[U-Boot] [PATCH] Added set feature command in FSL IFC nand controller driver for ONFI nand
This patch adds set feature command (EFh) support in Freescale IFC nand controller driver.
The SET FEATURES (EFh) command is used to modify the target's default power-on behavior. This command uses one-byte feature address to determine which sub-feature parameters will be modified.
Signed-off-by: Ronak Desai ronak.desai@rockwellcollins.com --- drivers/mtd/nand/fsl_ifc_nand.c | 51 +++++++++++++++++++++++++++++++++++++++ 1 file changed, 51 insertions(+)
diff --git a/drivers/mtd/nand/fsl_ifc_nand.c b/drivers/mtd/nand/fsl_ifc_nand.c index c93dbb0..45cba52 100644 --- a/drivers/mtd/nand/fsl_ifc_nand.c +++ b/drivers/mtd/nand/fsl_ifc_nand.c @@ -596,6 +596,23 @@ static void fsl_ifc_cmdfunc(struct mtd_info *mtd, unsigned int command, fsl_ifc_run_command(mtd); return;
+ case NAND_CMD_SET_FEATURES: { + ifc_out32(&ifc->ifc_nand.nand_fir0, + (IFC_FIR_OP_CW0 << IFC_NAND_FIR0_OP0_SHIFT) | + (IFC_FIR_OP_UA << IFC_NAND_FIR0_OP1_SHIFT) | + (IFC_FIR_OP_WBCD << IFC_NAND_FIR0_OP2_SHIFT)); + + ifc_out32(&ifc->ifc_nand.nand_fcr0, + (NAND_CMD_SET_FEATURES << IFC_NAND_FCR0_CMD0_SHIFT)); + + ifc_out32(&ifc->ifc_nand.row3, column); + + /* Write only 4 bytes from flash buffer */ + ifc_out32(&ifc->ifc_nand.nand_fbcr, 4); + fsl_ifc_run_command(mtd); + return; + } + case NAND_CMD_RNDOUT: { __le16 Tccs = 0; chip->onfi_version ? (Tccs = chip->onfi_params.t_ccs) @@ -899,6 +916,39 @@ static int fsl_ifc_sram_init(uint32_t ver, struct fsl_ifc_mtd *priv)
return 0; } +/** + * fsl_ifc_onfi_set_features- set features for ONFI nand + * @mtd: MTD device structure + * @chip: nand chip info structure + * @addr: feature address. + * @subfeature_param: the subfeature parameters, a four bytes array. + */ +static int fsl_ifc_onfi_set_features(struct mtd_info *mtd, struct nand_chip *chip, + int addr, uint8_t *subfeature_param) +{ + int status; + int i; + +#ifdef CONFIG_SYS_NAND_ONFI_DETECTION + if (!chip->onfi_version || + !(le16_to_cpu(chip->onfi_params.opt_cmd) + & ONFI_OPT_CMD_SET_GET_FEATURES)) + return -EINVAL; +#endif + + /* Want data from start of the buffer */ + set_addr(mtd, 0, 0, 0); + + for (i = 0; i < ONFI_SUBFEATURE_PARAM_LEN; ++i) + chip->write_byte(mtd, subfeature_param[i]); + + chip->cmdfunc(mtd, NAND_CMD_SET_FEATURES, addr, 0); + + status = chip->waitfunc(mtd, chip); + if (status & NAND_STATUS_FAIL) + return -EIO; + return 0; +}
static int fsl_ifc_chip_init(int devnum, u8 *addr) { @@ -957,6 +1007,7 @@ static int fsl_ifc_chip_init(int devnum, u8 *addr) nand->select_chip = fsl_ifc_select_chip; nand->cmdfunc = fsl_ifc_cmdfunc; nand->waitfunc = fsl_ifc_wait; + nand->onfi_set_features = fsl_ifc_onfi_set_features;
/* set up nand options */ nand->bbt_td = &bbt_main_descr; -- 1.7.9.5
Ronak Desai
