[PATCH v2 1/2] rockchip: video: Use ofnode_decode_display_timing() to parse timing
Use ofnode_decode_display_timing() instead of fdtdec_decode_display_timing() to parse display timing, so that we can support live DT.
Signed-off-by: Kever Yang kever.yang@rock-chips.com ---
Changes in v2: None
drivers/video/rockchip/rk_lvds.c | 3 +-- drivers/video/rockchip/rk_mipi.c | 3 +-- 2 files changed, 2 insertions(+), 4 deletions(-)
diff --git a/drivers/video/rockchip/rk_lvds.c b/drivers/video/rockchip/rk_lvds.c index cf5c0439b1..cae8bada32 100644 --- a/drivers/video/rockchip/rk_lvds.c +++ b/drivers/video/rockchip/rk_lvds.c @@ -160,8 +160,7 @@ int rk_lvds_enable(struct udevice *dev, int panel_bpp,
int rk_lvds_read_timing(struct udevice *dev, struct display_timing *timing) { - if (fdtdec_decode_display_timing - (gd->fdt_blob, dev_of_offset(dev), 0, timing)) { + if (ofnode_decode_display_timing(dev_ofnode(dev), 0, timing)) { debug("%s: Failed to decode display timing\n", __func__); return -EINVAL; } diff --git a/drivers/video/rockchip/rk_mipi.c b/drivers/video/rockchip/rk_mipi.c index f9280e8607..a77bdfd24d 100644 --- a/drivers/video/rockchip/rk_mipi.c +++ b/drivers/video/rockchip/rk_mipi.c @@ -29,8 +29,7 @@ int rk_mipi_read_timing(struct udevice *dev, { int ret;
- ret = fdtdec_decode_display_timing(gd->fdt_blob, dev_of_offset(dev), - 0, timing); + ret = ofnode_decode_display_timing(dev_ofnode(dev), 0, timing); if (ret) { debug("%s: Failed to decode display timing (ret=%d)\n", __func__, ret);
Use ofnode_ or dev_ APIs instead of fdt_ and fdtdec_ APIs so that the driver can support live DT.
Changes in v2: - use dev_read_s32() instead of dev_read_s32_default();
drivers/video/rockchip/rk3288_mipi.c | 1 - drivers/video/rockchip/rk3399_mipi.c | 1 - drivers/video/rockchip/rk_edp.c | 2 +- drivers/video/rockchip/rk_lvds.c | 28 +++++++++------------------- drivers/video/rockchip/rk_mipi.c | 11 +++++------ 5 files changed, 15 insertions(+), 28 deletions(-)
diff --git a/drivers/video/rockchip/rk3288_mipi.c b/drivers/video/rockchip/rk3288_mipi.c index f4444b9c34..71d3faf169 100644 --- a/drivers/video/rockchip/rk3288_mipi.c +++ b/drivers/video/rockchip/rk3288_mipi.c @@ -8,7 +8,6 @@ #include <clk.h> #include <display.h> #include <dm.h> -#include <fdtdec.h> #include <panel.h> #include <regmap.h> #include "rk_mipi.h" diff --git a/drivers/video/rockchip/rk3399_mipi.c b/drivers/video/rockchip/rk3399_mipi.c index 74ebe770a9..cfaa37797e 100644 --- a/drivers/video/rockchip/rk3399_mipi.c +++ b/drivers/video/rockchip/rk3399_mipi.c @@ -8,7 +8,6 @@ #include <clk.h> #include <display.h> #include <dm.h> -#include <fdtdec.h> #include <panel.h> #include <regmap.h> #include "rk_mipi.h" diff --git a/drivers/video/rockchip/rk_edp.c b/drivers/video/rockchip/rk_edp.c index 8703df0ec0..842034c77c 100644 --- a/drivers/video/rockchip/rk_edp.c +++ b/drivers/video/rockchip/rk_edp.c @@ -996,7 +996,7 @@ static int rk_edp_ofdata_to_platdata(struct udevice *dev) { struct rk_edp_priv *priv = dev_get_priv(dev);
- priv->regs = (struct rk3288_edp *)devfdt_get_addr(dev); + priv->regs = dev_read_addr_ptr(dev); priv->grf = syscon_get_first_range(ROCKCHIP_SYSCON_GRF);
return 0; diff --git a/drivers/video/rockchip/rk_lvds.c b/drivers/video/rockchip/rk_lvds.c index cae8bada32..a11d793135 100644 --- a/drivers/video/rockchip/rk_lvds.c +++ b/drivers/video/rockchip/rk_lvds.c @@ -171,32 +171,22 @@ int rk_lvds_read_timing(struct udevice *dev, struct display_timing *timing) static int rk_lvds_ofdata_to_platdata(struct udevice *dev) { struct rk_lvds_priv *priv = dev_get_priv(dev); - const void *blob = gd->fdt_blob; - int node = dev_of_offset(dev); int ret; - priv->regs = (void *)devfdt_get_addr(dev); + + priv->regs = dev_read_addr_ptr(dev); priv->grf = syscon_get_first_range(ROCKCHIP_SYSCON_GRF);
- ret = fdtdec_get_int(blob, node, "rockchip,output", -1); - if (ret != -1) { - priv->output = ret; - debug("LVDS output : %d\n", ret); - } else { - /* default set it as output rgb */ + if (!dev_read_s32(dev, "rockchip,output", &priv->output)) + debug("LVDS output : %d\n", priv->output); + else /* default set it as output rgb */ priv->output = LVDS_OUTPUT_RGB; - }
- ret = fdtdec_get_int(blob, node, "rockchip,data-mapping", -1); - if (ret != -1) { - priv->format = ret; - debug("LVDS data-mapping : %d\n", ret); - } else { - /* default set it as format jeida */ + if (!dev_read_s32(dev, "rockchip,data-mapping", &priv->format)) + debug("LVDS data-mapping : %d\n", priv->format); + else /* default set it as format jeida */ priv->format = LVDS_FORMAT_JEIDA; - }
- ret = fdtdec_get_int(blob, node, "rockchip,data-width", -1); - if (ret != -1) { + if (!dev_read_s32(dev, "rockchip,data-width", &ret)) { debug("LVDS data-width : %d\n", ret); if (ret == 24) { priv->format |= LVDS_24BIT; diff --git a/drivers/video/rockchip/rk_mipi.c b/drivers/video/rockchip/rk_mipi.c index a77bdfd24d..f1c21bb8d7 100644 --- a/drivers/video/rockchip/rk_mipi.c +++ b/drivers/video/rockchip/rk_mipi.c @@ -8,7 +8,6 @@ #include <clk.h> #include <display.h> #include <dm.h> -#include <fdtdec.h> #include <panel.h> #include <regmap.h> #include "rk_mipi.h" @@ -76,7 +75,7 @@ static void rk_mipi_dsi_write(uintptr_t regs, u32 reg, u32 val) int rk_mipi_dsi_enable(struct udevice *dev, const struct display_timing *timing) { - int node, timing_node; + ofnode node, timing_node; int val; struct rk_mipi_priv *priv = dev_get_priv(dev); uintptr_t regs = priv->regs; @@ -119,10 +118,10 @@ int rk_mipi_dsi_enable(struct udevice *dev, rk_mipi_dsi_write(regs, VID_PKT_SIZE, 0x4b0);
/* Set dpi color coding depth 24 bit */ - timing_node = fdt_subnode_offset(gd->fdt_blob, dev_of_offset(dev), - "display-timings"); - node = fdt_first_subnode(gd->fdt_blob, timing_node); - val = fdtdec_get_int(gd->fdt_blob, node, "bits-per-pixel", -1); + timing_node = ofnode_find_subnode(dev->node, "display-timings"); + node = ofnode_first_subnode(timing_node); + + val = ofnode_read_u32_default(node, "bits-per-pixel", -1); switch (val) { case 16: rk_mipi_dsi_write(regs, DPI_COLOR_CODING, DPI_16BIT_CFG_1);
Hi Kever,
Changes in v2:
priv->regs = dev_read_addr_ptr(dev); priv->grf = syscon_get_first_range(ROCKCHIP_SYSCON_GRF); return 0;
if (ret != -1) {
priv->output = ret;
} else {
Can you use dev_read_u32_default() ?
also below.
if (ret != -1) {
priv->format = ret;
} else {
if (ret != -1) {
"display-timings");
-- 2.17.1
Hi Simon,
On 2020/3/29 上午4:05, Simon Glass wrote:
Hi Kever,
Changes in v2:
if (ret != -1) {
priv->output = ret;
} else {
Could you share the point about which API should be used? It's both OK to me and I think
it's up to user to decide which is more convenient for them.
The main update of this version for this patch is update to use dev_read_s32() instead of
dev_read_u32_default() as your request. Maybe you can take V1 patch[0]?
Thanks,
- Kever
[0] http://patchwork.ozlabs.org/patch/1240459/
also below.
if (ret != -1) {
priv->format = ret;
} else {
if (ret != -1) {
"display-timings");
-- 2.17.1
Hi Kever,
On Sun, 29 Mar 2020 at 07:27, Kever Yang kever.yang@rock-chips.com wrote:
Hi Simon,
Hi Kever,
Changes in v2:
if (ret != -1) {
priv->output = ret;
} else {
Yes that was better, sorry.
Thanks,
- Kever
also below.
if (ret != -1) {
priv->format = ret;
} else {
if (ret != -1) {
"display-timings");
-- 2.17.1
Changes in v2: None
Kever Yang
