[U-Boot] [PATCH] Makefile: fix broken pipe error for lcd4_lwmon5 board
Before this commit, a broken pipe error sometimes happened when building lcd4_lwmon5 board with Buildman.
This commit re-writes build rules of u-boot.spr and u-boot-img-spl-at-end.bin more simply without using a pipe.
Besides fixing a broken pipe error, this commit gives us other advantages:
- Do not generate intermidiate files, spl/u-boot-spl.img and spl/u-boot-spl-pad.img for creating u-boot.spr
- Do not generate an intermidiate file, u-boot-pad.img for creating u-boot-img-spl-at-end.bin
Such intermidiate files were not deleted by "make clean" or "make mrpropr". Nor u-boot-pad.img was ignored by git.
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com ---
Hello Simon.
I noticed a broken pipe error when I was using Buildman. The error happens here:
$(obj)u-boot-img-spl-at-end.bin: $(obj)spl/u-boot-spl.bin $(obj)u-boot.img tr "\000" "\377" < /dev/zero | dd ibs=1 count=$(CONFIG_UBOOT_PAD_TO) \ of=$(obj)u-boot-pad.img 2>/dev/null
I cannot understand why this error happens on Buildman. (I have never seen it on MAKEALL script.) Does the same error happen on your machine too? Do you have any idea why this error happen?
What I did is as follows:
$ git checkout master
$ git describe v2014.01-rc2
$ git checkout -b cosmetic
Add many cosmetic commits. Do not change any source files. (For example, changing README files) I think about 20 commits are enough.
$ git branch --set-upstream-to=master
$ tool/buildman/buildman -b cosmetic lcd4_lwmon5 No section: 'make-flags' Building 21 commits for 1 boards (1 thread, 8 jobs per thread) Cloning repo for thread 0 14 7 0 /21 lcd4_lwmon5
$ tools/buildman/buildman -se -b cosmetic No section: 'make-flags' Summary of 21 commits for 1194 boards (8 threads, 1 job per thread) 01: Prepare v2014.01-rc2 powerpc: + lcd4_lwmon5 +tr: write error: Broken pipe +tr: write error 02: cosmetic1 powerpc: lcd4_lwmon5 -tr: write error: Broken pipe -tr: write error 03: cosmetic2 04: cosmetic3 05: cosmetic4 06: cosmetic5 07: cosmetic6 08: cosmetic7 09: cosmetic8 10: cosmetic9 11: cosmetic10 12: cosmetic11 13: cosmetic12 14: cosmetic13 15: cosmetic14 16: cosmetic15 powerpc: + lcd4_lwmon5 +tr: write error: Broken pipe +tr: write error 17: cosmetic16 18: cosmetic17 19: cosmetic18 20: cosmetic19 21: cosmetic20
Here, a broken pipe error occurred at 01 and fixed at 02. It happend again at 16.
But the result changes every time. The error happens randomly.
Makefile | 19 ++++++++----------- 1 file changed, 8 insertions(+), 11 deletions(-)
diff --git a/Makefile b/Makefile index f03d116..de5969c 100644 --- a/Makefile +++ b/Makefile @@ -471,12 +471,10 @@ $(obj)u-boot.sb: $(obj)u-boot.bin $(obj)spl/u-boot-spl.bin $(obj)u-boot.spr: $(obj)u-boot.img $(obj)spl/u-boot-spl.bin $(obj)tools/mkimage -A $(ARCH) -T firmware -C none \ -a $(CONFIG_SPL_TEXT_BASE) -e $(CONFIG_SPL_TEXT_BASE) -n XLOADER \ - -d $(obj)spl/u-boot-spl.bin $(obj)spl/u-boot-spl.img - tr "\000" "\377" < /dev/zero | dd ibs=1 count=$(CONFIG_SPL_PAD_TO) \ - of=$(obj)spl/u-boot-spl-pad.img 2>/dev/null - dd if=$(obj)spl/u-boot-spl.img of=$(obj)spl/u-boot-spl-pad.img \ - conv=notrunc 2>/dev/null - cat $(obj)spl/u-boot-spl-pad.img $(obj)u-boot.img > $@ + -d $(obj)spl/u-boot-spl.bin $@ + $(OBJCOPY) -I binary -O binary \ + --pad-to=$(CONFIG_SPL_PAD_TO) --gap-fill=0xff $@ + cat $(obj)u-boot.img >> $@
ifneq ($(CONFIG_TEGRA),) $(obj)u-boot-nodtb-tegra.bin: $(obj)spl/u-boot-spl.bin $(obj)u-boot.bin @@ -499,11 +497,10 @@ $(obj)u-boot-img.bin: $(obj)spl/u-boot-spl.bin $(obj)u-boot.img # at the start padded up to the start of the SPL image. And then concat # the SPL image to the end. $(obj)u-boot-img-spl-at-end.bin: $(obj)spl/u-boot-spl.bin $(obj)u-boot.img - tr "\000" "\377" < /dev/zero | dd ibs=1 count=$(CONFIG_UBOOT_PAD_TO) \ - of=$(obj)u-boot-pad.img 2>/dev/null - dd if=$(obj)u-boot.img of=$(obj)u-boot-pad.img \ - conv=notrunc 2>/dev/null - cat $(obj)u-boot-pad.img $(obj)spl/u-boot-spl.bin > $@ + cp $(obj)u-boot.img $@ + $(OBJCOPY) -I binary -O binary --pad-to=$(CONFIG_UBOOT_PAD_TO) \ + --gap-fill=0xff $(obj)u-boot.img $@ + cat $(obj)spl/u-boot-spl.bin >> $@
ifeq ($(CONFIG_SANDBOX),y) GEN_UBOOT = \
Hi Masahiro,
This looks like a nice improvement. Thanks!
Acked-by: Stefan Roese sr@denx.de
Thanks, Stefan
Hello Stefan
Thanks for you review. But I found a mistake. I posted v2.
Best Regards Masahiro Yamada
Masahiro Yamada
Stefan Roese
