Dear Tom,
The following changes since commit e4dba4ba6f61e8128be0b4200ca2d8cebf62180b:
Merge https://gitlab.denx.de/u-boot/custodians/u-boot-fsl-qoriq (2021-03-06 07:25:04 -0500)
https://source.denx.de/u-boot/custodians/u-boot-efi.git tags/efi-2021-04-rc3-3
for you to fetch changes up to 7d3eff3412886f277c724a9effcbe545c4cdd5b5:
efi_loader: correct uboot_bin_env.its file format (2021-03-07 17:37:26 +0100)
Gitlab CI showed no problems: https://source.denx.de/u-boot/custodians/u-boot-efi/-/pipelines/6683
---------------------------------------------------------------- Pull request for efi-2021-04-rc3-3
New:
* Provide library functions for converting UTF-8 streams either to code page 437 or Unicode code points.
Bug fixes:
* Fix the capsule update unit tests. * Use the terminal size of the video console if it is the primary output.
---------------------------------------------------------------- Heinrich Schuchardt (6): efi_loader: console size of vidconsole efi_loader: move codepage 437 table efi_loader: carve out utf_to_cp() lib/charset: utf8_get() should return error lib/charset: UTF-8 stream conversion efi_loader: correct uboot_bin_env.its file format
include/charset.h | 34 +++++++ lib/charset.c | 96 +++++++++++++++++-- lib/efi_loader/efi_console.c | 2 +- lib/efi_loader/efi_unicode_collation.c | 21 +---- test/py/tests/test_efi_capsule/uboot_bin_env.its | 4 +- test/unicode_ut.c | 114 +++++++++++++++++++++++ 6 files changed, 242 insertions(+), 29 deletions(-)
On Sun, Mar 07, 2021 at 08:07:37PM +0100, Heinrich Schuchardt wrote:
Dear Tom,
