[U-Boot-Users] pci.c in MPC8349ADS
Hi.
I wonder why PCI support was added to the MPC83xx in board/mpc8349ads as a board-specific thing, instead of a cpu-architecture-general thing in cpu/mpc83xx ?
Aside from the I2C setup of the IO-expander, it seems that the remainder of PCI initialization is 83xx generic..
-dbu.
On Nov 15, 2005, at 9:22 AM, David Updegraff wrote:
Hi.
I wonder why PCI support was added to the MPC83xx in board/ mpc8349ads as a board-specific thing, instead of a cpu-architecture- general thing in cpu/mpc83xx ?
-dbu.
Eventually it should be. However someone needs to get full support working for PCI2 and such before we go down that path and looking at what should be done in the board code and what should be done in cpu/ mpc83xx.
- kumar
At the time, when we added PCI support for the TQM834x boards, it looked as if it was board specific. When new 83xx boards get added and it turns out to be more generic then the code should be moved to cpu/mpc83xx; the question is how many #ifdef's will be needed - the TQM834x will probably require some.
Yes, in theory. When you have to deal with real hardware (and it's buggy early incarnations) things may look different.
David Updegraff
Kumar Gala
