[U-Boot] [PATCH v2] include: define bool type in the same way as Linux
Before this commit, U-Boot included <stdbool.h> in order to define bool, true and false.
The header <stdbool.h> of gcc generally defines them as macros as follows:
#define bool _Bool #define true 1 #define false 0
But this gave a bad imapct on common/cmd_test.c, which implements "true" and "false" commands:
U_BOOT_CMD( true, CONFIG_SYS_MAXARGS, 1, do_true, "do nothing, successfully", NULL );
In order to work around this problem, common/cmd_test.c defined _STDBOOL_H at the top in order to avoid including <stdbool.h>.
But this caused another problem: build error on Blackfin boards.
arch/blackfin/include/asm/blackfin_local.h uses bool type here: extern bool bfin_os_log_check(void);
This commit changes header files to define bool, true and false in the same way as Linux Kernel does.
This change also resolves the build error of common/cmd_test.c on Blackfin boards.
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com ---
For example, when I try to compile bct-brettl2 board, I got an error like follows at compiling common/cmd_test.c.
bfin-uclinux-gcc -g -Os -ffixed-P3 -fomit-frame-pointer -mno-fdpic -ffunction-sections -fdata-sections -mcpu=bf536-0.3 -D__KERNEL__ -I/home/yamada/u-boot/include -I/home/yamada/u-boot/arch/blackfin/include -fno-builtin -ffreestanding -nostdinc -isystem /opt/gcc-4.6.3-nolibc/bfin-uclinux/bin/../lib/gcc/bfin-uclinux/4.6.3/include -pipe -DCONFIG_BLACKFIN -Wall -Wstrict-prototypes -fno-stack-protector -Wno-format-nonliteral -Wno-format-security -o cmd_test.o cmd_test.c -c In file included from /home/yamada/u-boot/arch/blackfin/include/asm/blackfin.h:13:0, from /home/yamada/u-boot/include/common.h:92, from cmd_test.c:17: /home/yamada/u-boot/arch/blackfin/include/asm/blackfin_local.h:54:1: error: unknown type name 'bool' make[2]: *** [cmd_test.o] Error 1 make[2]: Leaving directory `/home/yamada/u-boot/common' make[1]: *** [common/built-in.o] Error 2 make[1]: Leaving directory `/home/yamada/u-boot' make: *** [bct-brettl2] Error 2
I think this patch will not break the other boards. I did build test for all target boards. I did run-time test only on sandbox. I confirmed that "true" and "false" commonds worked.
Changes in v2: - Change subject and commit log because it turned out the error is __not__ the compiler issue. - Delete the tweak in common/cmd_test.c because we will not include <stdbool.h>
arch/arm/cpu/armv7/mx6/soc.c | 1 - common/cmd_test.c | 9 --------- include/galileo/core.h | 2 +- include/linux/stddef.h | 5 +++++ include/linux/types.h | 3 ++- 5 files changed, 8 insertions(+), 12 deletions(-)
diff --git a/arch/arm/cpu/armv7/mx6/soc.c b/arch/arm/cpu/armv7/mx6/soc.c index a390296..54ef447 100644 --- a/arch/arm/cpu/armv7/mx6/soc.c +++ b/arch/arm/cpu/armv7/mx6/soc.c @@ -15,7 +15,6 @@ #include <asm/arch/sys_proto.h> #include <asm/imx-common/boot_mode.h> #include <asm/imx-common/dma.h> -#include <stdbool.h> #include <asm/arch/mxc_hdmi.h> #include <asm/arch/crm_regs.h>
diff --git a/common/cmd_test.c b/common/cmd_test.c index bacc368..76b62c4 100644 --- a/common/cmd_test.c +++ b/common/cmd_test.c @@ -5,15 +5,6 @@ * SPDX-License-Identifier: GPL-2.0+ */
-/* - * Define _STDBOOL_H here to avoid macro expansion of true and false. - * If the future code requires macro true or false, remove this define - * and undef true and false before U_BOOT_CMD. This define and comment - * shall be removed if change to U_BOOT_CMD is made to take string - * instead of stringifying it. - */ -#define _STDBOOL_H - #include <common.h> #include <command.h>
diff --git a/include/galileo/core.h b/include/galileo/core.h index 95013fa..2d1b2ed 100644 --- a/include/galileo/core.h +++ b/include/galileo/core.h @@ -14,7 +14,7 @@ space). The macros take care of Big/Little endian conversions.
/* includes */ #include "gt64260R.h" -#include <stdbool.h> +#include <linux/types.h>
extern unsigned int INTERNAL_REG_BASE_ADDR;
diff --git a/include/linux/stddef.h b/include/linux/stddef.h index c540f61..5893ec9 100644 --- a/include/linux/stddef.h +++ b/include/linux/stddef.h @@ -12,6 +12,11 @@ #include <linux/types.h> #endif
+enum { + false = 0, + true = 1 +}; + #ifndef __CHECKER__ #undef offsetof #define offsetof(TYPE, MEMBER) ((size_t) &((TYPE *)0)->MEMBER) diff --git a/include/linux/types.h b/include/linux/types.h index 9aebc4e..157e1ae 100644 --- a/include/linux/types.h +++ b/include/linux/types.h @@ -3,7 +3,6 @@
#include <linux/posix_types.h> #include <asm/types.h> -#include <stdbool.h>
#ifndef __KERNEL_STRICT_NAMES
@@ -18,6 +17,8 @@ typedef __kernel_daddr_t daddr_t; typedef __kernel_key_t key_t; typedef __kernel_suseconds_t suseconds_t;
+typedef _Bool bool; + #ifdef __KERNEL__ typedef __kernel_uid32_t uid_t; typedef __kernel_gid32_t gid_t;
Dear Masahiro Yamada,
In message 1384834977-10536-1-git-send-email-yamada.m@jp.panasonic.com you wrote:
I'm not happy with this modification. I feel we should leave the compiler provided implementation as is, and rather fix the root cause of the problem.
See the example patch I jut posted in the other thread - http://article.gmane.org/gmane.comp.boot-loaders.u-boot/174351
Masahiro Yamada
