Re: [U-Boot] Fat write problem
Hello again,
This week I decided to do some further research and testing regarding this problem. With the image I had from the previous time, I could immediately reproduce it and by adding more and more debug prints, I tried to find the cause. Sofar, I have not succeeded in this yet.
However: later on I started testing with a freshly formatted drive (32 MB FAT partition) and kept repeating the fatwrite command:
fatwrite mmc 0:1 42000000 test-x 200
where x runs from 1, 2,3 and further. And this way I could reproduce it quite easily. Writing always fails for the 32nd file. This is with the partition formatted with a 512 byte sector size and a cluster size of 4. If the cluster size is 1 (formatted by Windows), it already fails at the 8th file.
If I create a subdirectory (from Linux) with already 24 files in it, I can still write 29 files and it fails at number 30. Also, if earlier files were deleted from the root-directory, they still count in the total number of files here.
If I take out the card where u-boot fails to write new files, I can still add new files from my PC with Linux or Windows.
I tested with both long and short filenames (same result), VFAT is enabled.
I hope this gives you all some more information about this problem and perhaps it is even a known problem (limited number of files in the root directory?). I know it is voor FAT16, but that was 512 entries if I am correct.
Regards,
Ruud
-----Oorspronkelijk bericht----- Van: Ruud Commandeur Verzonden: woensdag 23 oktober 2013 17:18 Aan: U-Boot list Onderwerp: Fat write problem
Hi Everyone,
After about half a year without problems for fatwrite, I have some new problem. The fatwrites for the u-boot are used to write the uimage and dtb file to a 32 MB FAT16 partition on an SD-card. Since this morning, the writing of a new file keeps failing. I still can write files that are already present. But if try and write some file with a name that doe not exist yet, it fails. I guess this just hasn't been tested for a while, since these filenames don't change. Meanwhile some extra files have been copied to the partition from the Linux platform. I did check the SD-card partition with fsck and could not find any problems.
I did enable the debug for MMC and FAT to get the following output:
fatwrite mmc 0:1 42000000 test-file 200 writing test-file MMC0: CMD16 MMC0: CMD17 MMC0: CMD16 MMC0: CMD18 MMC0: CMD12 get_dentfromdir: test-file gc - clustnum: -6, startsect: 132 MMC0: CMD16 MMC0: CMD18 MMC0: CMD12 vfatname: |uimage| Mismatch: |uimage|uimage| vfatname: |imx28-evk.dtb| Mismatch: |imx28-~1.dtb|imx28-evk.dtb| vfatname: |linux-file1.txt| Mismatch: |linux-~1.txt|linux-file1.txt| Mismatch: |address.ini|| vfatname: |imx28-clb.dtb| Mismatch: |imx28-~2.dtb|imx28-clb.dtb| vfatname: |img-copy| Mismatch: |img-copy|img-copy| vfatname: |tessie| Mismatch: |tessie|tessie| vfatname: |img-copy2| Mismatch: |img-co~1|img-copy2| vfatname: |imx-28-clb-37.dtb| Mismatch: |imx-28~1.dtb|imx-28-clb-37.dtb| vfatname: |hello8000.wav| Mismatch: |hello8~1.wav|hello8000.wav| vfatname: |versions.ini| Mismatch: |versions.ini|versions.ini| vfatname: |mx28-310.dtb| Mismatch: |mx28-310.dtb|mx28-310.dtb| FAT16: entry: 0xfffffffa = -6, offset: 0x03fa = 1018 MMC: block number 0x1000806 exceeds max(0x762c00) FAT16: ret: 00000000, entry: fffffffa, offset: 03fa curclust: 0x0 Invalid FAT entry name.ext : <NULL>. FAT16: entry: 0x0003 = 3, offset: 0x0003 = 3 error: overflow occurs error: writing FAT blocks FAT16: entry: 0x0004 = 4, offset: 0x0004 = 4 error: overflow occurs error: writing FAT blocks FAT16: entry: 0x0005 = 5, offset: 0x0005 = 5 error: overflow occurs error: writing FAT blocks FAT16: entry: 0x0006 = 6, offset: 0x0006 = 6 ... and this goes on for a long long time...
It points to get_fatent_value( ) where things go wrong. Or perhaps the call of this function with the value 0xfffffffa (-6). I don't know if that is supposed to be possible?
At the moment I am a bit stuck here, so if anyone would have an idea what goes wrong here, please let me know.
Thanks,
Ruud
N.B. It might be that this can be solved by clearing the FAT partition and starting with a clean sheet. But I prefer not to lose this error situaion before I know what goes wrong here.
Hi Ruud,
Thanks for the extensive research into this problem. For people to help, I think the barrier of reproducing the problem is "somewhat high", so it occurred to me if you can help setup a very easy test for people to work on. Would you be able to generate a small image that one can dd to a mmc card and then immediately provoke the error? If you don't have any hosting space, as a last resort I'd be fine for you to put it on our wiki [1].
Cheers Detlev
[1] http://www.denx.de/wiki/view/U-Boot/TooBigPatches
-----Oorspronkelijk bericht----- Van: Detlev Zundel [mailto:dzu@denx.de] Verzonden: vrijdag 17 januari 2014 15:59 Aan: Ruud Commandeur CC: U-Boot list Onderwerp: Re: [U-Boot] Fat write problem
Hi Ruud,
regarding
cause. Sofar,
formatted drive (32
reproduce it
1 (formatted
files in it, I
deleted from the
problem and
directory?). I know
Hi Detlev,
Thanks for your response. Finally I get some ;-)
I can look for creating some image, but I don't think it is that hard to reproduce (now I think to know what causes it). Either use 32 times the fatwrite command (using the cmd history and increment the x-nr each time) or just copy up to 31 files to the root of the FAT partition by using the host machine and place the SD-card back on the targe device running u-boot.
Hope this makes it easy enough, otherwise I will be glad to hear from you.
N.B. All this was with a FAT16 partition. If I use FAT32, I have no such problem! At least not for 45 files up till now...
Regards,
Ruud
Cheers Detlev
-- Golden rule #12: When the comments do not match the code, they probably are both wrong. -- Steven Rostedt
1300126962.9910.128.camel@gandalf.stny.rr.com
DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-40 Fax: (+49)-8142-66989-80 Email: dzu@denx.de
-----Oorspronkelijk bericht----- Van: Ruud Commandeur Verzonden: vrijdag 17 januari 2014 16:50 Aan: 'Detlev Zundel' CC: U-Boot list Onderwerp: RE: [U-Boot] Fat write problem
Hi Ruud,
regarding
cause. Sofar,
formatted drive (32
reproduce it
1 (formatted
files in it, I
deleted from the
files, I can
problem and
directory?). I know
easy test for
for you to
Hi Detlev,
Regards,
Ruud
Hi Detlev (and others),
Just to be absolutely sure, I did a new attempt.
Created 32 MB FAT16 (type 06) partition with fdisk on my SD-Card (1st parttion). Formatted as FAT16, 4 sectors per cluster:
"sudo mkfs.vfat -v -n IPCAN -F 16 -s 4 /dev/sdf1"
Created 30 files on this mounted partition:
"for i in {1..30}; do touch /media/IPCAN/test-$i; done"
Plugged the SD-card into my EVK running u-boot and started fatwrite testing:
fatwrite mmc 0:1 42000000 test-31 writing test-31 0 bytes written CLB IP-CAN U-Boot > fatwrite mmc 0:1 42000000 test-32 writing test-32 MMC: block number 0x1002006 exceeds max(0x746000) error: overflow occurs error: overflow occurs ... ...
And the error is there and will remain there for any further attempts. So it doesn't matter how and where the files were created, and what size the files are, adding files >= 32 jut fails for FAT16.
Note that also "test-16" is missing when doing a "fatls mmc 0:1". The file can be read though when doing a fatload for this file. This is probably some other problem, but could be related.
For now, I will continue using FAT32. If any problems would arise there I will post them.
Regards,
Ruud
Cheers Detlev
Detlev Zundel
dzu@denx.de
Detlev Zundel
Ruud Commandeur
