[U-Boot] [PATCH 1/3] spl: Rename SPL_LEGACY_IMAGE_SUPPORT to SPL_IMAGE_FORMAT_LEGACY
We have a symbol named CONFIG_IMAGE_FORMAT_LEGACY already for non-SPL, so rename the SPL symbol so we can make more use of those checks.
Signed-off-by: Tom Rini trini@konsulko.com --- common/spl/Kconfig | 6 +++--- common/spl/spl.c | 2 +- configs/lion-rk3368_defconfig | 2 +- configs/puma-rk3399_defconfig | 2 +- 4 files changed, 6 insertions(+), 6 deletions(-)
diff --git a/common/spl/Kconfig b/common/spl/Kconfig index 206c24076da8..aef7c5b01465 100644 --- a/common/spl/Kconfig +++ b/common/spl/Kconfig @@ -92,7 +92,7 @@ config SPL_RAW_IMAGE_SUPPORT is y. If this is not set, SPL will move on to other available boot media to find a suitable image.
-config SPL_LEGACY_IMAGE_SUPPORT +config SPL_IMAGE_FORMAT_LEGACY bool "Support SPL loading and booting of Legacy images" default y if !TI_SECURE_DEVICE help @@ -102,7 +102,7 @@ config SPL_LEGACY_IMAGE_SUPPORT
config SPL_LEGACY_IMAGE_CRC_CHECK bool "Check CRC of Legacy images" - depends on SPL_LEGACY_IMAGE_SUPPORT + depends on SPL_IMAGE_FORMAT_LEGACY select SPL_CRC32_SUPPORT help Enable this to check the CRC of Legacy images. While this increases @@ -246,7 +246,7 @@ config SYS_MMCSD_RAW_MODE_U_BOOT_PARTITION_TYPE
config SPL_CRC32_SUPPORT bool "Support CRC32" - default y if SPL_LEGACY_IMAGE_SUPPORT + default y if SPL_IMAGE_FORMAT_LEGACY help Enable this to support CRC32 in uImages or FIT images within SPL. This is a 32-bit checksum value that can be used to verify images. diff --git a/common/spl/spl.c b/common/spl/spl.c index 88d4b8a9bf15..b6532a5234bd 100644 --- a/common/spl/spl.c +++ b/common/spl/spl.c @@ -236,7 +236,7 @@ int spl_parse_image_header(struct spl_image_info *spl_image, return ret; #endif if (image_get_magic(header) == IH_MAGIC) { -#ifdef CONFIG_SPL_LEGACY_IMAGE_SUPPORT +#ifdef CONFIG_SPL_IMAGE_FORMAT_LEGACY u32 header_size = sizeof(struct image_header);
#ifdef CONFIG_SPL_LEGACY_IMAGE_CRC_CHECK diff --git a/configs/lion-rk3368_defconfig b/configs/lion-rk3368_defconfig index d6dd0e5106ea..03409a38a4e9 100644 --- a/configs/lion-rk3368_defconfig +++ b/configs/lion-rk3368_defconfig @@ -33,7 +33,7 @@ CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_ARCH_EARLY_INIT_R=y CONFIG_SPL_BOOTROM_SUPPORT=y # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set -# CONFIG_SPL_LEGACY_IMAGE_SUPPORT is not set +# CONFIG_SPL_IMAGE_FORMAT_LEGACY is not set CONFIG_TPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_STACK_R=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x200 diff --git a/configs/puma-rk3399_defconfig b/configs/puma-rk3399_defconfig index 3fcff2580a19..0ab2a5d2b085 100644 --- a/configs/puma-rk3399_defconfig +++ b/configs/puma-rk3399_defconfig @@ -24,7 +24,7 @@ CONFIG_MISC_INIT_R=y CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_SPL_BOARD_INIT=y # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set -# CONFIG_SPL_LEGACY_IMAGE_SUPPORT is not set +# CONFIG_SPL_IMAGE_FORMAT_LEGACY is not set CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x4000 CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x200
So that we can switch legacy image format code off in SPL, change the places we check this outside of command code to use CONFIG_IS_ENABLED instead of a regular check.
Signed-off-by: Tom Rini trini@konsulko.com --- arch/arm/mach-imx/hab.c | 2 +- common/bootm.c | 8 ++++---- common/image-fdt.c | 6 +++--- common/image.c | 10 +++++----- include/image.h | 2 +- 5 files changed, 14 insertions(+), 14 deletions(-)
diff --git a/arch/arm/mach-imx/hab.c b/arch/arm/mach-imx/hab.c index d42a15e8772a..49b06b466269 100644 --- a/arch/arm/mach-imx/hab.c +++ b/arch/arm/mach-imx/hab.c @@ -310,7 +310,7 @@ static ulong get_image_ivt_offset(ulong img_addr)
buf = map_sysmem(img_addr, 0); switch (genimg_get_format(buf)) { -#if defined(CONFIG_IMAGE_FORMAT_LEGACY) +#if CONFIG_IS_ENABLED(IMAGE_FORMAT_LEGACY) case IMAGE_FORMAT_LEGACY: return (image_get_image_size((image_header_t *)img_addr) + 0x1000 - 1) & ~(0x1000 - 1); diff --git a/common/bootm.c b/common/bootm.c index 3adbceaa38e3..26fb47c9fbe0 100644 --- a/common/bootm.c +++ b/common/bootm.c @@ -98,7 +98,7 @@ static int bootm_find_os(cmd_tbl_t *cmdtp, int flag, int argc,
/* get image parameters */ switch (genimg_get_format(os_hdr)) { -#if defined(CONFIG_IMAGE_FORMAT_LEGACY) +#if CONFIG_IS_ENABLED(IMAGE_FORMAT_LEGACY) case IMAGE_FORMAT_LEGACY: images.os.type = image_get_type(os_hdr); images.os.comp = image_get_comp(os_hdr); @@ -743,7 +743,7 @@ err: return ret; }
-#if defined(CONFIG_IMAGE_FORMAT_LEGACY) +#if CONFIG_IS_ENABLED(IMAGE_FORMAT_LEGACY) /** * image_get_kernel - verify legacy format kernel image * @img_addr: in RAM address of the legacy format image to be verified @@ -812,7 +812,7 @@ static const void *boot_get_kernel(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[], bootm_headers_t *images, ulong *os_data, ulong *os_len) { -#if defined(CONFIG_IMAGE_FORMAT_LEGACY) +#if CONFIG_IS_ENABLED(IMAGE_FORMAT_LEGACY) image_header_t *hdr; #endif ulong img_addr; @@ -833,7 +833,7 @@ static const void *boot_get_kernel(cmd_tbl_t *cmdtp, int flag, int argc, *os_data = *os_len = 0; buf = map_sysmem(img_addr, 0); switch (genimg_get_format(buf)) { -#if defined(CONFIG_IMAGE_FORMAT_LEGACY) +#if CONFIG_IS_ENABLED(IMAGE_FORMAT_LEGACY) case IMAGE_FORMAT_LEGACY: printf("## Booting kernel from Legacy Image at %08lx ...\n", img_addr); diff --git a/common/image-fdt.c b/common/image-fdt.c index 01186aeac7a4..4178a4a856e3 100644 --- a/common/image-fdt.c +++ b/common/image-fdt.c @@ -33,7 +33,7 @@ static void fdt_error(const char *msg) puts(" - must RESET the board to recover.\n"); }
-#if defined(CONFIG_IMAGE_FORMAT_LEGACY) +#if CONFIG_IS_ENABLED(IMAGE_FORMAT_LEGACY) static const image_header_t *image_get_fdt(ulong fdt_addr) { const image_header_t *fdt_hdr = map_sysmem(fdt_addr, 0); @@ -263,7 +263,7 @@ error: int boot_get_fdt(int flag, int argc, char * const argv[], uint8_t arch, bootm_headers_t *images, char **of_flat_tree, ulong *of_size) { -#if defined(CONFIG_IMAGE_FORMAT_LEGACY) +#if CONFIG_IS_ENABLED(IMAGE_FORMAT_LEGACY) const image_header_t *fdt_hdr; ulong load, load_end; ulong image_start, image_data, image_end; @@ -345,7 +345,7 @@ int boot_get_fdt(int flag, int argc, char * const argv[], uint8_t arch, */ buf = map_sysmem(fdt_addr, 0); switch (genimg_get_format(buf)) { -#if defined(CONFIG_IMAGE_FORMAT_LEGACY) +#if CONFIG_IS_ENABLED(IMAGE_FORMAT_LEGACY) case IMAGE_FORMAT_LEGACY: /* verify fdt_addr points to a valid image header */ printf("## Flattened Device Tree from Legacy Image at %08lx\n", diff --git a/common/image.c b/common/image.c index 4d4248f234fb..120d37e05668 100644 --- a/common/image.c +++ b/common/image.c @@ -38,7 +38,7 @@ extern int do_bdinfo(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]);
DECLARE_GLOBAL_DATA_PTR;
-#if defined(CONFIG_IMAGE_FORMAT_LEGACY) +#if CONFIG_IS_ENABLED(IMAGE_FORMAT_LEGACY) static const image_header_t *image_get_ramdisk(ulong rd_addr, uint8_t arch, int verify); #endif @@ -377,7 +377,7 @@ void image_print_contents(const void *ptr)
#ifndef USE_HOSTCC -#if defined(CONFIG_IMAGE_FORMAT_LEGACY) +#if CONFIG_IS_ENABLED(IMAGE_FORMAT_LEGACY) /** * image_get_ramdisk - get and verify ramdisk image * @rd_addr: ramdisk image start address @@ -867,7 +867,7 @@ ulong genimg_get_kernel_addr(char * const img_addr) */ int genimg_get_format(const void *img_addr) { -#if defined(CONFIG_IMAGE_FORMAT_LEGACY) +#if CONFIG_IS_ENABLED(IMAGE_FORMAT_LEGACY) const image_header_t *hdr;
hdr = (const image_header_t *)img_addr; @@ -933,7 +933,7 @@ int boot_get_ramdisk(int argc, char * const argv[], bootm_headers_t *images, { ulong rd_addr, rd_load; ulong rd_data, rd_len; -#if defined(CONFIG_IMAGE_FORMAT_LEGACY) +#if CONFIG_IS_ENABLED(IMAGE_FORMAT_LEGACY) const image_header_t *rd_hdr; #endif void *buf; @@ -1025,7 +1025,7 @@ int boot_get_ramdisk(int argc, char * const argv[], bootm_headers_t *images, */ buf = map_sysmem(rd_addr, 0); switch (genimg_get_format(buf)) { -#if defined(CONFIG_IMAGE_FORMAT_LEGACY) +#if CONFIG_IS_ENABLED(IMAGE_FORMAT_LEGACY) case IMAGE_FORMAT_LEGACY: printf("## Loading init Ramdisk from Legacy " "Image at %08lx ...\n", rd_addr); diff --git a/include/image.h b/include/image.h index 765ffecee0a7..bcbc4d7835cc 100644 --- a/include/image.h +++ b/include/image.h @@ -561,7 +561,7 @@ int boot_get_setup(bootm_headers_t *images, uint8_t arch, ulong *setup_start, #ifndef USE_HOSTCC /* Image format types, returned by _get_format() routine */ #define IMAGE_FORMAT_INVALID 0x00 -#if defined(CONFIG_IMAGE_FORMAT_LEGACY) +#if CONFIG_IS_ENABLED(IMAGE_FORMAT_LEGACY) #define IMAGE_FORMAT_LEGACY 0x01 /* legacy image_header based format */ #endif #define IMAGE_FORMAT_FIT 0x02 /* new, libfdt based format */
When we have a FIT image being used by SPL by default that means the most common case is that we'll never run into a legacy image. Disable legacy image support by default in that case to reclaim space.
Signed-off-by: Tom Rini trini@konsulko.com --- common/spl/Kconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/common/spl/Kconfig b/common/spl/Kconfig index aef7c5b01465..65d19ebff771 100644 --- a/common/spl/Kconfig +++ b/common/spl/Kconfig @@ -94,7 +94,7 @@ config SPL_RAW_IMAGE_SUPPORT
config SPL_IMAGE_FORMAT_LEGACY bool "Support SPL loading and booting of Legacy images" - default y if !TI_SECURE_DEVICE + default y if !TI_SECURE_DEVICE && !SPL_LOAD_FIT help SPL will support loading and booting Legacy images when this option is y. If this is not set, SPL will move on to other available
