[U-Boot] commit 83e359adf9f578a58f20daf2e4425a754defac7b breaks mmc
commit 83e359a (am335x_evm: Enable CONFIG_SPL_ENV_SUPPORT on EMMC_BOOT) breaks MMC on some boards. I believe it only breaks if EMMC has no partition on it, so that would point out to a bug on spl env support itself and this has only exposed it.
Here's a bisection log anyway:
git bisect start # good: [524123a70761110c5cf3ccc5f52f6d4da071b959] Prepare v2014.07 git bisect good 524123a70761110c5cf3ccc5f52f6d4da071b959 # bad: [0b703dbcee7103f07804d0a4328d1593355c4324] patman: Fix detection of git version git bisect bad 0b703dbcee7103f07804d0a4328d1593355c4324 # good: [63b85adcecdd019f049cbbebf10119cea45d3645] imx: ventana: set dynamic env var for flash layout git bisect good 63b85adcecdd019f049cbbebf10119cea45d3645 # good: [63b85adcecdd019f049cbbebf10119cea45d3645] imx: ventana: set dynamic env var for flash layout git bisect good 63b85adcecdd019f049cbbebf10119cea45d3645 # good: [04b43f32731c1171877541050bb3f2bfeb100e3d] tools/genboardscfg.py: ignore defconfigs starting with a dot git bisect good 04b43f32731c1171877541050bb3f2bfeb100e3d # bad: [6defdc0b5552ab1af4a66a8abac8196cbb6b9e15] Merge branch 'master' of git://git.denx.de/u-boot-ti git bisect bad 6defdc0b5552ab1af4a66a8abac8196cbb6b9e15 # good: [6af857c50df4e62ec08e51ad73c96f63f1480386] Merge branch 'master' of http://git.denx.de/u-boot-sunxi git bisect good 6af857c50df4e62ec08e51ad73c96f63f1480386 # good: [7f14fb20f895016fb38d30ce71aeb4d441b5bcb8] Merge branch 'zynq' of git://www.denx.de/git/u-boot-microblaze git bisect good 7f14fb20f895016fb38d30ce71aeb4d441b5bcb8 # bad: [61f66fd5a81b97478e9d14326c1059baa6626680] keystone2: use EFUSE_BOOTROM information to configure PLLs git bisect bad 61f66fd5a81b97478e9d14326c1059baa6626680 # bad: [fea9543f1bd1d068a372ef378f624941c25989a8] board/ti/am335x: update configs for parallel NAND git bisect bad fea9543f1bd1d068a372ef378f624941c25989a8 # good: [e017fd61c5a89e32db682d94d8d669df1709edbb] tseries: Set CONFIG_ENV_IS_NOWHERE for SPL+NAND git bisect good e017fd61c5a89e32db682d94d8d669df1709edbb # bad: [83e359adf9f578a58f20daf2e4425a754defac7b] am335x_evm: Enable CONFIG_SPL_ENV_SUPPORT on EMMC_BOOT git bisect bad 83e359adf9f578a58f20daf2e4425a754defac7b # good: [00e385325fce36fa13d48091d73b1b3428394b6b] common/Makefile: Consolidate SPL ENV options, correct inclusion git bisect good 00e385325fce36fa13d48091d73b1b3428394b6b # first bad commit: [83e359adf9f578a58f20daf2e4425a754defac7b] am335x_evm: Enable CONFIG_SPL_ENV_SUPPORT on EMMC_BOOT
Revert that commit also makes it work, btw.
On a further dig into this, it looks like when enabling CONFIG_SPL_ENV_SUPPORT, somehow MMC numbering changes and u-boot ends up trying to read environment from a non-formatted EMMC.
forgot to mention, this is all on BBB and affects only am335x-based boards, of course.
I believe this is the problem that https://patchwork.ozlabs.org/patch/385354/ is intended to fix. See also discussion at http://www.mail-archive.com/u-boot@lists.denx.de/msg146396.html
Peter
Felipe Balbi
Peter A. Bigot
