[U-Boot] [PATCH] ARM: uniphier: move CONFIG_NAND to defconfig
This imply was added when the option was moved by the moveconfig tool, but the intention is not clear. Move it to defconfig.
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com ---
arch/arm/mach-uniphier/Kconfig | 1 - configs/uniphier_ld4_sld8_defconfig | 1 + configs/uniphier_pro4_defconfig | 1 + configs/uniphier_pxs2_ld6b_defconfig | 1 + 4 files changed, 3 insertions(+), 1 deletion(-)
diff --git a/arch/arm/mach-uniphier/Kconfig b/arch/arm/mach-uniphier/Kconfig index 6a7e239e0d28..ee2211241235 100644 --- a/arch/arm/mach-uniphier/Kconfig +++ b/arch/arm/mach-uniphier/Kconfig @@ -9,7 +9,6 @@ config ARCH_UNIPHIER_32BIT select CPU_V7_HAS_NONSEC select ARMV7_NONSEC select ARCH_SUPPORT_PSCI - imply NAND
choice prompt "UniPhier SoC select" diff --git a/configs/uniphier_ld4_sld8_defconfig b/configs/uniphier_ld4_sld8_defconfig index be0ae70f1a89..9c185e612b83 100644 --- a/configs/uniphier_ld4_sld8_defconfig +++ b/configs/uniphier_ld4_sld8_defconfig @@ -36,6 +36,7 @@ CONFIG_GPIO_UNIPHIER=y CONFIG_MISC=y CONFIG_I2C_EEPROM=y CONFIG_MMC_UNIPHIER=y +CONFIG_NAND=y CONFIG_NAND_DENALI=y CONFIG_SYS_NAND_DENALI_64BIT=y CONFIG_NAND_DENALI_SPARE_AREA_SKIP_BYTES=8 diff --git a/configs/uniphier_pro4_defconfig b/configs/uniphier_pro4_defconfig index 5ba8879af6ae..cdc4809bed6a 100644 --- a/configs/uniphier_pro4_defconfig +++ b/configs/uniphier_pro4_defconfig @@ -35,6 +35,7 @@ CONFIG_GPIO_UNIPHIER=y CONFIG_MISC=y CONFIG_I2C_EEPROM=y CONFIG_MMC_UNIPHIER=y +CONFIG_NAND=y CONFIG_NAND_DENALI=y CONFIG_SYS_NAND_DENALI_64BIT=y CONFIG_NAND_DENALI_SPARE_AREA_SKIP_BYTES=8 diff --git a/configs/uniphier_pxs2_ld6b_defconfig b/configs/uniphier_pxs2_ld6b_defconfig index 22c21548b6d7..b487b9dba49f 100644 --- a/configs/uniphier_pxs2_ld6b_defconfig +++ b/configs/uniphier_pxs2_ld6b_defconfig @@ -36,6 +36,7 @@ CONFIG_GPIO_UNIPHIER=y CONFIG_MISC=y CONFIG_I2C_EEPROM=y CONFIG_MMC_UNIPHIER=y +CONFIG_NAND=y CONFIG_NAND_DENALI=y CONFIG_SYS_NAND_DENALI_64BIT=y CONFIG_NAND_DENALI_SPARE_AREA_SKIP_BYTES=8
2017-08-29 15:41 GMT+09:00 Masahiro Yamada yamada.masahiro@socionext.com:
Applied to u-boot-uniphier.
Masahiro Yamada
