[PATCH] ARM: dts: rockchip: rk3588: sync with Linux
Sync the devicetree with linux-next tag: next-20230525
Signed-off-by: Eugen Hristev eugen.hristev@collabora.com --- arch/arm/dts/rk3588-rock-5b.dts | 152 ++++++++++++++++++++ arch/arm/dts/rk3588.dtsi | 68 +++++++++ arch/arm/dts/rk3588s-u-boot.dtsi | 12 -- arch/arm/dts/rk3588s.dtsi | 234 ++++++++++++++++++++++++++++++- 4 files changed, 449 insertions(+), 17 deletions(-)
diff --git a/arch/arm/dts/rk3588-rock-5b.dts b/arch/arm/dts/rk3588-rock-5b.dts index 95805cb0adfa..3e4aee8f70c1 100644 --- a/arch/arm/dts/rk3588-rock-5b.dts +++ b/arch/arm/dts/rk3588-rock-5b.dts @@ -2,6 +2,7 @@
/dts-v1/;
+#include <dt-bindings/gpio/gpio.h> #include "rk3588.dtsi"
/ { @@ -17,6 +18,31 @@ stdout-path = "serial2:1500000n8"; };
+ fan: pwm-fan { + compatible = "pwm-fan"; + cooling-levels = <0 95 145 195 255>; + fan-supply = <&vcc5v0_sys>; + pwms = <&pwm1 0 50000 0>; + #cooling-cells = <2>; + }; + + sound { + compatible = "audio-graph-card"; + label = "Analog"; + + widgets = "Microphone", "Mic Jack", + "Headphone", "Headphones"; + + routing = "MIC2", "Mic Jack", + "Headphones", "HPOL", + "Headphones", "HPOR"; + + dais = <&i2s0_8ch_p0>; + hp-det-gpio = <&gpio1 RK_PD5 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&hp_detect>; + }; + vcc5v0_sys: vcc5v0-sys-regulator { compatible = "regulator-fixed"; regulator-name = "vcc5v0_sys"; @@ -27,6 +53,132 @@ }; };
+&cpu_b0 { + cpu-supply = <&vdd_cpu_big0_s0>; +}; + +&cpu_b1 { + cpu-supply = <&vdd_cpu_big0_s0>; +}; + +&cpu_b2 { + cpu-supply = <&vdd_cpu_big1_s0>; +}; + +&cpu_b3 { + cpu-supply = <&vdd_cpu_big1_s0>; +}; + +&i2c0 { + pinctrl-names = "default"; + pinctrl-0 = <&i2c0m2_xfer>; + status = "okay"; + + vdd_cpu_big0_s0: regulator@42 { + compatible = "rockchip,rk8602"; + reg = <0x42>; + fcs,suspend-voltage-selector = <1>; + regulator-name = "vdd_cpu_big0_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <550000>; + regulator-max-microvolt = <1050000>; + regulator-ramp-delay = <2300>; + vin-supply = <&vcc5v0_sys>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdd_cpu_big1_s0: regulator@43 { + compatible = "rockchip,rk8603", "rockchip,rk8602"; + reg = <0x43>; + fcs,suspend-voltage-selector = <1>; + regulator-name = "vdd_cpu_big1_s0"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <550000>; + regulator-max-microvolt = <1050000>; + regulator-ramp-delay = <2300>; + vin-supply = <&vcc5v0_sys>; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; +}; + +&i2c6 { + status = "okay"; + + hym8563: rtc@51 { + compatible = "haoyu,hym8563"; + reg = <0x51>; + #clock-cells = <0>; + clock-output-names = "hym8563"; + pinctrl-names = "default"; + pinctrl-0 = <&hym8563_int>; + interrupt-parent = <&gpio0>; + interrupts = <RK_PB0 IRQ_TYPE_LEVEL_LOW>; + wakeup-source; + }; +}; + +&i2c7 { + status = "okay"; + + es8316: audio-codec@11 { + compatible = "everest,es8316"; + reg = <0x11>; + clocks = <&cru I2S0_8CH_MCLKOUT>; + clock-names = "mclk"; + #sound-dai-cells = <0>; + + port { + es8316_p0_0: endpoint { + remote-endpoint = <&i2s0_8ch_p0_0>; + }; + }; + }; +}; + +&i2s0_8ch { + pinctrl-names = "default"; + pinctrl-0 = <&i2s0_lrck + &i2s0_mclk + &i2s0_sclk + &i2s0_sdi0 + &i2s0_sdo0>; + status = "okay"; + + i2s0_8ch_p0: port { + i2s0_8ch_p0_0: endpoint { + dai-format = "i2s"; + mclk-fs = <256>; + remote-endpoint = <&es8316_p0_0>; + }; + }; +}; + +&pinctrl { + hym8563 { + hym8563_int: hym8563-int { + rockchip,pins = <0 RK_PB0 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + sound { + hp_detect: hp-detect { + rockchip,pins = <1 RK_PD5 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; +}; + +&pwm1 { + status = "okay"; +}; + &sdhci { bus-width = <8>; no-sdio; diff --git a/arch/arm/dts/rk3588.dtsi b/arch/arm/dts/rk3588.dtsi index d085e57fbc4c..8be75556af8f 100644 --- a/arch/arm/dts/rk3588.dtsi +++ b/arch/arm/dts/rk3588.dtsi @@ -7,6 +7,74 @@ #include "rk3588-pinctrl.dtsi"
/ { + i2s8_8ch: i2s@fddc8000 { + compatible = "rockchip,rk3588-i2s-tdm"; + reg = <0x0 0xfddc8000 0x0 0x1000>; + interrupts = <GIC_SPI 188 IRQ_TYPE_LEVEL_HIGH 0>; + clocks = <&cru MCLK_I2S8_8CH_TX>, <&cru MCLK_I2S8_8CH_TX>, <&cru HCLK_I2S8_8CH>; + clock-names = "mclk_tx", "mclk_rx", "hclk"; + assigned-clocks = <&cru CLK_I2S8_8CH_TX_SRC>; + assigned-clock-parents = <&cru PLL_AUPLL>; + dmas = <&dmac2 22>; + dma-names = "tx"; + power-domains = <&power RK3588_PD_VO0>; + resets = <&cru SRST_M_I2S8_8CH_TX>; + reset-names = "tx-m"; + #sound-dai-cells = <0>; + status = "disabled"; + }; + + i2s6_8ch: i2s@fddf4000 { + compatible = "rockchip,rk3588-i2s-tdm"; + reg = <0x0 0xfddf4000 0x0 0x1000>; + interrupts = <GIC_SPI 186 IRQ_TYPE_LEVEL_HIGH 0>; + clocks = <&cru MCLK_I2S6_8CH_TX>, <&cru MCLK_I2S6_8CH_TX>, <&cru HCLK_I2S6_8CH>; + clock-names = "mclk_tx", "mclk_rx", "hclk"; + assigned-clocks = <&cru CLK_I2S6_8CH_TX_SRC>; + assigned-clock-parents = <&cru PLL_AUPLL>; + dmas = <&dmac2 4>; + dma-names = "tx"; + power-domains = <&power RK3588_PD_VO1>; + resets = <&cru SRST_M_I2S6_8CH_TX>; + reset-names = "tx-m"; + #sound-dai-cells = <0>; + status = "disabled"; + }; + + i2s7_8ch: i2s@fddf8000 { + compatible = "rockchip,rk3588-i2s-tdm"; + reg = <0x0 0xfddf8000 0x0 0x1000>; + interrupts = <GIC_SPI 187 IRQ_TYPE_LEVEL_HIGH 0>; + clocks = <&cru MCLK_I2S7_8CH_RX>, <&cru MCLK_I2S7_8CH_RX>, <&cru HCLK_I2S7_8CH>; + clock-names = "mclk_tx", "mclk_rx", "hclk"; + assigned-clocks = <&cru CLK_I2S7_8CH_RX_SRC>; + assigned-clock-parents = <&cru PLL_AUPLL>; + dmas = <&dmac2 21>; + dma-names = "rx"; + power-domains = <&power RK3588_PD_VO1>; + resets = <&cru SRST_M_I2S7_8CH_RX>; + reset-names = "rx-m"; + #sound-dai-cells = <0>; + status = "disabled"; + }; + + i2s10_8ch: i2s@fde00000 { + compatible = "rockchip,rk3588-i2s-tdm"; + reg = <0x0 0xfde00000 0x0 0x1000>; + interrupts = <GIC_SPI 190 IRQ_TYPE_LEVEL_HIGH 0>; + clocks = <&cru MCLK_I2S10_8CH_RX>, <&cru MCLK_I2S10_8CH_RX>, <&cru HCLK_I2S10_8CH>; + clock-names = "mclk_tx", "mclk_rx", "hclk"; + assigned-clocks = <&cru CLK_I2S10_8CH_RX_SRC>; + assigned-clock-parents = <&cru PLL_AUPLL>; + dmas = <&dmac2 24>; + dma-names = "rx"; + power-domains = <&power RK3588_PD_VO1>; + resets = <&cru SRST_M_I2S10_8CH_RX>; + reset-names = "rx-m"; + #sound-dai-cells = <0>; + status = "disabled"; + }; + gmac0: ethernet@fe1b0000 { compatible = "rockchip,rk3588-gmac", "snps,dwmac-4.20a"; reg = <0x0 0xfe1b0000 0x0 0x10000>; diff --git a/arch/arm/dts/rk3588s-u-boot.dtsi b/arch/arm/dts/rk3588s-u-boot.dtsi index c703e41802b6..1bb3c6a9d958 100644 --- a/arch/arm/dts/rk3588s-u-boot.dtsi +++ b/arch/arm/dts/rk3588s-u-boot.dtsi @@ -174,18 +174,6 @@ status = "disabled"; };
- otp: nvmem@fecc0000 { - compatible = "rockchip,rk3588-otp"; - reg = <0x0 0xfecc0000 0x0 0x400>; - #address-cells = <1>; - #size-cells = <1>; - status = "okay"; - - cpu_id: id@7 { - reg = <0x07 0x10>; - }; - }; - rng: rng@fe378000 { compatible = "rockchip,trngv1"; reg = <0x0 0xfe378000 0x0 0x200>; diff --git a/arch/arm/dts/rk3588s.dtsi b/arch/arm/dts/rk3588s.dtsi index fca8503aed8c..7dbac9ae2e13 100644 --- a/arch/arm/dts/rk3588s.dtsi +++ b/arch/arm/dts/rk3588s.dtsi @@ -60,6 +60,8 @@ enable-method = "psci"; capacity-dmips-mhz = <530>; clocks = <&scmi_clk SCMI_CLK_CPUL>; + assigned-clocks = <&scmi_clk SCMI_CLK_CPUL>; + assigned-clock-rates = <816000000>; cpu-idle-states = <&CPU_SLEEP>; i-cache-size = <32768>; i-cache-line-size = <64>; @@ -136,6 +138,8 @@ enable-method = "psci"; capacity-dmips-mhz = <1024>; clocks = <&scmi_clk SCMI_CLK_CPUB01>; + assigned-clocks = <&scmi_clk SCMI_CLK_CPUB01>; + assigned-clock-rates = <816000000>; cpu-idle-states = <&CPU_SLEEP>; i-cache-size = <65536>; i-cache-line-size = <64>; @@ -174,6 +178,8 @@ enable-method = "psci"; capacity-dmips-mhz = <1024>; clocks = <&scmi_clk SCMI_CLK_CPUB23>; + assigned-clocks = <&scmi_clk SCMI_CLK_CPUB23>; + assigned-clock-rates = <816000000>; cpu-idle-states = <&CPU_SLEEP>; i-cache-size = <65536>; i-cache-line-size = <64>; @@ -222,6 +228,8 @@ cache-size = <131072>; cache-line-size = <64>; cache-sets = <512>; + cache-level = <2>; + cache-unified; next-level-cache = <&l3_cache>; };
@@ -230,6 +238,8 @@ cache-size = <131072>; cache-line-size = <64>; cache-sets = <512>; + cache-level = <2>; + cache-unified; next-level-cache = <&l3_cache>; };
@@ -238,6 +248,8 @@ cache-size = <131072>; cache-line-size = <64>; cache-sets = <512>; + cache-level = <2>; + cache-unified; next-level-cache = <&l3_cache>; };
@@ -246,6 +258,8 @@ cache-size = <131072>; cache-line-size = <64>; cache-sets = <512>; + cache-level = <2>; + cache-unified; next-level-cache = <&l3_cache>; };
@@ -254,6 +268,8 @@ cache-size = <524288>; cache-line-size = <64>; cache-sets = <1024>; + cache-level = <2>; + cache-unified; next-level-cache = <&l3_cache>; };
@@ -262,6 +278,8 @@ cache-size = <524288>; cache-line-size = <64>; cache-sets = <1024>; + cache-level = <2>; + cache-unified; next-level-cache = <&l3_cache>; };
@@ -270,6 +288,8 @@ cache-size = <524288>; cache-line-size = <64>; cache-sets = <1024>; + cache-level = <2>; + cache-unified; next-level-cache = <&l3_cache>; };
@@ -278,6 +298,8 @@ cache-size = <524288>; cache-line-size = <64>; cache-sets = <1024>; + cache-level = <2>; + cache-unified; next-level-cache = <&l3_cache>; };
@@ -286,6 +308,8 @@ cache-size = <3145728>; cache-line-size = <64>; cache-sets = <4096>; + cache-level = <3>; + cache-unified; }; };
@@ -304,10 +328,6 @@
scmi_clk: protocol@14 { reg = <0x14>; - assigned-clocks = <&scmi_clk SCMI_CLK_CPUB01>, - <&scmi_clk SCMI_CLK_CPUB23>; - assigned-clock-rates = <1200000000>, - <1200000000>; #clock-cells = <1>; };
@@ -414,7 +434,7 @@ <&cru ACLK_BUS_ROOT>, <&cru CLK_150M_SRC>, <&cru CLK_GPU>; assigned-clock-rates = - <100000000>, <786432000>, + <1100000000>, <786432000>, <850000000>, <1188000000>, <702000000>, <400000000>, <500000000>, @@ -1132,6 +1152,103 @@ status = "disabled"; };
+ i2s0_8ch: i2s@fe470000 { + compatible = "rockchip,rk3588-i2s-tdm"; + reg = <0x0 0xfe470000 0x0 0x1000>; + interrupts = <GIC_SPI 180 IRQ_TYPE_LEVEL_HIGH 0>; + clocks = <&cru MCLK_I2S0_8CH_TX>, <&cru MCLK_I2S0_8CH_RX>, <&cru HCLK_I2S0_8CH>; + clock-names = "mclk_tx", "mclk_rx", "hclk"; + assigned-clocks = <&cru CLK_I2S0_8CH_TX_SRC>, <&cru CLK_I2S0_8CH_RX_SRC>; + assigned-clock-parents = <&cru PLL_AUPLL>, <&cru PLL_AUPLL>; + dmas = <&dmac0 0>, <&dmac0 1>; + dma-names = "tx", "rx"; + power-domains = <&power RK3588_PD_AUDIO>; + resets = <&cru SRST_M_I2S0_8CH_TX>, <&cru SRST_M_I2S0_8CH_RX>; + reset-names = "tx-m", "rx-m"; + rockchip,trcm-sync-tx-only; + pinctrl-names = "default"; + pinctrl-0 = <&i2s0_lrck + &i2s0_sclk + &i2s0_sdi0 + &i2s0_sdi1 + &i2s0_sdi2 + &i2s0_sdi3 + &i2s0_sdo0 + &i2s0_sdo1 + &i2s0_sdo2 + &i2s0_sdo3>; + #sound-dai-cells = <0>; + status = "disabled"; + }; + + i2s1_8ch: i2s@fe480000 { + compatible = "rockchip,rk3588-i2s-tdm"; + reg = <0x0 0xfe480000 0x0 0x1000>; + interrupts = <GIC_SPI 181 IRQ_TYPE_LEVEL_HIGH 0>; + clocks = <&cru MCLK_I2S1_8CH_TX>, <&cru MCLK_I2S1_8CH_RX>, <&cru HCLK_I2S1_8CH>; + clock-names = "mclk_tx", "mclk_rx", "hclk"; + dmas = <&dmac0 2>, <&dmac0 3>; + dma-names = "tx", "rx"; + resets = <&cru SRST_M_I2S1_8CH_TX>, <&cru SRST_M_I2S1_8CH_RX>; + reset-names = "tx-m", "rx-m"; + rockchip,trcm-sync-tx-only; + pinctrl-names = "default"; + pinctrl-0 = <&i2s1m0_lrck + &i2s1m0_sclk + &i2s1m0_sdi0 + &i2s1m0_sdi1 + &i2s1m0_sdi2 + &i2s1m0_sdi3 + &i2s1m0_sdo0 + &i2s1m0_sdo1 + &i2s1m0_sdo2 + &i2s1m0_sdo3>; + #sound-dai-cells = <0>; + status = "disabled"; + }; + + i2s2_2ch: i2s@fe490000 { + compatible = "rockchip,rk3588-i2s", "rockchip,rk3066-i2s"; + reg = <0x0 0xfe490000 0x0 0x1000>; + interrupts = <GIC_SPI 182 IRQ_TYPE_LEVEL_HIGH 0>; + clocks = <&cru MCLK_I2S2_2CH>, <&cru HCLK_I2S2_2CH>; + clock-names = "i2s_clk", "i2s_hclk"; + assigned-clocks = <&cru CLK_I2S2_2CH_SRC>; + assigned-clock-parents = <&cru PLL_AUPLL>; + dmas = <&dmac1 0>, <&dmac1 1>; + dma-names = "tx", "rx"; + power-domains = <&power RK3588_PD_AUDIO>; + rockchip,trcm-sync-tx-only; + pinctrl-names = "default"; + pinctrl-0 = <&i2s2m1_lrck + &i2s2m1_sclk + &i2s2m1_sdi + &i2s2m1_sdo>; + #sound-dai-cells = <0>; + status = "disabled"; + }; + + i2s3_2ch: i2s@fe4a0000 { + compatible = "rockchip,rk3588-i2s", "rockchip,rk3066-i2s"; + reg = <0x0 0xfe4a0000 0x0 0x1000>; + interrupts = <GIC_SPI 183 IRQ_TYPE_LEVEL_HIGH 0>; + clocks = <&cru MCLK_I2S3_2CH>, <&cru HCLK_I2S3_2CH>; + clock-names = "i2s_clk", "i2s_hclk"; + assigned-clocks = <&cru CLK_I2S3_2CH_SRC>; + assigned-clock-parents = <&cru PLL_AUPLL>; + dmas = <&dmac1 2>, <&dmac1 3>; + dma-names = "tx", "rx"; + power-domains = <&power RK3588_PD_AUDIO>; + rockchip,trcm-sync-tx-only; + pinctrl-names = "default"; + pinctrl-0 = <&i2s3_lrck + &i2s3_sclk + &i2s3_sdi + &i2s3_sdo>; + #sound-dai-cells = <0>; + status = "disabled"; + }; + gic: interrupt-controller@fe600000 { compatible = "arm,gic-v3"; reg = <0x0 0xfe600000 0 0x10000>, /* GICD */ @@ -1141,7 +1258,24 @@ mbi-alias = <0x0 0xfe610000>; mbi-ranges = <424 56>; msi-controller; + ranges; + #address-cells = <2>; #interrupt-cells = <4>; + #size-cells = <2>; + + its0: msi-controller@fe640000 { + compatible = "arm,gic-v3-its"; + reg = <0x0 0xfe640000 0x0 0x20000>; + msi-controller; + #msi-cells = <1>; + }; + + its1: msi-controller@fe660000 { + compatible = "arm,gic-v3-its"; + reg = <0x0 0xfe660000 0x0 0x20000>; + msi-controller; + #msi-cells = <1>; + };
ppi-partitions { ppi_partition0: interrupt-partition-0 { @@ -1241,6 +1375,22 @@ status = "disabled"; };
+ timer0: timer@feae0000 { + compatible = "rockchip,rk3588-timer", "rockchip,rk3288-timer"; + reg = <0x0 0xfeae0000 0x0 0x20>; + interrupts = <GIC_SPI 289 IRQ_TYPE_LEVEL_HIGH 0>; + clocks = <&cru PCLK_BUSTIMER0>, <&cru CLK_BUSTIMER0>; + clock-names = "pclk", "timer"; + }; + + wdt: watchdog@feaf0000 { + compatible = "rockchip,rk3588-wdt", "snps,dw-wdt"; + reg = <0x0 0xfeaf0000 0x0 0x100>; + clocks = <&cru TCLK_WDT0>, <&cru PCLK_WDT0>; + clock-names = "tclk", "pclk"; + interrupts = <GIC_SPI 315 IRQ_TYPE_LEVEL_HIGH 0>; + }; + spi0: spi@feb00000 { compatible = "rockchip,rk3588-spi", "rockchip,rk3066-spi"; reg = <0x0 0xfeb00000 0x0 0x1000>; @@ -1572,6 +1722,26 @@ status = "disabled"; };
+ tsadc: tsadc@fec00000 { + compatible = "rockchip,rk3588-tsadc"; + reg = <0x0 0xfec00000 0x0 0x400>; + interrupts = <GIC_SPI 397 IRQ_TYPE_LEVEL_HIGH 0>; + clocks = <&cru CLK_TSADC>, <&cru PCLK_TSADC>; + clock-names = "tsadc", "apb_pclk"; + assigned-clocks = <&cru CLK_TSADC>; + assigned-clock-rates = <2000000>; + resets = <&cru SRST_P_TSADC>, <&cru SRST_TSADC>; + reset-names = "tsadc-apb", "tsadc"; + rockchip,hw-tshut-temp = <120000>; + rockchip,hw-tshut-mode = <0>; /* tshut mode 0:CRU 1:GPIO */ + rockchip,hw-tshut-polarity = <0>; /* tshut polarity 0:LOW 1:HIGH */ + pinctrl-0 = <&tsadc_gpio_func>; + pinctrl-1 = <&tsadc_shut>; + pinctrl-names = "gpio", "otpout"; + #thermal-sensor-cells = <1>; + status = "disabled"; + }; + i2c6: i2c@fec80000 { compatible = "rockchip,rk3588-i2c", "rockchip,rk3399-i2c"; reg = <0x0 0xfec80000 0x0 0x1000>; @@ -1627,6 +1797,60 @@ status = "disabled"; };
+ otp: efuse@fecc0000 { + compatible = "rockchip,rk3588-otp"; + reg = <0x0 0xfecc0000 0x0 0x400>; + clocks = <&cru CLK_OTPC_NS>, <&cru PCLK_OTPC_NS>, + <&cru CLK_OTP_PHY_G>, <&cru CLK_OTPC_ARB>; + clock-names = "otp", "apb_pclk", "phy", "arb"; + resets = <&cru SRST_OTPC_NS>, <&cru SRST_P_OTPC_NS>, + <&cru SRST_OTPC_ARB>; + reset-names = "otp", "apb", "arb"; + #address-cells = <1>; + #size-cells = <1>; + + cpu_code: cpu-code@2 { + reg = <0x02 0x2>; + }; + + otp_id: id@7 { + reg = <0x07 0x10>; + }; + + cpub0_leakage: cpu-leakage@17 { + reg = <0x17 0x1>; + }; + + cpub1_leakage: cpu-leakage@18 { + reg = <0x18 0x1>; + }; + + cpul_leakage: cpu-leakage@19 { + reg = <0x19 0x1>; + }; + + log_leakage: log-leakage@1a { + reg = <0x1a 0x1>; + }; + + gpu_leakage: gpu-leakage@1b { + reg = <0x1b 0x1>; + }; + + otp_cpu_version: cpu-version@1c { + reg = <0x1c 0x1>; + bits = <3 3>; + }; + + npu_leakage: npu-leakage@28 { + reg = <0x28 0x1>; + }; + + codec_leakage: codec-leakage@29 { + reg = <0x29 0x1>; + }; + }; + dmac2: dma-controller@fed10000 { compatible = "arm,pl330", "arm,primecell"; reg = <0x0 0xfed10000 0x0 0x4000>;
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
/dts-v1/;
- fan: pwm-fan {
- sound {
label = "Analog";
- vcc5v0_sys: vcc5v0-sys-regulator { compatible = "regulator-fixed"; regulator-name = "vcc5v0_sys";
+&cpu_b0 {
- cpu-supply = <&vdd_cpu_big0_s0>;
+&cpu_b1 {
+&cpu_b2 {
- cpu-supply = <&vdd_cpu_big1_s0>;
+&cpu_b3 {
+&i2c0 {
- pinctrl-names = "default";
- pinctrl-0 = <&i2c0m2_xfer>;
- status = "okay";
- vdd_cpu_big0_s0: regulator@42 {
reg = <0x42>;
regulator-boot-on;
- vdd_cpu_big1_s0: regulator@43 {
reg = <0x43>;
regulator-boot-on;
+&i2c6 {
- status = "okay";
- hym8563: rtc@51 {
reg = <0x51>;
#clock-cells = <0>;
wakeup-source;
+&i2c7 {
- status = "okay";
- es8316: audio-codec@11 {
reg = <0x11>;
port {
+&i2s0_8ch {
- pinctrl-0 = <&i2s0_lrck
&i2s0_mclk
&i2s0_sclk
&i2s0_sdi0
&i2s0_sdo0>;
- status = "okay";
- i2s0_8ch_p0: port {
dai-format = "i2s";
mclk-fs = <256>;
+&pinctrl {
- hym8563 {
- sound {
+&pwm1 {
- status = "okay";
- &sdhci { bus-width = <8>; no-sdio;
- i2s8_8ch: i2s@fddc8000 {
dmas = <&dmac2 22>;
dma-names = "tx";
- i2s6_8ch: i2s@fddf4000 {
dmas = <&dmac2 4>;
dma-names = "tx";
- i2s7_8ch: i2s@fddf8000 {
dmas = <&dmac2 21>;
dma-names = "rx";
- i2s10_8ch: i2s@fde00000 {
dmas = <&dmac2 24>;
dma-names = "rx";
- gmac0: ethernet@fe1b0000 { compatible = "rockchip,rk3588-gmac", "snps,dwmac-4.20a"; reg = <0x0 0xfe1b0000 0x0 0x10000>;
#size-cells = <1>;
status = "okay";
cpu_id: id@7 {
reg = <0x07 0x10>;
cache-level = <2>;
};cache-unified; next-level-cache = <&l3_cache>;
cache-level = <2>;
cache-level = <2>;
cache-level = <2>;
cache-level = <2>;
cache-level = <2>;
cache-level = <2>;
cache-level = <2>;
cache-level = <3>;
}; };cache-unified;
- i2s0_8ch: i2s@fe470000 {
&i2s0_sclk
&i2s0_sdi0
&i2s0_sdi1
&i2s0_sdi2
&i2s0_sdi3
&i2s0_sdo0
&i2s0_sdo1
&i2s0_sdo2
&i2s0_sdo3>;
- i2s1_8ch: i2s@fe480000 {
&i2s1m0_sclk
&i2s1m0_sdi0
&i2s1m0_sdi1
&i2s1m0_sdi2
&i2s1m0_sdi3
&i2s1m0_sdo0
&i2s1m0_sdo1
&i2s1m0_sdo2
&i2s1m0_sdo3>;
- i2s2_2ch: i2s@fe490000 {
&i2s2m1_sclk
&i2s2m1_sdi
&i2s2m1_sdo>;
- i2s3_2ch: i2s@fe4a0000 {
&i2s3_sclk
&i2s3_sdi
&i2s3_sdo>;
- gic: interrupt-controller@fe600000 { compatible = "arm,gic-v3"; reg = <0x0 0xfe600000 0 0x10000>, /* GICD */
ranges;
#size-cells = <2>;
msi-controller;
#msi-cells = <1>;
msi-controller;
#msi-cells = <1>;
- timer0: timer@feae0000 {
- wdt: watchdog@feaf0000 {
- spi0: spi@feb00000 { compatible = "rockchip,rk3588-spi", "rockchip,rk3066-spi"; reg = <0x0 0xfeb00000 0x0 0x1000>;
- tsadc: tsadc@fec00000 {
- i2c6: i2c@fec80000 { compatible = "rockchip,rk3588-i2c", "rockchip,rk3399-i2c"; reg = <0x0 0xfec80000 0x0 0x1000>;
- otp: efuse@fecc0000 {
#size-cells = <1>;
reg = <0x02 0x2>;
otp_id: id@7 {
reg = <0x07 0x10>;
reg = <0x17 0x1>;
reg = <0x18 0x1>;
reg = <0x19 0x1>;
reg = <0x1a 0x1>;
reg = <0x1b 0x1>;
reg = <0x1c 0x1>;
bits = <3 3>;
reg = <0x28 0x1>;
reg = <0x29 0x1>;
- dmac2: dma-controller@fed10000 { compatible = "arm,pl330", "arm,primecell"; reg = <0x0 0xfed10000 0x0 0x4000>;
Eugen Hristev
Kever Yang
