[U-Boot] [PATCH v2 0/8] dm: Various fixes in dm core/cpu/timer
This fixed several issues identified in dm core/cpu/timer codes.
The issues were found during RISC-V cpu/timer driver development for QEMU RISC-V port.
This series is available at u-boot-x86/dm-fixes for testing.
Changes in v2: - rebase on u-boot/master, and fix one build error
Bin Meng (8): dm: cpu: Fix print_cpuinfo() output cpu: mpc83xx: Remove unnecessary characters in the description string dm: util: Add a livetree equivalent API of dm_fdt_pre_reloc() dm: core: Respect drivers with the DM_FLAG_PRE_RELOC flag in lists_bind_fdt() dm: Correct pre_reloc_only parameter description in several APIs' comments dm: core: Mirror the chosen node parse logic in the livetree scanning test: dm: core: Add a test case for driver marked with DM_FLAG_PRE_RELOC flag timer: Sort Kconfig driver entries
arch/sandbox/dts/test.dts | 4 ++ common/board_f.c | 2 +- drivers/core/device.c | 2 +- drivers/core/lists.c | 9 +++- drivers/core/root.c | 20 +++++--- drivers/core/util.c | 25 ++++++++++ drivers/cpu/mpc83xx_cpu.c | 2 +- drivers/serial/serial-uclass.c | 2 +- drivers/timer/Kconfig | 110 ++++++++++++++++++++--------------------- drivers/timer/timer-uclass.c | 2 +- include/dm/device-internal.h | 4 +- include/dm/lists.h | 9 ++-- include/dm/root.h | 17 ++++--- include/dm/util.h | 27 +++++++++- test/dm/bus.c | 2 +- test/dm/test-fdt.c | 29 +++++++++-- 16 files changed, 180 insertions(+), 86 deletions(-)
It was observed that current output of print_cpuinfo() on QEMU x86 targets does not have an ending '\n', neither have a leading 'CPU:' any more. However it used to have these before.
It turns out commit c0434407b595 introduced a unified DM version of print_cpuinfo() that exposed such issue on QEMU x86.
Fixes: c0434407b595 ("board_f: Use static print_cpuinfo if CONFIG_CPU is active") Signed-off-by: Bin Meng bmeng.cn@gmail.com ---
Changes in v2: None
common/board_f.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/common/board_f.c b/common/board_f.c index 213d044..96503ff 100644 --- a/common/board_f.c +++ b/common/board_f.c @@ -187,7 +187,7 @@ static int print_cpuinfo(void) return ret; }
- printf("%s", desc); + printf("CPU: %s\n", desc);
return 0; }
Changes in v2: None
The description string should not contain unnecessary characters, like the ending '\n' or the leading 'CPU:'.
Changes in v2: None
drivers/cpu/mpc83xx_cpu.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/cpu/mpc83xx_cpu.c b/drivers/cpu/mpc83xx_cpu.c index 31717af..7bc86bf 100644 --- a/drivers/cpu/mpc83xx_cpu.c +++ b/drivers/cpu/mpc83xx_cpu.c @@ -262,7 +262,7 @@ static int mpc83xx_cpu_get_desc(struct udevice *dev, char *buf, int size) determine_cpu_data(dev);
snprintf(buf, size, - "CPU: %s, MPC%s%s%s, Rev: %d.%d at %s MHz, CSB: %s MHz\n", + "%s, MPC%s%s%s, Rev: %d.%d at %s MHz, CSB: %s MHz", e300_names[priv->e300_type], cpu_type_names[priv->type], priv->is_e_processor ? "E" : "",
Changes in v2: None
Changes in v2: None
Reviewed-by: Mario Six mario.six@gdsys.cc
This adds a new API dm_ofnode_pre_reloc(), a livetree equivalent API of dm_fdt_pre_reloc().
Changes in v2: None
drivers/core/util.c | 25 +++++++++++++++++++++++++ include/dm/util.h | 27 ++++++++++++++++++++++++++- 2 files changed, 51 insertions(+), 1 deletion(-)
diff --git a/drivers/core/util.c b/drivers/core/util.c index 451d476..27a6848 100644 --- a/drivers/core/util.c +++ b/drivers/core/util.c @@ -4,6 +4,7 @@ */
#include <common.h> +#include <dm/ofnode.h> #include <dm/util.h> #include <linux/libfdt.h> #include <vsprintf.h> @@ -53,3 +54,27 @@ bool dm_fdt_pre_reloc(const void *blob, int offset)
return false; } + +bool dm_ofnode_pre_reloc(ofnode node) +{ + if (ofnode_read_bool(node, "u-boot,dm-pre-reloc")) + return true; + +#ifdef CONFIG_TPL_BUILD + if (ofnode_read_bool(node, "u-boot,dm-tpl")) + return true; +#elif defined(CONFIG_SPL_BUILD) + if (ofnode_read_bool(node, "u-boot,dm-spl")) + return true; +#else + /* + * In regular builds individual spl and tpl handling both + * count as handled pre-relocation for later second init. + */ + if (ofnode_read_bool(node, "u-boot,dm-spl") || + ofnode_read_bool(node, "u-boot,dm-tpl")) + return true; +#endif + + return false; +} diff --git a/include/dm/util.h b/include/dm/util.h index 898822e..9ff6531 100644 --- a/include/dm/util.h +++ b/include/dm/util.h @@ -55,7 +55,7 @@ static inline void dm_dump_devres(void) * There are 3 settings currently in use * - * - u-boot,dm-pre-reloc: legacy and indicates any of TPL or SPL - * Existing platforms only use it to indicate nodes needee in + * Existing platforms only use it to indicate nodes needed in * SPL. Should probably be replaced by u-boot,dm-spl for * existing platforms. * @blob: devicetree @@ -65,4 +65,29 @@ static inline void dm_dump_devres(void) */ bool dm_fdt_pre_reloc(const void *blob, int offset);
+/** + * Check if an of node should be or was bound before relocation. + * + * Devicetree nodes can be marked as needed to be bound + * in the loader stages via special devicetree properties. + * + * Before relocation this function can be used to check if nodes + * are required in either SPL or TPL stages. + * + * After relocation and jumping into the real U-Boot binary + * it is possible to determine if a node was bound in one of + * SPL/TPL stages. + * + * There are 3 settings currently in use + * - + * - u-boot,dm-pre-reloc: legacy and indicates any of TPL or SPL + * Existing platforms only use it to indicate nodes needed in + * SPL. Should probably be replaced by u-boot,dm-spl for + * existing platforms. + * @node: of node + * + * Returns true if node is needed in SPL/TL, false otherwise. + */ +bool dm_ofnode_pre_reloc(ofnode node); + #endif
Changes in v2: None
I wonder if it is possible to delete the old code that doesn't support livetree? This implementation should support both.
- Simon
Hi Simon,
Changes in v2: None
Agreed. But there are two drivers (drivers/clk/at91/pmc.c and drivers/clk/altera/clk-arria10.c) that calls dm_fdt_pre_reloc() at this point. We can clean this up in the future.
Regards, Bin
Currently the comments of several APIs (eg: dm_init_and_scan()) say:
@pre_reloc_only: If true, bind only drivers with the DM_FLAG_PRE_RELOC flag. If false bind all drivers.
The 'Pre-Relocation Support' chapter in doc/driver-model/README.txt documents the same that both device tree properties and driver flag are supported.
However the implementation only checks these special device tree properties without checking the driver flag at all. This updates lists_bind_fdt() to consider both scenarios.
drivers/core/device.c | 2 +- drivers/core/lists.c | 9 ++++++++- drivers/core/root.c | 12 ++++-------- drivers/serial/serial-uclass.c | 2 +- drivers/timer/timer-uclass.c | 2 +- include/dm/lists.h | 5 ++++- 6 files changed, 19 insertions(+), 13 deletions(-)
diff --git a/drivers/core/device.c b/drivers/core/device.c index feed43c..1451689 100644 --- a/drivers/core/device.c +++ b/drivers/core/device.c @@ -815,5 +815,5 @@ int dev_enable_by_path(const char *path) if (ret) return ret;
- return lists_bind_fdt(parent, node, NULL); + return lists_bind_fdt(parent, node, NULL, false); } diff --git a/drivers/core/lists.c b/drivers/core/lists.c index a167726..a1f8284 100644 --- a/drivers/core/lists.c +++ b/drivers/core/lists.c @@ -122,7 +122,8 @@ static int driver_check_compatible(const struct udevice_id *of_match, return -ENOENT; }
-int lists_bind_fdt(struct udevice *parent, ofnode node, struct udevice **devp) +int lists_bind_fdt(struct udevice *parent, ofnode node, struct udevice **devp, + bool pre_reloc_only) { struct driver *driver = ll_entry_start(struct driver, driver); const int n_ents = ll_entry_count(struct driver, driver); @@ -171,6 +172,12 @@ int lists_bind_fdt(struct udevice *parent, ofnode node, struct udevice **devp) if (entry == driver + n_ents) continue;
+ if (pre_reloc_only) { + if (!dm_ofnode_pre_reloc(node) && + !(entry->flags & DM_FLAG_PRE_RELOC)) + return 0; + } + pr_debug(" - found match at '%s'\n", entry->name); ret = device_bind_with_driver_data(parent, entry, name, id->data, node, &dev); diff --git a/drivers/core/root.c b/drivers/core/root.c index 47d10b8..f918ee1 100644 --- a/drivers/core/root.c +++ b/drivers/core/root.c @@ -222,14 +222,12 @@ static int dm_scan_fdt_live(struct udevice *parent, int ret = 0, err;
for (np = node_parent->child; np; np = np->sibling) { - if (pre_reloc_only && - !of_find_property(np, "u-boot,dm-pre-reloc", NULL)) - continue; if (!of_device_is_available(np)) { pr_debug(" - ignoring disabled device\n"); continue; } - err = lists_bind_fdt(parent, np_to_ofnode(np), NULL); + err = lists_bind_fdt(parent, np_to_ofnode(np), NULL, + pre_reloc_only); if (err && !ret) { ret = err; debug("%s: ret=%d\n", np->name, ret); @@ -276,14 +274,12 @@ static int dm_scan_fdt_node(struct udevice *parent, const void *blob, continue; }
- if (pre_reloc_only && - !dm_fdt_pre_reloc(blob, offset)) - continue; if (!fdtdec_get_is_enabled(blob, offset)) { pr_debug(" - ignoring disabled device\n"); continue; } - err = lists_bind_fdt(parent, offset_to_ofnode(offset), NULL); + err = lists_bind_fdt(parent, offset_to_ofnode(offset), NULL, + pre_reloc_only); if (err && !ret) { ret = err; debug("%s: ret=%d\n", fdt_get_name(blob, offset, NULL), diff --git a/drivers/serial/serial-uclass.c b/drivers/serial/serial-uclass.c index ffdcae0..cc11474 100644 --- a/drivers/serial/serial-uclass.c +++ b/drivers/serial/serial-uclass.c @@ -61,7 +61,7 @@ static int serial_check_stdout(const void *blob, struct udevice **devp) * anyway. */ if (node > 0 && !lists_bind_fdt(gd->dm_root, offset_to_ofnode(node), - devp)) { + devp, false)) { if (!device_probe(*devp)) return 0; } diff --git a/drivers/timer/timer-uclass.c b/drivers/timer/timer-uclass.c index fe73f71..12ee6eb 100644 --- a/drivers/timer/timer-uclass.c +++ b/drivers/timer/timer-uclass.c @@ -108,7 +108,7 @@ int notrace dm_timer_init(void) * If the timer is not marked to be bound before * relocation, bind it anyway. */ - if (!lists_bind_fdt(dm_root(), node, &dev)) { + if (!lists_bind_fdt(dm_root(), node, &dev, false)) { ret = device_probe(dev); if (ret) return ret; diff --git a/include/dm/lists.h b/include/dm/lists.h index 13d1516..59094d7 100644 --- a/include/dm/lists.h +++ b/include/dm/lists.h @@ -53,10 +53,13 @@ int lists_bind_drivers(struct udevice *parent, bool pre_reloc_only); * @parent: parent device (root) * @node: device tree node to bind * @devp: if non-NULL, returns a pointer to the bound device + * @pre_reloc_only: If true, bind only nodes with special devicetree properties, + * or drivers with the DM_FLAG_PRE_RELOC flag. If false bind all drivers. * @return 0 if device was bound, -EINVAL if the device tree is invalid, * other -ve value on error */ -int lists_bind_fdt(struct udevice *parent, ofnode node, struct udevice **devp); +int lists_bind_fdt(struct udevice *parent, ofnode node, struct udevice **devp, + bool pre_reloc_only);
/** * device_bind_driver() - bind a device to a driver
Changes in v2:
The pre_reloc_only parameter description currently only mentions drivers with the DM_FLAG_PRE_RELOC flag, but does not mention the special device tree properties. Correct them.
Changes in v2: None
include/dm/device-internal.h | 4 ++-- include/dm/lists.h | 4 ++-- include/dm/root.h | 17 +++++++++-------- 3 files changed, 13 insertions(+), 12 deletions(-)
diff --git a/include/dm/device-internal.h b/include/dm/device-internal.h index 02ac4c7..ee2b24a 100644 --- a/include/dm/device-internal.h +++ b/include/dm/device-internal.h @@ -74,8 +74,8 @@ int device_bind_with_driver_data(struct udevice *parent, * tree. * * @parent: Pointer to device's parent - * @pre_reloc_only: If true, bind the driver only if its DM_INIT_F flag is set. - * If false bind the driver always. + * @pre_reloc_only: If true, bind the driver only if its DM_FLAG_PRE_RELOC flag + * is set. If false bind the driver always. * @info: Name and platdata for this device * @devp: if non-NULL, returns a pointer to the bound device * @return 0 if OK, -ve on error diff --git a/include/dm/lists.h b/include/dm/lists.h index 59094d7..810e244 100644 --- a/include/dm/lists.h +++ b/include/dm/lists.h @@ -39,8 +39,8 @@ struct uclass_driver *lists_uclass_lookup(enum uclass_id id); * each one. The devices will have @parent as their parent. * * @parent: parent device (root) - * @early_only: If true, bind only drivers with the DM_INIT_F flag. If false - * bind all drivers. + * @pre_reloc_only: If true, bind only drivers with the DM_FLAG_PRE_RELOC flag. + * If false bind all drivers. */ int lists_bind_drivers(struct udevice *parent, bool pre_reloc_only);
diff --git a/include/dm/root.h b/include/dm/root.h index 2b9c6da..c8d629b 100644 --- a/include/dm/root.h +++ b/include/dm/root.h @@ -48,8 +48,8 @@ int dm_scan_platdata(bool pre_reloc_only); * the top-level subnodes are examined. * * @blob: Pointer to device tree blob - * @pre_reloc_only: If true, bind only drivers with the DM_FLAG_PRE_RELOC - * flag. If false bind all drivers. + * @pre_reloc_only: If true, bind only nodes with special devicetree properties, + * or drivers with the DM_FLAG_PRE_RELOC flag. If false bind all drivers. * @return 0 if OK, -ve on error */ int dm_scan_fdt(const void *blob, bool pre_reloc_only); @@ -62,8 +62,8 @@ int dm_scan_fdt(const void *blob, bool pre_reloc_only); * of "clocks" node. * * @blob: Pointer to device tree blob - * @pre_reloc_only: If true, bind only drivers with the DM_FLAG_PRE_RELOC - * flag. If false bind all drivers. + * @pre_reloc_only: If true, bind only nodes with special devicetree properties, + * or drivers with the DM_FLAG_PRE_RELOC flag. If false bind all drivers. * @return 0 if OK, -ve on error */ int dm_extended_scan_fdt(const void *blob, bool pre_reloc_only); @@ -76,8 +76,9 @@ int dm_extended_scan_fdt(const void *blob, bool pre_reloc_only); * programmaticaly. They should do this by calling device_bind() on each * device. * - * @pre_reloc_only: If true, bind only drivers with the DM_FLAG_PRE_RELOC - * flag. If false bind all drivers. + * @pre_reloc_only: If true, bind only nodes with special devicetree properties, + * or drivers with the DM_FLAG_PRE_RELOC flag. If false bind all drivers. + * @return 0 if OK, -ve on error */ int dm_scan_other(bool pre_reloc_only);
@@ -88,8 +89,8 @@ int dm_scan_other(bool pre_reloc_only); * then scans and binds available devices from platform data and the FDT. * This calls dm_init() to set up Driver Model structures. * - * @pre_reloc_only: If true, bind only drivers with the DM_FLAG_PRE_RELOC - * flag. If false bind all drivers. + * @pre_reloc_only: If true, bind only nodes with special devicetree properties, + * or drivers with the DM_FLAG_PRE_RELOC flag. If false bind all drivers. * @return 0 if OK, -ve on error */ int dm_init_and_scan(bool pre_reloc_only);
Changes in v2: None
Commit f2006808f099: ("dm: core: parse chosen node") added a logic to parse the chosen node during dm_scan_fdt_node(), but unfortunately it missed adding the same logic in dm_scan_fdt_live(). This mirrors the logic in the livetree version.
The weird thing is that commit f2006808f099 did update the test case to test such logic, but I have no idea how the test case could pass.
With this fix, the following 2 test cases now pass:
Test: dm_test_bus_children: bus.c test/dm/bus.c:112, dm_test_bus_children(): num_devices == list_count_items(&uc->dev_head): Expected 7, got 6
Test: dm_test_fdt: test-fdt.c test/dm/test-fdt.c:184, dm_test_fdt(): num_devices == list_count_items(&uc->dev_head): Expected 7, got 6
Fixes: f2006808f099 ("dm: core: parse chosen node") Signed-off-by: Bin Meng bmeng.cn@gmail.com ---
Changes in v2: None
drivers/core/root.c | 10 ++++++++++ 1 file changed, 10 insertions(+)
diff --git a/drivers/core/root.c b/drivers/core/root.c index f918ee1..535084e 100644 --- a/drivers/core/root.c +++ b/drivers/core/root.c @@ -222,6 +222,16 @@ static int dm_scan_fdt_live(struct udevice *parent, int ret = 0, err;
for (np = node_parent->child; np; np = np->sibling) { + /* "chosen" node isn't a device itself but may contain some: */ + if (!strcmp(np->name, "chosen")) { + pr_debug("parsing subnodes of "chosen"\n"); + + err = dm_scan_fdt_live(parent, np, pre_reloc_only); + if (err && !ret) + ret = err; + continue; + } + if (!of_device_is_available(np)) { pr_debug(" - ignoring disabled device\n"); continue;
Changes in v2: None
I actually don't see that failure. Something odd is going on. Anyway this looks right to me.
Now that we fixed the pre-relocation driver binding for driver marked with DM_FLAG_PRE_RELOC flag, add a test case to cover that scenario.
Changes in v2: None
arch/sandbox/dts/test.dts | 4 ++++ test/dm/bus.c | 2 +- test/dm/test-fdt.c | 29 ++++++++++++++++++++++++++--- 3 files changed, 31 insertions(+), 4 deletions(-)
diff --git a/arch/sandbox/dts/test.dts b/arch/sandbox/dts/test.dts index 491f889..f12410f 100644 --- a/arch/sandbox/dts/test.dts +++ b/arch/sandbox/dts/test.dts @@ -146,6 +146,10 @@ compatible = "denx,u-boot-fdt-test"; };
+ h-test { + compatible = "denx,u-boot-fdt-test1"; + }; + clocks { clk_fixed: clk-fixed { compatible = "fixed-clock"; diff --git a/test/dm/bus.c b/test/dm/bus.c index e9a4028..c41bcf7 100644 --- a/test/dm/bus.c +++ b/test/dm/bus.c @@ -104,7 +104,7 @@ UCLASS_DRIVER(testbus) = { /* Test that we can probe for children */ static int dm_test_bus_children(struct unit_test_state *uts) { - int num_devices = 7; + int num_devices = 8; struct udevice *bus; struct uclass *uc;
diff --git a/test/dm/test-fdt.c b/test/dm/test-fdt.c index 79b1f1d..3da384f 100644 --- a/test/dm/test-fdt.c +++ b/test/dm/test-fdt.c @@ -84,6 +84,25 @@ U_BOOT_DRIVER(testfdt_drv) = { .platdata_auto_alloc_size = sizeof(struct dm_test_pdata), };
+static const struct udevice_id testfdt1_ids[] = { + { + .compatible = "denx,u-boot-fdt-test1", + .data = DM_TEST_TYPE_FIRST }, + { } +}; + +U_BOOT_DRIVER(testfdt1_drv) = { + .name = "testfdt1_drv", + .of_match = testfdt1_ids, + .id = UCLASS_TEST_FDT, + .ofdata_to_platdata = testfdt_ofdata_to_platdata, + .probe = testfdt_drv_probe, + .ops = &test_ops, + .priv_auto_alloc_size = sizeof(struct dm_test_priv), + .platdata_auto_alloc_size = sizeof(struct dm_test_pdata), + .flags = DM_FLAG_PRE_RELOC, +}; + /* From here is the testfdt uclass code */ int testfdt_ping(struct udevice *dev, int pingval, int *pingret) { @@ -168,7 +187,7 @@ int dm_check_devices(struct unit_test_state *uts, int num_devices) /* Test that FDT-based binding works correctly */ static int dm_test_fdt(struct unit_test_state *uts) { - const int num_devices = 7; + const int num_devices = 8; struct udevice *dev; struct uclass *uc; int ret; @@ -208,8 +227,12 @@ static int dm_test_fdt_pre_reloc(struct unit_test_state *uts) ret = uclass_get(UCLASS_TEST_FDT, &uc); ut_assert(!ret);
- /* These is only one pre-reloc device */ - ut_asserteq(1, list_count_items(&uc->dev_head)); + /* + * These are 2 pre-reloc devices: + * one with "u-boot,dm-pre-reloc" property (a-test node), and the other + * one whose driver marked with DM_FLAG_PRE_RELOC flag (h-test node). + */ + ut_asserteq(2, list_count_items(&uc->dev_head));
return 0; }
Changes in v2: None
This is currently out of order. Sort it.
Changes in v2: None
drivers/timer/Kconfig | 110 +++++++++++++++++++++++++------------------------- 1 file changed, 55 insertions(+), 55 deletions(-)
diff --git a/drivers/timer/Kconfig b/drivers/timer/Kconfig index a7d600b..8c0f356 100644 --- a/drivers/timer/Kconfig +++ b/drivers/timer/Kconfig @@ -37,6 +37,12 @@ config TIMER_EARLY use an early timer. These functions must be supported by your timer driver: timer_early_get_count() and timer_early_get_rate().
+config AG101P_TIMER + bool "AG101P timer support" + depends on TIMER && NDS32 + help + Select this to enable a timer for AG01P devices. + config ALTERA_TIMER bool "Altera timer support" depends on TIMER @@ -44,6 +50,34 @@ config ALTERA_TIMER Select this to enable a timer for Altera devices. Please find details on the "Embedded Peripherals IP User Guide" of Altera.
+config ARC_TIMER + bool "ARC timer support" + depends on TIMER && ARC && CLK + help + Select this to enable built-in ARC timers. + ARC cores may have up to 2 built-in timers: timer0 and timer1, + usually at least one of them exists. Either of them is supported + in U-Boot. + +config AST_TIMER + bool "Aspeed ast2400/ast2500 timer support" + depends on TIMER + default y if ARCH_ASPEED + help + Select this to enable timer for Aspeed ast2400/ast2500 devices. + This is a simple sys timer driver, it is compatible with lib/time.c, + but does not support any interrupts. Even though SoC has 8 hardware + counters, they are all treated as a single device by this driver. + This is mostly because they all share several registers which + makes it difficult to completely separate them. + +config ATCPIT100_TIMER + bool "ATCPIT100 timer support" + depends on TIMER + help + Select this to enable a ATCPIT100 timer which will be embedded + in AE3XX, AE250 boards. + config ATMEL_PIT_TIMER bool "Atmel periodic interval timer support" depends on TIMER @@ -66,18 +100,12 @@ config DESIGNWARE_APB_TIMER Enables support for the Designware APB Timer driver. This timer is present on Altera SoCFPGA SoCs.
-config SANDBOX_TIMER - bool "Sandbox timer support" - depends on SANDBOX && TIMER - help - Select this to enable an emulated timer for sandbox. It gets - time from host os. - -config X86_TSC_TIMER - bool "x86 Time-Stamp Counter (TSC) timer support" - depends on TIMER && X86 +config MPC83XX_TIMER + bool "MPC83xx timer support" + depends on TIMER help - Select this to enable Time-Stamp Counter (TSC) timer for x86. + Select this to enable support for the timer found on + devices based on the MPC83xx family of SoCs.
config OMAP_TIMER bool "Omap timer support" @@ -85,17 +113,19 @@ config OMAP_TIMER help Select this to enable an timer for Omap devices.
-config AST_TIMER - bool "Aspeed ast2400/ast2500 timer support" +config ROCKCHIP_TIMER + bool "Rockchip timer support" depends on TIMER - default y if ARCH_ASPEED help - Select this to enable timer for Aspeed ast2400/ast2500 devices. - This is a simple sys timer driver, it is compatible with lib/time.c, - but does not support any interrupts. Even though SoC has 8 hardware - counters, they are all treated as a single device by this driver. - This is mostly because they all share several registers which - makes it difficult to completely separate them. + Select this to enable support for the timer found on + Rockchip devices. + +config SANDBOX_TIMER + bool "Sandbox timer support" + depends on SANDBOX && TIMER + help + Select this to enable an emulated timer for sandbox. It gets + time from host os.
config STI_TIMER bool "STi timer support" @@ -104,47 +134,17 @@ config STI_TIMER help Select this to enable a timer for STi devices.
-config ARC_TIMER - bool "ARC timer support" - depends on TIMER && ARC && CLK - help - Select this to enable built-in ARC timers. - ARC cores may have up to 2 built-in timers: timer0 and timer1, - usually at least one of them exists. Either of them is supported - in U-Boot. - -config AG101P_TIMER - bool "AG101P timer support" - depends on TIMER && NDS32 - help - Select this to enable a timer for AG01P devices. - -config ATCPIT100_TIMER - bool "ATCPIT100 timer support" - depends on TIMER - help - Select this to enable a ATCPIT100 timer which will be embeded - in AE3XX, AE250 boards. - -config ROCKCHIP_TIMER - bool "Rockchip timer support" - depends on TIMER - help - Select this to enable support for the timer found on - Rockchip devices. - config STM32_TIMER - bool "STM32 timer support" + bool "STM32 timer support" depends on TIMER help Select this to enable support for the timer found on STM32 devices.
-config MPC83XX_TIMER - bool "MPC83xx timer support" - depends on TIMER +config X86_TSC_TIMER + bool "x86 Time-Stamp Counter (TSC) timer support" + depends on TIMER && X86 help - Select this to enable support for the timer found on - devices based on the MPC83xx family of SoCs. + Select this to enable Time-Stamp Counter (TSC) timer for x86.
endmenu
Changes in v2: None
Bin Meng
Mario Six
