[PATCH 1/1] log: output for CONFIG_LOG=n
If CONFIG_LOG=n, we should still output errors, warnings, notices, infos, and for DEBUG=1 also debug messages.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- include/log.h | 10 +++++----- 1 file changed, 5 insertions(+), 5 deletions(-)
diff --git a/include/log.h b/include/log.h index 62fb8afbd0..0453876001 100644 --- a/include/log.h +++ b/include/log.h @@ -115,11 +115,11 @@ static inline int _log_nop(enum log_category_t cat, enum log_level_t level, #define log_io(_fmt...) log(LOG_CATEGORY, LOGL_DEBUG_IO, ##_fmt) #else #define _LOG_MAX_LEVEL LOGL_INFO -#define log_err(_fmt...) log_nop(LOG_CATEGORY, LOGL_ERR, ##_fmt) -#define log_warning(_fmt...) log_nop(LOG_CATEGORY, LOGL_WARNING, ##_fmt) -#define log_notice(_fmt...) log_nop(LOG_CATEGORY, LOGL_NOTICE, ##_fmt) -#define log_info(_fmt...) log_nop(LOG_CATEGORY, LOGL_INFO, ##_fmt) -#define log_debug(_fmt...) log_nop(LOG_CATEGORY, LOGL_DEBUG, ##_fmt) +#define log_err(_fmt, ...) printf(_fmt, ##__VA_ARGS__) +#define log_warning(_fmt, ...) printf(_fmt, ##__VA_ARGS__) +#define log_notice(_fmt, ...) printf(_fmt, ##__VA_ARGS__) +#define log_info(_fmt, ...) printf(_fmt, ##__VA_ARGS__) +#define log_debug(_fmt, ...) debug(_fmt, ##__VA_ARGS__) #define log_content(_fmt...) log_nop(LOG_CATEGORY, \ LOGL_DEBUG_CONTENT, ##_fmt) #define log_io(_fmt...) log_nop(LOG_CATEGORY, LOGL_DEBUG_IO, ##_fmt) -- 2.24.1
Why not just change the default for CONFIG_LOG to y? This is effectively the same, except it still allows users to completely disable logging altogether.
--Sean
--Sean
I have tested your suggestion for qemu_arm64_defconfig:
Without my patch and CONFIG_LOG=n:
u-boot.bin 664200 bytes
With my patch and CONFIG_LOG=n:
u-boot.bin 664432 bytes
Without my patch but with CONFIG_LOG=y and CONFIG_CONSOLE=y:
u-boot.bin 666648 bytes
So your suggestion consumes 2216 additional bytes to produce the essentially the same console output.
IMHO CONFIG_LOG=y is currently only helpful in the following situation:
* You are debugging your board and want to interactively change logging levels. * You want to log to a remote syslog server.
Best regards
Heinrich
Hi Heinrich,
--Sean
What is CONFIG_CONSOLE?
OK. That is a lot more than I thought.
I'm not sure if it is possible to update the log test to cover your new case?
- You are debugging your board and want to interactively change logging levels.
- You want to log to a remote syslog server.
Actually a major reason is that you want the full firmware log to be reported to Linux so you can check for warnings, etc. However we don't currently support this.
On 2/11/20 12:13 AM, Simon Glass wrote:
Hi Heinrich,
--Sean
This is a typo. It should be CONFIG_LOG_CONSOLE.
Thanks for reviewing.
The current log test case in not a close fit, as filtering will be irrelevant.
It should be possible to create a test using console recording (CONFIG_CONSOLE_RECORD=y).
Looking at test/dm/test-main.c it seems that you once wanted to use console recording in a test but I could not identify any test actually using it up to now.
Best regards
Heinrich
Hi Heinrich,
Hi Heinrich,
--Sean
There is a pending pull request in dm/master which has this.
One challenge might be that you need a test that only runs if CONFIG_LOG is not enabled. Perhaps you could use sandbox_spl for that?
Sean Anderson
