[U-Boot] [PATCH v2 1/5] sf: Get spi locally from spi_flash
For better code readabilty, get the spi pointer from spi_flash{} locally and use it instead of direct dereferring spi pinter as flash->spi->*
Cc: Bin Meng bmeng.cn@gmail.com Signed-off-by: Jagan Teki jteki@openedev.com --- Changes for v2: - Fixed missing spi declaration for sst_write_*
drivers/mtd/spi/spi_flash.c | 51 ++++++++++++++++++++++++++------------------- 1 file changed, 29 insertions(+), 22 deletions(-)
diff --git a/drivers/mtd/spi/spi_flash.c b/drivers/mtd/spi/spi_flash.c index 7ffa136..30a381b 100644 --- a/drivers/mtd/spi/spi_flash.c +++ b/drivers/mtd/spi/spi_flash.c @@ -177,13 +177,15 @@ bank_end: #ifdef CONFIG_SF_DUAL_FLASH static void spi_flash_dual(struct spi_flash *flash, u32 *addr) { + struct spi_slave *spi = flash->spi; + switch (flash->dual_flash) { case SF_DUAL_STACKED_FLASH: if (*addr >= (flash->size >> 1)) { *addr -= flash->size >> 1; - flash->spi->flags |= SPI_XFER_U_PAGE; + spi->flags |= SPI_XFER_U_PAGE; } else { - flash->spi->flags &= ~SPI_XFER_U_PAGE; + spi->flags &= ~SPI_XFER_U_PAGE; } break; case SF_DUAL_PARALLEL_FLASH: @@ -268,7 +270,7 @@ int spi_flash_write_common(struct spi_flash *flash, const u8 *cmd, if (buf == NULL) timeout = SPI_FLASH_PAGE_ERASE_TIMEOUT;
- ret = spi_claim_bus(flash->spi); + ret = spi_claim_bus(spi); if (ret) { debug("SF: unable to claim SPI bus\n"); return ret; @@ -353,6 +355,7 @@ int spi_flash_cmd_erase_ops(struct spi_flash *flash, u32 offset, size_t len) int spi_flash_cmd_write_ops(struct spi_flash *flash, u32 offset, size_t len, const void *buf) { + struct spi_slave *spi = flash->spi; unsigned long byte_addr, page_size; u32 write_addr; size_t chunk_len, actual; @@ -385,9 +388,9 @@ int spi_flash_cmd_write_ops(struct spi_flash *flash, u32 offset, byte_addr = offset % page_size; chunk_len = min(len - actual, (size_t)(page_size - byte_addr));
- if (flash->spi->max_write_size) + if (spi->max_write_size) chunk_len = min(chunk_len, - (size_t)flash->spi->max_write_size); + (size_t)spi->max_write_size);
spi_flash_addr(write_addr, cmd);
@@ -413,7 +416,7 @@ int spi_flash_read_common(struct spi_flash *flash, const u8 *cmd, struct spi_slave *spi = flash->spi; int ret;
- ret = spi_claim_bus(flash->spi); + ret = spi_claim_bus(spi); if (ret) { debug("SF: unable to claim SPI bus\n"); return ret; @@ -438,6 +441,7 @@ void __weak spi_flash_copy_mmap(void *data, void *offset, size_t len) int spi_flash_cmd_read_ops(struct spi_flash *flash, u32 offset, size_t len, void *data) { + struct spi_slave *spi = flash->spi; u8 *cmd, cmdsz; u32 remain_len, read_len, read_addr; int bank_sel = 0; @@ -445,15 +449,15 @@ int spi_flash_cmd_read_ops(struct spi_flash *flash, u32 offset,
/* Handle memory-mapped SPI */ if (flash->memory_map) { - ret = spi_claim_bus(flash->spi); + ret = spi_claim_bus(spi); if (ret) { debug("SF: unable to claim SPI bus\n"); return ret; } - spi_xfer(flash->spi, 0, NULL, NULL, SPI_XFER_MMAP); + spi_xfer(spi, 0, NULL, NULL, SPI_XFER_MMAP); spi_flash_copy_mmap(data, flash->memory_map + offset, len); - spi_xfer(flash->spi, 0, NULL, NULL, SPI_XFER_MMAP_END); - spi_release_bus(flash->spi); + spi_xfer(spi, 0, NULL, NULL, SPI_XFER_MMAP_END); + spi_release_bus(spi); return 0; }
@@ -505,6 +509,7 @@ int spi_flash_cmd_read_ops(struct spi_flash *flash, u32 offset, #ifdef CONFIG_SPI_FLASH_SST static int sst_byte_write(struct spi_flash *flash, u32 offset, const void *buf) { + struct spi_slave *spi = flash->spi; int ret; u8 cmd[4] = { CMD_SST_BP, @@ -514,13 +519,13 @@ static int sst_byte_write(struct spi_flash *flash, u32 offset, const void *buf) };
debug("BP[%02x]: 0x%p => cmd = { 0x%02x 0x%06x }\n", - spi_w8r8(flash->spi, CMD_READ_STATUS), buf, cmd[0], offset); + spi_w8r8(spi, CMD_READ_STATUS), buf, cmd[0], offset);
ret = spi_flash_cmd_write_enable(flash); if (ret) return ret;
- ret = spi_flash_cmd_write(flash->spi, cmd, sizeof(cmd), buf, 1); + ret = spi_flash_cmd_write(spi, cmd, sizeof(cmd), buf, 1); if (ret) return ret;
@@ -530,11 +535,12 @@ static int sst_byte_write(struct spi_flash *flash, u32 offset, const void *buf) int sst_write_wp(struct spi_flash *flash, u32 offset, size_t len, const void *buf) { + struct spi_slave *spi = flash->spi; size_t actual, cmd_len; int ret; u8 cmd[4];
- ret = spi_claim_bus(flash->spi); + ret = spi_claim_bus(spi); if (ret) { debug("SF: Unable to claim SPI bus\n"); return ret; @@ -561,10 +567,10 @@ int sst_write_wp(struct spi_flash *flash, u32 offset, size_t len,
for (; actual < len - 1; actual += 2) { debug("WP[%02x]: 0x%p => cmd = { 0x%02x 0x%06x }\n", - spi_w8r8(flash->spi, CMD_READ_STATUS), buf + actual, + spi_w8r8(spi, CMD_READ_STATUS), buf + actual, cmd[0], offset);
- ret = spi_flash_cmd_write(flash->spi, cmd, cmd_len, + ret = spi_flash_cmd_write(spi, cmd, cmd_len, buf + actual, 2); if (ret) { debug("SF: sst word program failed\n"); @@ -590,17 +596,18 @@ int sst_write_wp(struct spi_flash *flash, u32 offset, size_t len, debug("SF: sst: program %s %zu bytes @ 0x%zx\n", ret ? "failure" : "success", len, offset - actual);
- spi_release_bus(flash->spi); + spi_release_bus(spi); return ret; }
int sst_write_bp(struct spi_flash *flash, u32 offset, size_t len, const void *buf) { + struct spi_slave *spi = flash->spi; size_t actual; int ret;
- ret = spi_claim_bus(flash->spi); + ret = spi_claim_bus(spi); if (ret) { debug("SF: Unable to claim SPI bus\n"); return ret; @@ -621,7 +628,7 @@ int sst_write_bp(struct spi_flash *flash, u32 offset, size_t len, debug("SF: sst: program %s %zu bytes @ 0x%zx\n", ret ? "failure" : "success", len, offset - actual);
- spi_release_bus(flash->spi); + spi_release_bus(spi); return ret; } #endif @@ -950,7 +957,7 @@ int spi_flash_scan(struct spi_flash *flash) /* Assign spi data */ flash->name = params->name; flash->memory_map = spi->memory_map; - flash->dual_flash = flash->spi->option; + flash->dual_flash = spi->option;
/* Assign spi flash flags */ if (params->flags & SST_WR) @@ -961,7 +968,7 @@ int spi_flash_scan(struct spi_flash *flash) flash->write = spi_flash_cmd_write_ops; #if defined(CONFIG_SPI_FLASH_SST) if (flash->flags & SNOR_F_SST_WR) { - if (flash->spi->op_mode_tx & SPI_OPM_TX_BP) + if (spi->op_mode_tx & SPI_OPM_TX_BP) flash->write = sst_write_bp; else flash->write = sst_write_wp; @@ -1025,7 +1032,7 @@ int spi_flash_scan(struct spi_flash *flash) flash->sector_size = flash->erase_size;
/* Look for the fastest read cmd */ - cmd = fls(params->e_rd_cmd & flash->spi->op_mode_rx); + cmd = fls(params->e_rd_cmd & spi->op_mode_rx); if (cmd) { cmd = spi_read_cmds_array[cmd - 1]; flash->read_cmd = cmd; @@ -1035,7 +1042,7 @@ int spi_flash_scan(struct spi_flash *flash) }
/* Not require to look for fastest only two write cmds yet */ - if (params->flags & WR_QPP && flash->spi->op_mode_tx & SPI_OPM_TX_QPP) + if (params->flags & WR_QPP && spi->op_mode_tx & SPI_OPM_TX_QPP) flash->write_cmd = CMD_QUAD_PAGE_PROGRAM; else /* Go for default supported write cmd */
Couldn't find the exact reason to define 'mode' for dm, probably it is not using in non-dm drivers but it need to visible both dm and non-dm as mode data is getting dereferred in spi flash core ie common to both.
Cc: Bin Meng bmeng.cn@gmail.com Cc: Simon Glass sjg@chromium.org Signed-off-by: Jagan Teki jteki@openedev.com --- Changes for v2: - newly added
include/spi.h | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/include/spi.h b/include/spi.h index b4d2723..713bab9 100644 --- a/include/spi.h +++ b/include/spi.h @@ -99,13 +99,13 @@ struct dm_spi_slave_platdata { * * @dev: SPI slave device * @max_hz: Maximum speed for this slave - * @mode: SPI mode to use for this slave (see SPI mode flags) * @speed: Current bus speed. This is 0 until the bus is first * claimed. * @bus: ID of the bus that the slave is attached to. For * driver model this is the sequence number of the SPI * bus (bus->seq) so does not need to be stored * @cs: ID of the chip select connected to the slave. + * @mode: SPI mode to use for this slave (see SPI mode flags) * @op_mode_rx: SPI RX operation mode. * @op_mode_tx: SPI TX operation mode. * @wordlen: Size of SPI word in number of bits @@ -120,11 +120,11 @@ struct spi_slave { struct udevice *dev; /* struct spi_slave is dev->parentdata */ uint max_hz; uint speed; - uint mode; #else unsigned int bus; unsigned int cs; #endif + u8 mode; u8 op_mode_rx; u8 op_mode_tx; unsigned int wordlen;
Used mode member from spi_slave{} instead of op_mode_tx.
Cc: Bin Meng bmeng.cn@gmail.com Cc: Simon Glass sjg@chromium.org Signed-off-by: Jagan Teki jteki@openedev.com --- Changes for v2: - none
drivers/mtd/spi/sf_probe.c | 2 +- drivers/mtd/spi/spi_flash.c | 4 ++-- drivers/spi/ich.c | 2 +- include/spi.h | 8 ++------ 4 files changed, 6 insertions(+), 10 deletions(-)
diff --git a/drivers/mtd/spi/sf_probe.c b/drivers/mtd/spi/sf_probe.c index 0cafc29..3519ffd 100644 --- a/drivers/mtd/spi/sf_probe.c +++ b/drivers/mtd/spi/sf_probe.c @@ -128,7 +128,7 @@ static int spi_flash_std_write(struct udevice *dev, u32 offset, size_t len,
#if defined(CONFIG_SPI_FLASH_SST) if (flash->flags & SNOR_F_SST_WR) { - if (flash->spi->op_mode_tx & SPI_OPM_TX_BP) + if (flash->spi->mode & SPI_TX_BP) return sst_write_bp(flash, offset, len, buf); else return sst_write_wp(flash, offset, len, buf); diff --git a/drivers/mtd/spi/spi_flash.c b/drivers/mtd/spi/spi_flash.c index 30a381b..836aad9 100644 --- a/drivers/mtd/spi/spi_flash.c +++ b/drivers/mtd/spi/spi_flash.c @@ -968,7 +968,7 @@ int spi_flash_scan(struct spi_flash *flash) flash->write = spi_flash_cmd_write_ops; #if defined(CONFIG_SPI_FLASH_SST) if (flash->flags & SNOR_F_SST_WR) { - if (spi->op_mode_tx & SPI_OPM_TX_BP) + if (spi->mode & SPI_TX_BP) flash->write = sst_write_bp; else flash->write = sst_write_wp; @@ -1042,7 +1042,7 @@ int spi_flash_scan(struct spi_flash *flash) }
/* Not require to look for fastest only two write cmds yet */ - if (params->flags & WR_QPP && spi->op_mode_tx & SPI_OPM_TX_QPP) + if (params->flags & WR_QPP && spi->mode & SPI_TX_QPP) flash->write_cmd = CMD_QUAD_PAGE_PROGRAM; else /* Go for default supported write cmd */ diff --git a/drivers/spi/ich.c b/drivers/spi/ich.c index f85af9c..64322dd 100644 --- a/drivers/spi/ich.c +++ b/drivers/spi/ich.c @@ -753,7 +753,7 @@ static int ich_spi_child_pre_probe(struct udevice *dev) */ if (plat->ich_version == 7) { slave->op_mode_rx = SPI_OPM_RX_AS; - slave->op_mode_tx = SPI_OPM_TX_BP; + slave->mode = SPI_TX_BP; }
return 0; diff --git a/include/spi.h b/include/spi.h index 713bab9..2b36c5a 100644 --- a/include/spi.h +++ b/include/spi.h @@ -23,6 +23,8 @@ #define SPI_LOOP 0x20 /* loopback mode */ #define SPI_SLAVE 0x40 /* slave mode */ #define SPI_PREAMBLE 0x80 /* Skip preamble bytes */ +#define SPI_TX_BP 0x100 /* transmit with 1 wire byte */ +#define SPI_TX_QPP 0x200 /* transmit with 4 wires */
/* SPI transfer flags */ #define SPI_XFER_BEGIN 0x01 /* Assert CS before transfer */ @@ -32,10 +34,6 @@ #define SPI_XFER_ONCE (SPI_XFER_BEGIN | SPI_XFER_END) #define SPI_XFER_U_PAGE (1 << 5)
-/* SPI TX operation modes */ -#define SPI_OPM_TX_QPP (1 << 0) -#define SPI_OPM_TX_BP (1 << 1) - /* SPI RX operation modes */ #define SPI_OPM_RX_AS (1 << 0) #define SPI_OPM_RX_AF (1 << 1) @@ -107,7 +105,6 @@ struct dm_spi_slave_platdata { * @cs: ID of the chip select connected to the slave. * @mode: SPI mode to use for this slave (see SPI mode flags) * @op_mode_rx: SPI RX operation mode. - * @op_mode_tx: SPI TX operation mode. * @wordlen: Size of SPI word in number of bits * @max_write_size: If non-zero, the maximum number of bytes which can * be written at once, excluding command bytes. @@ -126,7 +123,6 @@ struct spi_slave { #endif u8 mode; u8 op_mode_rx; - u8 op_mode_tx; unsigned int wordlen; unsigned int max_write_size; void *memory_map;
Hi Jagan,
Did you ever build this? spi->mode is declared as a u8, but SPI_TX_BP is 0x100.
slave->mode = SPI_TX_BP; } return 0;
- @cs: ID of the chip select connected to the slave.
- @mode: SPI mode to use for this slave (see SPI mode flags)
- @op_mode_rx: SPI RX operation mode.
- @op_mode_tx: SPI TX operation mode.
- @wordlen: Size of SPI word in number of bits
- @max_write_size: If non-zero, the maximum number of bytes which can
Regards, Bin
On Monday 14 December 2015 01:01 PM, Bin Meng wrote:
Hi Jagan,
Look like I sent the wrong patch, I made mode as uint will send that.
thanks!
And what about RX mode flags? Do you have plan to merge op_mode_rx into spi->mode as well?
Regards, Bin
Hi Bin,
Tried the same but for rx there is simple algo for finding fastest read using fls, so that fls in-deed need rx as separate member.
thanks!
Since SPI_TX_* are spi_slave{} members so use spi protocol notation instead spi flash programming, like
SPI_TX_BP => SPI_TX_BYTE SPI_TX_QPP => SPI_TX_QUAD
drivers/mtd/spi/sf_probe.c | 2 +- drivers/mtd/spi/spi_flash.c | 4 ++-- drivers/spi/ich.c | 2 +- include/spi.h | 4 ++-- 4 files changed, 6 insertions(+), 6 deletions(-)
diff --git a/drivers/mtd/spi/sf_probe.c b/drivers/mtd/spi/sf_probe.c index 3519ffd..daa1d5b 100644 --- a/drivers/mtd/spi/sf_probe.c +++ b/drivers/mtd/spi/sf_probe.c @@ -128,7 +128,7 @@ static int spi_flash_std_write(struct udevice *dev, u32 offset, size_t len,
#if defined(CONFIG_SPI_FLASH_SST) if (flash->flags & SNOR_F_SST_WR) { - if (flash->spi->mode & SPI_TX_BP) + if (flash->spi->mode & SPI_TX_BYTE) return sst_write_bp(flash, offset, len, buf); else return sst_write_wp(flash, offset, len, buf); diff --git a/drivers/mtd/spi/spi_flash.c b/drivers/mtd/spi/spi_flash.c index 836aad9..513d9ad 100644 --- a/drivers/mtd/spi/spi_flash.c +++ b/drivers/mtd/spi/spi_flash.c @@ -968,7 +968,7 @@ int spi_flash_scan(struct spi_flash *flash) flash->write = spi_flash_cmd_write_ops; #if defined(CONFIG_SPI_FLASH_SST) if (flash->flags & SNOR_F_SST_WR) { - if (spi->mode & SPI_TX_BP) + if (spi->mode & SPI_TX_BYTE) flash->write = sst_write_bp; else flash->write = sst_write_wp; @@ -1042,7 +1042,7 @@ int spi_flash_scan(struct spi_flash *flash) }
/* Not require to look for fastest only two write cmds yet */ - if (params->flags & WR_QPP && spi->mode & SPI_TX_QPP) + if (params->flags & WR_QPP && spi->mode & SPI_TX_QUAD) flash->write_cmd = CMD_QUAD_PAGE_PROGRAM; else /* Go for default supported write cmd */ diff --git a/drivers/spi/ich.c b/drivers/spi/ich.c index 64322dd..d11132c 100644 --- a/drivers/spi/ich.c +++ b/drivers/spi/ich.c @@ -753,7 +753,7 @@ static int ich_spi_child_pre_probe(struct udevice *dev) */ if (plat->ich_version == 7) { slave->op_mode_rx = SPI_OPM_RX_AS; - slave->mode = SPI_TX_BP; + slave->mode = SPI_TX_BYTE; }
return 0; diff --git a/include/spi.h b/include/spi.h index 2b36c5a..8ffd9aa 100644 --- a/include/spi.h +++ b/include/spi.h @@ -23,8 +23,8 @@ #define SPI_LOOP 0x20 /* loopback mode */ #define SPI_SLAVE 0x40 /* slave mode */ #define SPI_PREAMBLE 0x80 /* Skip preamble bytes */ -#define SPI_TX_BP 0x100 /* transmit with 1 wire byte */ -#define SPI_TX_QPP 0x200 /* transmit with 4 wires */ +#define SPI_TX_BYTE 0x100 /* transmit with 1 wire byte */ +#define SPI_TX_QUAD 0x200 /* transmit with 4 wires */
Since spi_read_cmds_array is used locally in spi_flash_scan, so move array to locally used function instead of defining global array.
Reviewed-by: Bin Meng bmeng.cn@gmail.com Signed-off-by: Jagan Teki jteki@openedev.com --- Changes for v2: - none
drivers/mtd/spi/spi_flash.c | 20 ++++++++------------ 1 file changed, 8 insertions(+), 12 deletions(-)
diff --git a/drivers/mtd/spi/spi_flash.c b/drivers/mtd/spi/spi_flash.c index 513d9ad..32b2d15 100644 --- a/drivers/mtd/spi/spi_flash.c +++ b/drivers/mtd/spi/spi_flash.c @@ -29,16 +29,6 @@ static void spi_flash_addr(u32 addr, u8 *cmd) cmd[3] = addr >> 0; }
-/* Read commands array */ -static u8 spi_read_cmds_array[] = { - CMD_READ_ARRAY_SLOW, - CMD_READ_ARRAY_FAST, - CMD_READ_DUAL_OUTPUT_FAST, - CMD_READ_DUAL_IO_FAST, - CMD_READ_QUAD_OUTPUT_FAST, - CMD_READ_QUAD_IO_FAST, -}; - static int read_sr(struct spi_flash *flash, u8 *rs) { int ret; @@ -909,9 +899,15 @@ int spi_flash_scan(struct spi_flash *flash) struct spi_slave *spi = flash->spi; const struct spi_flash_params *params; u16 jedec, ext_jedec; - u8 idcode[5]; - u8 cmd; + u8 cmd, idcode[5]; int ret; + static u8 spi_read_cmds_array[] = { + CMD_READ_ARRAY_SLOW, + CMD_READ_ARRAY_FAST, + CMD_READ_DUAL_OUTPUT_FAST, + CMD_READ_DUAL_IO_FAST, + CMD_READ_QUAD_OUTPUT_FAST, + CMD_READ_QUAD_IO_FAST };
/* Read the ID codes */ ret = spi_flash_cmd(spi, CMD_READ_ID, idcode, sizeof(idcode));
Bin Meng
Jagan Teki
