[PATCH v2] clk: ccf: replace the get_rate helper
The 12d152620d commit fixed the get_rate helper because the set_parent one did not re-parent the clock device to the new parent. The 4d139f3838 commit allows you to remove this workaround by calling the clk_get_parent_rate routine.
Signed-off-by: Dario Binacchi dariobin@libero.it
Changes in v2: - Replace clk_get_parent_rate with clk_generic_get_rate to avoid compilation warnings.
drivers/clk/clk-mux.c | 26 +------------------------- 1 file changed, 1 insertion(+), 25 deletions(-)
diff --git a/drivers/clk/clk-mux.c b/drivers/clk/clk-mux.c index 7a5ee7a45f..f1becd20d8 100644 --- a/drivers/clk/clk-mux.c +++ b/drivers/clk/clk-mux.c @@ -150,32 +150,8 @@ static int clk_mux_set_parent(struct clk *clk, struct clk *parent) return 0; }
-static ulong clk_mux_get_rate(struct clk *clk) -{ - struct clk_mux *mux = to_clk_mux(clk_dev_binded(clk) ? - dev_get_clk_ptr(clk->dev) : clk); - struct udevice *parent; - struct clk *pclk; - int err, index; - - index = clk_mux_get_parent(clk); - if (index >= mux->num_parents) - return -EFAULT; - - err = uclass_get_device_by_name(UCLASS_CLK, mux->parent_names[index], - &parent); - if (err) - return err; - - pclk = dev_get_clk_ptr(parent); - if (!pclk) - return -ENODEV; - - return clk_get_rate(pclk); -} - const struct clk_ops clk_mux_ops = { - .get_rate = clk_mux_get_rate, + .get_rate = clk_generic_get_rate, .set_parent = clk_mux_set_parent, };
Dario Binacchi
