[U-Boot-Users] How to make kernel aware of UBoot's bootargs?
I'm working on IBM Ebony board and trying to make linux running on it. I built a linux-2.6.10 (from kernel.org) image but somehow the kernel refused to pick up the bootargs because the kernel command linux shows nothing and ethernet address is all 0xFF. I've researched DULG and this mailing list and got some hints that this is usually caused by the kernel's unawareness of uboot's bd_info.
However adding #include <asm/ppcboot.h> in arch/ppc/platforms/4xx/ibm440gp.h doesn't help solve the problem. I must have missed something else. What am I missing here?
## Current stack ends at 0x07FAA580 => set upper limit to 0x00800000 ## cmdline at 0x007FFC00 ... 0x007FFC51 bd address = 0x07FAAF90 memstart = 0x00000000 memsize = 0x08000000 flashstart = 0xFF800000 flashsize = 0x00480000 flashoffset = 0x00000000 sramstart = 0x00000000 sramsize = 0x00000000 bootflags = 0x00000000 intfreq = 400 MHz busfreq = 133.333 MHz ethaddr = 00:04:AC:E3:1B:BB IP addr = 130.27.85.245 baudrate = 9600 bps No initrd ## Transferring control to Linux (at address 00000000) ... Linux version 2.6.10 (gcc version 3.3.3 (DENX ELDK 3.1 3.3.3-8)) #1 Fr i Feb 11 15:18:50 PST 2005 IBM Ebony port (MontaVista Software, Inc. (source@mvista.com)) Built 1 zonelists Kernel command line: PID hash table entries: 1024 (order: 10, 16384 bytes) <snipped> emac: IBM EMAC Ethernet driver, version 2.0 Maintained by Benjamin Herrenschmidt benh@kernel.crashing.org zmii0: input 0 in SMII mode eth0: IBM emac, MAC ff:ff:ff:ff:ff:ff eth0: Found Generic MII PHY (0x08) zmii0: input 1 in RMII mode eth1: IBM emac, MAC ff:ff:ff:ff:ff:ff eth1: Found Generic MII PHY (0x09) <snipped>
Thanks, -Shawn.
Shawn Jin
