Pull request doc-2023-10-rc5-2
Dear Tom,
The following changes since commit 252592214f79d8206c3cf0056a8827a0010214e0:
Merge tag 'doc-2023-10-rc5' of https://source.denx.de/u-boot/custodians/u-boot-efi (2023-09-09 09:33:02 -0400)
https://source.denx.de/u-boot/custodians/u-boot-efi.git tags/doc-2023-10-rc5-2
for you to fetch changes up to 8bd7d08407f986fe3c69f3e198f6f7152e12dea8:
binman: doc: fix reference tag placement for Logging section (2023-09-16 18:17:25 +0200)
Gitlab CI showed no issues: https://source.denx.de/u-boot/custodians/u-boot-efi/-/pipelines/17746
---------------------------------------------------------------- Pull request doc-2023-10-rc5-2
Documentation:
* fix code comments referring to doc/develop/expo.rst * remove unused values from Chromebook kernel command line * correct reference tag placement in tools/binman/binman.rst
Others:
* test: fix build dependency for event unit tests
---------------------------------------------------------------- Heinrich Schuchardt (1): test: build dependency for event unit tests
Jaewon Jung (1): doc: delete unused values kernel command line
Massimo Pegorer (2): expo: Fix documentation reference binman: doc: fix reference tag placement for Logging section
boot/expo_build.c | 6 +++--- doc/board/google/chromebook_coral.rst | 4 ++-- doc/usage/cmd/bootflow.rst | 4 ++-- include/expo.h | 2 +- test/common/Makefile | 2 +- tools/binman/binman.rst | 2 +- 6 files changed, 10 insertions(+), 10 deletions(-)
On Sun, Sep 17, 2023 at 02:14:03AM +0200, Heinrich Schuchardt wrote:
Dear Tom,
Hi Heinrich,
Dear Tom,
-- Tom
This merge includes the first version [1] of the patch "binman: doc: fix reference tag placement for Logging section", not the last one [2].
Let me know if I did something wrong in sending the v2 that causes this issue. Thanks.
Regards, Massimo
[1] https://patchwork.ozlabs.org/project/uboot/patch/20230909135235.21242-1-mass... [2] https://patchwork.ozlabs.org/project/uboot/patch/20230913161633.999542-1-mas...
Massimo Pegorer
