[U-Boot] [PATCH] HACK: arndale: deinit scsi before launching Linux
NOT TO BE APPLIED AS IS
Without this Linux fails to correctly init the phy (or something) and cannot detect the disk.
Even with this we can fail to detect the disk outselves on some fraction of boots, so something else is clearly up too. --- arch/arm/cpu/armv7/exynos/sata.c | 11 +++++++++++ arch/arm/lib/bootm.c | 4 ++++ board/samsung/arndale/arndale.c | 5 +++++ drivers/block/ahci.c | 4 ++++ include/scsi.h | 1 + 5 files changed, 25 insertions(+)
diff --git a/arch/arm/cpu/armv7/exynos/sata.c b/arch/arm/cpu/armv7/exynos/sata.c index 14d42e7..05f1372 100644 --- a/arch/arm/cpu/armv7/exynos/sata.c +++ b/arch/arm/cpu/armv7/exynos/sata.c @@ -310,6 +310,11 @@ static int exynos5_ahci_init(void __iomem *mmio) printf("%s: already calibrated?\n", __func__); }
+ /* Clear phy control enable. Seems to be necessary to + * reinitialise on a warm reboot, at least sometimes. */ + clrbits_le32(EXYNOS5_SATA_PHY_CONTROL, S5P_PMU_SATA_PHY_CONTROL_EN); + udelay(1000); + setbits_le32(EXYNOS5_SATA_PHY_CONTROL, S5P_PMU_SATA_PHY_CONTROL_EN);
__raw_writel(0, phy_ctrl + SATA_RESET); @@ -368,3 +373,9 @@ int exynos5_sata_init(void) } return -ENODEV; } + +int exynos5_sata_deinit(void) +{ + clrbits_le32(EXYNOS5_SATA_PHY_CONTROL, S5P_PMU_SATA_PHY_CONTROL_EN); + return 0; +} diff --git a/arch/arm/lib/bootm.c b/arch/arm/lib/bootm.c index 39fe7a1..9c8d242 100644 --- a/arch/arm/lib/bootm.c +++ b/arch/arm/lib/bootm.c @@ -15,6 +15,7 @@ #include <common.h> #include <command.h> #include <image.h> +#include <scsi.h> #include <u-boot/zlib.h> #include <asm/byteorder.h> #include <libfdt.h> @@ -81,6 +82,9 @@ static void announce_and_cleanup(int fake) #ifdef CONFIG_USB_DEVICE udc_disconnect(); #endif +#ifdef CONFIG_SCSI_AHCI_PLAT + scsi_deinit(); +#endif cleanup_before_linux(); }
diff --git a/board/samsung/arndale/arndale.c b/board/samsung/arndale/arndale.c index 551bfce..43c9694 100644 --- a/board/samsung/arndale/arndale.c +++ b/board/samsung/arndale/arndale.c @@ -36,6 +36,11 @@ int scsi_init(void) printf("ARNDALE SCSI INIT\n"); return exynos5_sata_init(); } + +int scsi_deinit(void) +{ + return exynos5_sata_deinit(); +} #endif
int board_init(void) diff --git a/drivers/block/ahci.c b/drivers/block/ahci.c index a93a8e1..a7e57be 100644 --- a/drivers/block/ahci.c +++ b/drivers/block/ahci.c @@ -959,6 +959,10 @@ void __weak scsi_init(void) { }
+void __weak scsi_deinit(void) +{ +} + #endif
/* diff --git a/include/scsi.h b/include/scsi.h index 73de7b7..06ad192 100644 --- a/include/scsi.h +++ b/include/scsi.h @@ -172,6 +172,7 @@ void scsi_low_level_init(int busdevfunc); * functions residing inside cmd_scsi.c */ void scsi_init(void); +void scsi_deinit(void); void scsi_scan(int mode);
/** @return the number of scsi disks */
On Tue, 2014-10-07 at 14:36 +0100, Ian Campbell wrote:
Please ignore, I ran git send-email from the wrong branch, this isn't ready yet...
Hi Ian,
In any case, if a patch is not to be applied but only commented, please think of adding the [RFC] tag to it.
Amicalement,
Albert ARIBAUD
Ian Campbell
