[U-Boot] [PATCH 4/5][v8] arch: powerpc: Move CONFIG_FSL_ELBC to Kconfig
Enable ELBC from Kconfig.
Signed-off-by: Prabhakar Kushwaha prabhakar.kushwaha@nxp.com --- Changes for v5: Added first time in the patch set Changes for v6: Sending as it is Changes for v7: Fix compiliation error Changes for v8: Fix compiliation for ids8313
arch/powerpc/cpu/mpc85xx/Kconfig | 20 ++++++++++++++++++++ include/configs/MPC8536DS.h | 1 - include/configs/MPC8569MDS.h | 2 -- include/configs/MPC8572DS.h | 1 - include/configs/P1022DS.h | 1 - include/configs/P1023RDB.h | 1 - include/configs/P2041RDB.h | 1 - include/configs/UCP1020.h | 1 - include/configs/controlcenterd.h | 1 - include/configs/corenet_ds.h | 1 - include/configs/cyrus.h | 1 - include/configs/km/kmp204x-common.h | 1 - include/configs/p1_p2_rdb_pc.h | 1 - include/configs/p1_twr.h | 1 - include/configs/xpedite537x.h | 1 - include/configs/xpedite550x.h | 1 - 16 files changed, 20 insertions(+), 16 deletions(-)
diff --git a/arch/powerpc/cpu/mpc85xx/Kconfig b/arch/powerpc/cpu/mpc85xx/Kconfig index 83df733..c06a4db 100644 --- a/arch/powerpc/cpu/mpc85xx/Kconfig +++ b/arch/powerpc/cpu/mpc85xx/Kconfig @@ -455,6 +455,7 @@ config ARCH_MPC8536 select SYS_FSL_SEC_BE select SYS_FSL_SEC_COMPAT_2 select SYS_PPC_E500_USE_DEBUG_TLB + select FSL_ELBC
config ARCH_MPC8540 bool @@ -478,6 +479,7 @@ config ARCH_MPC8544 select SYS_FSL_SEC_BE select SYS_FSL_SEC_COMPAT_2 select SYS_PPC_E500_USE_DEBUG_TLB + select FSL_ELBC
config ARCH_MPC8548 bool @@ -524,6 +526,7 @@ config ARCH_MPC8569 select SYS_FSL_HAS_SEC select SYS_FSL_SEC_BE select SYS_FSL_SEC_COMPAT_2 + select FSL_ELBC
config ARCH_MPC8572 bool @@ -538,6 +541,7 @@ config ARCH_MPC8572 select SYS_FSL_SEC_BE select SYS_FSL_SEC_COMPAT_2 select SYS_PPC_E500_USE_DEBUG_TLB + select FSL_ELBC
config ARCH_P1010 bool @@ -572,6 +576,7 @@ config ARCH_P1011 select SYS_FSL_SEC_BE select SYS_FSL_SEC_COMPAT_2 select SYS_PPC_E500_USE_DEBUG_TLB + select FSL_ELBC
config ARCH_P1020 bool @@ -585,6 +590,7 @@ config ARCH_P1020 select SYS_FSL_SEC_BE select SYS_FSL_SEC_COMPAT_2 select SYS_PPC_E500_USE_DEBUG_TLB + select FSL_ELBC
config ARCH_P1021 bool @@ -598,6 +604,7 @@ config ARCH_P1021 select SYS_FSL_SEC_BE select SYS_FSL_SEC_COMPAT_2 select SYS_PPC_E500_USE_DEBUG_TLB + select FSL_ELBC
config ARCH_P1022 bool @@ -613,6 +620,7 @@ config ARCH_P1022 select SYS_FSL_SEC_BE select SYS_FSL_SEC_COMPAT_2 select SYS_PPC_E500_USE_DEBUG_TLB + select FSL_ELBC
config ARCH_P1023 bool @@ -624,6 +632,7 @@ config ARCH_P1023 select SYS_FSL_HAS_SEC select SYS_FSL_SEC_BE select SYS_FSL_SEC_COMPAT_4 + select FSL_ELBC
config ARCH_P1024 bool @@ -637,6 +646,7 @@ config ARCH_P1024 select SYS_FSL_SEC_BE select SYS_FSL_SEC_COMPAT_2 select SYS_PPC_E500_USE_DEBUG_TLB + select FSL_ELBC
config ARCH_P1025 bool @@ -650,6 +660,7 @@ config ARCH_P1025 select SYS_FSL_SEC_BE select SYS_FSL_SEC_COMPAT_2 select SYS_PPC_E500_USE_DEBUG_TLB + select FSL_ELBC
config ARCH_P2020 bool @@ -664,6 +675,7 @@ config ARCH_P2020 select SYS_FSL_SEC_BE select SYS_FSL_SEC_COMPAT_2 select SYS_PPC_E500_USE_DEBUG_TLB + select FSL_ELBC
config ARCH_P2041 bool @@ -685,6 +697,7 @@ config ARCH_P2041 select SYS_FSL_QORIQ_CHASSIS1 select SYS_FSL_SEC_BE select SYS_FSL_SEC_COMPAT_4 + select FSL_ELBC
config ARCH_P3041 bool @@ -708,6 +721,7 @@ config ARCH_P3041 select SYS_FSL_QORIQ_CHASSIS1 select SYS_FSL_SEC_BE select SYS_FSL_SEC_COMPAT_4 + select FSL_ELBC
config ARCH_P4080 bool @@ -742,6 +756,7 @@ config ARCH_P4080 select SYS_FSL_QORIQ_CHASSIS1 select SYS_FSL_SEC_BE select SYS_FSL_SEC_COMPAT_4 + select FSL_ELBC
config ARCH_P5020 bool @@ -762,6 +777,7 @@ config ARCH_P5020 select SYS_FSL_SEC_BE select SYS_FSL_SEC_COMPAT_4 select SYS_PPC64 + select FSL_ELBC
config ARCH_P5040 bool @@ -782,6 +798,7 @@ config ARCH_P5040 select SYS_FSL_SEC_BE select SYS_FSL_SEC_COMPAT_4 select SYS_PPC64 + select FSL_ELBC
config ARCH_QEMU_E500 bool @@ -1277,6 +1294,9 @@ config SYS_PPC_E500_USE_DEBUG_TLB config FSL_IFC bool
+config FSL_ELBC + bool + config SYS_PPC_E500_DEBUG_TLB int "Temporary TLB entry for external debugger" depends on SYS_PPC_E500_USE_DEBUG_TLB diff --git a/include/configs/MPC8536DS.h b/include/configs/MPC8536DS.h index bc703ce..2267771 100644 --- a/include/configs/MPC8536DS.h +++ b/include/configs/MPC8536DS.h @@ -37,7 +37,6 @@ #define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE /* start of monitor */ #endif
-#define CONFIG_FSL_ELBC 1 /* Has Enhanced localbus controller */ #define CONFIG_PCI1 1 /* Enable PCI controller 1 */ #define CONFIG_PCIE1 1 /* PCIE controller 1 (slot 1) */ #define CONFIG_PCIE2 1 /* PCIE controller 2 (slot 2) */ diff --git a/include/configs/MPC8569MDS.h b/include/configs/MPC8569MDS.h index 2b0d98b..5cec847 100644 --- a/include/configs/MPC8569MDS.h +++ b/include/configs/MPC8569MDS.h @@ -10,8 +10,6 @@ #ifndef __CONFIG_H #define __CONFIG_H
-#define CONFIG_FSL_ELBC 1 /* Has Enhance localbus controller */ - #define CONFIG_SYS_SRIO #define CONFIG_SRIO1 /* SRIO port 1 */
diff --git a/include/configs/MPC8572DS.h b/include/configs/MPC8572DS.h index b933d21..3d4c8a8 100644 --- a/include/configs/MPC8572DS.h +++ b/include/configs/MPC8572DS.h @@ -28,7 +28,6 @@ /* High Level Configuration Options */ #define CONFIG_MP 1 /* support multiple processors */
-#define CONFIG_FSL_ELBC 1 /* Has Enhanced localbus controller */ #define CONFIG_PCIE1 1 /* PCIE controller 1 (slot 1) */ #define CONFIG_PCIE2 1 /* PCIE controller 2 (slot 2) */ #define CONFIG_PCIE3 1 /* PCIE controller 3 (ULI bridge) */ diff --git a/include/configs/P1022DS.h b/include/configs/P1022DS.h index 89eec12..04b0682 100644 --- a/include/configs/P1022DS.h +++ b/include/configs/P1022DS.h @@ -96,7 +96,6 @@ #define CONFIG_RESET_VECTOR_ADDRESS 0xeffffffc #endif
-#define CONFIG_FSL_ELBC /* Has Enhanced localbus controller */ #define CONFIG_PCIE1 /* PCIE controller 1 (slot 1) */ #define CONFIG_PCIE2 /* PCIE controller 2 (slot 2) */ #define CONFIG_PCIE3 /* PCIE controller 3 (ULI bridge) */ diff --git a/include/configs/P1023RDB.h b/include/configs/P1023RDB.h index 1369035..58a3507 100644 --- a/include/configs/P1023RDB.h +++ b/include/configs/P1023RDB.h @@ -25,7 +25,6 @@ /* High Level Configuration Options */ #define CONFIG_MP /* support multiple processors */
-#define CONFIG_FSL_ELBC /* Has Enhanced localbus controller */ #define CONFIG_PCI_INDIRECT_BRIDGE /* indirect PCI bridge support */ #define CONFIG_PCIE1 /* PCIE controller 1 (slot 1) */ #define CONFIG_PCIE2 /* PCIE controller 2 (slot 2) */ diff --git a/include/configs/P2041RDB.h b/include/configs/P2041RDB.h index f58fda1..1c3f43c 100644 --- a/include/configs/P2041RDB.h +++ b/include/configs/P2041RDB.h @@ -41,7 +41,6 @@
#define CONFIG_SYS_FSL_CPC /* Corenet Platform Cache */ #define CONFIG_SYS_NUM_CPC CONFIG_SYS_NUM_DDR_CTLRS -#define CONFIG_FSL_ELBC /* Has Enhanced localbus controller */ #define CONFIG_FSL_CAAM /* Enable SEC/CAAM */ #define CONFIG_PCIE1 /* PCIE controller 1 */ #define CONFIG_PCIE2 /* PCIE controller 2 */ diff --git a/include/configs/UCP1020.h b/include/configs/UCP1020.h index ad1a387..5f34a6d 100644 --- a/include/configs/UCP1020.h +++ b/include/configs/UCP1020.h @@ -14,7 +14,6 @@ #ifndef __CONFIG_H #define __CONFIG_H
-#define CONFIG_FSL_ELBC #define CONFIG_PCIE1 /* PCIE controller 1 (slot 1) */ #define CONFIG_PCIE2 /* PCIE controller 2 (slot 2) */ #define CONFIG_FSL_PCI_INIT /* Use common FSL init code */ diff --git a/include/configs/controlcenterd.h b/include/configs/controlcenterd.h index b1d67b2..666e8c6 100644 --- a/include/configs/controlcenterd.h +++ b/include/configs/controlcenterd.h @@ -137,7 +137,6 @@ /* * Local Bus Definitions */ -#define CONFIG_FSL_ELBC /* Has Enhanced localbus controller */
#define CONFIG_SYS_ELBC_BASE 0xe0000000 #ifdef CONFIG_PHYS_64BIT diff --git a/include/configs/corenet_ds.h b/include/configs/corenet_ds.h index 0f48f38..9b0afd7 100644 --- a/include/configs/corenet_ds.h +++ b/include/configs/corenet_ds.h @@ -59,7 +59,6 @@
#define CONFIG_SYS_FSL_CPC /* Corenet Platform Cache */ #define CONFIG_SYS_NUM_CPC CONFIG_SYS_NUM_DDR_CTLRS -#define CONFIG_FSL_ELBC /* Has Enhanced localbus controller */ #define CONFIG_FSL_CAAM /* Enable SEC/CAAM */ #define CONFIG_PCIE1 /* PCIE controller 1 */ #define CONFIG_PCIE2 /* PCIE controller 2 */ diff --git a/include/configs/cyrus.h b/include/configs/cyrus.h index 18a9156..2069346 100644 --- a/include/configs/cyrus.h +++ b/include/configs/cyrus.h @@ -49,7 +49,6 @@
#define CONFIG_SYS_FSL_CPC /* Corenet Platform Cache */ #define CONFIG_SYS_NUM_CPC CONFIG_SYS_NUM_DDR_CTLRS -#define CONFIG_FSL_ELBC /* Has Enhanced localbus controller */ #define CONFIG_PCIE1 /* PCIE controller 1 */ #define CONFIG_PCIE2 /* PCIE controller 2 */ #define CONFIG_FSL_PCI_INIT /* Use common FSL init code */ diff --git a/include/configs/km/kmp204x-common.h b/include/configs/km/kmp204x-common.h index 8669fcd..efd3b28 100644 --- a/include/configs/km/kmp204x-common.h +++ b/include/configs/km/kmp204x-common.h @@ -35,7 +35,6 @@
#define CONFIG_SYS_FSL_CPC /* Corenet Platform Cache */ #define CONFIG_SYS_NUM_CPC CONFIG_SYS_NUM_DDR_CTLRS -#define CONFIG_FSL_ELBC /* Has Enhanced localbus controller */ #define CONFIG_PCIE1 /* PCIE controller 1 */ #define CONFIG_PCIE3 /* PCIE controller 3 */ #define CONFIG_FSL_PCI_INIT /* Use common FSL init code */ diff --git a/include/configs/p1_p2_rdb_pc.h b/include/configs/p1_p2_rdb_pc.h index 5d70878..e376240 100644 --- a/include/configs/p1_p2_rdb_pc.h +++ b/include/configs/p1_p2_rdb_pc.h @@ -260,7 +260,6 @@
#define CONFIG_MP
-#define CONFIG_FSL_ELBC #define CONFIG_PCIE1 /* PCIE controller 1 (slot 1) */ #define CONFIG_PCIE2 /* PCIE controller 2 (slot 2) */ #define CONFIG_FSL_PCI_INIT /* Use common FSL init code */ diff --git a/include/configs/p1_twr.h b/include/configs/p1_twr.h index 52c544c..1ae7cf8 100644 --- a/include/configs/p1_twr.h +++ b/include/configs/p1_twr.h @@ -40,7 +40,6 @@
#define CONFIG_MP
-#define CONFIG_FSL_ELBC #define CONFIG_PCIE1 /* PCIE controller 1 (slot 1) */ #define CONFIG_PCIE2 /* PCIE controller 2 (slot 2) */ #define CONFIG_FSL_PCI_INIT /* Use common FSL init code */ diff --git a/include/configs/xpedite537x.h b/include/configs/xpedite537x.h index 5d78560..2f133d2 100644 --- a/include/configs/xpedite537x.h +++ b/include/configs/xpedite537x.h @@ -29,7 +29,6 @@ #define CONFIG_PCI_INDIRECT_BRIDGE 1 /* indirect PCI bridge support */ #define CONFIG_SYS_PCI_64BIT 1 /* enable 64-bit PCI resources */ #define CONFIG_FSL_PCIE_RESET 1 /* need PCIe reset errata */ -#define CONFIG_FSL_ELBC 1
/* * Multicore config diff --git a/include/configs/xpedite550x.h b/include/configs/xpedite550x.h index 6346f84..4ac25a6 100644 --- a/include/configs/xpedite550x.h +++ b/include/configs/xpedite550x.h @@ -30,7 +30,6 @@ #define CONFIG_PCI_INDIRECT_BRIDGE 1 /* indirect PCI bridge support */ #define CONFIG_SYS_PCI_64BIT 1 /* enable 64-bit PCI resources */ #define CONFIG_FSL_PCIE_RESET 1 /* need PCIe reset errata */ -#define CONFIG_FSL_ELBC 1
Prabhakar Kushwaha
