7>; + dma-names = "tx"; + clock-names = "mclk", "hclk"; + clocks = <&cru SCLK_SPDIF_8CH>, <&cru HCLK_SPDIF>; + pinctrl-names = "default"; + pinctrl-0 = <&spdif_bus>; + status = "disabled"; + }; + + i2s0: i2s@ff880000 { + compatible = "rockchip,rk3399-i2s", "rockchip,rk3066-i2s"; + reg = <0x0 0xff880000 0x0 0x1000>; + rockchip,grf = <&grf>; + interrupts = <GIC_SPI 39 IRQ_TYPE_LEVEL_HIGH>; + dmas = <&dmac_bus 0>, <&dmac_bus 1>; + dma-names = "tx", "rx"; + clock-names = "i2s_clk", "i2s_hclk"; + clocks = <&cru SCLK_I2S0_8CH>, <&cru HCLK_I2S0_8CH>; + pinctrl-names = "default"; + pinctrl-0 = <&i2s0_8ch_bus>; + status = "disabled"; + }; + + i2s1: i2s@ff890000 { + compatible = "rockchip,rk3399-i2s", "rockchip,rk3066-i2s"; + reg = <0x0 0xff890000 0x0 0x1000>; + interrupts = <GIC_SPI 40 IRQ_TYPE_LEVEL_HIGH>; + dmas = <&dmac_bus 2>, <&dmac_bus 3>; + dma-names = "tx", "rx"; + clock-names = "i2s_clk", "i2s_hclk"; + clocks = <&cru SCLK_I2S1_8CH>, <&cru HCLK_I2S1_8CH>; + pinctrl-names = "default"; + pinctrl-0 = <&i2s1_2ch_bus>; + status = "disabled"; + }; + + i2s2: i2s@ff8a0000 { + compatible = "rockchip,rk3399-i2s", "rockchip,rk3066-i2s"; + reg = <0x0 0xff8a0000 0x0 0x1000>; + interrupts = <GIC_SPI 41 IRQ_TYPE_LEVEL_HIGH>; + dmas = <&dmac_bus 4>, <&dmac_bus 5>; + dma-names = "tx", "rx"; + clock-names = "i2s_clk", "i2s_hclk"; + clocks = <&cru SCLK_I2S2_8CH>, <&cru HCLK_I2S2_8CH>; + status = "disabled"; + }; + + pinctrl: pinctrl { + compatible = "rockchip,rk3399-pinctrl"; + rockchip,grf = <&grf>; + rockchip,pmu = <&pmugrf>; + #address-cells = <2>; + #size-cells = <2>; + ranges; + + gpio0: gpio0@ff720000 { + compatible = "rockchip,gpio-bank"; + reg = <0x0 0xff720000 0x0 0x100>; + clocks = <&pmucru PCLK_GPIO0_PMU>; + interrupts = <GIC_SPI 14 IRQ_TYPE_LEVEL_HIGH>; + + gpio-controller; + #gpio-cells = <0x2>; + + interrupt-controller; + #interrupt-cells = <0x2>; + }; + + gpio1: gpio1@ff730000 { + compatible = "rockchip,gpio-bank"; + reg = <0x0 0xff730000 0x0 0x100>; + clocks = <&pmucru PCLK_GPIO1_PMU>; + interrupts = <GIC_SPI 15 IRQ_TYPE_LEVEL_HIGH>; + + gpio-controller; + #gpio-cells = <0x2>; + + interrupt-controller; + #interrupt-cells = <0x2>; + }; + + gpio2: gpio2@ff780000 { + compatible = "rockchip,gpio-bank"; + reg = <0x0 0xff780000 0x0 0x100>; + clocks = <&cru PCLK_GPIO2>; + interrupts = <GIC_SPI 16 IRQ_TYPE_LEVEL_HIGH>; + + gpio-controller; + #gpio-cells = <0x2>; + + interrupt-controller; + #interrupt-cells = <0x2>; + }; + + gpio3: gpio3@ff788000 { + compatible = "rockchip,gpio-bank"; + reg = <0x0 0xff788000 0x0 0x100>; + clocks = <&cru PCLK_GPIO3>; + interrupts = <GIC_SPI 17 IRQ_TYPE_LEVEL_HIGH>; + + gpio-controller; + #gpio-cells = <0x2>; + + interrupt-controller; + #interrupt-cells = <0x2>; + }; + + gpio4: gpio4@ff790000 { + compatible = "rockchip,gpio-bank"; + reg = <0x0 0xff790000 0x0 0x100>; + clocks = <&cru PCLK_GPIO4>; + interrupts = <GIC_SPI 18 IRQ_TYPE_LEVEL_HIGH>; + + gpio-controller; + #gpio-cells = <0x2>; + + interrupt-controller; + #interrupt-cells = <0x2>; + }; + + pcfg_pull_up: pcfg-pull-up { + bias-pull-up; + }; + + pcfg_pull_down: pcfg-pull-down { + bias-pull-down; + }; + + pcfg_pull_none: pcfg-pull-none { + bias-disable; + }; + + pcfg_pull_none_12ma: pcfg-pull-none-12ma { + bias-disable; + drive-strength = <12>; + }; + + pcfg_pull_up_8ma: pcfg-pull-up-8ma { + bias-pull-up; + drive-strength = <8>; + }; + + pcfg_pull_down_4ma: pcfg-pull-down-4ma { + bias-pull-down; + drive-strength = <4>; + }; + + pcfg_pull_up_2ma: pcfg-pull-up-2ma { + bias-pull-up; + drive-strength = <2>; + }; + + pcfg_pull_down_12ma: pcfg-pull-down-12ma { + bias-pull-down; + drive-strength = <12>; + }; + + pcfg_pull_none_13ma: pcfg-pull-none-13ma { + bias-disable; + drive-strength = <13>; + }; + + i2c0 { + i2c0_xfer: i2c0-xfer { + rockchip,pins = + <1 15 RK_FUNC_2 &pcfg_pull_none>, + <1 16 RK_FUNC_2 &pcfg_pull_none>; + }; + }; + + i2c1 { + i2c1_xfer: i2c1-xfer { + rockchip,pins = + <4 2 RK_FUNC_1 &pcfg_pull_none>, + <4 1 RK_FUNC_1 &pcfg_pull_none>; + }; + }; + + i2c2 { + i2c2_xfer: i2c2-xfer { + rockchip,pins = + <2 1 RK_FUNC_2 &pcfg_pull_none_12ma>, + <2 0 RK_FUNC_2 &pcfg_pull_none_12ma>; + }; + }; + + i2c3 { + i2c3_xfer: i2c3-xfer { + rockchip,pins = + <4 17 RK_FUNC_1 &pcfg_pull_none>, + <4 16 RK_FUNC_1 &pcfg_pull_none>; + }; + }; + + i2c4 { + i2c4_xfer: i2c4-xfer { + rockchip,pins = + <1 12 RK_FUNC_1 &pcfg_pull_none>, + <1 11 RK_FUNC_1 &pcfg_pull_none>; + }; + }; + + i2c5 { + i2c5_xfer: i2c5-xfer { + rockchip,pins = + <3 11 RK_FUNC_2 &pcfg_pull_none>, + <3 10 RK_FUNC_2 &pcfg_pull_none>; + }; + }; + + i2c6 { + i2c6_xfer: i2c6-xfer { + rockchip,pins = + <2 10 RK_FUNC_2 &pcfg_pull_none>, + <2 9 RK_FUNC_2 &pcfg_pull_none>; + }; + }; + + i2c7 { + i2c7_xfer: i2c7-xfer { + rockchip,pins = + <2 8 RK_FUNC_2 &pcfg_pull_none>, + <2 7 RK_FUNC_2 &pcfg_pull_none>; + }; + }; + + i2c8 { + i2c8_xfer: i2c8-xfer { + rockchip,pins = + <1 21 RK_FUNC_1 &pcfg_pull_none>, + <1 20 RK_FUNC_1 &pcfg_pull_none>; + }; + }; + + i2s0 { + i2s0_8ch_bus: i2s0-8ch-bus { + rockchip,pins = + <3 24 RK_FUNC_1 &pcfg_pull_none>, + <3 25 RK_FUNC_1 &pcfg_pull_none>, + <3 26 RK_FUNC_1 &pcfg_pull_none>, + <3 27 RK_FUNC_1 &pcfg_pull_none>, + <3 28 RK_FUNC_1 &pcfg_pull_none>, + <3 29 RK_FUNC_1 &pcfg_pull_none>, + <3 30 RK_FUNC_1 &pcfg_pull_none>, + <3 31 RK_FUNC_1 &pcfg_pull_none>, + <4 0 RK_FUNC_1 &pcfg_pull_none>; + }; + }; + + i2s1 { + i2s1_2ch_bus: i2s1-2ch-bus { + rockchip,pins = + <4 3 RK_FUNC_1 &pcfg_pull_none>, + <4 4 RK_FUNC_1 &pcfg_pull_none>, + <4 5 RK_FUNC_1 &pcfg_pull_none>, + <4 6 RK_FUNC_1 &pcfg_pull_none>, + <4 7 RK_FUNC_1 &pcfg_pull_none>; + }; + }; + + spdif { + spdif_bus: spdif-bus { + rockchip,pins = + <4 21 RK_FUNC_1 &pcfg_pull_none>; + }; + }; + + spi0 { + spi0_clk: spi0-clk { + rockchip,pins = + <3 6 RK_FUNC_2 &pcfg_pull_up>; + }; + spi0_cs0: spi0-cs0 { + rockchip,pins = + <3 7 RK_FUNC_2 &pcfg_pull_up>; + }; + spi0_cs1: spi0-cs1 { + rockchip,pins = + <3 8 RK_FUNC_2 &pcfg_pull_up>; + }; + spi0_tx: spi0-tx { + rockchip,pins = + <3 5 RK_FUNC_2 &pcfg_pull_up>; + }; + spi0_rx: spi0-rx { + rockchip,pins = + <3 4 RK_FUNC_2 &pcfg_pull_up>; + }; + }; + + spi1 { + spi1_clk: spi1-clk { + rockchip,pins = + <1 9 RK_FUNC_2 &pcfg_pull_up>; + }; + spi1_cs0: spi1-cs0 { + rockchip,pins = + <1 10 RK_FUNC_2 &pcfg_pull_up>; + }; + spi1_rx: spi1-rx { + rockchip,pins = + <1 7 RK_FUNC_2 &pcfg_pull_up>; + }; + spi1_tx: spi1-tx { + rockchip,pins = + <1 8 RK_FUNC_2 &pcfg_pull_up>; + }; + }; + + spi2 { + spi2_clk: spi2-clk { + rockchip,pins = + <2 11 RK_FUNC_1 &pcfg_pull_up>; + }; + spi2_cs0: spi2-cs0 { + rockchip,pins = + <2 12 RK_FUNC_1 &pcfg_pull_up>; + }; + spi2_rx: spi2-rx { + rockchip,pins = + <2 9 RK_FUNC_1 &pcfg_pull_up>; + }; + spi2_tx: spi2-tx { + rockchip,pins = + <2 10 RK_FUNC_1 &pcfg_pull_up>; + }; + }; + + spi3 { + spi3_clk: spi3-clk { + rockchip,pins = + <1 17 RK_FUNC_1 &pcfg_pull_up>; + }; + spi3_cs0: spi3-cs0 { + rockchip,pins = + <1 18 RK_FUNC_1 &pcfg_pull_up>; + }; + spi3_rx: spi3-rx { + rockchip,pins = + <1 15 RK_FUNC_1 &pcfg_pull_up>; + }; + spi3_tx: spi3-tx { + rockchip,pins = + <1 16 RK_FUNC_1 &pcfg_pull_up>; + }; + }; + + spi4 { + spi4_clk: spi4-clk { + rockchip,pins = + <3 2 RK_FUNC_2 &pcfg_pull_up>; + }; + spi4_cs0: spi4-cs0 { + rockchip,pins = + <3 3 RK_FUNC_2 &pcfg_pull_up>; + }; + spi4_rx: spi4-rx { + rockchip,pins = + <3 0 RK_FUNC_2 &pcfg_pull_up>; + }; + spi4_tx: spi4-tx { + rockchip,pins = + <3 1 RK_FUNC_2 &pcfg_pull_up>; + }; + }; + + spi5 { + spi5_clk: spi5-clk { + rockchip,pins = + <2 22 RK_FUNC_2 &pcfg_pull_up>; + }; + spi5_cs0: spi5-cs0 { + rockchip,pins = + <2 23 RK_FUNC_2 &pcfg_pull_up>; + }; + spi5_rx: spi5-rx { + rockchip,pins = + <2 20 RK_FUNC_2 &pcfg_pull_up>; + }; + spi5_tx: spi5-tx { + rockchip,pins = + <2 21 RK_FUNC_2 &pcfg_pull_up>; + }; + }; + + uart0 { + uart0_xfer: uart0-xfer { + rockchip,pins = + <2 16 RK_FUNC_1 &pcfg_pull_up>, + <2 17 RK_FUNC_1 &pcfg_pull_none>; + }; + + uart0_cts: uart0-cts { + rockchip,pins = + <2 18 RK_FUNC_1 &pcfg_pull_none>; + }; + + uart0_rts: uart0-rts { + rockchip,pins = + <2 19 RK_FUNC_1 &pcfg_pull_none>; + }; + }; + + uart1 { + uart1_xfer: uart1-xfer { + rockchip,pins = + <3 12 RK_FUNC_2 &pcfg_pull_up>, + <3 13 RK_FUNC_2 &pcfg_pull_none>; + }; + }; + + uart2a { + uart2a_xfer: uart2a-xfer { + rockchip,pins = + <4 8 RK_FUNC_2 &pcfg_pull_up>, + <4 9 RK_FUNC_2 &pcfg_pull_none>; + }; + }; + + uart2b { + uart2b_xfer: uart2b-xfer { + rockchip,pins = + <4 16 RK_FUNC_2 &pcfg_pull_up>, + <4 17 RK_FUNC_2 &pcfg_pull_none>; + }; + }; + + uart2c { + uart2c_xfer: uart2c-xfer { + rockchip,pins = + <4 19 RK_FUNC_1 &pcfg_pull_up>, + <4 20 RK_FUNC_1 &pcfg_pull_none>; + }; + }; + + uart3 { + uart3_xfer: uart3-xfer { + rockchip,pins = + <3 14 RK_FUNC_2 &pcfg_pull_up>, + <3 15 RK_FUNC_2 &pcfg_pull_none>; + }; + + uart3_cts: uart3-cts { + rockchip,pins = + <3 18 RK_FUNC_2 &pcfg_pull_none>; + }; + + uart3_rts: uart3-rts { + rockchip,pins = + <3 19 RK_FUNC_2 &pcfg_pull_none>; + }; + }; + + uart4 { + uart4_xfer: uart4-xfer { + rockchip,pins = + <1 7 RK_FUNC_1 &pcfg_pull_up>, + <1 8 RK_FUNC_1 &pcfg_pull_none>; + }; + }; + + uarthdcp { + uarthdcp_xfer: uarthdcp-xfer { + rockchip,pins = + <4 21 RK_FUNC_2 &pcfg_pull_up>, + <4 22 RK_FUNC_2 &pcfg_pull_none>; + }; + }; + + pwm0 { + pwm0_pin: pwm0-pin { + rockchip,pins = + <4 18 RK_FUNC_1 &pcfg_pull_none>; + }; + + vop0_pwm_pin: vop0-pwm-pin { + rockchip,pins = + <4 18 RK_FUNC_2 &pcfg_pull_none>; + }; + }; + + pwm1 { + pwm1_pin: pwm1-pin { + rockchip,pins = + <4 22 RK_FUNC_1 &pcfg_pull_none>; + }; + + vop1_pwm_pin: vop1-pwm-pin { + rockchip,pins = + <4 18 RK_FUNC_3 &pcfg_pull_none>; + }; + }; + + pwm2 { + pwm2_pin: pwm2-pin { + rockchip,pins = + <1 19 RK_FUNC_1 &pcfg_pull_none>; + }; + }; + + pwm3a { + pwm3a_pin: pwm3a-pin { + rockchip,pins = + <0 6 RK_FUNC_1 &pcfg_pull_none>; + }; + }; + + pwm3b { + pwm3b_pin: pwm3b-pin { + rockchip,pins = + <1 14 RK_FUNC_1 &pcfg_pull_none>; + }; + }; + }; +}; diff --git a/include/dt-bindings/clock/rk3399-cru.h b/include/dt-bindings/clock/rk3399-cru.h new file mode 100644 index 0000000..0a86aec --- /dev/null +++ b/include/dt-bindings/clock/rk3399-cru.h @@ -0,0 +1,746 @@ +/* + * Copyright (c) 2016 Rockchip Electronics Co. Ltd. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef _DT_BINDINGS_CLK_ROCKCHIP_RK3399_H +#define _DT_BINDINGS_CLK_ROCKCHIP_RK3399_H + +/* core clocks */ +#define PLL_APLLL 1 +#define PLL_APLLB 2 +#define PLL_DPLL 3 +#define PLL_CPLL 4 +#define PLL_GPLL 5 +#define PLL_NPLL 6 +#define PLL_VPLL 7 +#define ARMCLKL 8 +#define ARMCLKB 9 + +/* sclk gates (special clocks) */ +#define SCLK_I2C1 65 +#define SCLK_I2C2 66 +#define SCLK_I2C3 67 +#define SCLK_I2C5 68 +#define SCLK_I2C6 69 +#define SCLK_I2C7 70 +#define SCLK_SPI0 71 +#define SCLK_SPI1 72 +#define SCLK_SPI2 73 +#define SCLK_SPI4 74 +#define SCLK_SPI5 75 +#define SCLK_SDMMC 76 +#define SCLK_SDIO 77 +#define SCLK_EMMC 78 +#define SCLK_TSADC 79 +#define SCLK_SARADC 80 +#define SCLK_UART0 81 +#define SCLK_UART1 82 +#define SCLK_UART2 83 +#define SCLK_UART3 84 +#define SCLK_SPDIF_8CH 85 +#define SCLK_I2S0_8CH 86 +#define SCLK_I2S1_8CH 87 +#define SCLK_I2S2_8CH 88 +#define SCLK_I2S_8CH_OUT 89 +#define SCLK_TIMER00 90 +#define SCLK_TIMER01 91 +#define SCLK_TIMER02 92 +#define SCLK_TIMER03 93 +#define SCLK_TIMER04 94 +#define SCLK_TIMER05 95 +#define SCLK_TIMER06 96 +#define SCLK_TIMER07 97 +#define SCLK_TIMER08 98 +#define SCLK_TIMER09 99 +#define SCLK_TIMER10 100 +#define SCLK_TIMER11 101 +#define SCLK_MACREF 102 +#define SCLK_MAC_RX 103 +#define SCLK_MAC_TX 104 +#define SCLK_MAC 105 +#define SCLK_MACREF_OUT 106 +#define SCLK_VOP0_PWM 107 +#define SCLK_VOP1_PWM 108 +#define SCLK_RGA_CORE 109 +#define SCLK_ISP0 110 +#define SCLK_ISP1 111 +#define SCLK_HDMI_CEC 112 +#define SCLK_HDMI_SFR 113 +#define SCLK_DP_CORE 114 +#define SCLK_PVTM_CORE_L 115 +#define SCLK_PVTM_CORE_B 116 +#define SCLK_PVTM_GPU 117 +#define SCLK_PVTM_DDR 118 +#define SCLK_MIPIDPHY_REF 119 +#define SCLK_MIPIDPHY_CFG 120 +#define SCLK_HSICPHY 121 +#define SCLK_USBPHY480M 122 +#define SCLK_USB2PHY0_REF 123 +#define SCLK_USB2PHY1_REF 124 +#define SCLK_UPHY0_TCPDPHY_REF 125 +#define SCLK_UPHY0_TCPDCORE 126 +#define SCLK_UPHY1_TCPDPHY_REF 127 +#define SCLK_UPHY1_TCPDCORE 128 +#define SCLK_USB3OTG0_REF 129 +#define SCLK_USB3OTG1_REF 130 +#define SCLK_USB3OTG0_SUSPEND 131 +#define SCLK_USB3OTG1_SUSPEND 132 +#define SCLK_CRYPTO0 133 +#define SCLK_CRYPTO1 134 +#define SCLK_CCI_TRACE 135 +#define SCLK_CS 136 +#define SCLK_CIF_OUT 137 +#define SCLK_PCIEPHY_REF 138 +#define SCLK_PCIE_CORE 139 +#define SCLK_M0_PERILP 140 +#define SCLK_M0_PERILP_DEC 141 +#define SCLK_CM0S 142 +#define SCLK_DBG_NOC 143 +#define SCLK_DBG_PD_CORE_B 144 +#define SCLK_DBG_PD_CORE_L 145 +#define SCLK_DFIMON0_TIMER 146 +#define SCLK_DFIMON1_TIMER 147 +#define SCLK_INTMEM0 148 +#define SCLK_INTMEM1 149 +#define SCLK_INTMEM2 150 +#define SCLK_INTMEM3 151 +#define SCLK_INTMEM4 152 +#define SCLK_INTMEM5 153 +#define SCLK_SDMMC_DRV 154 +#define SCLK_SDMMC_SAMPLE 155 +#define SCLK_SDIO_DRV 156 +#define SCLK_SDIO_SAMPLE 157 +#define SCLK_VDU_CORE 158 +#define SCLK_VDU_CA 159 +#define SCLK_PCIE_PM 160 +#define SCLK_SPDIF_REC_DPTX 161 +#define SCLK_DPHY_PLL 162 +#define SCLK_DPHY_TX0_CFG 163 +#define SCLK_DPHY_TX1RX1_CFG 164 +#define SCLK_DPHY_RX0_CFG 165 +#define SCLK_RMII_SRC 166 +#define SCLK_PCIEPHY_REF100M 167 + +#define DCLK_VOP0 180 +#define DCLK_VOP1 181 +#define DCLK_VOP0_DIV 182 +#define DCLK_VOP1_DIV 183 +#define DCLK_M0_PERILP 184 + +#define FCLK_CM0S 190 + +/* aclk gates */ +#define ACLK_PERIHP 192 +#define ACLK_PERIHP_NOC 193 +#define ACLK_PERILP0 194 +#define ACLK_PERILP0_NOC 195 +#define ACLK_PERF_PCIE 196 +#define ACLK_PCIE 197 +#define ACLK_INTMEM 198 +#define ACLK_TZMA 199 +#define ACLK_DCF 200 +#define ACLK_CCI 201 +#define ACLK_CCI_NOC0 202 +#define ACLK_CCI_NOC1 203 +#define ACLK_CCI_GRF 204 +#define ACLK_CENTER 205 +#define ACLK_CENTER_MAIN_NOC 206 +#define ACLK_CENTER_PERI_NOC 207 +#define ACLK_GPU 208 +#define ACLK_PERF_GPU 209 +#define ACLK_GPU_GRF 210 +#define ACLK_DMAC0_PERILP 211 +#define ACLK_DMAC1_PERILP 212 +#define ACLK_GMAC 213 +#define ACLK_GMAC_NOC 214 +#define ACLK_PERF_GMAC 215 +#define ACLK_VOP0_NOC 216 +#define ACLK_VOP0 217 +#define ACLK_VOP1_NOC 218 +#define ACLK_VOP1 219 +#define ACLK_RGA 220 +#define ACLK_RGA_NOC 221 +#define ACLK_HDCP 222 +#define ACLK_HDCP_NOC 223 +#define ACLK_HDCP22 224 +#define ACLK_IEP 225 +#define ACLK_IEP_NOC 226 +#define ACLK_VIO 227 +#define ACLK_VIO_NOC 228 +#define ACLK_ISP0 229 +#define ACLK_ISP1 230 +#define ACLK_ISP0_NOC 231 +#define ACLK_ISP1_NOC 232 +#define ACLK_ISP0_WRAPPER 233 +#define ACLK_ISP1_WRAPPER 234 +#define ACLK_VCODEC 235 +#define ACLK_VCODEC_NOC 236 +#define ACLK_VDU 237 +#define ACLK_VDU_NOC 238 +#define ACLK_PERI 239 +#define ACLK_EMMC 240 +#define ACLK_EMMC_CORE 241 +#define ACLK_EMMC_NOC 242 +#define ACLK_EMMC_GRF 243 +#define ACLK_USB3 244 +#define ACLK_USB3_NOC 245 +#define ACLK_USB3OTG0 246 +#define ACLK_USB3OTG1 247 +#define ACLK_USB3_RKSOC_AXI_PERF 248 +#define ACLK_USB3_GRF 249 +#define ACLK_GIC 250 +#define ACLK_GIC_NOC 251 +#define ACLK_GIC_ADB400_CORE_L_2_GIC 252 +#define ACLK_GIC_ADB400_CORE_B_2_GIC 253 +#define ACLK_GIC_ADB400_GIC_2_CORE_L 254 +#define ACLK_GIC_ADB400_GIC_2_CORE_B 255 +#define ACLK_CORE_ADB400_CORE_L_2_CCI500 256 +#define ACLK_CORE_ADB400_CORE_B_2_CCI500 257 +#define ACLK_ADB400M_PD_CORE_L 258 +#define ACLK_ADB400M_PD_CORE_B 259 +#define ACLK_PERF_CORE_L 260 +#define ACLK_PERF_CORE_B 261 +#define ACLK_GIC_PRE 262 +#define ACLK_VOP0_PRE 263 +#define ACLK_VOP1_PRE 264 + +/* pclk gates */ +#define PCLK_PERIHP 320 +#define PCLK_PERIHP_NOC 321 +#define PCLK_PERILP0 322 +#define PCLK_PERILP1 323 +#define PCLK_PERILP1_NOC 324 +#define PCLK_PERILP_SGRF 325 +#define PCLK_PERIHP_GRF 326 +#define PCLK_PCIE 327 +#define PCLK_SGRF 328 +#define PCLK_INTR_ARB 329 +#define PCLK_CENTER_MAIN_NOC 330 +#define PCLK_CIC 331 +#define PCLK_COREDBG_B 332 +#define PCLK_COREDBG_L 333 +#define PCLK_DBG_CXCS_PD_CORE_B 334 +#define PCLK_DCF 335 +#define PCLK_GPIO2 336 +#define PCLK_GPIO3 337 +#define PCLK_GPIO4 338 +#define PCLK_GRF 339 +#define PCLK_HSICPHY 340 +#define PCLK_I2C1 341 +#define PCLK_I2C2 342 +#define PCLK_I2C3 343 +#define PCLK_I2C5 344 +#define PCLK_I2C6 345 +#define PCLK_I2C7 346 +#define PCLK_SPI0 347 +#define PCLK_SPI1 348 +#define PCLK_SPI2 349 +#define PCLK_SPI4 350 +#define PCLK_SPI5 351 +#define PCLK_UART0 352 +#define PCLK_UART1 353 +#define PCLK_UART2 354 +#define PCLK_UART3 355 +#define PCLK_TSADC 356 +#define PCLK_SARADC 357 +#define PCLK_GMAC 358 +#define PCLK_GMAC_NOC 359 +#define PCLK_TIMER0 360 +#define PCLK_TIMER1 361 +#define PCLK_EDP 362 +#define PCLK_EDP_NOC 363 +#define PCLK_EDP_CTRL 364 +#define PCLK_VIO 365 +#define PCLK_VIO_NOC 366 +#define PCLK_VIO_GRF 367 +#define PCLK_MIPI_DSI0 368 +#define PCLK_MIPI_DSI1 369 +#define PCLK_HDCP 370 +#define PCLK_HDCP_NOC 371 +#define PCLK_HDMI_CTRL 372 +#define PCLK_DP_CTRL 373 +#define PCLK_HDCP22 374 +#define PCLK_GASKET 375 +#define PCLK_DDR 376 +#define PCLK_DDR_MON 377 +#define PCLK_DDR_SGRF 378 +#define PCLK_ISP1_WRAPPER 379 +#define PCLK_WDT 380 +#define PCLK_EFUSE1024NS 381 +#define PCLK_EFUSE1024S 382 +#define PCLK_PMU_INTR_ARB 383 +#define PCLK_MAILBOX0 384 +#define PCLK_USBPHY_MUX_G 385 +#define PCLK_UPHY0_TCPHY_G 386 +#define PCLK_UPHY0_TCPD_G 387 +#define PCLK_UPHY1_TCPHY_G 388 +#define PCLK_UPHY1_TCPD_G 389 +#define PCLK_ALIVE 390 + +/* hclk gates */ +#define HCLK_PERIHP 448 +#define HCLK_PERILP0 449 +#define HCLK_PERILP1 450 +#define HCLK_PERILP0_NOC 451 +#define HCLK_PERILP1_NOC 452 +#define HCLK_M0_PERILP 453 +#define HCLK_M0_PERILP_NOC 454 +#define HCLK_AHB1TOM 455 +#define HCLK_HOST0 456 +#define HCLK_HOST0_ARB 457 +#define HCLK_HOST1 458 +#define HCLK_HOST1_ARB 459 +#define HCLK_HSIC 460 +#define HCLK_SD 461 +#define HCLK_SDMMC 462 +#define HCLK_SDMMC_NOC 463 +#define HCLK_M_CRYPTO0 464 +#define HCLK_M_CRYPTO1 465 +#define HCLK_S_CRYPTO0 466 +#define HCLK_S_CRYPTO1 467 +#define HCLK_I2S0_8CH 468 +#define HCLK_I2S1_8CH 469 +#define HCLK_I2S2_8CH 470 +#define HCLK_SPDIF 471 +#define HCLK_VOP0_NOC 472 +#define HCLK_VOP0 473 +#define HCLK_VOP1_NOC 474 +#define HCLK_VOP1 475 +#define HCLK_ROM 476 +#define HCLK_IEP 477 +#define HCLK_IEP_NOC 478 +#define HCLK_ISP0 479 +#define HCLK_ISP1 480 +#define HCLK_ISP0_NOC 481 +#define HCLK_ISP1_NOC 482 +#define HCLK_ISP0_WRAPPER 483 +#define HCLK_ISP1_WRAPPER 484 +#define HCLK_RGA 485 +#define HCLK_RGA_NOC 486 +#define HCLK_HDCP 487 +#define HCLK_HDCP_NOC 488 +#define HCLK_HDCP22 489 +#define HCLK_VCODEC 490 +#define HCLK_VCODEC_NOC 491 +#define HCLK_VDU 492 +#define HCLK_VDU_NOC 493 +#define HCLK_SDIO 494 +#define HCLK_SDIO_NOC 495 +#define HCLK_SDIOAUDIO_NOC 496 + +#define CLK_NR_CLKS (HCLK_SDIOAUDIO_NOC + 1) + +/* pmu-clocks indices */ + +#define PLL_PPLL 1 + +#define SCLK_32K_SUSPEND_PMU 2 +#define SCLK_SPI3_PMU 3 +#define SCLK_TIMER12_PMU 4 +#define SCLK_TIMER13_PMU 5 +#define SCLK_UART4_PMU 6 +#define SCLK_PVTM_PMU 7 +#define SCLK_WIFI_PMU 8 +#define SCLK_I2C0_PMU 9 +#define SCLK_I2C4_PMU 10 +#define SCLK_I2C8_PMU 11 + +#define PCLK_SRC_PMU 19 +#define PCLK_PMU 20 +#define PCLK_PMUGRF_PMU 21 +#define PCLK_INTMEM1_PMU 22 +#define PCLK_GPIO0_PMU 23 +#define PCLK_GPIO1_PMU 24 +#define PCLK_SGRF_PMU 25 +#define PCLK_NOC_PMU 26 +#define PCLK_I2C0_PMU 27 +#define PCLK_I2C4_PMU 28 +#define PCLK_I2C8_PMU 29 +#define PCLK_RKPWM_PMU 30 +#define PCLK_SPI3_PMU 31 +#define PCLK_TIMER_PMU 32 +#define PCLK_MAILBOX_PMU 33 +#define PCLK_UART4_PMU 34 +#define PCLK_WDT_M0_PMU 35 + +#define FCLK_CM0S_SRC_PMU 44 +#define FCLK_CM0S_PMU 45 +#define SCLK_CM0S_PMU 46 +#define HCLK_CM0S_PMU 47 +#define DCLK_CM0S_PMU 48 +#define PCLK_INTR_ARB_PMU 49 +#define HCLK_NOC_PMU 50 + +#define CLKPMU_NR_CLKS (HCLK_NOC_PMU + 1) + +/* soft-reset indices */ + +/* cru_softrst_con0 */ +#define SRST_CORE_L0 0 +#define SRST_CORE_B0 1 +#define SRST_CORE_PO_L0 2 +#define SRST_CORE_PO_B0 3 +#define SRST_L2_L 4 +#define SRST_L2_B 5 +#define SRST_ADB_L 6 +#define SRST_ADB_B 7 +#define SRST_A_CCI 8 +#define SRST_A_CCIM0_NOC 9 +#define SRST_A_CCIM1_NOC 10 +#define SRST_DBG_NOC 11 + +/* cru_softrst_con1 */ +#define SRST_CORE_L0_T 16 +#define SRST_CORE_L1 17 +#define SRST_CORE_L2 18 +#define SRST_CORE_L3 19 +#define SRST_CORE_PO_L0_T 20 +#define SRST_CORE_PO_L1 21 +#define SRST_CORE_PO_L2 22 +#define SRST_CORE_PO_L3 23 +#define SRST_A_ADB400_GIC2COREL 24 +#define SRST_A_ADB400_COREL2GIC 25 +#define SRST_P_DBG_L 26 +#define SRST_L2_L_T 28 +#define SRST_ADB_L_T 29 +#define SRST_A_RKPERF_L 30 +#define SRST_PVTM_CORE_L 31 + +/* cru_softrst_con2 */ +#define SRST_CORE_B0_T 32 +#define SRST_CORE_B1 33 +#define SRST_CORE_PO_B0_T 36 +#define SRST_CORE_PO_B1 37 +#define SRST_A_ADB400_GIC2COREB 40 +#define SRST_A_ADB400_COREB2GIC 41 +#define SRST_P_DBG_B 42 +#define SRST_L2_B_T 43 +#define SRST_ADB_B_T 45 +#define SRST_A_RKPERF_B 46 +#define SRST_PVTM_CORE_B 47 + +/* cru_softrst_con3 */ +#define SRST_A_CCI_T 50 +#define SRST_A_CCIM0_NOC_T 51 +#define SRST_A_CCIM1_NOC_T 52 +#define SRST_A_ADB400M_PD_CORE_B_T 53 +#define SRST_A_ADB400M_PD_CORE_L_T 54 +#define SRST_DBG_NOC_T 55 +#define SRST_DBG_CXCS 56 +#define SRST_CCI_TRACE 57 +#define SRST_P_CCI_GRF 58 + +/* cru_softrst_con4 */ +#define SRST_A_CENTER_MAIN_NOC 64 +#define SRST_A_CENTER_PERI_NOC 65 +#define SRST_P_CENTER_MAIN 66 +#define SRST_P_DDRMON 67 +#define SRST_P_CIC 68 +#define SRST_P_CENTER_SGRF 69 +#define SRST_DDR0_MSCH 70 +#define SRST_DDRCFG0_MSCH 71 +#define SRST_DDR0 72 +#define SRST_DDRPHY0 73 +#define SRST_DDR1_MSCH 74 +#define SRST_DDRCFG1_MSCH 75 +#define SRST_DDR1 76 +#define SRST_DDRPHY1 77 +#define SRST_DDR_CIC 78 +#define SRST_PVTM_DDR 79 + +/* cru_softrst_con5 */ +#define SRST_A_VCODEC_NOC 80 +#define SRST_A_VCODEC 81 +#define SRST_H_VCODEC_NOC 82 +#define SRST_H_VCODEC 83 +#define SRST_A_VDU_NOC 88 +#define SRST_A_VDU 89 +#define SRST_H_VDU_NOC 90 +#define SRST_H_VDU 91 +#define SRST_VDU_CORE 92 +#define SRST_VDU_CA 93 + +/* cru_softrst_con6 */ +#define SRST_A_IEP_NOC 96 +#define SRST_A_VOP_IEP 97 +#define SRST_A_IEP 98 +#define SRST_H_IEP_NOC 99 +#define SRST_H_IEP 100 +#define SRST_A_RGA_NOC 102 +#define SRST_A_RGA 103 +#define SRST_H_RGA_NOC 104 +#define SRST_H_RGA 105 +#define SRST_RGA_CORE 106 +#define SRST_EMMC_NOC 108 +#define SRST_EMMC 109 +#define SRST_EMMC_GRF 110 + +/* cru_softrst_con7 */ +#define SRST_A_PERIHP_NOC 112 +#define SRST_P_PERIHP_GRF 113 +#define SRST_H_PERIHP_NOC 114 +#define SRST_USBHOST0 115 +#define SRST_HOSTC0_AUX 116 +#define SRST_HOST0_ARB 117 +#define SRST_USBHOST1 118 +#define SRST_HOSTC1_AUX 119 +#define SRST_HOST1_ARB 120 +#define SRST_SDIO0 121 +#define SRST_SDMMC 122 +#define SRST_HSIC 123 +#define SRST_HSIC_AUX 124 +#define SRST_AHB1TOM 125 +#define SRST_P_PERIHP_NOC 126 +#define SRST_HSICPHY 127 + +/* cru_softrst_con8 */ +#define SRST_A_PCIE 128 +#define SRST_P_PCIE 129 +#define SRST_PCIE_CORE 130 +#define SRST_PCIE_MGMT 131 +#define SRST_PCIE_MGMT_STICKY 132 +#define SRST_PCIE_PIPE 133 +#define SRST_PCIE_PM 134 +#define SRST_PCIEPHY 135 +#define SRST_A_GMAC_NOC 136 +#define SRST_A_GMAC 137 +#define SRST_P_GMAC_NOC 138 +#define SRST_P_GMAC_GRF 140 +#define SRST_HSICPHY_POR 142 +#define SRST_HSICPHY_UTMI 143 + +/* cru_softrst_con9 */ +#define SRST_USB2PHY0_POR 144 +#define SRST_USB2PHY0_UTMI_PORT0 145 +#define SRST_USB2PHY0_UTMI_PORT1 146 +#define SRST_USB2PHY0_EHCIPHY 147 +#define SRST_UPHY0_PIPE_L00 148 +#define SRST_UPHY0 149 +#define SRST_UPHY0_TCPDPWRUP 150 +#define SRST_USB2PHY1_POR 152 +#define SRST_USB2PHY1_UTMI_PORT0 153 +#define SRST_USB2PHY1_UTMI_PORT1 154 +#define SRST_USB2PHY1_EHCIPHY 155 +#define SRST_UPHY1_PIPE_L00 156 +#define SRST_UPHY1 157 +#define SRST_UPHY1_TCPDPWRUP 158 + +/* cru_softrst_con10 */ +#define SRST_A_PERILP0_NOC 160 +#define SRST_A_DCF 161 +#define SRST_GIC500 162 +#define SRST_DMAC0_PERILP0 163 +#define SRST_DMAC1_PERILP0 164 +#define SRST_TZMA 165 +#define SRST_INTMEM 166 +#define SRST_ADB400_MST0 167 +#define SRST_ADB400_MST1 168 +#define SRST_ADB400_SLV0 169 +#define SRST_ADB400_SLV1 170 +#define SRST_H_PERILP0 171 +#define SRST_H_PERILP0_NOC 172 +#define SRST_ROM 173 +#define SRST_CRYPTO_S 174 +#define SRST_CRYPTO_M 175 + +/* cru_softrst_con11 */ +#define SRST_P_DCF 176 +#define SRST_CM0S_NOC 177 +#define SRST_CM0S 178 +#define SRST_CM0S_DBG 179 +#define SRST_CM0S_PO 180 +#define SRST_CRYPTO 181 +#define SRST_P_PERILP1_SGRF 182 +#define SRST_P_PERILP1_GRF 183 +#define SRST_CRYPTO1_S 184 +#define SRST_CRYPTO1_M 185 +#define SRST_CRYPTO1 186 +#define SRST_GIC_NOC 188 +#define SRST_SD_NOC 189 +#define SRST_SDIOAUDIO_BRG 190 + +/* cru_softrst_con12 */ +#define SRST_H_PERILP1 192 +#define SRST_H_PERILP1_NOC 193 +#define SRST_H_I2S0_8CH 194 +#define SRST_H_I2S1_8CH 195 +#define SRST_H_I2S2_8CH 196 +#define SRST_H_SPDIF_8CH 197 +#define SRST_P_PERILP1_NOC 198 +#define SRST_P_EFUSE_1024 199 +#define SRST_P_EFUSE_1024S 200 +#define SRST_P_I2C0 201 +#define SRST_P_I2C1 202 +#define SRST_P_I2C2 203 +#define SRST_P_I2C3 204 +#define SRST_P_I2C4 205 +#define SRST_P_I2C5 206 +#define SRST_P_MAILBOX0 207 + +/* cru_softrst_con13 */ +#define SRST_P_UART0 208 +#define SRST_P_UART1 209 +#define SRST_P_UART2 210 +#define SRST_P_UART3 211 +#define SRST_P_SARADC 212 +#define SRST_P_TSADC 213 +#define SRST_P_SPI0 214 +#define SRST_P_SPI1 215 +#define SRST_P_SPI2 216 +#define SRST_P_SPI3 217 +#define SRST_P_SPI4 218 +#define SRST_SPI0 219 +#define SRST_SPI1 220 +#define SRST_SPI2 221 +#define SRST_SPI3 222 +#define SRST_SPI4 223 + +/* cru_softrst_con14 */ +#define SRST_I2S0_8CH 224 +#define SRST_I2S1_8CH 225 +#define SRST_I2S2_8CH 226 +#define SRST_SPDIF_8CH 227 +#define SRST_UART0 228 +#define SRST_UART1 229 +#define SRST_UART2 230 +#define SRST_UART3 231 +#define SRST_TSADC 232 +#define SRST_I2C0 233 +#define SRST_I2C1 234 +#define SRST_I2C2 235 +#define SRST_I2C3 236 +#define SRST_I2C4 237 +#define SRST_I2C5 238 +#define SRST_SDIOAUDIO_NOC 239 + +/* cru_softrst_con15 */ +#define SRST_A_VIO_NOC 240 +#define SRST_A_HDCP_NOC 241 +#define SRST_A_HDCP 242 +#define SRST_H_HDCP_NOC 243 +#define SRST_H_HDCP 244 +#define SRST_P_HDCP_NOC 245 +#define SRST_P_HDCP 246 +#define SRST_P_HDMI_CTRL 247 +#define SRST_P_DP_CTRL 248 +#define SRST_S_DP_CTRL 249 +#define SRST_C_DP_CTRL 250 +#define SRST_P_MIPI_DSI0 251 +#define SRST_P_MIPI_DSI1 252 +#define SRST_DP_CORE 253 +#define SRST_DP_I2S 254 + +/* cru_softrst_con16 */ +#define SRST_GASKET 256 +#define SRST_VIO_GRF 258 +#define SRST_DPTX_SPDIF_REC 259 +#define SRST_HDMI_CTRL 260 +#define SRST_HDCP_CTRL 261 +#define SRST_A_ISP0_NOC 262 +#define SRST_A_ISP1_NOC 263 +#define SRST_H_ISP0_NOC 266 +#define SRST_H_ISP1_NOC 267 +#define SRST_H_ISP0 268 +#define SRST_H_ISP1 269 +#define SRST_ISP0 270 +#define SRST_ISP1 271 + +/* cru_softrst_con17 */ +#define SRST_A_VOP0_NOC 272 +#define SRST_A_VOP1_NOC 273 +#define SRST_A_VOP0 274 +#define SRST_A_VOP1 275 +#define SRST_H_VOP0_NOC 276 +#define SRST_H_VOP1_NOC 277 +#define SRST_H_VOP0 278 +#define SRST_H_VOP1 279 +#define SRST_D_VOP0 280 +#define SRST_D_VOP1 281 +#define SRST_VOP0_PWM 282 +#define SRST_VOP1_PWM 283 +#define SRST_P_EDP_NOC 284 +#define SRST_P_EDP_CTRL 285 + +/* cru_softrst_con18 */ +#define SRST_A_GPU 288 +#define SRST_A_GPU_NOC 289 +#define SRST_A_GPU_GRF 290 +#define SRST_PVTM_GPU 291 +#define SRST_A_USB3_NOC 292 +#define SRST_A_USB3_OTG0 293 +#define SRST_A_USB3_OTG1 294 +#define SRST_A_USB3_GRF 295 +#define SRST_PMU 296 + +/* cru_softrst_con19 */ +#define SRST_P_TIMER0_5 304 +#define SRST_TIMER0 305 +#define SRST_TIMER1 306 +#define SRST_TIMER2 307 +#define SRST_TIMER3 308 +#define SRST_TIMER4 309 +#define SRST_TIMER5 310 +#define SRST_P_TIMER6_11 311 +#define SRST_TIMER6 312 +#define SRST_TIMER7 313 +#define SRST_TIMER8 314 +#define SRST_TIMER9 315 +#define SRST_TIMER10 316 +#define SRST_TIMER11 317 +#define SRST_P_INTR_ARB_PMU 318 +#define SRST_P_ALIVE_SGRF 319 + +/* cru_softrst_con20 */ +#define SRST_P_GPIO2 320 +#define SRST_P_GPIO3 321 +#define SRST_P_GPIO4 322 +#define SRST_P_GRF 323 +#define SRST_P_ALIVE_NOC 324 +#define SRST_P_WDT0 325 +#define SRST_P_WDT1 326 +#define SRST_P_INTR_ARB 327 +#define SRST_P_UPHY0_DPTX 328 +#define SRST_P_UPHY0_APB 330 +#define SRST_P_UPHY0_TCPHY 332 +#define SRST_P_UPHY1_TCPHY 333 +#define SRST_P_UPHY0_TCPDCTRL 334 +#define SRST_P_UPHY1_TCPDCTRL 335 + +/* pmu soft-reset indices */ + +/* pmu_cru_softrst_con0 */ +#define SRST_P_NOC 0 +#define SRST_P_INTMEM 1 +#define SRST_H_CM0S 2 +#define SRST_H_CM0S_NOC 3 +#define SRST_DBG_CM0S 4 +#define SRST_PO_CM0S 5 +#define SRST_P_SPI6 6 +#define SRST_SPI6 7 +#define SRST_P_TIMER_0_1 8 +#define SRST_P_TIMER_0 9 +#define SRST_P_TIMER_1 10 +#define SRST_P_UART4 11 +#define SRST_UART4 12 +#define SRST_P_WDT 13 + +/* pmu_cru_softrst_con1 */ +#define SRST_P_I2C6 16 +#define SRST_P_I2C7 17 +#define SRST_P_I2C8 18 +#define SRST_P_MAILBOX 19 +#define SRST_P_RKPWM 20 +#define SRST_P_PMUGRF 21 +#define SRST_P_SGRF 22 +#define SRST_P_GPIO0 23 +#define SRST_P_GPIO1 24 +#define SRST_P_CRU 25 +#define SRST_P_INTR 26 +#define SRST_PVTM 27 +#define SRST_I2C6 28 +#define SRST_I2C7 29 +#define SRST_I2C8 30 + +#endif
But please fix the typo in the commit subject.
RK3399 is a SoC from Rockchip with dual-core Cortex-A72 and qual-core Cortex-A53 CPU. It supports two USB3.0 type-C ports and two USB2.0 EHCI ports. Other interfaces are very like RK3288, the DRAM are 32bit width address and support address from 0 to 4GB-128MB range.
arch/arm/Kconfig | 3 -- arch/arm/mach-rockchip/Kconfig | 25 +++++++++- arch/arm/mach-rockchip/Makefile | 2 +- arch/arm/mach-rockchip/rk3399/Kconfig | 19 ++++++++ arch/arm/mach-rockchip/rk3399/Makefile | 5 ++ board/rockchip/evb_rk3399/Kconfig | 15 ++++++ board/rockchip/evb_rk3399/MAINTAINERS | 0 board/rockchip/evb_rk3399/Makefile | 7 +++ board/rockchip/evb_rk3399/evb-rk3399.c | 41 +++++++++++++++++ include/configs/evb_rk3399.h | 24 ++++++++++ include/configs/rk3399_common.h | 84 ++++++++++++++++++++++++++++++++++ 11 files changed, 220 insertions(+), 5 deletions(-) create mode 100644 arch/arm/mach-rockchip/rk3399/Kconfig create mode 100644 arch/arm/mach-rockchip/rk3399/Makefile create mode 100644 board/rockchip/evb_rk3399/Kconfig create mode 100644 board/rockchip/evb_rk3399/MAINTAINERS create mode 100644 board/rockchip/evb_rk3399/Makefile create mode 100644 board/rockchip/evb_rk3399/evb-rk3399.c create mode 100644 include/configs/evb_rk3399.h create mode 100644 include/configs/rk3399_common.h
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 8a9cfcc..6e4d78a 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -846,10 +846,7 @@ config STM32
config ARCH_ROCKCHIP bool "Support Rockchip SoCs" - select SUPPORT_SPL - select SPL select OF_CONTROL - select CPU_V7 select DM
config TARGET_THUNDERX_88XX diff --git a/arch/arm/mach-rockchip/Kconfig b/arch/arm/mach-rockchip/Kconfig index 2a8afac..2a739ea 100644 --- a/arch/arm/mach-rockchip/Kconfig +++ b/arch/arm/mach-rockchip/Kconfig @@ -1,5 +1,8 @@ if ARCH_ROCKCHIP
+config RK_TIMER + bool + config ROCKCHIP_RK3288 bool "Support Rockchip RK3288" help @@ -8,6 +11,10 @@ config ROCKCHIP_RK3288 video interfaces supporting HDMI and eDP, several DDR3 options and video codec support. Peripherals include Gigabit Ethernet, USB2 host and OTG, SDIO, I2S, UART,s, SPI, I2C and PWMs. + select CPU_V7 + select RK_TIMER + select SUPPORT_SPL + select SPL
config ROCKCHIP_RK3036 bool "Support Rockchip RK3036" @@ -16,6 +23,21 @@ config ROCKCHIP_RK3036 including NEON and GPU, Mali-400 graphics, several DDR3 options and video codec support. Peripherals include Gigabit Ethernet, USB2 host and OTG, SDIO, I2S, UART, SPI, I2C and PWMs. + select CPU_V7 + select RK_TIMER + select SUPPORT_SPL + select SPL + +config ROCKCHIP_RK3399 + bool "Support Rockchip RK3399" + help + The Rockchip RK3399 is a ARM-based SoC with a dual-core Cortex-A72 + and qual-core Cortex-A53. + including NEON and GPU, 1MB L2 cache, Mali-T7 graphics, two + video interfaces supporting HDMI and eDP, several DDR3 options + and video codec support. Peripherals include Gigabit Ethernet, + USB2 host and OTG, SDIO, I2S, UART,s, SPI, I2C and PWMs. + select ARM64
config SYS_MALLOC_F default y @@ -42,8 +64,9 @@ config DM_GPIO default y
config BLK - default y + default y if CPU_V7
source "arch/arm/mach-rockchip/rk3288/Kconfig" source "arch/arm/mach-rockchip/rk3036/Kconfig" +source "arch/arm/mach-rockchip/rk3399/Kconfig" endif diff --git a/arch/arm/mach-rockchip/Makefile b/arch/arm/mach-rockchip/Makefile index 55567cb..50246f0 100644 --- a/arch/arm/mach-rockchip/Makefile +++ b/arch/arm/mach-rockchip/Makefile @@ -10,6 +10,6 @@ obj-$(CONFIG_ROCKCHIP_RK3036) += rk3036-board-spl.o else obj-$(CONFIG_ROCKCHIP_RK3288) += board.o endif -obj-y += rk_timer.o +obj-$(CONFIG_RK_TIMER) += rk_timer.o obj-$(CONFIG_ROCKCHIP_RK3288) += rk3288/ obj-$(CONFIG_ROCKCHIP_RK3036) += rk3036/ diff --git a/arch/arm/mach-rockchip/rk3399/Kconfig b/arch/arm/mach-rockchip/rk3399/Kconfig new file mode 100644 index 0000000..603f534 --- /dev/null +++ b/arch/arm/mach-rockchip/rk3399/Kconfig @@ -0,0 +1,19 @@ +if ROCKCHIP_RK3399 + +config TARGET_EVB_RK3399 + bool "RK3399 evb board" + help + Firefly is a RK3288-based development board with 2 USB ports, + HDMI, VGA, micro-SD card, audio, WiFi and Gigabit Ethernet, It + also includes on-board eMMC and 1GB of SDRAM. Expansion connectors + provide access to display pins, I2C, SPI, UART and GPIOs. + +config SYS_SOC + default "rockchip" + +config SYS_MALLOC_F_LEN + default 0x0800 + +source "board/rockchip/evb_rk3399/Kconfig" + +endif diff --git a/arch/arm/mach-rockchip/rk3399/Makefile b/arch/arm/mach-rockchip/rk3399/Makefile new file mode 100644 index 0000000..ca69207 --- /dev/null +++ b/arch/arm/mach-rockchip/rk3399/Makefile @@ -0,0 +1,5 @@ +# +# Copyright (C) 2016 Rockchip Electronics Co., Ltd +# +# SPDX-License-Identifier: GPL-2.0+ +# diff --git a/board/rockchip/evb_rk3399/Kconfig b/board/rockchip/evb_rk3399/Kconfig new file mode 100644 index 0000000..412b81c --- /dev/null +++ b/board/rockchip/evb_rk3399/Kconfig @@ -0,0 +1,15 @@ +if TARGET_EVB_RK3399 + +config SYS_BOARD + default "evb_rk3399" + +config SYS_VENDOR + default "rockchip" + +config SYS_CONFIG_NAME + default "evb_rk3399" + +config BOARD_SPECIFIC_OPTIONS # dummy + def_bool y + +endif diff --git a/board/rockchip/evb_rk3399/MAINTAINERS b/board/rockchip/evb_rk3399/MAINTAINERS new file mode 100644 index 0000000..e69de29 diff --git a/board/rockchip/evb_rk3399/Makefile b/board/rockchip/evb_rk3399/Makefile new file mode 100644 index 0000000..aaa51c2 --- /dev/null +++ b/board/rockchip/evb_rk3399/Makefile @@ -0,0 +1,7 @@ +# +# (C) Copyright 2016 Rockchip Electronics Co., Ltd +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y += evb-rk3399.o diff --git a/board/rockchip/evb_rk3399/evb-rk3399.c b/board/rockchip/evb_rk3399/evb-rk3399.c new file mode 100644 index 0000000..357b08b --- /dev/null +++ b/board/rockchip/evb_rk3399/evb-rk3399.c @@ -0,0 +1,41 @@ +/* + * (C) Copyright 2016 Rockchip Electronics Co., Ltd + * + * SPDX-License-Identifier: GPL-2.0+ + */ +#include <dm.h> +#include <common.h> +#include <asm/armv8/mmu.h> + +DECLARE_GLOBAL_DATA_PTR; + +static struct mm_region rk3399_mem_map[] = { + { + .base = 0x0UL, + .size = 0x80000000UL, + .attrs = PTE_BLOCK_MEMTYPE(MT_NORMAL) | + PTE_BLOCK_INNER_SHARE + }, { + .base = 0xf0000000UL, + .size = 0x10000000UL, + .attrs = PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRNE) | + PTE_BLOCK_NON_SHARE | + PTE_BLOCK_PXN | PTE_BLOCK_UXN + }, { + /* List terminator */ + 0, + } +}; + +struct mm_region *mem_map = rk3399_mem_map; + +int board_init(void) +{ + return 0; +} + +int dram_init(void) +{ + gd->ram_size = 0x80000000; + return 0; +} diff --git a/include/configs/evb_rk3399.h b/include/configs/evb_rk3399.h new file mode 100644 index 0000000..0bf4f66 --- /dev/null +++ b/include/configs/evb_rk3399.h @@ -0,0 +1,24 @@ +/* + * (C) Copyright 2016 Rockchip Electronics Co., Ltd + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __EVB_RK3399_H +#define __EVB_RK3399_H + +#include <configs/rk3399_common.h> + + +#define CONFIG_ENV_IS_IN_MMC +#define CONFIG_SYS_MMC_ENV_DEV 0 +/* SPL @ 32k for ~36k + * ENV @ 96k + * u-boot @ 128K + */ +#define CONFIG_ENV_OFFSET (96 * 1024) + +#define CONFIG_SYS_WHITE_ON_BLACK +#define CONFIG_CONSOLE_SCROLL_LINES 10 + +#endif diff --git a/include/configs/rk3399_common.h b/include/configs/rk3399_common.h new file mode 100644 index 0000000..1c13e2e --- /dev/null +++ b/include/configs/rk3399_common.h @@ -0,0 +1,84 @@ +/* + * (C) Copyright 2016 Rockchip Electronics Co., Ltd + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __CONFIG_RK3399_COMMON_H +#define __CONFIG_RK3399_COMMON_H + +#define CONFIG_SYS_CACHELINE_SIZE 64 + +#include <asm/arch/hardware.h> + +#define CONFIG_SYS_NO_FLASH +#define CONFIG_NR_DRAM_BANKS 1 +#define CONFIG_ENV_SIZE 0x2000 +#define CONFIG_SYS_MAXARGS 16 +#define CONFIG_BAUDRATE 1500000 +#define CONFIG_SYS_MALLOC_LEN (32 << 20) +#define CONFIG_SYS_CBSIZE 1024 +#define CONFIG_SKIP_LOWLEVEL_INIT +#define CONFIG_DISPLAY_BOARDINFO + +#define CONFIG_SYS_NS16550 +#define CONFIG_SYS_NS16550_MEM32 + +#define CONFIG_SYS_TEXT_BASE 0x00200000 +#define CONFIG_SYS_INIT_SP_ADDR 0x00300000 +#define CONFIG_SYS_LOAD_ADDR 0x00800800 + +#define CONFIG_ROCKCHIP_COMMON +#define CONFIG_SYS_BOOTM_LEN (64 << 20) /* 64M */ + +/* MMC/SD IP block */ +#define CONFIG_MMC +#define CONFIG_GENERIC_MMC +#define CONFIG_SDHCI +#define CONFIG_BOUNCE_BUFFER +#define CONFIG_ROCKCHIP_SDHCI_MAX_FREQ 200000000 + +#define CONFIG_DOS_PARTITION +#define CONFIG_FAT_WRITE +#define CONFIG_PARTITION_UUIDS +#define CONFIG_CMD_PART + +/* RAW SD card / eMMC locations. */ +#define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR 256 +#define CONFIG_SYS_SPI_U_BOOT_OFFS (128 << 10) + +/* FAT sd card locations. */ +#define CONFIG_SYS_MMCSD_FS_BOOT_PARTITION 1 +#define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot.img" + +#define CONFIG_SPL_PINCTRL_SUPPORT +#define CONFIG_SPL_RAM_SUPPORT +#define CONFIG_SPL_DRIVERS_MISC_SUPPORT + +#define CONFIG_SYS_SDRAM_BASE 0 +#define CONFIG_NR_DRAM_BANKS 1 +#define SDRAM_BANK_SIZE (2UL << 30) + +#define CONFIG_SPI_FLASH +#define CONFIG_SPI +#define CONFIG_SF_DEFAULT_SPEED 20000000 + +#ifndef CONFIG_SPL_BUILD +#include <config_distro_defaults.h> + +#define ENV_MEM_LAYOUT_SETTINGS \ + "scriptaddr=0x00000000\0" \ + "pxefile_addr_r=0x00100000\0" \ + "fdt_addr_r=0x01f00000\0" \ + "kernel_addr_r=0x02000000\0" \ + "ramdisk_addr_r=0x04000000\0" + +/* First try to boot from SD (index 0), then eMMC (index 1 */ +#define BOOT_TARGET_DEVICES(func) \ + func(MMC, mmc, 0) \ + func(MMC, mmc, 1) + +#include <config_distro_bootcmd.h> +#endif + +#endif
Hi Kever,
nits below
select SUPPORT_SPL
+config RK_TIMER
bool
select CPU_V7
select RK_TIMER
select SUPPORT_SPL
select SPL
select CPU_V7
select RK_TIMER
select SUPPORT_SPL
select SPL
help
select ARM64
config BLK
default y
default y if CPU_V7
help
Firefly?
Please check that this help is correct.
+config SYS_SOC
default "rockchip"
default 0x0800
+config SYS_BOARD
+config SYS_VENDOR
default "rockchip"
def_bool y
- (C) Copyright 2016 Rockchip Electronics Co., Ltd
.base = 0x0UL,
0,
Please drop extra blank line
- ENV @ 96k
- u-boot @ 128K
What is this header file for?
func(MMC, mmc, 0) \
func(MMC, mmc, 1)
1.9.1
This patch add basic config option for evb-rk3399 board.
configs/evb-rk3399_defconfig | 32 ++++++++++++++++++++++++++++++++ 1 file changed, 32 insertions(+) create mode 100644 configs/evb-rk3399_defconfig
diff --git a/configs/evb-rk3399_defconfig b/configs/evb-rk3399_defconfig new file mode 100644 index 0000000..5c82cb1 --- /dev/null +++ b/configs/evb-rk3399_defconfig @@ -0,0 +1,32 @@ +CONFIG_ARM=y +CONFIG_ARCH_ROCKCHIP=y +CONFIG_ROCKCHIP_RK3399=y +CONFIG_TARGET_EVB_RK3399=y +CONFIG_DEFAULT_DEVICE_TREE="rk3399-evb" +CONFIG_HUSH_PARSER=y +CONFIG_CMD_BOOTZ=y +# CONFIG_CMD_IMLS is not set +CONFIG_CMD_MMC=y +CONFIG_CMD_SF=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_TIME=y +CONFIG_CMD_GPT=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y +CONFIG_REGMAP=y +CONFIG_SYSCON=y +CONFIG_CLK=y +CONFIG_FIT=y +CONFIG_SYSRESET=y +CONFIG_DM_MMC=y +CONFIG_ROCKCHIP_SDHCI=y +CONFIG_PINCTRL=y +CONFIG_RAM=y +CONFIG_DEBUG_UART=y +CONFIG_DEBUG_UART_BASE=0xFF1A0000 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_USE_TINY_PRINTF=y +CONFIG_ERRNO_STR=y
Rockchip rk3399 using arasan sdhci-5.1 controller. This patch add the controller support to enable mmc device and tested on rk3399 evb board.
drivers/mmc/Kconfig | 6 +++++ drivers/mmc/Makefile | 1 + drivers/mmc/rockchip_sdhci.c | 58 ++++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 65 insertions(+) create mode 100644 drivers/mmc/rockchip_sdhci.c
diff --git a/drivers/mmc/Kconfig b/drivers/mmc/Kconfig index c80efc3..75c2d92 100644 --- a/drivers/mmc/Kconfig +++ b/drivers/mmc/Kconfig @@ -52,6 +52,12 @@ config ZYNQ_SDHCI help Support for Arasan SDHCI host controller on Zynq/ZynqMP ARM SoCs platform
+config ROCKCHIP_SDHCI + bool "Arasan SDHCI controller for Rockchip support" + depends on DM_MMC && OF_CONTROL + help + Support for Arasan SDHCI host controller on Rockchip ARM SoCs platform + config MMC_UNIPHIER bool "UniPhier SD/MMC Host Controller support" depends on ARCH_UNIPHIER diff --git a/drivers/mmc/Makefile b/drivers/mmc/Makefile index 3da4817..7cb2ab0 100644 --- a/drivers/mmc/Makefile +++ b/drivers/mmc/Makefile @@ -53,6 +53,7 @@ obj-$(CONFIG_SPEAR_SDHCI) += spear_sdhci.o obj-$(CONFIG_TEGRA_MMC) += tegra_mmc.o obj-$(CONFIG_MMC_UNIPHIER) += uniphier-sd.o obj-$(CONFIG_ZYNQ_SDHCI) += zynq_sdhci.o +obj-$(CONFIG_ROCKCHIP_SDHCI) += rockchip_sdhci.o
ifdef CONFIG_SPL_BUILD obj-$(CONFIG_SPL_MMC_BOOT) += fsl_esdhc_spl.o diff --git a/drivers/mmc/rockchip_sdhci.c b/drivers/mmc/rockchip_sdhci.c new file mode 100644 index 0000000..bee269d --- /dev/null +++ b/drivers/mmc/rockchip_sdhci.c @@ -0,0 +1,58 @@ +/* + * (C) Copyright 2016 Fuzhou Rockchip Electronics Co., Ltd + * + * Rockchip SD Host Controller Interface + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <dm.h> +#include <fdtdec.h> +#include <libfdt.h> +#include <malloc.h> +#include <sdhci.h> + +/* 400KHz is max freq for card ID etc. Use that as min */ +#define EMMC_MIN_FREQ 400000 + +static int arasan_sdhci_probe(struct udevice *dev) +{ + struct mmc_uclass_priv *upriv = dev_get_uclass_priv(dev); + struct sdhci_host *host = dev_get_priv(dev); + + + host->version = sdhci_readw(host, SDHCI_HOST_VERSION); + host->quirks = SDHCI_QUIRK_WAIT_SEND_CMD; + + add_sdhci(host, CONFIG_ROCKCHIP_SDHCI_MAX_FREQ, EMMC_MIN_FREQ); + + upriv->mmc = host->mmc; + host->mmc->dev = dev; + + return 0; +} + +static int arasan_sdhci_ofdata_to_platdata(struct udevice *dev) +{ + struct sdhci_host *host = dev_get_priv(dev); + + host->name = dev->name; + host->ioaddr = (void *)dev_get_addr(dev); + + return 0; +} + +static const struct udevice_id arasan_sdhci_ids[] = { + { .compatible = "arasan,sdhci-5.1" }, + { } +}; + +U_BOOT_DRIVER(arasan_sdhci_drv) = { + .name = "arasan_sdhci", + .id = UCLASS_MMC, + .of_match = arasan_sdhci_ids, + .ofdata_to_platdata = arasan_sdhci_ofdata_to_platdata, + .probe = arasan_sdhci_probe, + .priv_auto_alloc_size = sizeof(struct sdhci_host), +};
Hi Kever,
Can you please update this to define CONFIG_BLK and CONFIG_DM_MMC_OPS? This will give it full driver-model support.
See msm_sdhci.c for an example.
help
- (C) Copyright 2016 Fuzhou Rockchip Electronics Co., Ltd
- Rockchip SD Host Controller Interface
You can use dev_get_addr_ptr() here.
.id = UCLASS_MMC,
1.9.1
Hi Simon,
On 07/15/2016 11:20 AM, Simon Glass wrote:
Hi Kever,
Signed-off-by: Kever Yang kever.yang@rock-chips.com
Sorry, missing this reply when I send out patch V2/V3, will update with full driver-model support.
Thanks, - Kever
help
- config MMC_UNIPHIER bool "UniPhier SD/MMC Host Controller support" depends on ARCH_UNIPHIER
.id = UCLASS_MMC,
1.9.1
Hi Kever,
This patchset add support for rk3399 with ATF based on Rockchip miniloader as secondary bootloader instead of u-boot SPL.
U-Boot
Rockchip miniloader init the DRAM and load the ATF and u-boot to runing address, and then jump to ATF, ATM do some init and switch to EL2/EL1 mode before jump to next loader which is u-boot here.
Pls reference board/rockchip/evb_rk3399/README to setup the board.
Will migrate to SPL once its ready for ATF.
This patch set is based on below patch: "board: move all the rockchip board in one folder"
This patch set has been test on rk3399 evb board.
Kever Yang (5): dts: add support for rkchichip rk3399 soc ARM64: rockchip: add support for rk3399 SoC based evb-board config: add config file for evb-rk3399 mmc: rockchip: add SDHCI driver support for rockchip soc ARM64: evb-rk3399: add a README for this board setup
I don't see this last patch on the mailing list.
arch/arm/Kconfig | 3 - arch/arm/dts/Makefile | 3 +- arch/arm/dts/rk3399-evb.dts | 104 ++++ arch/arm/dts/rk3399.dtsi | 1028 ++++++++++++++++++++++++++++++++ arch/arm/mach-rockchip/Kconfig | 25 +- arch/arm/mach-rockchip/Makefile | 2 +- arch/arm/mach-rockchip/rk3399/Kconfig | 19 + arch/arm/mach-rockchip/rk3399/Makefile | 5 + board/rockchip/evb_rk3399/Kconfig | 15 + board/rockchip/evb_rk3399/MAINTAINERS | 0 board/rockchip/evb_rk3399/Makefile | 7 + board/rockchip/evb_rk3399/README | 73 +++ board/rockchip/evb_rk3399/evb-rk3399.c | 41 ++ configs/evb-rk3399_defconfig | 32 + drivers/mmc/Kconfig | 6 + drivers/mmc/Makefile | 1 + drivers/mmc/rockchip_sdhci.c | 58 ++ include/configs/evb_rk3399.h | 24 + include/configs/rk3399_common.h | 84 +++ include/dt-bindings/clock/rk3399-cru.h | 746 +++++++++++++++++++++++ 20 files changed, 2270 insertions(+), 6 deletions(-) create mode 100644 arch/arm/dts/rk3399-evb.dts create mode 100644 arch/arm/dts/rk3399.dtsi create mode 100644 arch/arm/mach-rockchip/rk3399/Kconfig create mode 100644 arch/arm/mach-rockchip/rk3399/Makefile create mode 100644 board/rockchip/evb_rk3399/Kconfig create mode 100644 board/rockchip/evb_rk3399/MAINTAINERS create mode 100644 board/rockchip/evb_rk3399/Makefile create mode 100644 board/rockchip/evb_rk3399/README create mode 100644 board/rockchip/evb_rk3399/evb-rk3399.c create mode 100644 configs/evb-rk3399_defconfig create mode 100644 drivers/mmc/rockchip_sdhci.c create mode 100644 include/configs/evb_rk3399.h create mode 100644 include/configs/rk3399_common.h create mode 100644 include/dt-bindings/clock/rk3399-cru.h
-- 1.9.1
Kever Yang
