[U-Boot] [PATCH] sunxi: Machine id hack to prevent loading buggy sunxi-3.4 kernels
Store the 'compatibility revision' number in the top 4 bits of the machine id and pass it to the kernel. The old buggy kernels will fail to load with a very much googlable error message on the serial console:
"Error: unrecognized/unsupported machine ID (r1 = 0x100010bb)"
This error message can be documented in the linux-sunxi wiki with proper explanations about how to resolve this situation and where to get the necessary bugfixes for the sunxi-3.4 kernel.
The fixed sunxi-3.4 kernels can implement a revision compatibility check and clear the top 4 bits of the machine id if everything is alright.
Signed-off-by: Siarhei Siamashka siarhei.siamashka@gmail.com ---
To be used together with: https://groups.google.com/forum/#!topic/linux-sunxi/LOAxP3kAYs8
include/configs/sun4i.h | 4 ++-- include/configs/sun5i.h | 4 ++-- include/configs/sun7i.h | 4 ++-- include/configs/sunxi-common.h | 7 +++++++ 4 files changed, 13 insertions(+), 6 deletions(-)
diff --git a/include/configs/sun4i.h b/include/configs/sun4i.h index 87d269b..1537e53 100644 --- a/include/configs/sun4i.h +++ b/include/configs/sun4i.h @@ -13,8 +13,6 @@ */ #define CONFIG_CLK_FULL_SPEED 1008000000
-#define CONFIG_MACH_TYPE 4104 - #ifdef CONFIG_USB_EHCI #define CONFIG_USB_EHCI_SUNXI #define CONFIG_USB_MAX_CONTROLLER_COUNT 2 @@ -25,4 +23,6 @@ */ #include <configs/sunxi-common.h>
+#define CONFIG_MACH_TYPE (4104 | ((CONFIG_MACH_TYPE_COMPAT_REV) << 28)) + #endif /* __CONFIG_H */ diff --git a/include/configs/sun5i.h b/include/configs/sun5i.h index 52e3a6f..e755531 100644 --- a/include/configs/sun5i.h +++ b/include/configs/sun5i.h @@ -13,8 +13,6 @@ */ #define CONFIG_CLK_FULL_SPEED 1008000000
-#define CONFIG_MACH_TYPE 4138 - #ifdef CONFIG_USB_EHCI #define CONFIG_USB_EHCI_SUNXI #define CONFIG_USB_MAX_CONTROLLER_COUNT 1 @@ -25,4 +23,6 @@ */ #include <configs/sunxi-common.h>
+#define CONFIG_MACH_TYPE (4138 | ((CONFIG_MACH_TYPE_COMPAT_REV) << 28)) + #endif /* __CONFIG_H */ diff --git a/include/configs/sun7i.h b/include/configs/sun7i.h index 7cd7890..f817f73 100644 --- a/include/configs/sun7i.h +++ b/include/configs/sun7i.h @@ -14,8 +14,6 @@ */ #define CONFIG_CLK_FULL_SPEED 912000000
-#define CONFIG_MACH_TYPE 4283 - #ifdef CONFIG_USB_EHCI #define CONFIG_USB_EHCI_SUNXI #define CONFIG_USB_MAX_CONTROLLER_COUNT 2 @@ -31,4 +29,6 @@ */ #include <configs/sunxi-common.h>
+#define CONFIG_MACH_TYPE (4283 | ((CONFIG_MACH_TYPE_COMPAT_REV) << 28)) + #endif /* __CONFIG_H */ diff --git a/include/configs/sunxi-common.h b/include/configs/sunxi-common.h index 5ece020..f3e764a 100644 --- a/include/configs/sunxi-common.h +++ b/include/configs/sunxi-common.h @@ -14,6 +14,13 @@ #define _SUNXI_COMMON_CONFIG_H
/* + * Compatibility guard to prevent loading old buggy sunxi-3.4 kernels. + * Only sunxi-3.4 kernels with appropriate fixes applied are able to + * pass beyond the machine id check. + */ +#define CONFIG_MACH_TYPE_COMPAT_REV 1 + +/* * High Level Configuration Options */ #define CONFIG_SUNXI /* sunxi family */
TBH I'm not a big fan if this.
Nor of this one.
What I would prefer is for CONFIG_OLD_SUNXI_KERNEL_COMPAT to go away and for u-boot to automatically do the right thing when booting an old kernel.
Recently some patches where merged to make "bootm" work without an fdt even when build with fdt support.
Specifically in common/image-fdt.c line 437 there is:
if (!select && ok_no_fdt) { debug("Continuing to boot without FDT\n"); return 0; }
So we known when executing the bootm command that we do not have an fdt.
If this is the case, and only when this (no fdt) is the case then in arch/arm/lib/bootm.c: boot_prep_linux()
The board specific setup_board_tags() function gets called, we could define our own version of this (it has an empty weak default), and in our own version fixup things for the old kernel to just work.
That means:
Halving PLL5, then waiting for it to settle, then reprogramming the DRAM clk divider, I'm assuming that this will work if done in this order, but we obviously need to test this thoroughly.
Halving PLL6, then waiting for it to settle, then reprogram the MBUS divider, and check and update mmc mod clock dividers.
Modifying armv7_boot_nonsec so that we can override the default. We can do this e.g. by adding a global armv7_boot_nonsec_default variable and setting that from setup_board_tags().
This way we can just do the right thing automatically, and this has the added advantage that if we later find out that we're doing something in u-boot which is not good for the older kernels we can fix it in u-boot without needing to coordinate with the sunxi-3.4 kernels. In my experience the version check for compatibility style solution you are proposing brings a large maintenance burden, and it does not actually help the user, as the users wants something which just works.
Ian, would something like the above be acceptable to you ?
Regards,
Hans
Nor of this one.
Yes, the CONFIG_OLD_SUNXI_KERNEL_COMPAT option is barely useful for anything right now. And it would be great to get rid of it.
Sure, but first we need to define what is the "right thing".
Sounds like we are coming back to
http://lists.denx.de/pipermail/u-boot/2014-October/191697.html
As you may guess, I'm in favour of having everything working automatically without the need to set extra Kconfig options or environment variables :-)
That means:
This already looks somewhat more complicated than necessary...
By the "right thing", do you mean booting the sunxi-3.4 kernel with weird PLL5 and PLL6 settings just because some *older* versions of this kernel used to have bugs in the past?
I don't expect any maintenance burden at all. We only ever need this coordination to take care of very serious showstopper bugs. And such bugs have been already fixed.
We probably might only need an update for this version check if we try to adjust AXP152 DCDC4 voltage on A10s (and the sunxi-3.4 kernel would need to be patched in order not to touch DCDC4). Or if some other critical compatibility problem gets reported.
Please note that the newly discovered PLL6 issue is not a critical one and does not even deserve any coordination or version bump at all. It only causes some performance drop (MBUS clock speed reduction from 204 MHz to 150 MHz) and is easy to workaround in other ways.
And the users do have something that just works.
The only problem here is poor errors reporting. Tsvetan and Lars wasted some of their time doing debugging simply because they picked a wrong kernel. If they had a sane error message right from the start, then they would have just switched to a different kernel and be good. Or cherry picked the important fixes in the case of working with a heavily diverged sunxi-3.4 fork.
Tsvetan, Lars: do you have any comments on this?
Nor of this one.
Yes.
So am I.
That means:
So how about we just halve the frequency of the 2 PLL-s (PLL6 only on sun5i) everywhere and be done with it?
It seems to me that the advantage of having them doubled so that we can get more clocks is mostly theoretical in both cases anyways.
I'm fine with halving PLL6 on sun5i, but I believe we should then really also have PLL5 everywhere, taking us back to the original allwinner / u-boot-sunxi settings.
I seriously wonder what exactly, concretely having PLL5 doubled gains us. Yes we could run MBUS on 2/3th of the DRAM speed which we cannot do otherwise, but AFAIK we want MBUS at 300 for optimal perfomance, and we can get MBUS at exactly 300 by using pll6 as its parent (even if we halve PLL6).
Do you have any non theoritical example where having PLL5 doubled helps? Because if not then I'm becoming more and more in favor of just halving it leaving us with only the A20 sec vs nonsec boot thing for which the solution which I've outlined in my previous mail should work nicely.
Been there done that did not like it, this is going to suck big time, trust me I've done enough of this kinda stuff to know.
Regards,
Hans
Nor of this one.
Yes.
So am I.
That means:
Yes, that's what I also asked in
http://lists.denx.de/pipermail/u-boot/2015-February/205637.html
It is not so theoretical for PLL5P though.
We might potentially want to set MBUS higher than 300. Yes, the A13 manual says that 300MHz is the limit. But in practice it can be increased as high as 576MHz on more than one board (with some VDD-DLL voltage increase). There seems to be really a lot of headroom and going slightly beyond 300MHz might be OK.
Sigh. I believe, that I had already explained it multiple times in various e-mail posts. But here we go again:
1. The G2D (Mixer Processor) clock speed has a certain limit. We don't know what it is exactly, but the sunxi-3.4 kernel used to hardcode it to 1/2 of the PLL5P speed, which means that we can assume at least 240MHz for the boards with 480MHz DRAM clock speed.
Now let's see what happens if we try to increase the DRAM clock speed to 504MHz. In the case of the doubled PLL5P and divisor 5, we can get 1008MHz / 5 = 201.6 MHz clock speed for the G2D. But in the case of the same PLL5P as the DRAM clock speed, we have to use the divisor 3 and only get 504MHz / 3 = 168MHz. Obviously, 201.6MHz is faster than 168MHz.
The erratic G2D clock speed drops when gradually increasing the DRAM clock speed are not very nice. People are going to have a lot of headache finding a reasonable compromise between the DRAM and G2D performance. Doubling PLL5 reduces the performance penalties.
And yes, G2D is used today in the sunxi-3.4 kernel. Hopefully it will be also supported in the mainline kernel soon.
2. If we configure the DRAM clock speed as 648MHz, then the PLL5 clock speed already becomes rather high. IMHO, it is not healthy for the peripherals even without further doubling it. Tsvetan reported LCD flicker problems at 768MHz, which is not terribly far away from 648MHz. The real solution is to use the bugfixed sunxi-3.4 kernels, and the fixes are not very invasive (which means that they can be cherry picked to any potential fork).
3. Not quite related to PLL5, but we have to deal with the voltage regulators too. Old buggy kernels are also trying to change the DCDC3 voltage in the case of AXP209 and DCDC4 voltage in the case of AXP152. Which means that u-boot can't safely change these voltages if the compatibility with old buggy kernels is desired. Without increasing the VDD-DLL voltage, we can't reach very high MBUS and DRAM clock speeds. This is yet another PITA, which holds us back.
4. Currently running DRAM reliability tests requires the sunxi-3.4 kernel (see https://github.com/ssvb/lima-memtester/ for more details). I don't really like having different DRAM clock speed setup for the mainline kernel and for the sunxi-3.4 kernel, that's why using the CONFIG_OLD_SUNXI_KERNEL_COMPAT option is not a very good idea in general. It's much better to use the bugfixed sunxi-3.4 kernel without CONFIG_OLD_SUNXI_KERNEL_COMPAT.
The sun4i/sun5i/sun7i DRAM controller code in u-boot is ready for much faster DRAM clock speeds since the v2014.10 release. We are only missing the appropriate 'dram_para' settings for the boards, which can be prepared/verified according to the instructions from the linux-sunxi wiki. But there does not seem to be much interest in the performance and reliability for the sunxi boards yet. And participation of the hardware vendors (for doing large scale tests on many boards) is missing too.
Maybe now after the introduction of the Raspberry Pi 2, the Allwinner based devboard manufacturers might become a bit more interested in tweaking the performance in order to remain competitive.
I believe that every Cubietruck user had more than enough time to try my 'highspeedtruck' branches posted at
http://lists.denx.de/pipermail/u-boot/2014-July/183981.html
That's "the proof of the pudding", which demonstrates what is possible with this hardware :-)
But now you are telling me that you are in favour of crippling it before it really takes off the ground...
Well, this is not really a news. We could have fixed the sec vs nonsec boot thing months ago (if there only was a consensus about it). But better late than never.
I would say, that it would be a good idea to trust me this time for a change :-) You were given a chance to enforce your own solution, and it quite predictably sucks. Too bad that Tsvetan and Lars had to encounter problems in order to (hopefully) make this clear for everyone.
In fact, I have a better suggestion. We can have this versioned machine id hack active only when CONFIG_OLD_SUNXI_KERNEL_COMPAT is not defined. So that the normal build does not have non-obvious runtime failures with unpatched sunxi-3.4 kernels anymore. And the CONFIG_OLD_SUNXI_KERNEL_COMPAT still works just like before. I'll send a v2 patch shortly.
Nor of this one.
Yes.
So am I.
That means:
- The G2D (Mixer Processor) clock speed has a certain limit. We don't
Hmm, I see that is a nasty problem, esp. with the older kernels not dealing well with the doubled pll.
- If we configure the DRAM clock speed as 648MHz, then the PLL5
Ok, but then we should really also fix the PLL6 issue on sun5i in the older kernels, that should be as simple as simply removing the call setting the PLL6 speed from the code you pointed too, everything else can pretty much be kept as is. But I'm afraid I've other priorities then fixing this.
- Not quite related to PLL5, but we have to deal with the voltage
And something which we could fix by increasing the number you want to store in the high bits of the machine id and then too old kernels would simply not work rather then be unreliable. So yes I can see why you want what you want.
- Currently running DRAM reliability tests requires the sunxi-3.4
I still believe that the only way to get anywhere wrt getting better DRAM speeds is to just make the change. As said before if you submit patches to increase DRAM speed on some boards I'll put them in my personal sunxi-wip and the official u-boot-sunxi/next asap, and then we can ask people to test that, and once the merge window for v2015.07 opens we can land those changes and see from there.
What would also be welcome is a wiki page for reading DRAM chip markings, so that people can figure out what their board should be able to handle theoretically (assuming the pcb is not holding things back).
When I was asking why not just halve pll5 I was sincerely asking, and your g2d story is a compeling reason not to do that, if only the g2d could use pll6 as a parent, then we could just run it as 300MHz (which I believe should be a safe speed, as that is what the limit seems to be for the backend and frontend bits), but alas like the backend / frontend it has an IMHO weird set of parent choices. Given that weird set of parent choices I see the logic in not wanting to halve pll5, so lets try to find another solution for this.
Fixing this only becomes interesting IMHO once we've the other bits sorted out. Also I know the involved code a lot better know then back then which has resulted in me seeing a possible way to fix this relatively cleanly.
By the right thing I mean having things just work for the end user, whatever I'm doing having things just work is always my end goal. This is also why I'm mostly focussing upstream, which has resulted in Fedora 21 and the upcoming Debian release supporting allwinner devices ootb (albeit only headless) and the upcoming F-22 release will have much improved allwinner device support, supporting more devices, and supporting video output, etc.
Ok, I think I can live with that as solution, esp. since it will also work to ensure that we don't run old kernels which muck with voltages making things run unreliable in an unpredictable manner.
I'm not 100% happy about overloading the upper id bits though, that is not how machine ids are supposed to work officially, I guess we can get away with this since we are keeping all related changes confined to sunxi code only. But I'm not 100% enthusiastic about this.
Ian, can you live with overloading the high machine-id bits to deliberately break old kernels when not compiled with old kernel compatibility?
Regards,
Hans
Speaking of which, if someone were to identify a suitable set of simple-fb backports for 3.16 and they are reasonably self contained I'd happily backport them to the kenrel which is going to be in the next Debian release too...
It kind of sucks, but so do all the options it seems, I guess we can live with it...
Ian.
You will need all patches by me and by "Luc Verhaegen" from here: https://git.kernel.org/cgit/linux/kernel/git/torvalds/linux.git/log/drivers/...
As well as these dts patches:
https://git.kernel.org/cgit/linux/kernel/git/torvalds/linux.git/commit?id=57... https://git.kernel.org/cgit/linux/kernel/git/torvalds/linux.git/commit?id=d5... https://git.kernel.org/cgit/linux/kernel/git/torvalds/linux.git/commit?id=e5... https://git.kernel.org/cgit/linux/kernel/git/torvalds/linux.git/commit?id=8e... https://git.kernel.org/cgit/linux/kernel/git/torvalds/linux.git/commit?id=a9... https://git.kernel.org/cgit/linux/kernel/git/torvalds/linux.git/commit?id=8c... https://git.kernel.org/cgit/linux/kernel/git/torvalds/linux.git/commit?id=fd...
Those combined with a new enough u-boot should get you video output on most devices supported in upstream u-boot.
Ok, I'll go and merge the v2 patch then. Siarhei, I'm working on a linux-sunxi-3.4 fix for the sun5i PLL6 issue, please do not add a patch to the linux-sunxi-3.4 kernels claiming "COMPAT_REV 1" compatibility until that patch is done and merged.
Thanks & Regards,
Hans
Thanks!
While we are at it, could linux-sunxi-3.4 be also patched to not touch DCDC4 on AXP152? It serves the same role as DCDC3 on AXP209 and is connected to VDD-INT/VDD-DLL. I don't have A10s hardware myself.
Thanks!
Since I'm working on this now anyways I'll whip up a patch for this.
Regards,
Hans
https://git.kernel.org/cgit/linux/kernel/git/torvalds/linux.git/commit?id=67...
I inserted this one here so the following stuff would cherry-pick ok, I think that was the right thing to do.
Indeed, this gets me graphics on my Cubietruck at least.
Thanks!
Ian.
On Sat, 28 Feb 2015 16:18:16 +0000 Ian Campbell ijc+uboot@hellion.org.uk wrote:
Thanks!
This looks great, thanks. The video output support in Debian is going to be very much appreciated. It looks like I don't really need to do anything other than just installing the U-Boot bootloader by
http://lists.denx.de/pipermail/u-boot/2015-January/202306.html https://github.com/ssvb/sunxi-bootsetup/releases/tag/20141215-sunxi-bootsetu...
And can simply delegate everything else to the Debian installer :-)
Just one suggestion. It would be really nice if the Debian installer could present itself on all the available consoles, so that the user can use any of them for providing input to the installer.
Otherwise there will be a need to provide separate SD card images for the HDMI console (for the Raspberry Pi wannable competitors), the UART serial console (A10/A20 development boards without HDMI) and the USB OTG serial gadget console (for the tablets without HDMI). Instead of just having only a single SD card image to handle everything automatically.
Oh, and one more suggestion. The SD card partitioning could be also improved in order to make it more user friendly. Right now the user may be confused by the Debian installer regarding what to do with the existing partition on the SD card (yes, it can be safely erased since the installer is running from RAM and does not rely on the data from that partition anymore).
There is some reason why d-i doesn't do this by default. I think it's to do with bricking or otherwise interfering with devices attached to serial ports e.g I think Braille terminals were mentioned, but I suppose any random device might not like getting random strings of characters.
I've backported DT the /chosen/stdout-path support to the kernel a while ago and I thought together with Hans' u-boot patches to populate this field with the right thing then console selection would Just Work(tm).
At least for HDMI vs. UART since I'm not quite sure how the OTG gadget console is presented to Linux and whether it falls into this stuff correctly.
I leave this one to Karsten who looks after the SD card images.
Ian.
On Tue, 03 Mar 2015 08:17:56 +0000 Ian Campbell ijc+uboot@hellion.org.uk wrote:
There could be perhaps a fake kernel cmdline option to specify the exact list of consoles to be used by the Debian installer?
I need to check this new feature myself, especially whether it can do user input handling.
It should be seen as just one more /dev/tty* entry (maybe USB or ACM).
My original plan from
was to make the bootable SD card just drop into the FEL mode in the case if an A13/A23 SoC is detected or if there is no HDMI monitor connected. Then a custom application running on a desktop PC could upload a custom SPL for the only purpose of identifying the DRAM size and bus width. Then present a choice of the possibly matching devices to the user, boot the system via FEL, run hardware reliability tests and move on to preparing the rootfs.
But with the Debian installer, this becomes somewhat more difficult. Because we need a way of handling user input during the installation (for the language selection, time zone, and other things).
However with the new USB OTG code from Hans hopefully coming into the Linux kernel, we can have everything much easier and more unified :-) Basically, the serial port over USB should work fine even in Windows (at least it works for the Arduino people):
http://arduino.cc/en/Guide/Windows
And because the BROM is able to use USB OTG for the FEL mode on all sunxi devices, the serial console over USB should also work in a generic image without any special device dependent configuration.
I just mean that the Debian installer could be a little bit more aware of the target platform and guide the user appropriately without leading to any surprises.
On 4 March 2015 at 16:17, Siarhei Siamashka siarhei.siamashka@gmail.com wrote:
For things selectable from a menu it might be possible to use the volume and power keys as the Android recovery does.
Driver for the power key is already in u-boot. It's just not hooked up to provide input.
I pretty much use only the OTG port when I boot GNU/Linux on a tablet. yes, I can get display output but any input has to come over OTG so I use ethernet gadget and ssh.
That also happens to cover downloading stuff in case the WiFi chipset is not supported. I have yet to see an Allwinner tablet with supported touchscreen.
Thanks
Michal
Yes it was, sorry for overlooking that one.
Cool.
Regards,
Hans
Hello,
This is a reply to an old thread http://lists.denx.de/pipermail/u-boot/2015-February/205761.html
Just to make it clear. I'm still not in favour of pushing potentially reliability degrading changes to any repository, where they can be picked up by unsuspecting users. And I'm going to be strict about it, so no compromise is possible. Sorry about this.
The users must be well aware of what they are trying, which tests to run and what kind of feedback is expected from them. Otherwise very few will notice anything even if they get unreliable DRAM setup. A good example is the unstable "1008MHz, 1.4V" CPU voltage/frequency configuration on the A10-Lime board. Only a small fraction of boards was affected, and the symptoms were not very obvious (it is not like the board fails to boot). And the users had to unnecessarily play the "guinea pig" role for a very long time.
As I said, the best possible scenario would be a participation of the board manufacturers (OLIMEX, CubieTech, LeMaker, ...). So that we could collect sufficient statistics from multiple board samples (preferably from different batches) and check whether we can select the settings, which work fine on all of them. But if there is no interested board manufacturer, then the only option is to ask users for help. Unfortunately the users are not always cooperative and disciplined. So it becomes a real hassle in practice.
We already got some interesting results though. For example, Adam Sampson tried to follow the guide from the linux-sunxi wiki and run my DRAM settings bruteforcing scripts on two pcDuino3 Nano boards. He also managed to reach 648MHz DRAM clock speed (though increasing MBUS to anything higher than 300MHz resulted in stability problems). It's surely good that we can potentially get into the 600MHz DRAM clock speed range on one more board model in addition to Cubietruck and A13-OLinuXino-Micro. But the most interesting part is that he had the results updated in real time on a web server as the scripts were progressing (now this link contains the final report): http://stuff.offog.org/tpr3.html
The Adam's work also demonstrated that the current scripts do not support efficient handling of multiple boards at one. The html report is a bit messy when there is more than one board. I could try to introduce some improvements in this area. And inspired by Adam's web server usage for real-time progress tracking, in fact it may be beneficial to move from the current NFS based setup to a server in the Internet, which could show statistics in realtime, implement a simple communication protocol and coordinate the DRAM settings bruteforcing process by issuing commands to the connected "slave" devices. Anyone who is interested in participating, would only need to use a special bootable SD card and just let the device out in the Internet...
However now I'm really disappointed in the whole idea of relying on anyone else, because this proved to be really inefficient. So I have bought 5 pcDuino V2 boards myself from http://www.exp-tech.de/pcduino-v2-linux-android-arduino-dev-board They are currently available at a discounted price 22.5 euro, which seemed to be a reasonably good deal for me :-)
I'm just going to take care of tuning the DRAM settings for pcDuino V2. But I'm not setting any deadline and will do it as time permits. And then we can see what happens. After I'm done experimenting with the DRAM settings, I will probably donate extra boards to other people.
And we still do have preliminary DRAM settings for Cubietruck, which had been tested on my Cubietruck board: http://linux-sunxi.org/User:Ssvb/Cubietruck_DRAM_Calibration But Cubietruck is relatively expensive and I can't afford to buy many boards. I only initially selected Cubietruck because this was the first sunxi board added to the mainline U-Boot. Also both Hans de Goede and Ian Campbell own Cubietruck boards, so there was a hope that they could help by running some simple quick tests. But as we can see, no progress can be realistically made on the Cubietruck front, so the only choice is to focus on pcDuino V2 for now.
Again, I'm not suggesting to use ~600MHz DRAM clock speed settings by default. They are just good for exploring the limits of hardware capabilities and demonstrate that the ZQ calibration and carefully selected delay settings improve reliability if done right. What is a reasonable default DRAM clock speed is yet to be decided though.
PS. Raspberry Pi supports DRAM overclocking up to 600MHz as an option, so it is not something really extraordinary.
How is it really different from my announcement of the Cubietruck test branch and the request to try it?
All the DRAM chips appear to be at least DDR3-1333 in practice. There are also DRAM chip compatibility lists from Allwinner available on the Internet. We have not seen any exception from this pattern so far. And newer devices tend to use DDR3-1600 chips.
Moreover, reading the markings would not help anyone. Not every person would want to open their device. And not every person would be able to read and correctly interpret the markings, no matter how good is the documentation. Also unlike robots, humans tend to make silly mistakes occasionally :-)
It is much better to just run a quick DRAM reliability test as a part of the Linux distribution installation procedure [1]. Finding good DRAM settings is a difficult and slow process. But verifying them is relatively simple and fast (while also ensuring some safety headroom). In a way, it's very similar to passwords bruteforcing. Bruteforcing a password is difficult, slow and needs special tools. However it is trivially simple to verify whether a password is good.
[1] http://lists.denx.de/pipermail/u-boot/2015-January/202306.html
Hans de Goede
Ian Campbell
Michal Suchanek
Siarhei Siamashka
